Visitor Agreement.
regards, Ian
a dealer can help you.
regards, Ian
Electric Fan Motor
Belt Tensioner
Tranny
Brake Shoes and Pads
Mind you everybody tells me i'm EXTREMELY rough on cars and well in the past the longest i've had cars was maybe 6 to 8mths and well i'm bout to go on my 3rd year of having this car.. I want to say also that i'm slowly learning from experience of having to do all the work myself and paying for what i do wrong that it doesn't pay to be rough on cars..
As far as safety goes i've been really lucky with my car i was in a frontal collision about a year or so ago and i had kinda T-Boned a Ranger, to put it mildly i was able to drive away from the wreck, he wasn't. His back axle was lay in in the middle of the road.
Also when i bought this car i bought it with a salvage/rebuilt title. i got a hell of a deal on it, blue book was like 3500 at the time, and i paid like 2000. i had always told myself i would never buy a saturn but after seeing how happy my friend was with her 2000 Saturn SL2 i decided to get a saturn and it has NEVER failed me, and as far as fuel economy not too shabby with my driving either i get like 30mpg average.
Like i posted the other day about the Low Coolant/High Trans temp light the other day that is the only problem with it right now. For anybody looking for a good, safe, reliable used car i would GLADLY recommend them to a Saturn. I'll brag again and say it has NEVER EVER let me down even in cold weather.
Thanks Saturn for a great, cheap to repair car... Although i'm a little skeptical on the user friendly part about buying the car but each dealer is different.
Thanks Guys for your time.
The Service Engine Soon light came on. Was due to get oil changed in a week, so would have them look at it then. Two days of that and it went away. Today (next day) all gauges went wonky on me. While driving the speedometer first started fluctuating then dropped to ZERO, then gas gauge went to EMPTY, then thermostat went to C. Then after 3 more minutes the Tachometer went to ZERO. Two minutes later the car just sputtered out. Still have juice but cant crank engine.
Any thoughts? Hoping its fuse or relay or something - anyone have ideas? 116k miles but dont feel like big bill on an old car.
- Bill.
I have a 95 SL1 and it goes thru. a litre a week on in town drving.It hardly uses as much on the highway. It burned the same amount at 97K as it does at 260K.
Still the best car I've owned.It cost me about $2000 in maintainance over a 12 year period.
IAN B.
Solution:
Replaced the alternator and a now weak battery.
Tom
What should I do, to get back atleast half my money. Should I call The saturn dealer. Any help would be really appreciated.
Went out to start my 02 Saturn SL DOHC and it sort of burped and will not start up. Turns over freely and every once in a while, it sounds like it will fire but doesn't. Fuel pump turns on and I pumped the gas pedal a few times and I smell gas. Replaced the timing belt, gears @ 20k miles back. Car has @94 k miles on it. No warning with this issue....has been running great. Please advise if someone has a solution. This is my first time using a forum....looking forward to it!
Kevin
I am not sure of how to better diagnose the problem, but it sounds very similar to what happened to my car, 1998 SL2. Sometimes it would start perfectly for weeks at a time, and sometimes it might take me 15 minutes of trying before it finally started. My son said that it sounded like the "Camshaft Position Sensor" was bad. I bought one at the dealer for about $35 and he replaced it. That was a year ago, when the car had about 250,000 miles; I now have over 280,000 and it has never given me trouble since then. He told me that it was very painful to be able to reach it, but with a lot of patience he loosened the bolt holding the old one and then plugged in the new one. I do not know what it would cost for a dealer to install it, but maybe they can at least try to diagnose it for you. Good luck,
Jim
Best regards
Ian
Crankshaft position sensor-tells the fuel injectors when to fire
Corrosion on the coil packs you need to remove them and check underneath - no spark...no run....
You could go with a junkyard trans but I would NOT recomend that, it will still cost you a good grand for labor at least and if the trans doesn't work you have to pay to have it pulled and another one put in now a used trans just cost you more than a new/rebiult one. Shop around at shops, trans shops. I guess the one you bought it from won't give your money back? Pull the dip stick and if it smells burnt and is dark red or brown then its the trans but you know that already. If you didn't pay for it yet don't!!! unless its a great deal!
Any thoughts?
