Pontiac Grand Am
1293032343551
  • deboraht1deboraht1 Member Posts: 2
    The axle that goes in to the transmission has freeplay movement in it which causes a tapping sound while driving it.
    Anyone out there having similar problems?
  • jc1973jc1973 Member Posts: 63
    do not buy a grand am i made that horrible mistake i bought a 97 3.1 v6 what a worthless pos u couldn,t give me anothet pontiac
  • jdexter23jdexter23 Member Posts: 94
    I brought my 00 GA to the dealer about fan speeds 1 and 2 not working and poor mileage a couple weeks ago. It was just the resistor that needed replacing for the fan. They added a "GM Highly Concentrated" fuel injector cleaner, but that didn't help. Cost me $102 for those items. They couldn't help with the burning smell coming from the engine compartment, but they were sure it wasn't electrical, burning oil, burning rubber, or brakes. Basically they told me they couldn't figure it our and just live with it.
    Since then, my front suspension has gotten very "talkative". Any decent sized bump makes the front left suspension make a creaking noise. I hope that will go away once it warms up. It hasn't been above 20 degrees here in almost 2 weeks:) Think I need to sell this car and be done with it...
  • 97grandamse97grandamse Member Posts: 3
    I have a 97 GA with 2.4L and auto, purchased new in 96. Enjoy the car and has been reliable over all. The engine has a timing chain. Experienced no problems with transmission or major engine malfunctions. With 68k, it has had replaced; a water pump, O2 sensor, alternator, 2 pairs front brakes, 1 pair rear breaks, front rotors, battery, lower control arms front suspension, oil pump cover. Getting low-mid 20s mpg mostly city, has 150hp, does the job for highway entrance ramps. I like the lines on this car. Easy on the wallet. No plans of trading or selling. Good luck Grand Am hunting.
  • jodar96jodar96 Member Posts: 400
    Thanks for your comments. This is the type of info I am looking for. My son is bent on Grand Am. We have narrowed the field down to 96-98's with 2.4L.
    From what I know they stopped putting that troublesome 2.3L quad four in 1996 model year, and the 2.4L was a new engine in 96.
    I have a 96' se with 2.4 and manual tranny. replaced water pump at about 80k miles and ignition switch last year. Other then that it has been mostly normal stuff like brakes and currently drivers doorlock giving me a little grief. Only have 192k miles on it now so we we have to wait and see if problems crop up ;-)
  • nickpernickper Member Posts: 28
    I have a 96/2.4L/automatic. I got it May of 99 with 32,000 as GM Certified. It has 125,000k miles on it now. Never left me stranded and no major out of warranty problems. Here is what has gone wrong though:
    IN WARRANTY: water pump around 35,000; O2 sensor about the same time
    OUT OF WARR: transmission mount came loose, O2 sensor on the rocks again
    My car was dealer maintained and I had the oil changed every 3k. Tune-up at 100,000k too at the dealer. Trans flush every 50k.
    I have been happy and as a college student I don't have a lot of $$ to drop on car repairs...
  • grand_am_03grand_am_03 Member Posts: 1
    Purchased a Grand Am SE V6 on Jan 11, 03. I have a slight Idle vary also when car has warmed up and I am stopped at a light. Idle varies about 600 RPM up and down, no error lights. Have not reported problem to dealer. I like the car a lot but hate problems that can not be found or fixed. Also two days ago my alarm sounded and airbag warning light came on then went off. This happened on a level road with cruse on at 65 MPH. Will have dealer service check this weekend.
    Thanks for everyone's input regarding Grand Am. I ended up buying a 99 GA with 2.4L auto and 93K miles. It seemed decent for the miles. I already changed the oil/filter, air filter, plugs, and rotated the tires.
    I will replace the coolant and fuel filter today, and have the transmission pan/filter serviced done next week. Any more, they hardly drop the pan. they do the fluid flush. I still like to change the filter. The good thing about the flush is that it gets the torque converter fluid as well. Never undestood why there is not a drain plug for torqure converters. Japanese have magnatic drain plug for rear axles, American cars/trucks don't.
    The gas mileage does not appear great. My 96 Camry XLE with V-6 engine does 29-31 on the highway. This car went through 3/4 of the tank doing 240 miles. To be fair, the outside temp was like 10 degrees at the time. With new plugs and warmer weather, I expect it to do better.
    For changing spark plugs, I have a suggestion. loosen and slide out fuel lines bracket. The electrical connector for ignition coil that is bolted to undeside of spark plug top cover COULD BREAK while trying to put the cover back on.
    One question: Is there an air bleed valve anywhere for coolant? I checked around thermostat housing and did not see a bleed off screw.
    GM did a nice job with coolant drain plug location, and the wing nut screws for removal of lower plastic cover for oil filter access.
    The location of oil dipstick is odd, and for transmiison filling hole they could have made the housing extend higher, so filling is easier.
    The front seat belt should have had one of those plastic bottons
    inside the belt that could postion the buckle up next to anchoring bolt for easy reach. Every time you unbuckle, the buckle drops all the way down. Not a big deal, but annoying.
    The cupholders are good for 8 oz. cups. I noticed that 2000 model and up have cupholder between the gear shift and storage compratment.
    The gearshift indicator should be in instrument panel as well. You could be in 3rd gear for a long time, before you notice that you slipped passed "D". You should not have to take your eyes off the road to see which gear you are in.
  • montanafanmontanafan Member Posts: 945
    Congrads on the car. Couple things to help answer your questions.
    Trans Fill--since the trans was designed to be "filled for life", not sure we can pick on filler location.
    2000 Cupholder--is an add on part that will fit your 1999 as I recall. Brother got one for his '99.
    Seat Belt Button--GM does have a replacement button kit for belts where they break. Check your belt webbing and you will see where it was. Can get the right color from a dealer.
    Best of luck.
  • joe3891joe3891 Member Posts: 759
    button missing on 00 Cavalier and the dealer fix was new belt assy.
  • wsuball27wsuball27 Member Posts: 1
    i have a 2001 grand am gt and i heard some talk of problems with the head gasket on the 3.4l v6. can anyone shed some light on this.
    I don't understand why GM is putting that raised little circle in the bottom of the cup holders.
    All they do, is making your coffee cup wobble and spill!!!!
    What is wrong with flat surface cupholders? They have the problem with 2001 U-vans (Chevy Ventures).
  • saturnfreak01saturnfreak01 Member Posts: 134
    Does anyone know when GM started using the new ecotec engine in the Grand AM? Was it 2002 or before? ... I wonder if the new engine would be any more reliable? It seems to have held up ok in the Saturn L Series...
    Also, for 2003 I heard that there is no more body side cladding on the grand am... personally I liked the cladding and felt it offered greater protection against thoughtless door flingers.. I may be buying a 2002 model Grand Am SE/1 , I have seen many for around 10 to 11 grand with under 30,000 miles. .. seems like a good deal.
  • hoyahenryhoyahenry Member Posts: 399
    2002 was the first year for the Ecotech and the last year for the cladding. The 03s look like they have come cladding but not like on the 02.
    I'd say 30K is fairly high mileage for the age of the vehicle.
  • vocusvocus Member Posts: 7,777
    You're right, 30K is high for a 2002 vehicle. My 02 Jetta has the same miles on it, and it cuts severely into the value of the car. Also, make sure if you buy one of these that it was properly cared for, lest you get yourself into trouble with it.
    Starting in 2003MY, GM is offering less car for the same or more money.
    ABS as standard item is gone. You must pay $400 to get it now. In Grand Prix, it is about $700. They dropped cladding because it costs money.
    My son's 99 GA, has cloth trim in interior panel of the door. I checked out a 2003 on dealer showroom the other day, it had all vinyl panel. Gone is the cloth. If I am not mistaken the lock in glovebox is gone too.
    Between decontenting the cars, and beating the crap out of its suppliers for lower prices, GM is financing its zero percent and its expensive rebate.
    GM used Toyota Camry as an example for making ABS optional. Toyota charges $300 for ABS on Camry, GM charges $400-$700.
    Now, ABS is standard on Accord. I very much doubt GM will use Accord as an example to bring ABS back as standard equipment.
    The best GM buys are probably 2001-2003 models where the cars were better equipped.
    Recent article talked about ABS. http://www.usatoday.com/money/autos/2003-02-13-safety-option_x.ht- - m .
    Grand Am SE: antilock brakes/traction control $400
    Honda Accord DX: ABS Std Traction Control N/A
    Honda Accord LX 4cyl: ABS Std Traction N/A
    Honda Accord LX V6 Auto: ABS & Traction Std $23500
    There are whole threads here at Edmunds pleading with Pontiac to drop the "cladding" for looks. GM now has people in charge who agree.
    How big was the rebate when your son bought his 1999? $0? $500? $750? I think most people would rather have $3000 then glove box locks.
    Don't be fooled by these rebates..... I take a 2003 Honda Accord LX anyday over GA. I have driven both cars.
    I bought the GA for my son because he likes the car. To me, GA has a very gimmicky and confining interior, very flat supension, uncomfortable seats, and not a fun car to drive, at least not the SE model. I can not speak for the GT.
    Also with any new car, try to pay attention to what is discontended. You are paying $400 more for ABS, you are not paying $400 less for not having it. Normally when you decontent the car, you lower the sticker price.
    Rebates are kind of a joke. GM has had four price increases in 2003MY alone. Your $3000 rebate is not what you think it is. IF GA is worth $14K, then GM should price it that way.
    By the way, I paid $4,800 for the 99GA with 93K miles just a little more than $3K rebate you get on the 03MY. It is in very good shape, and has the $14K GA look and the interior.
    As I said 2-3 year old GM cars are excellent values for what you pay for them. NEW GM cars are different matter. Where can you find a 99 Accord with the condition of this 99 GA for $4800? You can't find any.
    Please don't get me wrong. GM is building and selling a lot of GA's. It is not a bad car but in my opinion, it is no Honda Accord.
    Once again, bad news for John Public and good news for product liability attorneys.
    I can already see the cycles forming, and all of them end with higher costs for consumers for everything from milk to car insurance with a net decrease in value.
    has anyone had any light ticking coming from there grand am,s 3.1 engine mine just started doing this couple days ago and i can,t figure out why it,s a 98 with 70000 miles i just recently bought it it has the usual gm piston slap but now it ticks oil is full and clean
    One possible ticking noise cause my be the engine drive belt tensioner. This is a pulley the belt goes around that has a spring to keep the belt tight. Relatively inexpensive if it is it, and not a bad thing to replace to prevent a possible breakage which would cause the belt to fall off.
    I DON,T REALLY THINK IT,S THAT I HAD A 94 WITH THAT PROBLEM IT WAS ALMOST LIKE A SQUEALING SOUNDING THIS SEEMS TO BE COMING FROM THE ENGINE JUST STARTED 5 DAYS AGO ONLY HAD THE CAR 4 MONTHS
  • scott13713scott13713 Member Posts: 11
    i connecting rod to crankshaft bearing went out of my 93 3.3L v-6 am. I replaced it with another 3.3L from a 93 achieva. This engine had only 80k on it(compared to my 120) so it was a good buy for 350 bucks. Anyways, after installing it, i drove the car a bit and noticed it ran a little rough. the service engine soon light went on so i thought id check the trouble codes and see what was up. I got a knock sensor code. Now i know what the knock sensor is and what it does. But thwere in the world is it at and how do i replace it. All i should need to do is take the old one off my other engine and put it on the new one. any info on where its at, if i left a clip off or sumthing.....HELP
  • speedingticketspeedingticket Member Posts: 33
    I have a '97 Grand Am with 113,000 km. The car has been over all fairly reliable with the exception of the following:
    - 3 water pumps before 100k
    - Rack and pinion replaced at 40k
    - Alternator replaced at 100k
    - Brakes wear out way too early
    As this car has a timing chain, the dealer has not been able to get the timing right. The knock sensor has been changed twice and the computer cannot compensate for the poor adjustment. I will have to live with the knocking. Fuel mileage is as bad as my 2002 Intrepid which is a 200 hp car.
    I would strongly suggest getting the V6, the mileage is not much better and the 2.4 engine is poorly designed.My advice; keep shopping
    New Grand Am body style will arrive as 2005MY with start of production of July 2004 .
    2005 only SE1 and GT with LX-9 3.5 V-6
    2006 will add: SE with LE5 (HO 2.4L four), GTP with LZ8 (3.9L V-6 auto and 6 speed manual)
    2007 new engine in SE1 and GT (LZ3 3.5 V-6) will replace LX-9 V-6.
    New GA's will be built at Lake Orion plant. The current ones are built at Lansing North and South plants. It is possible that GM continues to build current GA with 2.2L engine as base SE model well into 2005.
    Would be nice to believe that the new Grand Ams are that close. But GM lately has been showing the Production Show Cars over a year in advance. The recent shows include the Chevrolet Equinox which dosen't enter production until next year. And I think the Chicago show had a Dawoo built Cheverolet that will come out next year. Unless there is a New York show debut in ?-April-?, I think it would be doubtful that July is start up. But we can hope. Thanks for the post.
    GM needs to show off and get customers excited about the first vehicle off its Epsilon platform which is Malibu. Showing off GA along Malibu will steal thunder from Malibu that will start production about a year ahead of GA.
    It is a good thinking on GM part to keep GA underwrap as long as possible. Historically,GM cars have been stealing sales from each other rather than from potential Camry and Accord buyers.
    There will be some overlap of old and new GA, as it was with Lumina and Impala, and still is with S-10 Blazer and Trailbalzer.
    all i can say is this never buy a ga i have a 98 and i f in hate biggest pos ever
  • jbmulderjbmulder Member Posts: 3
    I see GA hunters, I'm selling my GA since I want a std . trans., got tired of auto., I live in VA and selling my GA for $3,500 o.b.o, it has 160k and never got a major problem I keep up with the maintenance schedule, needs only a radiator and one front wheel bearing.
  • ted151ted151 Member Posts: 3
    Hello, Im new to the board and sort of have a problem wth my grand am.
    Ever since I took it to the dealer to get an extra keypad and key made for my car, the car has been chiming. Every 2-3 minutes it chimes 3 tmes in quick succesion, whether I'm driving or whether the car just sitting there without a key in the ignition. The dealer said it could be a number of things causing this and wants me to take the car in again. Errr I'd rather not go through the hassle if its something so simple as a reset switch or something. Anyone have any ideas why my car is doing this???
    You don't say what year your Grand Am is, but I assume it is a 1999 or up with the delayed locking feature. This is the feature that locks the door 5 seconds after the last door shuts. You activate it by hitting the lock switch on the door or remote with the door open. You hear the chime three times to indicate the car has the signal. This matches your description of the chime. But it shouldn't happen with the doors closed or the car running. Somehow it appears the car is getting a lock signal incorrectly. The only thing you might try is driving without any remotes in the car and see if things are different. Also check the owners manual, there may be a way to turn off the delayed lock feature. Other then that a dealer may have to check it out. Post back.
    And yeah your right its a 2000 red gt coupe actually. I remember reading something about delayed locking in the owners manual but never really played with it to see how it works. Sounds like Pontiac does just about everything possible to keep someone from locking their keys in the car. I'll read up on the delayed locking and see if I can't get it to stop. Weird problem huh, poor things prolly chiming in the garage as I type. And it started every since the dealer configured that keypad and made a key.
    By the way I just got the car last wednesday and I love it. Its a pure joy to drive and that red paint is just beautiful when its all clean.
    The owner's manual of 99 GA says 15 gallons. Edmunds review says 14.1, and I almost ran it empty, and was able to put in only 12.22 gallons.
    There is no way that this is a 15 gallon tank. my 96 Camry says 18.5 and i have put 18.5 in it.
    The gas mileage with mostly HWY driving is about 25. Reaching 300 miles on a gallon of tank is a stretch and it is disappointing. The Camry with V-6 with the same driving does 29-30. My old Dodge Stratus with 2.4L 4 cylinder used to do 29-30 also.
    For a 4 cylinder car with 12.2 gallon tank and doing 25 MPG, I am alot more in gas stations that I used to be. I replaced the plugs and both air and fuel filters. The tire pressure is at 32PSI.
    I haven't seen 300 miles per tank in probably 4 to 5 months. I would expect to get slightly lower mileage in the winter but this is getting downright stupid. My 00 GA V6 is getting 16-18 MPG around town, 22 on the highway. I might as well drive an SUV! I brought it to my dealer to see what might be the problem; they gave me a $12 bottle of fuel injector cleaner, which they claimed was more potent than the stuff you'd buy at Wal-Mart. It didn't do me any good.
    The funny thing is that there is not a hint of decreased performance, like you might get with a dirty air filter, old plugs, etc. As the gas prices keep rising, so does my discontentment with this car.
    You do know about the 'reserve' built into the tank, right? There is at least a 2-gallon reserve built into the gas tank, so you don't run out of gas the second the fuel light comes on.
    Yes, I do know about the reserve. If you refuel as soon as the light comes on, I bet you can't put more than 10-11 gallons in. There is NO WAY that the gas tank holds 15 gallons. One of these days I will run it dry and fill it up and let you know how much it holds.
    Has anyone put 14 gallons of gas in 99-03 GA?
    I don't have a Grand Am, but in my VW if the light comes on, it takes about 11 gallons and my tank is 14.5. According to the manual, the reserve is 1.9gals. Of course, the light could be coming on because of the angle the car's at, you know?
    I've had fill ups at 14 gallons plus a few times, but typically I don't let it get that low. All of these times the low fuel warning light has come on and the chimes have sounded, but I have not always refilled immediately since the reserve capacity is 2 gal. or so. I think the last time it took 14.2 gal.
    I just turned 80K on the 99SE. The only repair (other than expected maintenance) I have done is to replace the fan resistor board at about $25.
    The 95SE (now my daughters car) is at about 78K, but has had a few more problems.
  • the_art_guythe_art_guy Member Posts: 61
    jodar and jdexter...
    I have a 2000 Grand Am SE with the 3.4L V6 and I replaced the spark plugs almost 2 years ago now, around 28k miles. I now have about 75k and get great gas mileage. I consistantly get 300+ miles out of a tank of gas (without the light coming on.) My stock plugs were fine, but I just wanted to replace them to see what happened. I ended up putting in Bosch "Platinum +4" plugs and immediately saw an increase in my gas mileage, about 15-20%. I've also noticed smoother shifts too.
    I'm not saying this would be the case for you,
    but it can't hurt. I changed the plugs myself and it was a bear getting to the three cylinders on the backside of the engine, it took me 3 hours!
    Hope this helps.
    My first fill up I put in 11 gallons and just barely got 200 miles out of it in all city driving. I dunno what the equates to exactly just know its under 20 mpg. I expected a bit better but I'll have to see how it does in the summer.
    And my car has been to the dealer 2 times to try and figure out whats making it chime. Now my car is spending the night over there cause they never got it figured out. I guess its not a big priority for them since they dont get paid for fixing problems that they caused.
    Art Guy,
    How much of the injection system did uyou have to take off to reach the 3 plugs closest to the firewall? I'm the kind of guy who likes to do most of my own car work, but when I saw how obstructed the rear plugs were I seriously considered letting a mechanic deal with it. Since you have been through it, what would you suggest?
    Update on my situation: 2000 GA SE1 V6 - 60,000 miles. Car has been dependable, but have minor irritations like: Poor gas milage, creaky front suspension, poor seating support and a flakey CD player (replaced that with a Pioneer 5 Months ago). Have replaced the battery, front brake pads and rotors, CD player, & Fan resistor board. Plan on replacing the drivers seat foam once it warms up.
  • bill211bill211 Member Posts: 21
    I can do mine in 30 mins without any dismantling of other parts. The trick is having the right tools. You need a deep well spark plug socket a 3 in ratchet extender and a swivle attachment. Then those 3 in back are not difficult at all.
    Also what do you think are the best performing plugs. Delco, bosch ,NGK. I always use the rapid fire model.
    jdexter...
    I agree with bill211, you need a 3" rachet extension, as well as the spark plug socket. I didn't have an extension when I did it and I tore my knuckles up on the engine. You don't need to remove anything, just make sure you do it with a COLD engine and don't overtighten the new plugs when you screw them in. Also, I would recommend spreading some anti-seize compound (available at the auto store) on the threads of the new plugs...when it comes time to remove them, they'll come out a lot easier.
    The Bosch plugs were not cheap, around $5 per plug if I remember correctly.
    Good luck!
    I did put Bosch platinum plugs in. They were one-prong ones at $1.75 I did put four prong ones in my Camry (since double prong ones were not out two years ago), and I really could not tell the difference. The Camry runs as good as it did before changing the plugs.
    It is interesting to see that someone said they put 14.2 gallons in theirs. I expect the gas mileage to get better than 25 HWY for 2.4L engine once weather warms up.
    Our company van, a 2002 Chevy Venture has the same GA's 3.4L V-6 in it. on trips, I have got 27MPG in the van. The van has 58K miles on it.
    On my 94 Honda Accord 4 cylinder with 17.1 gal tank, once I got an unbelievable 610 miles before fill up doing 65-70.
    I got this E-mail back from one of the GM engineers that works on this car platform. Malibu and Grand AM are basically off the same platform.
    " Regarding your car, in MY1999 the fuel tank actually had 1 gallon more
    capacity that in MY 2000 when we went to the plastic fuel tank. 15.1
    gallons is correct volume from fuel run-out. Those fuel tanks had a very
    generous empty reserve (you can drive a long way on indicated Empty and
    even <Empty) so the numbers you quote do not surprise me. That was an
    issue with the fuel gage calibration for those vehicles. We got it better
    in MY2000 with the plastic tanks. Put some injector cleaner in the fuel
    tank and see how that works for the mileage issue. You did not mention any
    Check Engine lights so I assume that you don't have any. Those mileage
    numbers are a little low. My V6 Malibu will consistently get 28 MPG."
  • dick59dick59 Member Posts: 9
    My 1999 GT1 consistently gets 20-21 miles per gallon in Los Angeles mixed city and freeway driving. I can get consistently 300+ miles between gas fillups. The low fuel light comes on when you have used up around 11-12 gallons of gas. So, yes, you have a large reserve and you can wait until the gauge shows slightly less than E before being worried. I have had fillups close to 14 gallons, never close to 15 though. My highest mileage has been 24-25 miles per gallon. I have original plugs and have 38,000 miles of totally maintenance free driving. This is one great car.
  • buggywhipbuggywhip Member Posts: 188
    I have a 1995 with the 3.1L 6-cyl. I've been slowly losing coolant, can't find the leak, can't really smell it either. The thermostat slowly climbs to redline after driving for the first 5 minutes, but it eventually returns to normal temp and stays there. The plastic jug coolant recovery tank is always nearly empty--nowhere near the "full cold" mark and it's never full even when the engine is hot. Anyone else have the same prob? What is it?..................BTW, the 3.1L is a great engine. Very economical and powerful.
  • rs_pettyrs_petty Member Posts: 423
    Probably the back side head gasket. Same problem on my 99 Lumina. The gasket is plastic rimmed and cracks over time. Have the system pressure checked and they'll probably find it.
    rs_petty, thanks much for your superb expertise and diagnosis. I am deeply sorry that you experienced the same prob on your late model Lumina.........BTW, what's a repair like that cost, ballpark figure? I imagine your Lumina was covered under warranty.
