Now my doors sometimes won't unlock. I once got locked inside the car with the windows rolled up and hubbie outside with the key which wouldn't open the door (the old fashion mechanical way). After being locked inside a J you soon realize how small these puppies are. Ended getting out after hubbie fished a coat hanger in and got the lock to open. Dealer says it could either be the the timing actuater or some thing else which I can't remember. Oh, and sometimes the driver door won't close, something wrong with the latch. I now climb out the passenger door. My front lights work intermittently, but it sounds like it is the relay (thanks to everyone here) so I will try replacing that.
So all these problems have pushed me over the edge. I love the performance of my J, but I really need more seating room so I am looking for another car. Thought I would have to buy one this week with the headlight issue, but maybe I can drag it out a few months.
Wished I had found you guys earlier.
also this is just out of curiosity, the car that i looked at was a jade green which is not too green so i'm ok with it but how much would it cost to coat it single or double with black color?
since this car did not get a tune up at 60k how much would it cost?
to all the J30 gurus out there please share the wealth for a 20 year old J lover.
Thanks to everyone who might take their time to share the knowledge.
However could my car be rolled back. it's almost ten yrs. old but only has about 66,000. well i checked the carfax report provided by the current owner and the numbers kinda matched or i assume because I really don't know too much about cars.
well remember my questions about the dashboard lightswhich won't come on? and the paint job of getting single or souble coat of black on top of my dark green J? and also I noticed that the passenger side back window gets stuck half way while going up or down,it actually makes a loud jamming noise and or cracking sound which i really can't remember or describe but it does go up after the noise. from reading the forum i guess i know what to do.... but additional tips or advices are gratefully welcome.... thanks to all the J fanatics out there. And plz gimme an advice ASAP
because i am waiting in front of my computer for a comment..... like a 7 yr old in front of a toy shop.....
The dashlight problem could be a fuse, try replacing that.
Infiniti used very good paint on the J's, it resists fade and oxidation, so I would not paint over it. Live with the green, just give it a good polish and wax detailing. Zymol wax works well.
Let us know your mechanic's opinion.
Thanks for your responses
Jon
I just won the did on a 1995 J30 with 96000 miles form $5200. Price im not concerned about because I dont have 12 months to look for a car. My concerns are, after reading these messages I wonder did i do the right thing or would i have been better with the I30. Should I exspect to have many problems with this car and cost me $
Also, I am seeming to have a problem with the electrical system in my car. I have had 3 different brake lights replaced in the past 2 months, and my audio deck light is behaving with a mind of its own. It is inconsistenly on, sometimes being completely off or very dim. It is frustrating to not be able to see what track the cd is on, or what stations you are flipping through. Any ideas as to what is wrong with my car? Possibly a wiring issue? Or perhaps some creature of Satan has evoked its wrath upon my vehicle? Nonetheless, any help or advice will be, once again, greatly appreciated.
I have a problem with my 1997 Q45, the idle is high (2500) while in neutral, when I shift to drive or reverse, it goes back down to normal (800 or so) while not moving. When the car is moving it idles normal it seems. Also, just before the idle problem started, my "CHK ENG" - TCS OFF - ABS - SLIP ----- lights are all ways on, on the dashboard now and my RPM hand has stop working. Any ideas? I took it in to one "mechanic" and he stated that I needed an ECU and a WIRING harness and the total cost would run around $5000.00. I can't afford that, I need some help if anyone can. Thanks
PS: On a side note, it seems there are more questions than answers on this board.
The octane 91 grade is the minimun grade of gas that it requires.
The ideal thing would be to put a Gas STP cleaner with every gas fill up.
That will better your milage to a good extent.
Infinity leaves holes in the pocket in this expensive market.
It might be a low price, but the maintanance is a very big problem.
Low milage and lot of electric problems are common in the car. Also check if the stereo is working.
The milage on the infinity is just 13miles to a gallon.
Recently the passenger side door of my infiniti j30 started having problems and wouldnt open with the wireless key fob and I was just opening it manually.
The door lock on the inside would open and close but the door would remain just locked and would open only after i inserted the key.
Now the door got stays closed and does not open even manually. I am getting into the car now using the front passenger side door. The mechanic says it will cost upwards of $300 to open the door and
then fix it.
The motorized window works. When I was able to open the door manually with the key, the door lock on the inside would click as if the relay was having problems. I wish I had it fixed when the problem was not as bad
Anyhelp would be really really appreciated.
In your experience - you get far more snow than we're used to here - do you find that you need snow tires, or are all-weather radials plus some "ballast" in the trunk sufficient?
http://www.fuzzycats.com/j30_diy.htm
Also the car does not give heat till driving for a long time. I have bought a thermostat, but I can't determine where to place it. Suggestions appreciated.
Thanks...
Jpclass
I've read posts about the "door lock timers", but i don't think thats my problem. I have a programmed keyless entry that came with the car, that i use often. Since the last owner, when i open the door with the key--the alarm goes off. So i just used the keyless entry all the time.
When i attempt to unlock my doors, i can hear some kind of mechanical "gears" almost struggling to open the door. The actual lock button (above the latch to open the door iteself) will only be pushed out half way. As soon as i open the latch to the door fully, BOOM! the DOOR LOCKS itself again.
I currently only have 1 door that opens, the back passenger door. So i have to crawl through the back seat into the drivers side.
I've had a problem like this before with the doors, however it fixed itself. i just kept unlocking and unlocking the door, but somehow i think i've gotten myself into way more trouble doing that this time.
***I noticed today before i got locked in, when i went to shut the driver side door--it flung back open. when i shut it again it locked me in.
my doors also have a funny lock system, when i unlock the door with the keyless entry the driver side door unlocks alone, i have to click the button twice to open all doors.
PLEASE SOMEONE HELP ME, I NEED TO GET IN AND OUT OF MY CAR NORMALLY ON A DIALY BASIS!
Also, has anybody else tried putting using Mobil 1 oil? I'm thinking about switching to this soon.
Also, the stereo will not play. I have it pulled from the dash but am unable to get it to work. Does anybody have any ideas?
What is the easiest way to sew the seam of the driver's side seat cover?
Any and all help is greatly appreciated!!!!!!!!!!!!!
It does have a little stiff steering when Parking. The suspension has a Loud thug/knock when going on speed bumps.
I did an inspection the Power steering fluid was over full; I fixed that. The Radius Rod bushing were gone. I have the new bushing I will have to take to a shop to have them pressed on.
Anyone else have similar problem.
The sun roof I can hear the motor work but it does not open
The driver side door has a broken key in it.
The car has 12k mikes on any and all info will help
Thanx
I offer the following summary, with my comments, added for those who may yet need this good bit of advice.
The instrument lighting dimmer switch on the J30 can be serviced (replaced or cleaned) by unscrewing the panel on which both the dimmer switch and cruise control switch are mounted. This panel can be removed by removing the two screws along its bottom edge, (one on either side of the steering column). There is an electrical plug in either switch, which can be removed by squeezing the square locking tab in on each plug, and pulling them out of their respective switches gently. Adjust the steering column to its lowest setting to allow the switch panel to swing down and away from the dash.
Remove the dimmer switch assembly and trim fascia from the switch panel by removing the three self-tapping screws. Gently pry the black switch assembly (out of) away from the dash colored fascia. You will see the small rotating contactors at the outer edge of the switch near the thumb wheel. I used electrical parts cleaner spray to clean mine. Then blow the switch off with compressed air, as the solvent-based compounds in the cleaner spray might dissolve the thumb wheel or other plastic components of the switch assembly if left in contact with it.
You can test the switch by reinserting it in its harness plug if you want before reassembling the dash panel. I found it helped to depress the locking tab in and gently wiggle the dimmer switch and cruise switch plugs back in, rather than try to use any significant force, which might bend the small copper pins that have to slide into the plugs. Even though the switch worked fine during my pre-dash assembly test, it did not work after I assembled the dash. Fortunately I left the lights on, and in the process of wiggling the harness plug out, the dash lights came on and the switch now works fine, which suggest to me that the process of inserting the plug, which is rather snug, can distort the switch case. So if you have the same problem with a new switch or newly cleaned switch, leave the light on and see if the dash lights come on while you are removing or installing the plug.
