Visitor Agreement.
M
M
The car was very good for the first month or so, then overnight the exhaust got loud. Turns out the car needs a manifold and resonator pipe ($500 for those) I hear Prizm exhausts are short lived but it was out of the blue. The battery and e-brake lights come on at random, but they seem to be working fine. The car does run very well though and tranny is smooth (A 3 sd auto sucks, but it was always like that) The car went through a spell where it would randomly not start unless i gently touched the positive terminal, but when i would wiggle it hard the car would never shut off.. it hasnt done this in a few months though. Overall a good car.. I'll sell it for a couple hundred.
Actual cooling is regulated by a mechanical device called thermostat. I never replaced one on Prizm so I am not sure exactly where it is, but if you carefully trace the path of the radiator hoses, you will find it.
I hope the "clicking sound" does not imply internal damages to the engine due to overheating... Thermostat should be less than $20, but excessive overheating can ruin the engine. Blown head gasket also results in overheating, but for $20 you should replace the thermostat and see what happens.
Good Luck,
M
I would start by checking all fuses. There may be some under hood as well. If you have a wiring diagram or just a fuse layout, look for a fuse that is shared by the affected components. It will be helpful to know what else is not working, such as radio, headlight, etc. 99 is too new to have a serious problem so I am thinking this is a fuse issue.
M
0. Has the thermostat been replaced?
1. Does the car still overheat?
2. Does the clicking noise occur at all times?
3. Did you check for cracks in the exhause manifold? (this can cause ticking or clicking noise as well as loud exhaust noise in general)
This is not very likely but has anyone checked the valve adjusters? They are hydraulic type and when they fail they cause ticking noise.
M
the exhaust is brand new and so is the transmission. Car was working great til a week ago. When you try to drive you can push your foot down on the gas and it doesn't want to accelerate. A friend makes custom parts for cars and works in a auto supply company and works on cars and he's been replacing parts left and right...the codes said fuel injector (#1) been replaced and still doesn't want to work. :mad:
Did you put gas in the car right before the problems started? If the gas station let the fuel level in their tank to too low, bad stuff could come out of the pump. It is unlikely but still a possibility.
Has the timing been checked? If the timing belt is loose and the belt skipped the teeth, the car won't run right. Symptoms of wrong timing would be loss of power and overheating. I would definitely check the timing if you haven't done so yet.
M
Ignition timing is timing for the spark plugs to fire, and it is not related to valve timing at all. It too can go out of adjustment, and "tuneup" service usually includes ignition timing check. You should have it checked as well.
Let me know how it goes.
M
I have a Fiat Punto 1.2 8Valve and it has a similar problem.
It will overheat within about 15 mins of starting, but just before light comes on, it will make a clicking sound with the throttle, and the more throttle i give it, the louder it gets. If i'm off the throttle, then go on it, i hear a fast click a few times, then it stops a bit, like a slipping, clicking, hard to describe on here.
I am getting a new thermostat fitted, so leaving it at that for now but i'll let you know what happens. Mine only does it when it's getting hot though.
Hopefully this should solve problem, no hot air through vents, thats why we think it's the thermostat... or the water pump?
Wish they were still making this car new. 40 MPG in a automatic Prizm beats the hell out of a smaller less powerful Aveo that can only manage 35MPG
Thermostat failure is fairly common so let's hope that solves the problem.
If it doesn't solve the problem, check ignition timing with a timing light. Check if the timing belt is tight. Clogged (internally or externally) radiator is another possibility. You can squeeze a radiator hose in your hand and see if the coolant is flowing once the engine warms up. Hoses should get hot as the engine gets hot, if the water pump is indeed circulating the coolant (be careful doing this). If the coolant is circulating, water pump should be ok.
Good Luck.
M
Toyota Corolla is still in production and it is almost identical to the Prizm, except that the Corolla has gone through a model change since the last generation of Prizm/Corolla co-production. My GF has a 05 Corolla, and it is much quieter and more comfortable than my 94 Prizm.
The new bargain is going to be Toyota Matrix/Pontiac Vibe. They are much more spacious than the Corolla and very good on gas. I expect the Vibe to depreciate in value much faster than the Matrix, and it will be just as reliable as the Matrix.
M
I would not assume that you need a new head gasket.
Some cars have engine oil cooler inside the cooling system. One possible location for this device is near the intake manifold. This takes hot oil from the engine to the coolant (in separate a tube of course) for cooling of engine oil. There may be a heat exchanger (should look llike mini-radiator within the cooling system) bathed in coolant, and if there is a leak, oil will end up leaking into the radiator.
I read somewhere that oil pressure in this oil cooler is typically higher than the coolant pressure, hence oil leaking into the coolant, not the other way around.
M
But hey shocked the guys when I got the book out and replaced some of the parts myself lol
It's an annoyance, really, since the only symptom other than the light is a hestitation sometimes when accelarating from a stop (I'm extra cautious about pulling into traffic now!).
Out of solutions other than having the fuel filter replaced, which I imagine would be expensive as heck given its location, I'm wondering whether the PO171 problem may be related to another issue I had at the beginning of the summer, namely my A/C refusing to cool. I added more refrigerant without any luck, then replaced the filter/orifice, which was completely clogged, and refilled with coolant. Both times the car cooled for a day, then stopped. I have an ultraviolet light to pick up the dye in the coolant, but I can't detect any leaks.
I'm out of ideas, so I'm wondering whether ya'll might think there's a connection, however unlikely, between the PO171 issue and the failure of the A/C to cool. Or, if you have more suggestions on how to remedy either, I'd welcome them!
Anybody else have a problem like this?
However, I heard back from the dealer an hour or two after I dropped the car off. As with other folks' experience with this problem, it was the mass air flow sensor. Parts and labor and a new sensor cost me $352.99 overall. Pricey, but the car runs like new now, and even the A/C seems to cool quicker (though I reckon I have to wait till summer to test that out fully!).
Am I wrong? Or will my repairman have to remove the entire shifter cover to replace the bulb?
Shawn
Parts replaced so far:
O2 sensor - no change in symptoms
Fuel Filter - no change in symptoms
Fuel Pump and pressure regulator - better for awhile but symptoms returned a week later.
Drove to Nascar race in Atlanta ~350 miles one way. It went smooth on the interstate and highways with no problems as long as I didn't have to stop for a traffic light or stop sign. Only died twice on the way and twice on the way back. Averaged 35 M.P.G. for the trip.
Timing Belt and alternator belt not for symptoms but wanted it done anyway - ran great that evening even through mechanics test drive but when I went to test drive it the symptoms returned. Next morning it wouldn't start at all. When checked found plenty of spark but no pulse at fuel injectors. :sick:
ECU - (obtained at reasonable price from eBay with warranty) Finally got it to start but symptoms remain. Next morning no start again. Found code retrieval info and got code from ECU that read normal (steady flash).
Throttle Position Sensor (changed but not adjusted to specs as we couldn't find pin outs to follow adjustment procedure)- Drove to parts store where it "acted up" on the way to and on the return trip. Checked ECU for code and retrieved code 31 .
M.A.P. Sensor - Finally got it to start again but accelleration again produces different results. Sometimes it is smooth. Sometimes it chokes, dies, diesels and hard to restart. Sometimes dies right away on accelleration and easy to restart. Next morning no start again. :mad: ECU returns no code .
This is where I am at after 7 months of chasing my tail and my Mechanic is just pulling his hair out now. Any ideas out there????? This is my only car and now has me stranded until I get this solved. The no starting just started since the weather turned cold. I only paid $600 US for the car when I bought it in April, 2005, now I'm at ~$760 in parts and labor since July. I'm willing to put a little more change into it since the gas mileage is so good on it though.
Few simple items to check:
Coolant level & condition- Do you have enough? If you or the previous owner kept adding water to the radiator, it may not circulate well through the heater core when it is partially frozen.
Temp gauge-is the engine really warming up? See if the temp gauge needle goes up to where it normally does in warmer months. If the thermostat is stuck open, your car may never reach the operating temp. Then the heater would not work. Bad for engine too. Symptoms: the car takes very long time to warm up. In stop and go traffic the temp gauge needle creeps up, but in constant highway speed it begins to cool all the way to where you started in the morning. If this is the case and if you can be EXTREMELY CAREFUL, you might try blocking 1/2 of the radiator with a piece of cardboard. This an emergency measure, and it will work on the highway, but could lead to severe overheating in stop and go traffic. I have used this method before but I kept very close eye on the temp gauge and replaced the thremostat as soon as possible. A couple of times I had to stop and pull the cardboard out to prevent overheating in stop and go traffic.
Heater control knob-if it is broken and/or slipping, it may not be moving the actual temp control lever.
There are space-heater like devices that you can plug into the cigrette lighter. You can get one at any auto parts store. At 600 watts it is not strong, but might serve as a hand warmer. This is obviously a temporary measure, because the alternator has to work hard to supply that kind of output. But if you are really frezing and can't fix the problem right away... Make sure you don't kill the battery with it. It is worse to get stuck with a dead battery when it's 12 degrees out.
Good luck
If you checked the battery, battery cables, and cable connections (both battery side and car side), the next stop is the starter itself. Starter solenoid can fail, starter itself can fail in such a way that it requires larger current to turn over the engine.
Any ideas what the issue could be?
If the problem is not fan related check the standard items like coolant level and thrmostat operation. If the thermostat is partially stuck you might see overheating in warmer weather. It could also keep the coolant from flowing into the heater core at low water pump pressuer at low rpm.
My prime suspect is the fuse for the fan.
M
How low does the oil get? In 100 miles, does it burn 1 quart or more? If so, you should also see black smoke coming out of the tailpipe. If this is the case it is likely that something happened to the piston rings. Have a mechanic check the compresstion in each cylinder. I don't know how much a ring job should cost. But whatever it is, it will not be worthwhile unless you are absolutely sure that low oil level did not cause other internal damages.
OR the car is leaking oil in the driveway...Easy to check.
OR the oil is leaking into the cooling system. Take the radiator cap off (when cold) and see if the coolant comes up all the way to the cap. When you drain the coolant make sure it is nice and green with no oil mixed in it. If you find oil in coolant...head gasket is blown and you probably don't want to spend the money to repair that.
Don't change anything expensive...just yet. Spark plugs did not cause this problem, but they might be dirty if the engine is burning oil.
I am sorry to have to suggest this but I suspect that the oil level was allowed to go too low, and bearings and piston rings got burnt up, hence the awful noise. You may have timing belt issues as well, but that cannot cause the engine to burn oil. Noticeable change in oil level in 100 miles is not good. Are you sure?
Thanks so much...
I would assume that the bumper and headlight must be fixed, as potential safety issues on the car, but what abut the hood? Is there a safety issue with the hood, or is it purely aesthetic?
1. The hood does not block driver's view.
2. The hood is not damaged in such a way that it catches a lot of wind at high speed. If it does, the hood release latch is the only thing that's keeping it from flying off the car. The latch itself may have been damaged by the impact, so you should inspect it very carefully.
A used hood from a junkyard should be available at a fraction of the quoted cost ($1000). You might want to look into that option.
M
Make sure you disconnect the battery's negative (-) terminal before attempting to remove the part, unless you want to see some sparks!
If you see burnt wires or connections it means you were drawing too much power from the lighter. It will happen again if you plug in a high wattage appliance into the inverter. Remember never to substitute a larger fuse to prevent a blown fuse. Always use the correct amp fuse designed for the part. You would rather have blown fuses than burnt wire somewhere in the circuit, or worse yet the car catching on fire!!!
M
1. Is it even reasonable to use a roof rack to transport 100 lb or so on such a small car?
2. If it is ok: what brand/model of racks is recommended?
3. How to find what is compatible with my vehicle? I did some googling for fit lists but the results are unconclusive.
TIA,
