You may not have noticed that is a very old post you answered, but I should let you know that the CarSpace Forums may not be used for buying and selling. Check the Membership Agreement for further details. Feel free to email me with any questions.
Generally, it was a very reliable / safe car. Sounds like a potential electrical problem.
Best of luck
I've tried pulling the antenna fuse thinking this would simply cut the power to the antenna. Since my radio doesn't work, I don't need the antenna anyway. Any advice??!
Also... I've normally taken my J to the dealer to be worked on, but that's been costly. I'm planning to find an independent repair shop to do the work. Any advice on finding a shop who I can trust to deal with the quirky-but-great J30?
Here are some questions,
can a door lock timer partially work?
I think the passenger door is a physical problem (as opposed to an emotional one) is this common?
Could all the locking rods inside the doors go bad at once?
two 1cm rods, and a vacuum type line (rubber)
