My 2001 is quieter, smoother, and has a few more features, plus, the SL1 now has painted bumpers- improving its looks greatly I believe. It already has around 1700 miles on it- been good so far (knock on wood)
The people have changed, but the methods have not. The mechanics left the air connection at the mixing head loose ("Oh, it is easy to tighten, just do this"), stripped the mounting washers on my brake drums ("Oh, they only put them on in the factory, we don't do that here") and they were power-tightening my wheel lugs ("Hey, Jose, he wants them hand-torqued"). I do not know what else they did incorrectly, but expect to find out later, I suppose. I checked and was told they are all factory-trained.
The message of what they found follows...
Funny thing about those work shops, when you go looking for problems, you find them, or should I say, they find you
So, this is what they found (their $$ estimate) [with my comments]:
Worn wiper blades ($10) [no way I want them new yet].
Wrong coolant ($99) [I inquired how they found that. The man said the color is red and it should be green.]
Oil change ($29) [I just replaced the oil about 500 miles ago, but the dipstick showed it at a low level. I need to simply add a quart soon at for about $1.]
Camcover gasket leaking oil ($135). [I replaced the original head gasket about a year ago, since all the oil wells on my SL-2 engine were full of oil. The gasket holds but the mechanic found some residual oil with a flashlight in one of the spark plug wells. I am sure I did not wipe all the oil out completely, starting with cupfulls in each well.]
Upper TA (engine) mount worn out, causing excessive engine vibration. ($99). [This one worries me to the point that I will start watching it.]
What is your folks opinion?? Appreciate any comments/advice.
You bought a major P.O.S. - a car that probably has been abused.
Where did you buy it from? If you got it from a dealer I would go back and try to find out why they sold you such a pile and try to get them to fix it or take it back. If they are a reputable dealer they will probably be willing to work with you.
WARNING TO ANY USED CAR BUYERS OF ANY MAKE AND MODEL
Have an inspection done before you buy the car by a third party - or make them give you in writing a 3 day money back guarentee so you can have the car checked out.
In any case the vibration is probably a worn out motor mount.
I thought it was neat that Motorweek's on Speedvision, as I've been a PBS fan for about 10 years now (since I moved to within broadcast distance of the States) and just love Motorweek. It's no Wall Street Week with Louis Rukeyser, but then again, what is? ;-)
http://www.pbs.org/mpt/motorweekold/goss/goss1938.html
http://www.pbs.org/mpt/motorweek/goss.shtml
Compared to my 1998 Saturn SL which I had previously, my 2001 doesn't score as high in the build quality area, but only has minor groans at times.
I believe/hope it will be as economical and dependable as my last Saturn, and I must say this one looks much better.
All I know so far is the ecotec engine 4-cyl found in the L-series and making it's way into other GM models now will be poweering it. I have seen one heavily disguised spy photo in AMI Auto World magazine (July issue) but it diddn't give away much at all. It's only a year away yet Saturn is being really tight about it.
Of course, the Saturn delaership's primary goal is out to take my money (if it isn't they don't deserve to be in business) but they do it with so much more STYLE than other dealers. They know who I am, they are always VERY efficient, and ALWAYS wash my car (sounds trivial, but it's just . . .STYLE).
I religiously change my oil every 4000 miles, and I have been getting 35 mpg IN THE CITY WITH THE AC ON. Yeeha. About twice a year I make an 1800 mile trip and I have gotten 40-41 mpg on some stretches. Inside it's cheap, and pretty crowded, and boy do I miss power door locks.
Note to those people complaining about imperceptible steering wheel shaking at 75 mph: if you're that obsessive, get a REAL car, like a BMW or Mercedes. If, like me, you can't afford one, then quit bothering the dealerships with complaints like this.
I like my Saturn and am so far very happy with it.
Here's hoping they at least keep the dent resistant panels for the WHOLE car, unlike the L, which has steel rear quarters.
I now have a 01 SC2 with 33,500 miles and my steering wheel is smooth and has been since new. I have been up to 95 MPH with no shake. The rotors are starting to warp. Hopefully they won't get too bad. The brake pads still look new since all my miles are highway. Overall a good car for the money.
The 03' S-series will be built on GM's "delta" platform and have the polymer panels and use a version of GM's ecotec engine in 1.8 or 2.0 liter sizes. There is a article about a Saturn supercharged roadster based on the new delta platform on the Saturn.com site. It has a instrument cluster like the Toyota Echo in the middle of the dash. I hope this design doesn't make it to production though, I think it could turn off alot of drivers to the car.
Only a few minor problems, including a broken sun visor fitting (which was fixed under warranty). I'm keeping to the regular Saturn maintenance schedule.
I've seen stories by the so-called "car nuts" who want passion in their driving machines, and think Saturns don't have any passion. Maybe so. But I need good transportation, not a flash-in-the-pan. Maybe if these self-described "car experts" had to drive to work every day like most of us, they'd realize reliability and competence will win out over horsepower or whether you can take the curves at 90. I'm sticking with my Saturn.
Changed the spark plugs today (didn't need it - the originals looked great). Went with "Bosch PLUS 4" and noticed a slight pick-up in acceleration.
P.S. the stock tires are Firestone FR680, any feedback would be Greatly appreciated
If you return it you may wan't to look at used SL2's. Power is much better as well as handling with the twin cam engine and 15" wheels and a rear anti-sway bar. The car is basically the same since the first year it came out so a 99 or 2000 model will still have the improvements over the early years and you won't really be getting a older car. Gas mileage is still decent with the twin cam but I have noticed a huge difference depending on how I drive heavy or feather foot. 94 SL2 auto.
I wouldn't risk it
If they can't fix it - return it.
It has been a great car so far, and as far as wheel vibration goes, at speeds of well over 75mph I haven't experienced any wheel vibration, I too cannot wait till the 2003 S Series arrives- assuming it is what Saturn and GM claim it will be- I will be trading my 2001 SL1 in for one.
Floridian
What's the cause of this excitation ?
Could it be Affinity perturbations ?
Firestone giving me bad vibrations...
...soon I'll be needing de-fibrillation
(singing falseto now) Bad, bad, bad, bad vibrations
(Tenor) YEAH!
(singing falseto now) Bad, bad, bad, bad vibrations....(fade out)"
With apologies to The Beach Boys, and no apologies to Firestone for not understanding the term: Quality Control. It's not "the lab" guys - it's the people on the floor and the manufacturing process you approved. These are only ones who can ever control the quality of the product coming off the line.
But they wont make marginal product if they can't sell it. Write GM TODAY !!! "Dear Sir or Madam, why do you continue to use substandard parts as OEM equipment? ..."
Regards loridian
Ours had a lot of "orange peel" tho. For some reason Saturn did not feel the need to clearcoat the inside of the deck lid and hood. One dealer I shopped the thing to swore to me that the car had been wrecked and a poor repaint done and what did I think I was trying to pull on him LOL.
Oh well, it's all history now. Onward and upward to better things. Don't look back.
Floridian
I on the other hand, love my Saturn, my second one to be exact. The paint and finish is excellent, as it was on my last Saturn. Good luck to you
It was not "given" to me (or the business) we took it in lieu of a debt owed to the company from a customer that was about to go belly up.
I just think for a vehicle that had a MSRP of over 20K you sure did not get much for your money. Sure am glad we didn't buy the thing. Twenty grand and not even power windows or locks or mirrors !! Door and hood gaps you could throw a dead cat thru (come to think of it, it kinda smells like a dead cat inside too LOL), shut the door and the tailgate rattles as well as that third door , ah yes, great QC out of that plant in Shreveport,LA.
Floridian
