Visitor Agreement.
or directly behind it...
...I had disconnected a large round twist off connector that sits directly above the main abs brake unit, had forgot to take off the neg. battery cable, (don't ask) and the dash ABS light stays on and I don't think the ABS is activating... Any suggestions?
But if you haven't, the voltage of a battery should be 12.6 volts. That's 6.1 volts for each of the six cells in a Pb acid battery. You may have a problem battery or a badly calibrated meter.
It appears that I was fortunate enough not to have only purchased 1 bad brand new battery but 2 bad brand new batteries. I kept testing my battery with my volt meter and everytime the car was turned off the battery died instantly!
This was the second battery that I had put in since around March of this year this battery was to replace the original I bought in March. So I took my car to a place that specializes in just batteries and he told me I had a couple of dead cells and marked them off so I could return my battery once again. I then bought a battery from him and he replaced the bolts because the place where I had the other battery put in well it appears that they badly stripped them! Its been since about June 23 and I have not had any problems at all I am still monitoring the voltage on my battery and it is staying charged! Hopefully you will figure out what your problem is. Every place I have been to has commented on the shape of my car and my mechanic said they have excellent engines and will go on forever I like you did not want to part with my car.
My problem was the same I would boost it and it would run for a day or so then it was getting to the point where every time I turned off my car I would need to boost it!! I
Good luck with your car! Hopefully you will get it going before spending alot of money on things that you do not need to fix like I did.
It's happened to me a couple of times with a dirty resistor contact. Scrape it, pencil eraser is good for cleaning. But you have towait 3 or 4 minutes until the computer for the key resets; once you turn the key 3 times with a bad read from the resistor it turns off the ability to start the car for 3 minutes.
There is a possibility it's the ignition switch not connecting to the start mode wire. That's on top of the steering column just above the brake pedal. Then there's the small computer that reads the key chip; I think it's buried inside the instrument panel behind the speedometer so that it's not easily bypassed. I'd start with the easiest first. Connections at starter, bad starter, etc.
where can i get a new panel?
Please help.
Do you see any drips on the ground when you park the car after it's hot? That might show you it's under the radiator or the water pump area.
My 1993 had that. I never followed up to clean and tighten the grounds because I traded the car before it started doing it enough. It would go to air conditioning defrost default and the power door locks wouldn't work for a few minutes.
There also is a ground under the carpet between the door sill and the driver's seat. It would be about where your fingers hang straight down while you're sitting in the seat. You can feel the plastic cover above the connects that may also be related to some dash operations.
You probably won't either unless you go off-roading or have lots of road debris where you drive.
I bought a new regulator and replaced it myself. The door panel is attached with a series of fasteners around the edge and a couple in the middle. Start by prying the panel out from the bottom and work around the edges. When the clips are free lift the panel up to free the top edge from the door. On the right rear door there should only be one electrical connector (for the power window switch) to disconnect. Under the panel is a moisture barrier glued to the door which needs to be carefully peeled away (don't tear it). There are a couple of clamps that attach the glass to the regulator. Close the window and tape it to the frame so when the clamps are loosened the window stays in place. Unclamp the glass and remove the regulator mounting bolts. The regulator is hard to get out through the opening but it I found the new regulator has the motor attached at a different angle which makes it easier to get in than the old one was to get out. See my message on the Bonneville problems board #1242 mlm4, "Pontiac Bonneville Owners: Problems & Solutions" #1242, 24 Dec 2003 6:39 pm
Does anyone know if the pulley - and possibly the clutch if necessary - can be removed from the A/C compressor pulley, so that I would not have to replace the whole $250 compressor?
Auto parts stores have already told me that they only carry the complete compressor; however, the pulley itself appears to be in good condition - it's just this bearing that is going bad. If anyone has ANY ideas for saving me a lot of money, or can refer me to the proper forum for posting this problem, I'd would very much appreciate it.
-Ron
Some cowardly kids smashed my rear side and back windows. It's going to cost me at least $250 to fix them so I'm trying to do stuff by myself. I started with the rear side window yesterday in bone-chill weather; managed to completely remove the door panel from the steel frame. However inserting the glass from the top is becoming a nightmare; what else do I need to remove? I'm thinking I might have to remove the pillar btn the side frames. Any assistance will be appreciated. Thanks
We take out fuses to keep the battery from discharging, but this is going to get old.....
Any ideas?
The 300 is not competition in our area. Buyers of 300 from Chrysler usually were already Chrysler buyers and a few others were attracted to the "odd" design.
The Charger looks smaller than the full-size LeSabre was/is.
I just see the LeSabre as quality, dependable transportation for 6 adults with a durable, strong motor that holds more power in the LeSabre application than most realized until they drove one for a while. LeSabre was not flashy--it had become the Camry and Accord while they bloated to something different.
I believe a lot of LeSabre buyers will have LaCrosses and low priced Lucernes. The lower-priced Lucerne has run-of-the-mill struts and suspensions and tuning in the body. These saved cost along with the 3800 motor. This will appeal to the LeSabre buyers. The V8 Lucerne will attract some of the Lexus - Avalon buyers who don't want the Avalon problems.
A V6 in Lucerne would have given too much similarity to the motors and cars. They would have had to ditch the 3800 which would probably cost a lot of UAW paid for no work time and they probably wouldn't be able to phase down the production at the 3800 build location without advance notice and agreement from the UAW.
I haven't driven a Lucerne. The dealer had 3 in but two were sold and were just being shown in the showroom since they hadn't been picked up by the owners. I suspect the 3800 will be more than adequate for many drivers' wants; me included. Probably most are previous LeSabre owners who don't drive aggressively.
Driver's I've seen in Lucernes look a lot younger than they used to!!! A black CSX (CXS) with chrome wheels and the Northstar makes a good-looking car.
To adjust it the inner door panel needs to be removed, then the water seal needs to be carefully peeled away so you can get at the two access holes for the clamps. With the window closed, loosen the two clamp screws using a socket wrench. Lower the window carefully just a bit. If the window is stuck in the weather seal you might need to push it down to break it loose. Then with the engine running for maximum electrical power, fully raise the window to seat it. Tighten the clamps to 9 N-m.
If that's not the case and the glass needs to come inward I would check to make sure the three window regulator bolts are fully tightened. If the top one is loose maybe the whole assembly could tip the glass outward. Also try lowering the window a little and trying to rock the glass in and out to see if there is any play. Good luck
