Visitor Agreement.
The only way to really check mileage is to keep a log book and do it over several fills and 1000-2000 miles.
Check them out.
Oh, yea, ALL cars have their problems, I just think back on Gen Motors cars relatives have had and think I'm lucky with my Merc GM. Brother has a 99 Concorde that is almost deafening at speed window seals falling off doors, etc.
Obviously the alignment is key, but the ball joints should have prompted a good one. I saw a similar problem once, caused by seperated belts inside the tire. Try swapping front tires with rear. Also has the car ever been repaired from a rear end crash. Sometimes a car's crooked rear end can be way out of alignment. The rear of such a car can track 4-6" off center compared to the front end. This can also create poor overall tracking. You could try bringing the 'toe in' to the limit allowed (front of tires closer than rear), to try and get better self centering of steering wheel. Good luck.
The police said our car with a "frame" underneath saved her. Her only injuries where a broken toe from slamming the brakes so hard by reaction, a belt on chest soar and now a permanent fear of any car coming up to an intersection while I drive.
That is the only car we buy as of now, and the ride can't be beat.
You might want to look at third-party warranties in addition to the ones offered by Ford. They tend to be *much* less expensive, offer varying terms and coverage levels, and can be used at virtually any service station (not just a Ford dealership). Two sites to check out are: www.warrantygold.com and www.warrantydirect.com.
To rea98d, the guy with the noisy front suspension:
Try greasing the hood latch. It sounds silly, but it quieted down my front-end squeak when I first had my car. Also make sure the steering stops are well lubed, else your car will make grinding noises when the wheel is at full-turn.
OH to Atlanta GA (by way of Raleigh) which was about 900 miles. Not one drop of oil seems to have been lost/burned during the entire trip. Car is in immaculate shape, is an LX with full leather and 10 CD changer. Now that I have paid cash for this one, I can sell my '99 LX and lose it's $ 400.00 / month loan payment. Anyway, sorry for my rambling. I have two questions:
I have heard of 2 schools of thought on the changing of fluid, etc on the transmissions on these cars. One says to "change fluid/filters every 30,000 miles", other says "if you haven't changed it, just leave it alone and make sure to keep it topped off, being careful to ALWAYS use Mercon such and such". The car could not possibly be in better shape after 140K miles so all indications are that it was VERY well taken care of. Should I get the transmission "serviced" or should I just leave it alone, my recollections are something about changing viscosity of fluid by changing it....... or something like that, any comments welcome.
Question 2: The car has a 10 CD cartridge unit in the trunk with a little control panel mounted on the dashboard to the left of the radio. The owner's manual makes no mention of this little control panel and only refers to controlling the CD player via the existing radio controls. I tried it the way the manual says, without results. Any suggestions as to where I can get help with this, I can just imagine walking into a Ford Dealership and asking them to look at my sound system (although, it is a "Ford / JBL sound system").
My guess is that the car was driven nearly every day and was very well taken care of. As I said, I put 900 + miles on it bringing it home and it felt just about as nice as my 99. Also, has the nicest feature a car can have, or not have....a loan payment every month.....although I suspect I'll be visiting my local auto mechanic buddy more frequently.......Thanks in advance for any input..... or any other comments on care/feeding of a 94 CVic with 140K miles !!!
sullivanmdsp, you should have a dipstick that doubles as the cap of the transmission fill hole, and it should tell you how much transmission fluid you have. If there's no dipstick, you're looking at the prospect of putting the car on a lift, and playing with a little drain screw on the bottom. Somehow, the stream coming out indicates how much fluid you have. And to get technical, Crown Victorias don't have a transaxel. Except for maybe Corvettes and a few exotics, transaxles are the exclusive domain of FWD cars.
try this smmsmm, power up your cd unit by the external pad, then play a cd. you should see the cd track# and minutes counting down in the extternal pad display. while it's playing you should hear mostly static on all local fm channels. now scan the fm band, start low or auto scan the whole range. your radio (or you) should stop on the one frequency that is playing the cd! I find the quality to be good on my changer. most factory car speakers and radios are no way near cd quality. these changers put out about 90% of the cd signal, which is pretty good(they are limited by fm reception limitations) you would need a fabulous factory system, or spend some decent cash on an aftermarket system, to notice and appreciate the difference in sound quality between the fm modulator system and the direct slave changer(which are generally more money). most people i know would not notice, care or be able to tell the difference. the major downside to me (for the fm system)is the little extra pod stuck on the dash, and having to use redundant sets of radio controls. hope this clears up things...
(this 93 has NEVER seen snow ice salt etc. & there is absolutly no rust but does have 205,000 km & is in perfect shape otherwise - no collisions). The next day it drove it slowly to the Ford dealer with the loose rivet in my pocket. Told the dealer the problem & mentioned that there may be a Ford warranty repair because this was plainly an assembly/design failure (as I'd read in Edmunds that hoods flying open on cv police is a listed failure, gm is the same car). The dealer said that they never heard of this failure & that I'd have to pay for it & go after Ford direct. Several calls from & to the dealer later about what the repair is for I pick-up the car after work & the dealer presents me with a "no charge" bill & new "pop" rivets are installed on the catch.
vin # 2MELM75WOPX671251 93 Grand Marquis LS
1. I have seen a 2001 CV (not an LX) advertised at $19500. The base invoice from Edmund's and Cars.Com is $21740 with destination. Could this indicate desperation on Ford's part to sell these cars? I worry about resale value down the road. Should this car be ordered with at least the P and H package along with ABS/Tract Control options for better resale in 4 to 6 years?
2. Does anyone know if the CV will definitely undergo a change for 2002? I'm not comfortable buying a first year model Toyota much less a Ford.
Any feedback on these topics would be appreciated.
Norman
My, what passes as a sports package these days!
I've heard the CV/GM will be getting a makeover for the 2002 or 2003 model year, but I'm not sure which. Either way you won't be buying a "first year" model. The core car will remain the same, except for some sheet metal and some other minor adjustments. Side-air bags will probably become standard. That kind of thing. Besides, any "new" stuff on the Fords is usually "tested" out by Lincoln for a few years prior.
Get ABS, T/C, and P&H because it's the right thing to do. Yes, they will increase resale value. Dramatically if it's the difference between crashing and not crashing. Marginally so if the car is older with a lot of miles. :-)
I have a 99 GM LS with 39k miles. Whenever I accelerate the car does not go at a fast rate. My bro has a 96 GM with 96k miles and that thing just flies down the interstate!! What are the things that need to be checked?!!
Also my rear view mirror with compass and temp is displaying a "C" what is the quick fix on this?
You will loose, however, a couple of mpg's with dual exhaust, that is easy to notice. He never had more than 24, and I typically have 26+ on interstate.
I don't have ABS nor traction control. I can still drive in snow, never had a problem, and we do have snow in Iowa. Saying that RWD with no ABS is useless in snow is not exactly truth.
The most important for safe driving are driver's skills and driving style. If you are jumping from line-to-line, turn into wrong lanes, never use turn signals, and show disrespect to other drivers in other ways the traction control and ABS are not going to help you much. I agree that it is not a bad thing to have, especially if you don't "feel" your car. Though I remember that statistics few years ago indicated that there was no difference in accidents for cars with ABS and without. Explanation was that those with ABS 1) don't know how to use them (release brakes when ABS kicks back), and, 2) relay on ABS too much.
And remember, american cars are useless. They are not reliable. Buy japaniese one, every reviewer agrees. Don't be silly. And don't buy those useless small cars, they offer little protection even with ABS. Buy the biggest SUV you can. You will be safer, and who cares about those useless people in useless small cars with no ABS?
Everytime I accelerate or I make a sudden stop I hear a strange friction noise in the lower back part of the car between the carpet and the chassis, like friction with rubber with metal....
I greased the exterior area where the noise is but I keep hearing the same noise what can I do.
You might also want to bounce the rear of the car to see if you hear the noise and perhaps better pinpoint where it's coming from. My guess is it's something simple, like a tailpipe bushing or some such. Have you taken it to the dealer?
My 98 has the air suspension and I carry a lot of weight in the trunk and haven't heard any strange noises from back there.
Thanks.............
Ron35
But if you're still in or close to warranty, get them replaced.
