Visitor Agreement.
I have been going through the same problem over the last few weeks with my 99 villager. We just discovered the other day that the front motor mount needs to be replaced. I had someone step on the brake and slightly press down on the gas while I watched the engine. There was quite a bit of movement as the engine lifted up due to the extra play in the motor mount. I am guessing replacing the motor mount is going to correct the shaking problem. You might want to have someone inspect your motor mounts as well.
John
I have a 95 Nissan Quest with 170,000+ miles. When we are at a stop, the engine shudders really bad and the RPMs go down to 500...Then when you take off from the stop it is REALLY sluggish until about 25-30 mph, then its fine. It also shudders (though not as much) in Neutral. I'm hoping this isn't a transmission problem...could it maybe be the pistons misfiring? I have no clue about cars so any help you could provide would be appreciated!!
Anyone?
Based on other messages in the forum, it probably needs a new distributor/rotor.
I saw this message while I was trying to figure out why my 93 villager was doing almost the same thing. It was stalling at random for my wife. I took it and found it was shaking all over the place, especially on acceleration, and had a decrease in power. Every once in a while, though, it would run just as smooth as glass for a minute or 2. Being a dinosaur myself, I thought back to a simpler time and figured it was a fouled plug. I found one plug totally covered in carbon and changed the plugs. It missed a little, but ran smooth for a half a day. Then it deteriorated back to what it was. Now I'm going to try replacing the rotor and distributor cap.
Probably either the rear controller or the front controller box. First you have to check to see if there is power coming to the rear box. If there is, you need to replace the rear controller. If there isn't, you have to replace the front controller. The controllers are expensive (hundreds), but you can get them really cheaply over the web from "auto parts recyclers" (junk yards). I paid $45 used instead of $450 new. If you need the front one, you have to be sure that you tell them that you have the rear controller in your car. There are 2 versions of the front controller, one with rear controls and one with just front controls. Make sure you get the one with rear controls. On www.car-part.com they call it "w/rear AC" or "w/o rear AC". I see, also, that for your year, you have to know when the car was built.
My 1996 Quest had the same problem and it is very common. Found the solution on the internet. The front slider has a cold solder joint. You need to disassemble the slider and find a dull looking solder joint. On mines I couldn't really tell so I resoldered all the major joints and when I put it all together, the back blower started working.
Let us know how it goes for you.
I would love to have the instructions on how to "fix" the gas pedal sticking problem that happens about every 8,000 (our car) miles as you shared. The dealer wants 110.00 to fix it! The first time it happened it was covered under warranty. The 2nd time it happened it was just out of warranty and they wanted to charge me. I told them if they did, it would be the last Nissan product I would buy for it was a design defect. I can't believe how "stupid" some dealers are re: this known problem and not getting Nissan to pay for the fixes. I hope you can find it for the pedal on our 1999 Quest is getting worse. Many thanks!
Mike
An educated (or not:)) guess may be that your motor mounts are bad. The symptoms you describe "When we are at a stop, the engine shudders really bad and the RPMs go down to 500...Then when you take off from the stop it is REALLY sluggish ..." can be from the mounts, however it could be the linkage to the tranny. I don't think it's the transmission itself (symptoms don't seem to match). Let me know what you find out. My wife drives a Nissan GLE Quest with 39,000 miles and I hope it makes it to 170,000!. Mike
dhoff, "Nissan Quest/Mercury Villager problems" #592, 24 Jan 2001 4:54 pm
What you will need is a phillips head screwdriver, a pair of pliers, an old toothbrush and a can of spray throttle body/air intake cleaner. Make sure it is sensor safe. It will say on the can if it is.
Start by removing the air filter. This is a good time to change it if it is dirty. Then remove the black rubber hose leading from the air filter to the throttle body by loosening the clamp at the end. You may also have to disconnect a couple of other lines that lead into this using the pliers.
Then (with the engine off) spray the cleaner into the throttle body while holding the throttle plate open. (It's a good idea to wear eye protection while doing this - is smells vicious! I also wear latex gloves to keep it off my skin.) Take the old toothbrush and scrub inside the TB and both sides of the plate, and wipe out the inside as well as possible with a clean rag.
Once it's cleaned up, button everything back up (make sure everything is connected) and start the engine. It will crank for a while, and run rough for a little while, that's normal.
Dave
How long does it take you to complete this task? Whatever time is takes you, I will most likely have to double it for I am not mechanically inclined re: Cars (I am not totally lame:)). I can use some of my skills re: taking apart (down to the bare bones) and fixing/re-building my friends PC's:) Thanks a million.
Mike
I try to take my time and be sure I have everything put back together correctly. Last fall I added some oil to my other car and went off across town. When I stopped I smelled oil. I had forgotten to put the filler cap back on. There was oil all over under the hood but luckily the cap was still sitting right on the valve cover. Lesson learned!
Dave
{loose spark plug will send RPM wild)
Check that all spark plugs are tight. You can even do it yourself if have the right wrench and socket.
Good luck
My question is: How real is the danger of snapping off these posts?
Unfortunately, this is the second time I’m down this road. The first time around, the van was 4 years old and one of the myriad hoses had a 45 day lead time. We had to leave the existing hose which now has deteriorated to the point it needs replacing. I’m debating if I should bail out now or risk the repair.
Keith
Just depends on whether you think it's worth putting the money into it. If you do have it done, it might be worthwhile to replace all the hoses "while you are in there",.
Dave
Any suggestions?
1) the shoulder-belt tracks in the front doors; a loud rattling noise as they retract w/opening & closing doors. To lube or not to lube? Can't compromise safety.
2) rusty clamps on center bench seat, not locked into mounts; adult passengers play 'urban cowboy' on short stops. Swap seat, or can they be repaired/replaced?
3) factory cassette radio (mid-line) won't eject completely. Radio plays OK, but if I gotta hear Kool & the Gang one more time... ! (of course, it's one of my wife's faves, so the tape must be extracted without harm.)
How to resolve this problem? It is very annoying and frustating problem.
I have a 2002 mercury villager and am having problems that the turn signal flasher (on the dashboard) seems to be intermittently flashhing very rapidly. It seems to start off at the normal speed and then quickly seems to go into "super-speed". My local gas station attendent looked at the signals and said they were "normal".
any ideas?
Thanks, Pat
I have a 1996 Mercury Villager with 170K miles that the timing belt just broke. It was running when it stopped running. I was exiting the interstate, and at the end of the ramp the motor stopped. Any-how a long story short, I'd like to know if the motor was running when the belt went-out and it being a 1996, forgive the way I'm asking but... I was told that it could have possibly messed up the top-end, and have to replace the head and valves and..... Another mechanic said I may be lucky and with it being a 96 or newer, there may be clearence to prevent ruining the motor when the timing belt goes with it running. I hope someone understands what I'm trying to ask...
Thanks again..
While I'm spending YOUR money, I'd suggest having a new belt put on ($2/3/400 ?) and good luck. If the engine is toast, junk the vehicle. I think it'll be just fine.
The price of the advice is that you have to let us know how it turns out...
Good luck,
-Mathias
I will let you know the out-come. I am having the belt replaced along with the water pump for $415.00. I went with your info as well as calling some dealers, both Nissan and Mercury, and was told that there is a tiny possibility that the valves are bent, but in all the ones I called (6), said they have yet to see it happen. So....
With a prayer and fingers crossed, I'll let you know. Thanks again, Jim
Then I cut part of the black plastic away and popped another white plastic section off the switch (shown in the lower part of photo), and that gave me access to a little metal rocker and the dirty contact.
Ideally you'll try to keep the black plastic tab intact (the tall part standing in the photo next to the cutout) so the switch won't be too loose when you glue and snap everything back together. But the switch seems pretty snug even with the black plastic cut away on the first switch I butchered.
Or just pay the ~$80 and swap it out for a new one.
Thanks to all who write into this forum on Quests and Villagers. I used it last week to replace the front blower sensor board for speeds 1,2 and 3. I then replaced my driver's window switch. Both fixes were as easy as everyone wrote so thanks again.
Now for the radio display...which is out completely. My Nissan dealer in Mass never heard of the problem which I find difficult to believe and just said any radio problems get sent out to an independant shop. He had no idea how much it would cost. So, I went to my local Ford dealer and explained the problem. Much more helpful and said it would cost about $375. That's $300 for a refurbed radio and $75 for removal and re-install.
Has anyone had this job done cheaper? I don't want to spend that much on a 6 yr old van with 104,000...but I like to know the time!
Thanks everyone.
Sites:
http://www.shareamemory.com/radio/
Currently on ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7973589440&category=386- 40&sspagename=WD4V
There are also some other messages in this forum on some other links for information. ( I am too lazy to find them).
