Visitor Agreement.
The only suggestion I have for the pins is spray them with electronic cleaner and connect and reconnect the plug 6 or more times to scrape the corrosion off.
Also there was a TSB on the 95 to install a water shield so the connector would not corrode.
I need to change the wire (it went loose) that goes from the gear shift to the gear box, does anyone has a manual with instructions or an idea on how to do it. Mine is a 98LS Auto, 2.2. Thanks
get it going faster,, I still think fuel line somehow.. but I had it flushed... going crazy now.. lol :confuse:
can you email me. chuckphillips@juno.com.
I have a 1998 Chev Cavalier which doesn't have power locks.
My drivers door is stuck on lock, the only way I can get the door open is if i put my key in, turn as if I was unlocking the door then pull the handle. I MUST hold the key in the unlocked position until I pull the handle up. It won't unlock. When I get out of the car I need to pull open the lock and hold it while pulling the handle to get out.
How hard/easy would it be to fix that myself, and what am I going to be looking for when I open it up?
If you find you have to add coolant frequently, I would also inspect all hoses and the tank itself for leaks. Hope all goes well
The power steering pump was replaced 2 years ago.
I have a really simple question to ask that I need help on because I know nothing about cars. Anyways, my '96 chevy cavalier was broken into and somebody stole the really car radio that the previous owner had installed. I still have the original factory radio to replace it but I am having some difficulty.
Well my problem is that there are two wires in the dashboard thing to plug into the radio. I have plugged in the one thats for the power but there is the other plug that I am sure is for the radio antenna because the radio works but does not pick up any stations.
I'm not sure how to plug radio wire in because I dont think there is a place on the factory radio for it. It has a plug that looks like a big ear phone plug, unlike the power plug that looks like a hard drive plug. Let me know what to do or if I need to describe the situation better. Thanks a lot to anyone that can help.
http://www.hama.de/bilder/00043/abb/00043622abb.jpg
and the factory radio must have an input like the end of the upper item in the same picture (sometimes on the side and not the back of the radio)
Let me know if I have misunderstood your info or question.
The Chilton Manual may be available at your local library. I'm no mechanic, but I would suggest you seek professional help in getting chain properly timed.
I have a 98 Cavalier with daytime running lights. Problem is when I turn on the headlights the passenger side headlight is dim while the drivers side one is normal, High beams both work fine. Both lights are dim when on during the daylight hours (about the same intensity as the dim headlight is when I turn on the headlights at night. I'm thinking a bad ground somewhere but sure could us some help.
Bob
I have no idea what the problem could be and don't really have the cash to have a mechanic look at it. I was hoping someone with some knowledge would have something of a better answer for me,
However, Amazon.com is presently selling the "Lisle 14700 Oil Filter Wrench for GM 2.2L" for $8.94 --- shipping is free if you buy something else that makes your order total over $25 (the something else can be anything you were probably going to buy anyway --- such as say a computer printer ink cartridge.)
thanks again,
Josh
comes on when you are idling or when you put the brakes on to slow down or stop. Anyone know what this could be? Thanks
You might check out the thread below for a similar problem and the replies. Start with message #3365.
"Engine Oil - A slippery subject Part 2"
Cheers
When car is on and u turn lights on nothing happens except tail and signal lights. if the lights off and put into drive the right headlight indicator flashes 4-5 times and service eng light comes on. If u leave in park and turn lights on no flashing or eng soon light but no lights are on.
DRL relay was checked and headlamps are good.
Did you browse the Brakes forum for an answer?
http://townhall-talk.edmunds.com/WebX/.ef14c39/?ed_displayMakeModelRelatedDiscus- - sions!make=CATS&model=Brakes
