Chevrolet (Geo) Prizm
1568101129
  • pat97pat97 Member Posts: 1
    Hi, I am going to buy a GEO Prizm 96 w/ 83K mile, AT. Not much power options but with ABS. The seller told me above average maintenance has been done. Has passed the MD state inspection test.
    Please do me a favor - is this a good deal??
  • tim1mytim1my Member Posts: 6
    I was unable to find the info out on any brochure.... but was hoping someone familiar with the 2001 Prizm could tell me if it still comes with a timing belt, or if it is a chain now. If it's a belt, do you know how often it requires changing. Thanx in advance.
  • jodar96jodar96 Member Posts: 400
    Toyota uses timing belt on all their passenger cars. Geo Prism/Chevy Prism are Toyota Corolla twin. I don't know what they do in Lexus line.
    Chain set up is a more expensive way to build engines
  • enetheneth Member Posts: 285
    Not all Toyotas use belts. The 1.8L engine in the Corolla and Prizm (1998 to present) use a chain-driven camshaft, not a belt. It does not require routine replacement as a belt does.
    This is very interesting. I have never seen anybody using chain on such a small engine. Timing chains are usually used in bigger displacement and more advanced engines.
    I trust what is said here, and will verify it. Thanks for the info. Chains last much longer than belts, but over the years, they get noisy.
    That Toyota engine is among the more advanced 4-cylinder engines you'll see on the market.
    Other makers use chains in similar-displacement engines as well - Saturn, for one. The home-grown Saturn 1.9L 4-cylinder uses a chain (not sure about the European 4- and 6-cylinder engines in the L-series, though).
    Nissan is also using timing chains. I own Prizms and a Nissan. Many small motors now have timing chains.
  • ken126ken126 Member Posts: 39
    I went looking at the new prizms and to tell you the truth they are very bland and the rear leg room is no better than my 90 model. It almost felt and looked like the same car from 11 years ago. I didnt want to look else where, but I dont think I can buy this car again. I am going to check the Sentra and Elantra next.
  • wenyuewenyue Member Posts: 558
    Toyota Corolla from 1998 onward uses the timing chain. If I remember right, it only recommend inspection every 36K miles, no replacement is required until well after 100,000 miles (if ever).
    1998-current Prizm uses the Toyota engine. So it's the same timing mechanism.
    ....to everyone who provided their insights regarding my timing belt or chain question. The moment you took to share it is appreciated.
  • k33k33 Member Posts: 1
    I own a 1999 Chevy Prizm without ABS.
    Is it possible to put ABS on it? If
    so, any idea what the cost would be
    to have it done?
    Ken
    I doubt it. ABS is extremely complex, and it's a factory option. I don't think any ordinary dealer could do the job. :(
  • badbrett79badbrett79 Member Posts: 29
    even if u could get abs aftermarket youd probably pay dearly for them try trading in on a lsi which iccludes abs
    fluid on the manual 5sp 95 prizm??it looks like u have to vacuum it out and pump i back in the same hole !!???. this car has 90k and never changed and my bro learned to drive o this car lots of gear grindidng and it seems its getting harder andharder to shift now imagine the fluid is really worn out, on that note can u chqange the power steering fluid,clutch fluid, is there any need ? thanks, brett
    the spark plugs on this there also 90k miles old (nowonder im only getting 200 miles ona full tank of gas i hope) i cant even fit a spark plug remover past those stupid sleeves at the top of the engine, nay ideas
  • grishlangrishlan Member Posts: 1
    How worth it would it be to buy a '93 Prizm, 80000 miles, with no body problems for $5495?
    Please let me know at grishlan@yahoo.com
    although thats lower miles for any 93 car, but there one for sale here a 95 with 90k for 5k, depends if its an lsi or base with 5sp or auto,the main dif is the passenger airbag added in 1995,let me know if u have any questions about this car. later, brett oh i own a 95
  • snitssnits Member Posts: 1
    I am looking at purchasing a '93 Prizm LSi that has less than 24k miles for 4995. It's very clean (almost flawless)...does this sound reasonable?
    thats extremely low miles and at that price its a steal, i still would make sure it had its reg mainance though, some parts are more affected by just sitting and not bein driven, like exhaust, rotors, body drain channels, i bought my 95 with 80k for more than that, would be excited on having a very low mleage one like that, it will take care of u , good luck these are very reliable trouble free cars!! oh u mentioned lsi it should have the 1.8 motor and some power options even makesm it a better deal
  • kat47kat47 Member Posts: 1
    Bought a used 94 Prizm with just 6200 miles (standard/3 spd) for $6000. Two things -- is there no trunk light? and rear window defogger isn't working (replaced fuse but that wasn't the problem). Where do we look next to fix this thing? I don't have a repair manual yet with the wiring layout. Thanks.
  • akb1akb1 Member Posts: 5
    In 1999 I bought a 96 Geo Prizm with 33,000 miles on it. I commute on freeway. Now this car has about 47,000 miles. I noticed that engine is pretty noisey at about 75 MPH.
    I also have a 94 Sentra that has been extremely good to me for 130,000 (I will put another 30K - 35K by end of 2002 And perhaps retire it and start using Geo). The Sentra with its high mileage is still less noisy at the same speed.
    Do Geos make more noise than Sentras?
    I have been thinking to take it to the dealer or auto shop?
    Any thoughts?
    Automatic or manual, and if automatic, is it a 3-speed or a 4-speed. The 3-speed auto forces the engine to rev higher at highway speeds and as a result is noisier.
    It is a 3 speed automatic.
  • pshockpshock Member Posts: 2
    I bought a geo tracker in 1999 and was about to sell it to a private indivual and found out through prospective buyer that my car was involved in accident prior to my buying it from dealer and was never disclosed... now my transmission is failing as a result of prior undisclosed accident...according to mechanic... can I give the car back to gmac now without repercussions...pls advs asap...thku...
    how do I lower my beacon score if I have located errors in my credit report... or is there a different credit report the dealers based their apr rate on...pls ads
  • capie41capie41 Member Posts: 3
    for four thou from a dealer..
    i traded in a 93 maxda protege LX that had the clunking problem (when you shift gears) that a lot of them have! even the new, new proteges.
    anyway, the prism only has 63k on it, and it looks like new. it's not the lsi and i miss the lux of the LX, but this one also has a "roadier", more sporty feel that is hard to explain, but i like driving it better.
    i hope this car is as reliable as it's cracked up to be. has anyone switched from mazda to geo and happy they made the change?
  • kneehowmakneehowma Member Posts: 17
    Hi y'all,
    I am a proud owner of a new 2001 Prizm. Put up 2000 miles in less than a month and did an oil/filter change around 1500 miles. So far so good, the car runs fine with no problems and engine noise is non-existance even with 3-spd automatic.
    However, I noticed that the coolant level is kinda low and I am wondering what type of coolant should I use? After doing some research, I narrowed down to either GM Dex-Coolant (orange color) or Toyota red coolant. Since Prizm is basically a Corolla, should I go with the Toyota red coolant? Also should I flush the coolant and place it with regular green coolant when that maintenance schedule come up? Thanks for any help!
    Use the Toyota coolant. It is not the same formulation as the green stuff (Prestone, etc.), nor is it the same as in true GM vehicles.
    If you don't get discount coupons, find a friend who has a Toyota - they send discount coupons all the time, which make the cost of routine parts (antifreeze, filters, etc.) just about as inexpensive (or cheaper in some cases) than you'd find by buying decent aftermarket maintenance items.
  • sighsigh Member Posts: 2
    Hi, I just purchased a '93 prim psi 1.6l 3 up auto. When I am going over 50mph and accelerate there seems to be a shaking coming from the front left side. It gets a lot worse if I am going around a right turn. If I let off the gas the shaking goes away. I originally thought front wheel bearings but once it gets up to speed it's fine and doesn't rumble like I'm used to with bad bearings. The car is going in the shop tomorrow but any help would be appreciated.
    Frank
    Has the car been aligned, and have the wheels been balanced lately?
    I don't know if it's been aligned lately but it goes down the road straight as an arrow with no pulling what-so-ever. I don't think it's a tire balance problem either because the guy I bought it from just put new tires on it, also unbalanced tires shake at certain speeds whether you accelerate or not I think, mine will shake the whole time I accelerate...
    Frank
  • shishi Member Posts: 6
    How about the universal joint on the axle
  • ravramravram Member Posts: 7
    Hello!
    I have been reading all the posts, and this sounds like such a great little car! No wonder I'm buying one on April 2nd..... :-)
    Anyway, please bear with my stupidity, but when you get ANYTHING done on these brand new cars--you take it back to the Chevy Dealeership, right? I'm only asking because of post #380 about the coolant. I hate to feel like a retard, but I have never had a brand spankin' new car.....the closest I've had was a 1999 bought in 2000 with 14K miles on it....
    Also, another weird question, does anyone have (or know where to find) written down, blow by blow maintenance schedule (for dummies like me!)??
    For example, it would say like:
    1,000 miles Oil Change
    3,000 miles Oil Change, radiatior flush,
    5,000 miles Whatever.....
    And on, and on, and on.....
    Any advice/help would be appreciated. Thanks!
    Ramona
  • kunze1kunze1 Member Posts: 19
    Ramona - Hi! I too am joining your new 01 Prizm club. Picking up new LSi up in 4 days. Great deals available out there (Twin Cities area). Got a silver $17,000 LSi (window sticker) for $13,000 even. Got the $1,500 factory rebate (good till April 2), dealer down close to invoice, and then another $1400 off with the GM card. All stock LSi 5spd., with CD and alloy wheels as only options. This one has Goodyears on it (not the less desirable Firestones). Looking forward to driving this reliable sedan, hoping to get 37 to 40 mpg (41 mpg highway rating) on my daily highway 142 mile round trip commute (4 days/week). Also, considered the Mazda Protoge, but the so/so mileage was the turn off, and then the Corolla quality won me over to the well made Prizm. Ramona & others: - The low coolant situation should be taken care of under warranty by dealer. The owners manual should list the maintenance schedule for oil changes etc., in the back somewhere. With my 98 Geo Metro I had been going 6k to 7k miles between Mobile One changes. Used no oil at all with 78k miles on the clock. Reliable car, is up for sale now. Concerning the question of the 93 Prizm with shaking - Get it up in the air and spin all tires by hand and observe for a rim wobble or tire wobble or bobble. Likely is one of these two, even with the new tires mentioned. Also, try to shake all wheels back and forth and up and down also, to check for loose joints or excess bearing play. You should find the problem. If not have balance re-checked, and go from there.
    Thanks for the response!
    I am so fed up with my current car--a 1999 Kia Sportage EX, 4X4. I bought it last July and have had nothing but problems with it! It has been in the shop at least once a month.... What burns my a** is that I was stupid enough to believe that I was buying a "reliable" automobile--yeah right! I can rely on seeing the service department once a month! Anyway, to make a horrible story even worse, I am "upside down" on the payments--meaning I still owe 13K on the car, and the most I have been able to find a dealership to give me for my POS is 10K. Sheesh! The Chevy Dealership here in Ann Arbor MI is really great, and they are trying really hard to work with me--the Prizm has the best lease special that I can find right now. I have been trying to sell my car by myself for almost three months now--NO CALLS!!! So, I am cutting my losses.....Then, even WORSE, my car totally would not start at all last night--I ran errands all day, came home around 1 pm, then had to go back out at 5 pm, and surprise, surprise, my POS wouldn't start! I had this problem last November and December--I would go somewhere and come out 5 minutes to an hour later, and it wouldn't start. They fixed it before Christmas, and now, it's acting up again. I CAN'T WAIT TO TRADE THIS IN!!!!! I don't even want to list all the things that have gone wrong with this car (at only 22K miles no less!) because I will just work myself up into a rage and go postal on a co-worker!!! Suffice to say, I will be sooo happy when I get into another car!
    Also, you mentioned the special only going on until April 2nd??? I was told by Rampy Chevrolet, here in Ann Arbor, that the special is STARTING on April 1st. Are they lying to me?
    Thanks for reading and sharing!
    Ramona
  • uis00snuis00sn Member Posts: 18
    Does anybody know how many up that car has? It was the last version before the re-design.
    Thanks,YG.
    Sorry, meant to say 'Hp' (horsepower)...
    I believe it was right around 120 HP in 1997. I know that I was told by dealer that the new variable valve timing technology in the newest Prizms added 5 HP making the current 125 HP. Makes for a pretty peppy car, since it only weighs in at 2400 lbs. - Dave -
    Ramona - I checked the rebate and incentive section of this Web Site, and it still says $1500 until April 2. However, your dealer may know about up coming rebates (not announced yet) and be basing his statements to you on that. If I were you I would just phone another Chev dealer in your area, express and interest in a new Prizm, and inquire about current and future rebates. Ramona - Sorry to hear about your Kia Sportage problems. You may need to advertise it in a wider area, and with different mediums (Web, Auto shoppers, another big paper, for sale signs in window and park at local mall as much as you can). If it is still under warranty, I would stress that in your advertising. -Dave-
    Thanks Dave.
    Hit enter by accident, sorry.....
    Anyway, thanks for all the information!
    Well, I don't have to worry about the POS Kia anymore--although, kunze1, I did try everything to sell this thing, flyers at my work, and everyone else I know--their work too, flyers in the window, autotrader.com and the magazine, all local newspapers, etc.....
    I picked up my new Prizm last night--from a different dealership than in Ann Arbor. To think of the mess I could have gotten into with those people! And, now I KNOW for a fact that they were lying to me--they told me that the rebate didn't START until the 1st of April--and come to find out here that it ends on the 2nd!!! I came sooo close to being screwed! Thank GOD I found a good dealership--and this one is right by my house, so I'll be close by for oil changes and such (hopefully, not much more than that!) I'll have to update in a couple of months, because of course, everyone loves the car brand spankin' new.....
    Thanks to everyone for listening to my grumblings, and for all the help and advice. This site is great!
    Ramona
  • bk_furmanbk_furman Member Posts: 3
    I bought a 2000 Chevrolet Prizm with a lot of apprehension. This was my first brand new car purchase. I wanted to make sure that it would be the right one. I already owned a 1994 Dodge Caravan SE and needed a car with good gas mileage to get to and from work.
    I looked at the Saturn S wagon, Ford Focus Wagon and Ford Escort, Dodge Neon, and Chevy Cavalier, before I looked at the Chevy Prizm. I wanted to look at the Toyota Cars, but my wife did not want anything from Japan. So to appease us both, I went with the Prizm.
    I got a 3 speed automatic for $13,800 with a five year 60,000 mile warranty. I have 9500 miles on it now, and life could not be better. After the last oil change (at 9000 miles), the oil was almost like new. The car drives great, and has surprising power for a 4 cylinder engine. The engine is quiet, even at start up, and I get around 25 miles to the gallon in bumper to bumper Houston traffic.
    I have only have two complaints about the car, but they are my own fault. One, a rear window defogger. I did not know it was not standard on the car. And two, power door locks. It is a pain to reach around to unlock doors for kids. Other than that, I am 100% happy with this vehicle. I hope that this will be my son's first car when he turns 16, 10 years from now.
    It is a shame though that Chevrolet is phasing this car out. I think it is the best car they have. It makes the Cavalier look silly.
    I hope this helps anyone thinking of buying a Prizm.
    Whew!!! That was a close one Ramona! Close, concerning your factory rebate situation and the April 2nd expiration date. Glad it worked out for you! Typically there will be other rebates offered later in the year, but " a bird in hand is worth more than one in the bush". Did you trade your Kia in? (Couldn't tell for sure from your post.) Hope you unloaded it OK. What Prizm and equipment did you get?
    I just picked up my new silver with alloy wheels Prizm LSi 5 speed tonight, celebrated at Chi Chi's with my wife, and then drove home 60 miles. Sharp looking, and wow, what a smooth running and driving little sedan! More impressed now than my initial dealer test drive, and very peppy too! I like the way the RPM's drop down low at highway cruising speeds (did not do this well, on a Mazda Protoge I test drove, so no wonder the Protoge is only rated around 30 mpg on the highway). The new Prizm gas gauge was still above full when I got home, so that is a good sign. Concerning tires, before purchase, I had noticed some LSi's on the dealer lot had Firestone, and some had Goodyear Integrity tires. I then looked at the Tire Rack web site to compare the ratings of the Firestones to the Goodyears. The Goodyears were rated a little better in just about every category (wet and dry traction, snow, etc.) so I requested they swap out wheels, tires, and all from another Prizm to get the Goodyears. This they willingly did, and gave me the Goodyear warranty paper work. With the LSi (and with either tire) one gets little wider tire P185, instead of the P175, so road handling should be a little improved, over base Prizm. Since I put on at least 145 miles a day (4 day work week) I should have on about 600 miles by this time next week. (Unless I just go out and drive it around for fun this weekend!!!!) Found out the Chev dealer has factory mud guards available, so may invest in some soon.
    Dave
  • jfranks1jfranks1 Member Posts: 1
    We just bought a used 1999 prizm lsi and love the car. it is still under warranty. As i was checking out the trunk I noticed water in the driver's side, right behind the wheel-well. The cover over the spare tire was not wet at all, only under it. I dried it up and then the next rain filled it again. The car was not driven before the 2nd incident. Would anyone know what is happening. thank you in advance.
    Hello all!
    kunze1, sorry my earlier post was not so clear...
    I did take a HUGE loss on the Kia, but I was expecting that. The problem was, I owed close to 3.5K negative balance on the POS, and I only had $500 to my name. So, with the rebate, I only had to go over the price of the Prizm by $1500. I probably could have tried to bargain with the dealership (which, by the way, is a great place! University Chevrolet, in Ypsilanti MI.) but too bad I had NO leverage--I just needed to unload the Kia ASAP! Hopefully, I have now learned my lesson, and will never be in another situation like this. I am a bargain shopper by nature, so I wish I could have bargained for this car, but oh well.....
    The sticker price was $15,795, for the basic Prizm, 5 speed, medium red color. The funny thing is, it has power nothing, but it does have a sunroof and cruise control. Weird!
    Anyway, I don't know how they worked everything out, (and I personally couldn't care at this point--I just hope it's not another lemon...) but I walked out of there with the new car after putting $500 down only, and my payments (including tax, title, etc...) are at $294.51 a month. I know, I know, I wanted to keep them under $250 a month (was paying $350/month for the Kia) but it was physically impossible, with how much negative balance I had on the previous car. I don't know how good of a deal this is or not, but like I said, I was in no position to bargain with them, and I got rid of my POS Kia, and I am driving a new car, while paying off the stupid negative in 3 years. The other dealership in Ann Arbor, on the other hand, kept telling me to BUY a car (yeah right! Get into even MORE years of payments than I'm in right now?!?!?!? HA!), dragged their feet on paperwork for a week, and they came up with some outrageous figure of $380 per month, with $2700 down. Buddy, (I said) if I had that kind of money, I wouldn't be in the mess I'm in right now!!! So, I pretty much told them to go fly a kite. On a side note, I also think I have a stalker from that bad dealership. The salesguy called me (after I had bought my Prizm from the good dealership) wondering if I had any family members that worked for GM, that they would try to work with me and get me a deal, blah, blah, blah. Ya know what? It was the most satisfying thing in the world to tell him that they blew it, and I was already driving a new Prizm, WITH the deal that I wanted, and I did it in ONE DAY!!! He just kept sputtering about how that was an impossible deal, and how'd they do that, and on, and on, and on..... So what, I'm a liar now? Puhleeze, give me a break. Well, I think he is stalking me because since that converstaion, I have 5 other voicemails at work. I don't think I will be calling back.....
    But, I know what you mean about the gas guage! I got the car on Thursday with 12 miles on it, it now has 170 miles, and the needle is barely at 3/4 tank! This is great! My boyfriend was laughing at me and calling me "Base Model", and I told him to just drive it, and then see. Well, since then, he has wanted to go places all weekend, and "spare" me from driving in the traffic and bad weather (it's snowing here in Michigan right now...) Yeah, right! My little egg beater is pretty fun to drive, base model or not! :-) Let's hope it keeps on goin' strong--I'm freaked out after owning that lemon Kia POS!
    bk_furman, where did you hear that they are phasing the car out??? Eeek! Just my luck, I find a car that is great, and it will be discontinued--Madonn' Mia!!!
    Once again, thanks for listening (reading) and sorry for the super long posting....
    Mona
    Mona - Glad to hear you got out from under your Kia and ended up with monthly payments under $300! Sounds like to me you did pretty good, unless your payments go on for life! Your Prizm sounds super nice with the sunroof (come on summer!) and the cruise control, to help keep you under the speed limit. The 5 speed will save you some gas money. Sounds like you found a good dealer, and, if you have concerns about the other salesman (harassment), I would call the dealership and ask to talk to the owner or manager about it. That kind of stuff is totally uncalled for! Enjoy your new Prizm this week, as will I!
    Sorry, this is an old news. But I just found out that GM is going to discontinue Prizm after 2002 model year. :( What's GM management thinking?! Maybe I should go buy another one next year for my aging parents because it's such a nice, easy-to-drive, reliable car. Sad to see it go....
    http://www.caranddriver.com/xp/Caranddriver/dai/December/20001201_dai_gmprizm.xml
  • thegrog3thegrog3 Member Posts: 6
    I was in an accident on 3/19/01. My car has only 69,000 miles on it and is in immaculate condition. The repair estimate is around $4,500. Kelley Blue Book says the retail value is $5,090. My lawyer says Allstate is offering a little over $3,800. The only major problem that has gone wrong is an alternator. I also have an extended warranty through AAA that is good til 75,000 miles or July 2002. Any ideas to back me up that they should fix my car?
    thegrog3@hotmail.com
    I believe you should hold out for full blue book value, as that is only fair, to cover your potential replacement costs, when you attempt to find a similar, good vehicle. That is why you put out good money monthly, so they will fully cover the risk. You know what you have with that 93 Prizm, as you have maintained it, and expensive surprises should be minimal. Remind them that you want to be able to continue to reccomend All state Insurance and agents to your friends, and to the thousands of readers of internet automotive forum chat groups like this. I, for one am already getting a very bad impression of this mufti-million dollar company, just reading your story. Is this their idea of public relations? If you go out and replace the vehicle you still won't have the warrantee coverage, unless you spend more good money, and re-purchase it on another vehicle. That value will just, be lost, if they don't re-build, so remind them of that.
