I am having the starter replaced this week because of an electrical dead spot, and the service manager mentioned inspecting the ring gear while it's visible.
bob
The actuators are pretty easy to replace. I've seen them on eBay for under $15, but being a Sunday when I did mine, and in a hurry, I picked one up from NAPA for about $40.
First, you have to remove the inside door panel. It should pull straight out at each pin location, if I remember correctly. And there's no need to remove the speaker covers from the panel for any reason, though you do need to pop the little covers on the armrest to remove some screws underneath.
And you are correct - you have to drill out the mounting rivets for the actuator. 'Not a big deal, and they can be replaced with small nuts and bolts.
The part goes in easily, but look to see how the connecting rod is connected before you take it out.
The whole job, (less the trip to the hardware store for nuts and bolts), took less than a half hour, and brought my system back to full functionality.
John - '99 Astro
universal joint. The vibration starts at 40 mph (slight)and comeson strong at around 55 mph. The entire vehicle shakes similar to the pulse one gets if you press on the brakes with warped rotors. Thanks in advance for your help.
Where are all the bolts? There are two in front and the one in back on the top appears not have been installed as I can feel the screw hole.
It is still in there tight. What am I missing. I have a guide for a 96 and it talks about an alternator bracket. Is this what I am missing?
KentL
Mine started right after a thunderstorm while I was on a handyman job. I always keep my van unlocked on calls and my keys in the cup holders so they don't stab me in the "you know whats" when I crouch down. Well when I went to load up the tools the van was all locked up! :mad: I thought I locked it up by accident. After my wife brought me the spare key and on my way home my locks were freaking out the whole way, :confuse: I decided that it was a lightning strike on the golf course near my van that had fried the door lock relay - I was wrong, but here is how I figured it out and fixed it.
The first thing I did was to isolate the problem was to disconnect each door lock button one at a time until the random lockings stopped - mine turned out to be the rear hatch switch. I used a multi meter to determine that power was indeed getting to the switch but not through it. I am glad it wasn't the actuator. I took the switch out (the whole keyhole push button assembly) - took it apart and noticed all the contacts inside were corroded. I used some 220 sand paper and cleaned off the contacts and put the switch back together and tested it before installing it back in the hatch and it worked better than ever. Then I put the whole shebang back together and now no freaky ghost locking and unlocking. :shades:
As a side note I should have known it was this switch because previous to being locked out, it would sometimes take me 3 or 4 pushes on that button to get the back hatch to open.
Fix it before you get locked out and your significant other has to come save your butt! And makes you pay for dinner.
Sorry my post is so long - but I lack the ability to be brief...
Just had tires put on the front and they didn't tork the lugnuts right and it warped the rotars. But my brake pedal doesn't vibrate.
It only has the vibration after repeated braking. It seems like something is heating up and causing this. If there is any one that knows about this please help. This is the wife's van and I need to keep her happy. Thank you
They have what you are looking for. 2”-12 lift for astro and savanna.
John
Steve
I have recently done a tuneup on it, plugs, wires,cap, roter, wires ,,,,,, & had several diagnostic tests done on it, which all passed, replaced an egr valve, & the ignition module, ( it was corroded green ) & yet still, since the day i purchased it, there is still a very heavy exhaust smell coming out of the tail pipe. It smells like unburnt fuel to me ,,,,, :P no "rotten egg smell" , just very heavy fumes all the time ,,,, i can smell it when the windows are open, its really bugging me as i want it to run as efficiantly as poss, not only for my pocketbook , but for the enviroment as well. It seems to have plantly of power, however i have yet to do a mpg test,,
Any insight to this problem would be really appreciated ,,,,,,,,,
Hope you all cruise smoothly,.
cheers ,,,,,,
Franky
ps ,,,,
i did put in a sweet sound system in a few weeks ago , sounds quite good , nothing too extreme , Clarion 200 wt, deck with usb, 4 - 6.5 coaxial Pheonix Gold SD radial speakers, front & rear doors, Pheonix Gold 400 wt 4 channel amp, powering the rear speakers & 10 Clarion sub, ( behind my seat , where i can feel the bass, but not so much as to enetertain the nighbourhood when cruising
cheers :shades:
Lou
