Visitor Agreement.
Any suggestions are appreciated. Thank you.
I have a 95 MX-6 with the 4. I just bought it from a family member. It had 128k when I bought it, so I just did the timing belt and water pump at the same time. I was quoted 360, I think it came closer to 400. A tensioner broke during the chain of the belt.
I got to say that I'm impressed with how this car runs. Mine is a five speed and it is responsive and very good on gas. I've gotten 31 to 34 mpg consistenlty.
I've been reading through the post to get an idea of problems and durability with this car/engine. Doesn't appear to be many issues. I know this car has seen synthetic oil its whole life. So I think the last thing to die will be the engine.
I would not change the water pump at 77K miles. The chance of it failing within next three years are not high. I changed the waterpump preventively on my 92 Protege at 65K miles and the original waterpump was like new.
My son will be taking the car from Massachusett to LA and I don't want to worry about it.
Mazda recommends changing exactly same belt at 105K miles in California and some other states..so I think we should be fine too.
For the battery, measure the voltage at the terminals. It should be about 12.5 volts for a fully charged battery. With the engine running, and all eletrical accessories off, if the alternator voltage regulator is working properly, the battery voltage should be between about 13.5 - 14.5 volts. If the alternator voltage regulator voltage does not exceed the static battery voltage, the alternator will not charge your battery. Second, perform a load test on the battery. This will verify the ability of the battery to hold charge. The fact that the battery is only one year old does not mean much. I have seen week old batteries suddenly fail.
Concerning the battery cables, do not assume they are OK without checking the crimped cable terminals both at the battery and on the opposite side. Especially check the negative cable terminal lug where it bolts to the engine block and ensure you have a clean and tight connection. If the connection here is loose or corroded, your car may stall at speed because not enough current is available for the fuel injection system to operate. Fuel injectors consume a lot more current than the ignition system.
Seems to me that your dealer is not performing any systematic checks to find the problem. Maybe you should try another dealer or an independent repair shop.
The shifter linkage is located directly over the catalytic converter, which only has a thin metal shield over it. Is it possible that some bushings in the shifting linkage may need replacing or greasing? Or that the catalytic converter is heating up hotter than usual now that the car has almost 100K miles on it? Anybody experienced anything similar? The problem does not appear to be clutch or trasmission related becauase the car shifts fine except for those few instances.
original message
My '00 LX-V6 just went in to the dealer yesterday for clunking in the rear suspension. They're telling me a sway bar link is loose and in need of replacement. Didn't look under it myself, but it sure sounded loose.
They're ordering the part for next week so I have the car back, but they must have done something to tighten things up a bit, because it doesn't clunk as much as it did before yesterday.
This is the second time getting the problem corrected on my car, first time was in May last year under the B2B warranty. Fortunately, this time is also a freebie as I'm still under the 12mo/12Kmi parts/labor warranty from the first repair job.
This clunking noise is driving me nuts!!
I tried again to convince the dealer to give me more info last time I got the car back, but they are never willing to discuss technical details with me (you know, that mechanic who did the work always seems to be unavailable when I want to talk to him). They did finally admit that it is a common problem with '00 models, but of course they wouldn't tell me why or what I should do about it.
It might be time for me to invest in the service manual(s) and get to the bottom of this. I'm hoping that some fasteners can just be re-torqued at oil change time to prevent this sort of thing. I definitely don't want to pay someone to fix it if it does happen again, as sway bars and their associated components are ususally simple enough to deal with easily. Let me know if you find anything out on your end. The only thing I can find on Google that might be relevant is this person's MX-6 page, but I don't know how similar the MX-6 and 626 suspensions are:
http://www.mx3gsr.freeservers.com/maintenance.htm
Now as far as roll bar bushings:
- the ones on the end looked pretty good and I could not find any loosness in them
- then there are two other rubber bushings(rotarykid mentioned these I belive in some earlier posts on this subject) that are more toward the middle of the bar and those made some noise(after I shaked the bar pretty hard) which sounded like metal to metal contact even though the bushings looked ok from the outside.
if those two are the source of the noise that can be replaced very easy(only two bolts are holding them) and they should be very cheap I think.
I think I will make some pics with my digital camera and then we can make sure we are talking about same thing.
One unpleasant thing about replacing the timing belt on a V6 is that you must jack up the engine and remove the front engine mount to remove the old belt and to slip a new one on. Mazda sells a special tool to hold the crankshaft harmonic balancer pulley stationary so you can properly torque the center bolt (removing the bolt is easy with an air impact wrench).
Good luck with that timing belt. Sounds like you're going to be under the hood for a while. Are you getting all this good info from your dealer, or from the service manuals?
The information on timing belt replacement: I got it from the factory shop manual. Mazda also makes a special tool for supporting and lifting the engine to remove the front mount - the tool is essentially a steel bar with a small chain hoist that is placed across the engine compartment and rests on inner fender grooves. I am sure it is expensive and not worth buying unless you use it commercially. I was wrong about the price of the timing belt tensioner - it is outrageous - get this: $ 199 list price for the tensioner leg, and $ 120 for the body of the tensioner. So I will not be replacing it preventively. The timing belt, oil seals, water pump, and water pump O-ring (separate part which does not come with the water pump) cost me about $ 200 with a 20% discount from our local Mazda dealer. The timing belt itself lists for $ 92.70! For some reason the timing belt for my 95 V6 Nissan pickup is only $ 28 from a dealer, and both vehicles have overhead cam V6 engines, so the belts are comparable in size.
Here is a list of parts you need to replace the timing belt and the water pump in a 99 V6:
part number/ part name/ list price
KL01-12-205-9U/ timing belt/ $ 92.70
BP01-10-602A/ camshaft oil seal/ $ 8.00 (2 required)
FS02-10-602/ front crankshaft oil seal/ $ 9.60
KL47-15-010C/ water pump/ $ 104.76
KL01-15-106/ water pump O-ring/ $ 18.60
Note: replacing of the oil seals and the water pump is not necessary to replace the timing belt: however, failure and replacement of any of these will require timing belt removal and reinstallation.
Maybe you're right about the shift linkage binding, p100. My tranny seems to be happiest when outside temperatures are between 30 and 80 degrees or so, and anything outside of that seems to make shifting a bit more difficult in general. The cold weather issue is understandable, although I'm not sure why hot weather would bother it, but you're theory may be correct. I have noticed that my transmission gets a bit more obstinate than usual when our summer temps are at their peak (90-95 degrees).
That timing belt tensioner price IS outrageous - I hope it is well constructed! The water pump on my mother's '99 Park Avenue seized up (at ~80K miles) last month while she was on the highway, and all that was left of the tensioner pulley was a small round disk made of plastic. The rest it must have disintegrated and flew out of the engine compartment, because it didn't look much like a pulley at that point. At any rate, those Mazda parts prices are pretty steep, I hope they are good quality. How did you get that 20% discount, anyway?!?
I must say that I was left with an even more positive impression of the car after I did that 180 degree spin on dry pavement, with a set of four new snow tires on it's feet. Although the incident took place in just a few seconds, I was completely concious of the car's movement the whole time, and I never felt as though I might flip over, since the car barely leaned into the spin at all. Gotta love that Mazda suspension! Those tires are not the sort which encourage extreme driving maneuvers, either. Nice and grippy for snow, but very soft and spongy feeling in turns.
So unfortunately, I won't get a chance to test the car's longevity any further. However, at 50K miles, it was still doing quite well mechanically. The only components which exhibited any noticable degradation were the clutch, brake pads and rotors, but to a degree that was certainly beween average and above average in my book.
My only significant mechanical failures were those pesky stabilizer links and bushings we've just been discussing, which I never could get the whole story on from the dealer. I did manage to dig up both my invoices from the related warranty service, so if I get a chance I'll post the details in another message.
Well, at any rate I'll be in the market for another car within the next couple days. Maybe another Mazda, maybe not. Need to get a look at the insurance check first I suppose. Good luck to the rest of you and your 626's, and thanks much to those of you who shared such valuable information about your experiences with your own cars!
If I were you I would be heading to test drive Mazda 6...if you liked 626 ride you will love 6 ride...
as far as my rear clunk it is still there and it is not brake pad related since ih happens even under braking. I will take pics this weekend so I can figure out which bushings I need to tackle first.
I wonder can you post pics on this board?
slickdog I would appreciate if you could let me know what parts did they exactly change on yours.
zoomzoom626
Just got back from the Mazda dealer a couple hours ago, wanted to get some quick photos of my car before it left for the boneyard. While I was there I checked out the new 6 sedan, hatchback and wagon real quick in the showroom - very nice indeed. Didn't have time to drive, but I'll definitely be doing that within the next couple days.
I'll try to post whatever details I have on my rear suspension service tonight.
BTW I just hit 100K miles today in my 99 ES V6. The car runs great, I have no more issues with harder shifting now that the hot summer weather is over here in Florida.
Good luck with the next 100K miles.
Date: 5/22/03
Mileage: 32432
Customer reports: GETTING A KNOCKING NOISE FROM REAR END OVER BUMPS CHECK AND ADVISE
Caused by NOISE COMING FROM WORN REAR SWAYBAR LINKS AND BUSHINGS,REPLACED LINKS AND BUSHINGS
Installed GG2A-28-156 :BUSH,STABILIZER-RR Qty: 2
Installed GD1J-28-170 :LINK,CONTROL-STAB Qty: 2
Date: 3/04/04
Mileage: 39006
Customer reports: GETTING A CLUNKING SOUND FROM THE REAR
Ordered GD1J-28-170 :LINK,CONTROL-STAB 1@42.75
NOISE COMING FROM LEFT REAR SWAYBAR LINK
ORDERED LINK WILL CALL WHEN COMES IN.
Date: 3/10/04
Mileage: 39254
Customer reports: GETTING A CLUNKING SOUND FROM REAR OVER BUMPS INSTALL SOP.
Caused by FOUND LEFT REAR SWAYBAR LINK HAS A LOT OF PLAY IN IT.REPLACED LEFT REAR WORN SWAYBAR LINK UNDER PARTS WARRANTY.
Installed GD1J-28-170 :LINK,CONTROL-STAB Qty: 1
The owners manual doesn't tell me much, just consult an authorized mazda dealer as soon as possible. My car is a 95 MX-6 with the four cylinder.
Is this Mazda's equivalent to a Service Engine soon light? The car is running great and always gets between 31 and 34 MPG.
Any help or experiences is appreciated.
I'm also thinking that it could be an 02 sensor. The car has almost 134k on it and I'm sure it is the original 02 sensor.
Do you know if this model stores codes. I'm thinking it is not an OBD 2 system. Thus interegating the computer will not tell you anything.
http://www.mazda626.net/index.php?act=ST&f=3&t=5598&s- =98e2846d570c710bf765cdcfe5f827e6
BTW, I have a strong dislike for polished clearcoated alloy wheels. I have had absolutely no problems with rough cast painted alloy wheels on my 92 Protege or 98 Maxima. The polished clearcoated wheels look nice when new, but they are not practical at all and susceptible to corrosion under the clearcoat. The 626 polished wheels are especially delicate, because when they balance the wheels, and use a centering cone, the metal cone damages the clearcoat, and the wheel will corrode around the center cap. If you do not touch up the clearcoat immediately, you will not prevent this corrosion. One way to prevent this damage is to use a smaller diameter centering cone, but this only works with certain wheel balancers, such as Coats balancers which use a smaller diameter wheel mount shaft (I think 25 mm vs 40), so a smaller cone can be used. The smaller cone then tightens against the inner center hole lip, not the outer clearcoated one.
