Not buying Mazda/Ford again (FOrd AT on Mazda)
Also Heater/Coolant Core leaking (cost $600 to fix,
mostly labor). Had Toyotos for 160K and 130K and
did not have these problems!
and where would we put this skipole handle?
In other words, you have an oxygen sensor that's gone south more or less permanently.
You will have to repair/replace, or you will never pass emissions.
You also need to replace the engine coolant. If you will have your water pump changed with the timing belt, they will replace the coolant as well. Make sure they use the genuine orange Mazda coolant, not the green stuff (e.g Prestone). Replacing the drive belts at 60K is also a good idea. When you replace the timing belt, I would also replace the cam sprocket seals and the front crankshaft seal.
Many recommend fuel system service at 60K miles. You can simply run several bottles of Chevron Techron fuel injector cleaner through several tankfuls of fuel and accomplish the same purpose. Throttle body needs to be cleaned of accumulated carbon.
I would strongly recommend using genuine Mzda parts for plugs, plug wires, drive belts and the timing belt. I had terrible experience with aftermarket cheap drive belts which constantly stretch and require frequent retightening.
Don't change: no need to change spark plug leads until they go bad and you will notice belive me(they should be good for at least 120K), timing belt is good for at least 90K(even 105K, V6 are non interference engines-belt can break without damage!), change the drive belts and water pump when you change timing belt.
THANKS IN ADVANCE!
-Allen/16/m/ms
I tried both times to convince my dealer to replace them with leather ones like the ES models have, but they refused to do it as warranty work, even when I offered to pay the difference in cost between the two.
I also inquired about the cost of just purchasing the leather boots so I could install them myself, and if I remember correctly the total came to over $200.00, much more than I want to spend. I've not really spent much time researching the possibility of getting aftermarket boots. For now I'm just living with the torn ones.
Looking into vinyl boots from a '99 is a good idea p100. Perhaps they are more durable for that year, and should be cheaper than leather.
I believe that JC Whitney used to sell universal leather boots for shifters. I do not know if they still do, but it would be worth checking.
As far as reliability for my 626 goes, it's run like a top from day 1 and now has 111k trouble free miles.
The car has been surprisingly reliable though. I had some very annoying warranty issues, but virtually no problems in the last few years. 90K miles and running strong.
The best way to prevent rotor warpage is to always torque your lugnuts to specifications and NEVER let anybody use an air impact wrench to tighten your lugnuts. My brakes work like new at 90k miles without any chatter or other problems. The lugnuts on this car were always hand tightened using a torque wrench, and proper tightening sequence.
- 3 lug nuts on each wheel
- radio mounted vertically in the center console
- wallpaper for headliner
- large rubberized cloth sunroof (about 4 ft long) which folded back and made the car look like an open can. It was secured in the closed position with two rubber hooks
- hood hinged in the front of the car
- spare tire mounted on top of the engine under the hood (heat so dryrotted the spare that when I used a brand new spare for the first time, it disintegrated before my eyes)
- no door handles, only a button which need to be pushed and recessed area behind it to pull the door open
- radiator cap which required a large wrench to remove
- transaxle mounted in front of the engine. The transaxle had a drain plug which looked just like engine oil drain plug. First time I changed engine oil I mistakenly drained the transaxle. Fortunately, I caught the mistake when I added four additional quarts of oil into the engine and the oil was 1.5 inches above the full mark on the dipstick.
- longitudinal torsion bars for the front suspension
- transverse torsion bars for the rear suspension (absolutely unique, never saw another car like this)
- large "LeCar" decals on both doors
- cloth seats so cheap that they fell apart just from rubbing against the front seats when the rear seat was folded down
- rubbery manual transmission shifter, which was unlike any other manual shifter I ever tried
-cylinder sleeves in the engine block
-air cleaner that looked like an old canister vacuum cleaner
- the most complicated and overdesigned emission control system in existence - source of constant problems
-the engine displacement was 1400cc's, peak power 51 HP, and the vehicle curb weight was 1800 lbs
Owning this car was truly a unique experience. It had an amazingly smooth ride for a small car, and delivered around 35-38 MPG.
One night I drove the car a little fast (maybe 60 MPH) on this twisty mountain road in West Virginia. Before I knew what happened, I spun around 180 degrees and stopped facing in the opposite direction in the middle of the road. This was in summertime and the road was dry. Nothing like this has ever happened in any other car since. At least it did not roll. The unique suspension did its job.
a poster. I'm sure you helped with your feedback on
some issues but everyone should have a possitive
experience with ones mode of transpo...Good Luck
in your next automotive adventure. My wife and I
couldn't be more happy after 48K Bryan
So we'll just stay put
Maybe that was one of those cars made on friday?
Some tips for changing manual transaxle oil on the V6:
There is a drain plug on the bottom of the transaxle and an identical fill plug just above the backup light switch on the side of transaxle toward the front of vehicle. Both of these plugs have 23 mm hex heads. I had to use a 24 mm socket, which was slightly oversized, but did the job. 23 mm is not a standard size metric socket and I have no idea why Mazda selected this size. They probably sell a special tool socket just for this purpose. I tried SAE sockets, but none would fit right. 24mm was the closest fit. Nobody sells 23 mm metric sockets! I have all kinds of tools and many socket sets, and none contain a 23 mm socket! Both fill and drain plugs have aluminum washers, which need to be replaced. Do not reuse these washers! The reason is that they are soft and the plugs will cut a groove in them. If you do not line up the groove with the plug when you reuse them, they will leak. These are cheap to replace, but hard to find, and I had to go to my local Mazda dealer to get them. It is a good idea to get spare washers before you start changing your oil.
I used a small hand pump for pumping fresh oil into the transaxle. I attached about 5 ft length of clear vinyl tubing to the pump outlet and inserted the other tubing end into the transaxle fill opening from above (hood opened). This way I could comfortably pump the oil in without working under the car. There is simply not enough room under the car to operate this hand pump wihout jacking up the car. Doing it from above is much easier and much less messy.
The proper oil level is attained when oil is level with the bottom of the fill plug opening. I just kept pumping the oil until it started leaking out of the fill plug opening, then stopped, removed the tubing, and let the oil ooze out of the opening into a drain pan until it stopped. Then I replaced the fill plug using a new aluminum washer.
So far I found the Redline oil to improve shifting considerably. The oil contains special friction modifiers to provide for proper synchro engagement in manual transaxles.
I too had difficulty with the socket size, p100. I'm a bit of a perfectionist and have been burned too many times by using the wrong size before, so I went on an exhaustive search for the 23mm. Even the Sears hardware store with the huge glass case containing hundreds of sockets didn't have it. After trying 3 hardware stores and 2 auto parts stores, Napa finally came through with the right size. Try them if you want one for next time. Of course that socket hasn't been used since, but it's there if I need it!
My Nissan V6 pickup has pipe plug type differential, transmission, and transfer case fill and drain plugs with internal square 14 mm opening! Try to find the right tool for that! 1/2 inch socket extension was too small and the plugs were extremely tight.
After searching for months I finally discovered a special set of drain plug sockets in some tool catalog, which happened to contain a 14 mm square socket(incidentally this set did not contain a 23 mm hex socket that would fit Mazda). Before I found this set, I went to Nissan dealer and they did not list any special tools for these plugs and did not have any of course. If they use a 1/2 inch extension end on these plugs, they will damage every one of them.
The fill and drain plugs were so tight on this Nissan that I had to use a long 1/2 inch drive breaker bar with the special socket to break them loose. I have a total of 8 of these plugs on my truck - 2 for each differential, 2 for transmission, and 2 for the transfer case.
