Infiniti J30
18910111214»
  • pure_chaos1488pure_chaos1488 Member Posts: 1
    shoot.....I have a 94 J30t that I might want to sell........
  • patpat Member Posts: 10,421
    Hi there,
    You may not have noticed that is a very old post you answered, but I should let you know that the CarSpace Forums may not be used for buying and selling. Check the Membership Agreement for further details. Feel free to email me with any questions.
  • elamotheelamothe Member Posts: 1
    I bought a 93/j30 about 6 months ago and im very happy overall but lately my headlights go off all by themselves in some very scary situations.Im willing to do what is necessary to fix them if I knew what to do.Please help!!!
  • ilikeboatingilikeboating Member Posts: 2
    I'm sorry I can't hellp you. In the years that we owned our Infiniti J30 we never had anything like that happen to us.
    Generally, it was a very reliable / safe car. Sounds like a potential electrical problem.
    Best of luck
  • 30yearvet30yearvet Member Posts: 1
    I had the same problem with my 93/j30. The symptoms were a little different in that the headlights never went off while I was actually driving. In my case they either failed to come on at all or only the driver's side headlights would work. I took the car to an auto electric shop earlier this week and they diagnosed the problem as a faulty headlight relay switch. The part from the Infiniti dealership, labor plus a "diagnostic" fee came to just under $300.
  • coupedncalcoupedncal Member Posts: 252
    This is a pretty common issue with J30. If original poster has same problem, replacing the relay is an easy 30 min do it yourself task. the relay sits near the firewall in the engine bay.
  • 94j94j Member Posts: 5
    I have a 94 J (114K mi.)... and although my radio & CD player stopped working a few years ago (and I chose to not go through the expense of replacing/repairing it), my antenna has developed a weird quirk. Actually, this may be happening because the tip of my antenna broke off... but the antenna no longer fully retracts when I turn off the engine; it makes a noise like it's trying to retract, but can't. The noise lasts about 10 seconds after the key is removed. The antenna also randomly attempts to go up & down while I'm driving, making that same obnoxious (and embarrassing) noise. Stepping on the brake seems to always trigger action in the antenna, but it also happens randomly.
    I've tried pulling the antenna fuse thinking this would simply cut the power to the antenna. Since my radio doesn't work, I don't need the antenna anyway. Any advice??!
    Also... I've normally taken my J to the dealer to be worked on, but that's been costly. I'm planning to find an independent repair shop to do the work. Any advice on finding a shop who I can trust to deal with the quirky-but-great J30?
  • the_jammerthe_jammer Member Posts: 1
    edited January 2011
    my car runs for about 3 -4 minutes then cuts off.. it wont start 4 maybe a few hours.. no one can seem to tell me what the problem is.. i've had fuel pump, fuel line, filter , tune up.and still it keeps doing this...help...................................this is a 94 also.
    Sounds like it is some kind of electrical relay. You will need to take it some inde mechanic who works on electrical stuff. My mazda had something similar and it turned out to be a pickup coi probleml. Not sure if J30 has similar design.
  • ricomadricomad Member Posts: 1
    I own a '93 j30 (bought it used with 160000 on it)and both back doors are locked, the passenger door sometimes locks on it's own, and the drivers door you need to push up and slam it, usually 2-3 times! I've read every thing twice about the Door Lock Timer and have taken it and re-soldered all the points. The locks on all doors click/flip, (the little thumb nob moves)
    Here are some questions,
    can a door lock timer partially work?
    I think the passenger door is a physical problem (as opposed to an emotional one) is this common?
    Could all the locking rods inside the doors go bad at once?
  • lescortlescort Member Posts: 1
    i have a repair metod for this issue, with a 23 mm diameter tube (1cm long)
    two 1cm rods, and a vacuum type line (rubber)
    Could you elaborate on what the fix is other than buying new window regulators?
    Hi. The windshield washer fluid barely dribbles out when I turn on the wiper switch. The fluide level is fine. Could it be a clog in the line? Or is there a pump that might be malfunctioning? Has anyone had this problem? Advice please. Thanks!
  • tazandteetazandtee Member Posts: 1
    Help anyone. The original owner of car added wood trim to each door. It is not the trim on the armrest, this trim is a piece about 1 inch wide and 20 inches long and it runs parallel to the window. (about 2 inches under the window) Have searched everywhere and can't find a place to purchase..
  • vance6vance6 Member Posts: 1
    WOW!!! That comment was posted a LONG time ago!!
