High End Luxury Cars
1207208210212213463
  • brightness04brightness04 Member Posts: 3,148
    What do you think causes this? The European car I see all the time with a front bulb out is the 1998-2005 Passat. I mean without fail and its usually on the newer 2001 facelifted model. Is this improper sealing of the headlamp assembly or just cheap bulbs or something else?
    IMHO, it's due to light enclosure design/engineering, either a moisture issue or a heat dissipation issue. I replace my bulbs with the best on the market; in fact I checked the ones on my Japanese cars, and replace the European cars' bulbs with the same brands, yet they still fail on the European cars. It's very frustrating indeed, especially since I used to drive a lot on dark country roads, with frequent deer crossings.
    BUT this is a far cry from what was repeated in this forum yesterday that buying a German car involves replacing bulbs every few months!
    If both headlights have to be replaced every year, that makes for one headlight replacement every six months on average. Then there are the tail lights (2 or 4 of them), brake lights (3 or 5 of them), side-marker lights and turning lights. The result is one light bulb replacement every few months. In fact, I have a cache of replacement light bulbs in my garage just from owning European cars.
  • deweydewey Member Posts: 5,251
    Slight clarification required! You are discussing your car! What you are saying is not representative of most German cars!
    Refer to the prior post about Toyota/Honda transmission issues. It would be bogus for anybody that makes a conclusion that Japanese cars have tranny issues based solely on certain Honda and Toyota models! The same logic applies for bulbs!
    I wonder what is causing this bulb problem. My neighbor has a Range Rover and I asked him if he's had any problems and he said he has replaced both of his headlights in a year. Faulty design or faulty bulbs?
    In the vernacular sense of the word, it's a design issue. However, on a more strict search for responsibility, it's an engineering issue. The designers' responsibiity is to make the light enclosures look pretty on the outside. It's the engineers' job to make sure they work and will stay in working condition for years to come. IMHO, the Europeans just never really worked through the detailed engineering minutia to make sure that the light enclosures will keep out the moisture and dissipate heat properly, yet at the same time properly insulated from vehicle vibration. It's indeed an engineering challenge, one that is a much more worthwhile pursuit for the hundreds of thousands of cars sold out there than figuring out how to put 400hps into a few hundred tuner project cars.
    What really worries me is not just the light bulbs failures themselves, but that being the tip of an iceberg: what else is wrong in the system integration. Considering that today's cars are so reliant on electronics, the lack of long-term reliability could well be a safety issue: I don't want to find out the electronics involved in the brake force distribution system and vehicle stability control is faulty on a crowded slippery highway in a snow storm! There is no real way for me to find out until there is a near-accident. The infamous Car and Driver test BMW was a dramatic demonstration of the issue.
    Brightness04
    Great statistical sampling!
    Congratulations! Now I guess you can successfully conclude all BMWs have bulb issues! :P
    I have had two 5 series, one E class, and two Saabs of very different vintages. They all had light bulb problems. In fact, it was so prevalent that I thought light bulbs always required replacement once a year and that's why they had annual state inspections. That view underwent a drastic change after I started buying Japanese cars, none of which have had bulb burn out on my watch so far.
    In case you did not notice, other owners are experiencing similar problems. And we did not come here for bulb fixing; i.e. no self-selection like the tranny problem with the few Japanese models that you are referring to. Also, if you want to talk about tranny problem, the Europeans are even worse anyway, in a very statisticly significant way.
    I feel for your pain with German bulbs!
    But your experience is statistically insignificant in terms of German cars in general!
    Uncalled for sarcasm aside, did I say Car and Driver's testcar electrnoic failure was proof of bulb issue? Obvously not. It was however a dramatic demostration of just how important reliable electronics and dependable system integration are to the safety of a modern car.
    These were not even German bulbs. The German cars were killing the bulbs.
    But your experience is statistically insificant in terms of German cars in general!
    I have no idea what "insificant" means, but apparently statistics from the driving population in general are significant enough for people, including cops, to notice.
    Other than VWs please point out which German car other than VWs have transmission issues?
    This should be easy to answer since most car marques will have a tranny issue!
    Typo error: Insignificant
    Is it possible that you have never done a typo error before?
    Maybe the cops you met, but not the general population of cops!
    VW happens to make more cars than any other German marque. Look through the CR rating on cars, Germans don't exactly rate high on trasmission reliability, or any other parts of the car. That's statisticly significant data. From my personal experience, the very first 5 series I had had a transmission problem that required a rebuild. A close friend of mine had an S class that had trasmission crapping out on him within the first year of ownership.
    Maybe the cops met, but not the general population of cops!
    Your desperation is showing.
    OK let us conclude that your personal experience with a 5 series is statistically significant in terms of German reliability! :P :P
    Stats please, stats! Or are you going to talk about your Aunt Sarah's unreliable BMW 5 series?
  • lexusguylexusguy Member Posts: 6,419
    The LS was and continues to be the JD Power reigning champ for reliability. Not the Corolla. For the '02 MY VDS:
    "The LS 430 luxury sedan, with a score of 90 PP100, is the first model in the history of this study to receive fewer than 100 problems per 100 vehicles."
  • oacoac Member Posts: 1,594
    Nah, it's basically the same ol’ drivel. Go unpack, have a cocktail, dinner, then come back to the computer and pay attention… I’m sure you will find something to torque you off.
    Designman: You are so right !!! Geez....Argument for the pure sake of arguing... But I am unpacked and rested from the jetlags. BTW, I think the LF-Sh is truly the new LS, and if you must know it, the wife finally gave her blessing to my 2007 LS purchase. Boy, was I stunned or what ? I quickly had her sign a paper to that effect before she changes her mind :):):) So understand that I am now realllllllyyyy looking forward to that car. I guess a late Fall 2006 or early 2007 purchase would be in the cards. Hopefully, they price the new LS competitively to allow buyers make a no-brainer purchase of this car.
    How 'bout you ? Any plans to upgrade that 530i or the Boxter anytime soon ?
  • patpat Member Posts: 10,421
    in here is obliterating the very reasonable points some of you are making...
  • killerbunnykillerbunny Member Posts: 141
    Have you actually read most these posts? Most of them are routine bulb changes. What statistical proof are you talking about? Nothing so notorious about them, dont you think?
    The phrase "routine bulb changes" makes me laugh. Over the last 16 years, my family owned a total of 4 Japanese cars(and no other cars). Never had one bulb replacement.
    So, dewey, in your opinion, bulb replacement is routine for German cars and thus does not count as a mechanical/electronics failure?
    True according to JD Power the LS is a reliability champ!
    According to CR it is not!
    The next question now is which source is more reliable:
    CR or JD Power?
    Oh, let's don't.
    Could we just try ... try ... to stick to High End Luxury Marques and not drag every single tangentially-related topic no matter how loosely connected we can think of into this?
    :confuse:
    I am responsibe for this tedium by trying to show proof that some notions about High End Luxury Marques are false.
    The end-result was a big waste of time and I apologize to fellow members for the flood of posts which at least appear irrelevant to High End Luxury Marques
    I think it is time I take an extended holiday from this foum!
    No way is the Phaeton overpriced! The Phaeton is cheaper than the S-Class and 7-Series. It wasn't intended from the start to compete with cars like the LS430 which isn't a "benchmark" in Europe. Europe being where VW wanted to make an engineering statement in MB's face. Selling it here was debated, delayed and then half-done. The car was intended to be a cheaper rival to the S-Class and to a lesser degree the 7-Series and it is cheaper than those cars.
    It's not you who determine whether or not Phaeton is overpriced. The market has spoken! That car just does not sell at the price. VW can either cut the price or cease the production. It's that simple.
    Ignoring Lexus, the leading luxury marque in the largest auto market, is also a mistake. Even MB and BMW cannot afford to do that, what makes VW so confident?
    As I mentioned, the Lexus LS started out in the price range of an E-class and still undercuts S-class by at least 20% as of today. E-class price level is where Phaeton should start, even in the absence of Lexus. Otherwise, it is overpriced. To my knowledge, Phaeton was no better off in Germany.
    After five for five (including three Germans) being less reliable than all the Japanese cars that I have owned, I'm inclined to conclude that European/German are statisticly less reliable than Japanese cars. Most others seem to agree to. As to "let us," apparently you are not willing to accept any report of unreliability related to your beloved German cars.
    I don't have any Aunt Sarah. I had two BMW 5 series, one had a transmission problem that cost me close to two grand to fix. The other, I got rid off after having too many small things that needed fixing, bulbs, roof leaks, etc.. If you want stats, CR provides a treasure trove in stats.
  • michael_mattoxmichael_mattox Member Posts: 813
    Dewey:
    Consumer reports (april auto issue 05) rates the ES330 Transmission in 03 as ALL BRIGHT RED and in 04 1/2 red both excellent ratings...It doesn't seem that they actually have UNCOVERED THESE DIFFICULTIES...it sure isn't in their ratings....
    It is recommended for 05 and called the most comfortable and quiet driving experience in it's class...impressive in fit and finish. a comfortable interior, smooth ride.
    NO MENTION OF A TRANSMISSION PROBLEM ALTHOUGH PREDICTED RELIABILITY IS ONLY 1/2 RED...A LOW RATING FOR A LEXUS...AND A RATING ANY GERMAN CAR WOULD DIE FOR.
    I missed that Avg. that LS got in 99 for electrical Good catch. HOWEVER; even with all the exectronic gear that the LS has compared to the relatively spartin Corolla the LS is equal to or better then the Corolla in every other year and I do think the discussion started with over all reliability but I don't remember for sure any longer.
    Of course...LS is superior or equil in ALL THE OTHER CATAGORIES...and Both are EXCELLENT.
    THE LS...DOES NOT HAVE TRANSMISSION ISSUES...as I have pointed out. Has not had transmission going back to 97 which is as far back as my consumer reports goes and I don't want to dig out the older issues.
    Dewey:
    What on earth are you talking about...What car specifically has a better reliability record then the LS...
    There is only the Acura that competes with it for reliability but it is not in the same class..and the LS overall Numbers are still better.
  • bdr127bdr127 Member Posts: 950
    I'm still wondering if this thread can discuss anything except reliability.... In my previous post, I set a challenge at going three posts without mentioning reliability. I'm upping that challenge to two posts!
    Reliability is the bedrock upon which almost every single high end luxury marque with a history of success was built:
    Rolls Royce had Silver Ghost, a car known for its silence and reliability;
    Bentley built its reputation at Le Mans endurance race of the 1920's;
    Mercedes-Benz was the benchmark of reliability, for many decades;
    The success of Lexus and utter failure of VW further goes to show that a High End Luxury Marque, for cars anyway, is not built upon charging higher prices, but on impeccable reliability. Reliability alone is not sufficient condition for a high end luxury marque, but without it, one can seldomly build a high end luxury marque.
    As usual, you castigate every dissenting viewpoint to yours... Hype, wannabe, envy, etc.. Here is a simple factoid for you: can you tell us which MB has had an in-dash CD changer for years and are sold here in the US ???
    And as usual your posts are minus the facts. Yes I can tell you, the E-Class. The E has had an in-dash CD changer since 2003. Audis had them from 2002-2004, until the moved the back to the glovebox for the latest A6 and A8. A simple check of the fact OAC will do it everytime. To say that they can't is simply nothing more than hype because they have (E/Audis) and will (upcoming S).
    Of course. German cars were never defined by cup holders either, but they do now, eh ? Maybe the point escapes you: that the Germans think CD changers deserve to be in the trunk, while a $15K KIA can put one in-dash. I chose Kia, a Korean car as an example here. I could have chosen a Ford ZX3, which is even cheaper at $11K.... And please note that luxury car makers don't brag about having an in-dash CD changer, but it sure sucks if your $60K+ car cannot even provide a basic feature you'd find in far less cars ??? That's the point....
    Point is that nearly no one cares as much as people who tend to knock every German car to begin with. Please note that because German cars don't put CD changers where you think they should be doesn't mean the world or much of anything to everyone else. When those lower level cars you harp about drive anything like a German car then you'll have a point, until then you don't. Pure hype and minus the facts at that.
    M
    Luxury cars are about amenities, and inpeccable ownership experience. If the Germans are inferior on amenities and ownership experience (reliability), then on what ground do they sell their luxury cars? Snob appeal alone? Horsepower is never a trademark of luxury automobiles, nor handling.
    The first part of this is true, but a CD changer not being in the right place? Thats a pretty lame thing to disqualify a car like a Mercedes or BMW on imo. Secondly I disagree, power is most definitely what a luxury car is about. It may not be a "trademark" but it is part of the reason people buy luxury cars.
    M
    Guy that wouldn't make a bit of difference. Please ask around about the prices a Phaeton is going for nowadays. A dealer here has one in the showroom for 12K off! That is to anyone that walks in, forget the people who know about the car and know that VW is deperate move them. That savy group is likely to get even more off the MSRP.
    You could ask any traditional German luxury car buyer and most of them would tell you the Phaeton is a bargain compared to a S-Class or 7-Series. The problem is not price, its the dealer, being a VW and being a VW and being a VW. VW's don't have the stuff to command 68K to gasp(!) 90K for one of their cars. That is the problem. They've even offered the Phaeton V8 for $499 a month for lease a while back and still nothing. People don't even know about the car until they see it on the VW showroom floor and Jetta/Passat/Golf/Beetle buyers can't just say "Oh I'll take the Phaeton". Doesn't happen. Won't happen.
    Thanks to VWOA hardly anyone buying in this market segment we talk about here even knows about the car. The only reason any of us know about the car is because we "follow" cars to varying degrees here.
    Oh I agree that the car was a grand mistake. Automobile just complete a long-term test in which they called it "The World's Most Perfect and Pointless Car" or something like that.
    Yeah that is pretty much what I stated earlier. A SWB Phaeton might sell a little better for about 58K and some serious promotion on the part of VWOA. Problem is that anything over 35K is an iffy sell for VW. This new Passat is already going to run into price problems when fully loaded.
    M
  • manifoldmanifold Member Posts: 57
    Actually snob appeal play a huge part. Or what is actually called branding. Cars like MB and BMW have established their image as being upscale items. Much like a Ralph Lauren polo cost $60 while an exact shirt at the Gap cost $25. You're paying for the brand and all the image that comes with it. As for the Phaeton discussion, VW's image is (or used to be) the "People's Car". They worked for many years to establish that brand. To come out with a with $60k car is sort of contradictory. But they've been working hard towards the more upscale image the past few years. I remember when the redesigned "rounder" Jettas came out, the ads were targeted towards the yuppy dotcommies. Their marketing campaign and car design was so successful that I've had friends buy the Jetta over a 325i which they could easily afford. Now, the latest Jetta design is a bit hoaky and now resembles a Corolla which of course doesnt have the upscale image. Bad move by VW there and watch brand loyalty diminish - regardless of what junk they put in the car. The Phaeton is a beautiful car, but just doesn't jive with people's perception of the level of the VW brand at the momment. People dont think of VW as in league with MB - yet.
    You wont necessarily establish an upscale brand just by putting leather and all the cool gadgets and amenities in the car. Those are just "touches". The Land Rover Defender doesn't have much it in but someone who owns a 100 acre country estate would no doubt want to show that off in his/her driveway because it speaks blue blood. It took Land Rover many many years to get that image. I dont care what Lexus or Acura does, it will take them a while before they get accepted in the very snobbish world of luxury cars.
    My 2 centavos.
  • designmandesignman Member Posts: 2,129
    Lenscap, thanks for the link. Here’s the 85% quote:
    “Inside sources say this is “about 85 percent” of what the new LS will look like.”
    That’s pretty vaque and surely indicates to me that the actual LS is going to be considerably different. Perhaps it will have the same overall countenance, but it doesn’t take much for a style to lose or gain in quality. I would point to the G coupe vs G sedan and also the facelifted 7-series as examples. Is the facelifted 7 85% of the original? I would call it about 98%, yet it looks better in my opinion. You know, they can screw up the LF-Sh very quickly by tampering with the grille, headlamps and other things... yep, very quickly.
    Anyway, this is why I haven’t made much comment about the LF-Sh. I really like the design and have studied it considerably from the images that are available. Some aspects are almost spectacular such as the front end and the overall subtle contours. I even like the way the expanse of the sides (I refrain from using the term slab-sidedness here) contrasts with the detail on both ends.
    The comparisons to Banglism are getting me sick because BMWs show no restraint and attempt at elegance whereas the LF-Sh clearly shows sophistication and more thought. BMW features scream and compete for attention. The Lexus features and motifs are integrated and balanced. The overall impression I take from the LF-Sh is a subtle blend of retro and future, kind of like a documentary on the state of auto design. To me, this is as good as it gets considering the state of shamble automotive styling is in today.
    Well, I sure hope the 15% in question is actually an improvement because the design as it stands is going to help sell this car bigtime IMO. I’ve said this before… Toyota and Lexus is showing a clue. They’ve been indicted a lot over the years in all manner of styling and I sense the tide may be turning somewhat.
    Oac,
    So, you’ve inked a deal with the boss. Sounds good. I know a thing or two about those deals.
    I have no plans of retiring the 530 anytime soon. To give you an idea why, my wife said we should have bought two of them. She loves it and, like me, doesn’t like what’s out there. I showed her the movies and shots of the LF-Sh at Tokyo and her first impression was… gasp… “it looks like the new BMWs that we hate.” Perhaps she will see it in better light once she studies it more.
    As far as the sports car, that’s a different story. I’m kinda’ chomping at the bit to get into more power. I’ve test driven driven plenty of 911s before but had a chance to get up close and personal with a 996 Cab for 5 days last month. The dealer gave it to me as a loaner when I brought the Box in for service and they had to order a part. Sports cars are like computers. Once you get one with more power it’s hard to turn back. Anyway the following are on my short list: 997 Carrera, 996 Turbo, Z06 Vette.
    You may ask how the Z06 fits in. The only way I can answer it is perhaps with the mid-life crises thing although I think I am past that. Little kids who liked cars and grew up in the 50s, only to stand on the sidelines witnessing the sons of rich kids driving the muscle cars of the 60s never lose their vroom vroom libido. You know… once, just once, it would be nice to experience the authoritative rumble of a hot V8 and learn how to apply it to the surface of a track.
    Gotta sort it out in my head, then see if I can ink the same kind of deal that you got.
  • sysweisyswei Member Posts: 1,804
    Thanks for sharing your thoughts on the LF-Sh, your design opinions always seem well-reasoned and I enjoy reading them. Glad you like the car.
  • lenscaplenscap Member Posts: 854
    I think I can help answer the ES transmission issue. I had a 2002 ES 300. The transmission never really shifted smoothly at low speeds as there was a little lag when accelerating from a stop or slow speed. Even after the dealer updated my software I still had the lag. I wound up talking with Lexus and they said that from a reliability issue there was nothing wrong. The transmission was in no danger of failing or breaking. So, that would explain the Consumer Reports high transmission rating. Although not smooth, the transmission was reliable.
    However, I was still disappointed that a car like this would have a lag. Lexus apparently agreed and bought my car back. They stood by me and were really great. It is because of this that I plan on getting the new IS 350 at some point within the next year.
    That is excellent dealer service. Most dealers would either say you were "making it up", or that its "supposed to be like that".
    Only a while. Less than 10 years, to be exact.
    Lexus was introduced in 1990 and became the top-selling brand before 2000. They are already accepted. Lexus, Acura and Infinity combined outsells BMW, MB and Audi combined.
  • ljflxljflx Member Posts: 4,690
    Lexus is already there and will jump higher with the 2007 LS, the LFA and the new LX. Acura lacks the V8 and that continues to hurt them and they are the Audi of the Japanese market from a perspective standpoint. Infiniti is gaining but unless they establish the Q, they'll never get there.
    I like it ! Imagine a 997 Carerra or a 996 Turbo... These are the fun cars to have.... I would kill for one of those if I can ever afford one. They are soooooo much fun than a Box... I won't even think of a Z06. Gotta go for the sports car of sports cars, IMO. And these would be the Porsche's, at least in the affordability bracket (<$100K).
    Yes, like you the pre-Bangled BMWs are my favorites. And the 530i is certainly nicely balanced b/w the high power and rough riding 540i, and the ripoff 525i. But, do you find the 530i underpowered ? Now that power seems to be in the cards for you, mid-life crises or not :)
    Based on what C&D had to say about it, I think you should spend a lot of time with a Z06 before handing the check over. They did rank it ahead of the Viper because it is faster and does have a price advantage, but they said it was nearly impossible to drive fast without having a heart attack because the car likes to snap oversteer at the drop of a hat, with absolutely no warning, like a '70s era 911. Its a "for experts only" car like the GT2. By comparison, the Viper was a friendly companion on the track, with predictable and managable understeer.
    I spent some time recently with a 997 Cabrio, definitely a fun car.
    merc.
    Was the German through the dash CD changer just a Single disk changer or would it hold multiple disks?..
    Why did they stop using them?
    Merc
    Comfort and convience...easy to use...Spells Luxury...A nav. system that doesn't require a disk change every time you drive out of your region and is easy to understand and use is a luxury feature...
    A CD player that you don't have to crawl under the seat or into the trunk to change CDs is also a luxury feature.
    A car that is so reliable it usually only needs to be brought to the shop for oil changes, that doesn't need light bulbs constantly changed, or never ending repairs ...is a luxury feature.
    LG: While searching for an LX470 for the spouse, I am starting to consider the Cayenne S Turbo, slightly used (2004-ish) for around $40K. Found a few on EBay.... I don't want to wade through thousands of pages on Edmunds, so I might as well ask if you or anyone know what to be wary of ? What are the issues to be concerned about with this truck ? Any help will be appreciated.
  • bigobigo Member Posts: 22
    What do u guys think? and witch one do u guys think is better? Navigator or Escalade?
    Look at the GX470 before you make a decision - it'S fabulous.
    The fact that its a close cousin of the VW Toureg would make me very nervous. CR ratings for the '04 Cayenne are absolutely horrendous, with very poor scores in 8 catergories. Not quite as bad as the Toureg's eleven catergories of full black dots, but not exactly confidence inspiring. Also.. doesnt a new Cayenne Turbo S cost like $90 grand? Does it really depreciate by more than half of its value in under two years?
    For about the same money, you can get a brand new Infiniti FX45. Not quite as much power, but its lighter than the Porsche by some 800lbs, and has been very reliable.
    I agree, check out the GX. A brand new Mercedes G class is also coming soon.
