Ian B
Yesterday, while climbing a hill, with A/C on, the engine suddenly began struggling to maintain speed and began to heat up. I turned off the A/C and pulled over to find the engine running very rough, but without the load, the temp returned to normal. I continued for another 35 miles, but noticed the engine was struggling, so shut it down to begin testing. Notably, exhaust was not particularly smokey.
I pulled spark plug wires one at a time and found that the #2 cylinder was not contributing - spark was there, but roughness did not change when spark plug wire was pulled. After a 165 mile tow, this morning I ran a compression test to find #1, 3, and 4 running at appx 180 psi. #2 at 0 psi. Spark plugs #1,3, and 4 had a white-ish buildup on the ground electrode, and buildup on #2 appears to have broken off (maybe stuck in valve?)
I reason that I may have a stuck valve, or burned valve. I rule out broken rings due to clean exhaust. Maybe a broken piston?
I assume the next step is to pull the valve cover, but have never done this on this vehicle. Any guidance and or discussion would be appreciated. Any steps to take that would narrow down the possibilties?
Thank you - RenoMike
IAN
