Visitor Agreement.
In fact Ziebart is now into the aftermarket car accessory business.
My grandfather's 1984 Crown Vic is about to die. He recently found what seems like a decent deal on a 98 Grand Marquis. I would like to know if anyone has suggestions for things I should warn him about, or at least have him ask the dealer about, specific to this car/model-year. Things like 'The tranny in this year died on lots of cars' etc. I checked the consumer ratings and the 98 model seemed to be a significant improvement over the 97 year model (don't know why...was it a new design?). Any help you could give me I would appreciate.
James Feger
While visiting The Henry Ford Museum last week, I saw staffers were putting a new Freestar on display in the lobby. A nice looking van with some neat innovations. No prices listed, though.
You can see mine on Muth website under Owner's Gallery
http://www.muthco.com/customers/ownersgallery.htm or http://www.muthco.com/customers/herminiorodriguez/herminiorodrigu- ez.htm
They are nice additions and prevent many cross lanes from others. I'll recommend them.
Are there any upgrade/performance parts available through Ford that will not void my warranty? Looking for a little better cornering, horse power, etc. What, if anything, can I use from the Marauder?
I've enjoyed the discussions here converning V6 FWD and V8 RWD. I own a 98 Olds Intrigue 3.8L that is pretty quick, but it was the first FWD and six cylinder car I owned. Everything else was either Mopar (440-powered New Yorkers and Furys) and Ford (76 LTD 351M and 84 CV 5.0L).
Thanks for any links, experiences and help you can throw my way to get me to decide.
Deke
www.crownvic.net is a good source for these cars
There's a lot of stuff going on in there, and it's fairly quiet generally, but a ticking isn't unusual. NOw, if it's a snapping sound, that could be a lifter, except that you have an SOHC engine, and there are valves opening and closing from the overhead cam.
Finally, I told the Sales Manager to keep the damn car and drive it himself until he heard the ticking, and took a loaner car. Didn't care how long it took. Took 3 days for him to hear it, but when he did, he got right out and found it. Never did it again.
Good luck!
What sort of problems should he expect to encounter in the 100,000 to 125,000 mile interval? Are there accessories or components that have been known to fail as these vehicles age? He has kept meticulous car of the car and would consider keeping it if he could be convinced that the car will likely hold together for the next 1-2 years without hassle.
I have the older 5.0 version, and it has gone 222k without a major problem.
ride of the '03 GM?
-replace shocks?
-replace springs?
-or what else?
If so, what brands and product names/#'s
-will '02 or prior year's rear shocks fit an '03 and
would they fix the problem?
I have complained to the Mercury dealer. They checked my shock part #s and I have the standard shocks. They have been trying to check with Ford re: my spring #s, but so far they cannot determine whether or not I have standard springs. Also, they have new shock part #s from Ford for shocks to be released in Dec., but no one knows what these new shocks are; softer or stiffer.
However, has anyone found any other manufacturer's shocks that are softer and will fit an '03?
Thanks to all who answer.
I have heard that springs interchange from all years '79 and up, but I have not tried this personally. If it is true, I might have to get myself some '03 PI springs.
jrc346- Good point on the oil pressure problem. I forgot to consider the possibility that it could just be the gauge/light or sending unit.
Any ideas what may be causing this? Thanks.
Good luck,
Goldranger
There are such things as freak failures in transmissions. Could have been a defective part in the original transmission that failed, then the rebuild was done incorrectly and had to be replaced, too.
as far as the smoke problem, assuming you're talking about oil smoke from the tailpipe, then yes, a set of rebuilt heads is the probably the solution.
p.s. it is one on the best riding cars around, it has the air suspension, thats great.
