Chevrolet Impala Audio
1252627282931»
  • jntjnt Member Posts: 316
    It is likely the external audio amplifier problem: one possible cause
    But it could also be the shorting of the two speaker wires somewhere between the Audio Amplifier and the speaker in question. When the speaker wires are shorted, you, for sure, lose that channel. But in some case, you would lose all 4 channels. You can check the shorting of the speaker wires/ Amp outputs by probing the speaker connectors (after removing the speaker from the connector) using an Ohm meter.
    Another possibility is the broken speaker wire(s) or connection problem. Checking for broken wire is harder since you have to probe at both ends (speaker end and the Audio Amplifier end). But indirectly, you could check the DC voltage at each wire (again with the speaker taken out). At each wire, you should measure something around 6V - 8V (depending on the battery voltage. This is normally 1/2 BATTERY voltage). Broken wire has no voltage at all or some voltage out of range (13V if it is shorted to BATTERY).
    Sometime it could be the radio itself is at fault (connection problem at radio side, blown one audio driver inside the radio)
    jt
  • don8455don8455 Member Posts: 1
    I was wondering if there was a way that I could get the song title and artist to scroll across my screen when the XM radio is on. As of right now when I press the information (i) button on the top left I can choose to show only one of them. I don't know if I imagined it but I thought they did scroll when I first got the car (before I started experimenting with the buttons).
  • johnkuxjohnkux Member Posts: 4
    I have a 2007 Impala with about 13,000 miles on it an am on my third radio. The prievious radios just went dead. Dealer, aren't they always so helpful?, said the problem was the radio and replaced it twice. The last new radio was two weeks ago and this one is already starting to not work. Symptoms are no sound, period. Sometimes it will start working then go dead again. Dealer said they cannot fix it until I bring it in with the radio not working. Help.
  • bigjim5bigjim5 Member Posts: 3
    See if you have an amp in the trunk between the speakers. This is probably the problem. Tell the dealers to check it, or send it out to a radio shop.
    Jim
  • bugbugbugbugbugbug Member Posts: 1
    Could you share with us what the fix was?
  • quietproquietpro Member Posts: 702
    The "Black Tie" stereos do not offer XM title scrolling. If you tune to an RDS FM station, you'll notice that the information from the FM station will scroll. This may be what you remember seeing. I researched in great detail after first purchasing my car. I had ASSUMED it would scroll since the earlier models' stereos scrolled the information but it simply isn't a capability designed into the new stereos.
    There is a TSB regarding the amplifiers in the 2006 Impala. I believe it was fixed at the factory later in the model year run and as far as I know, didn't affect subsequent model years. However, the actual fix was to replace the amp between the speakers on the read deck (visible from the trunk) and to reprogram the radio's head unit. If I remember correctly, the newer amp has "Bose" molded into the metal casing (whereas I don't think the old one did).
    As I stated in the earlier post, the hiss was reduced but it's still very noticeable by someone with an "ear" for it. I had been wanting to compare my car with a newer one ever since the "fix" came out but wasn't able to until this past Christmas. My sister bought an '07 LTZ and it has the exact same hiss as mine. So, mine is as good as it gets, I believe, which isn't saying a lot.
    If you suspect you have the old amp in your car, take a look at it and describe it here. I also think the heat fins on the new amp run diagonal whereas the old amps fins ran inline with the sides of the casing. I'll go look at mine again if need be.
    Good luck and keep us posted!
    Ron
  • loc2275loc2275 Member Posts: 2
    trying to hook up a line out converter so i can hook up my sub and amp to it but dont know what wires are the speaker wires please help new to this site
  • tylerdreibtylerdreib Member Posts: 1
    just wondering if there is a place where i can order a replacement speaker grill cover online or the best way to go about getting one
  • junkieturtlejunkieturtle Member Posts: 1
    Hi there. I'm installing a 4 channel amp and new speakers into my 2004 LS impala that has the factory amplifier. My question is this.
    Does the system split the signal sent to the front speakers so that the woofer is only getting a low end signal and the tweeter is only getting a high end signal? For example, if I replaced the front 6 3/4 speakers, would they be receiving a full range signal or is it run through a crossover to split it up between the 6 3/4 and the tweeter?
  • bradharmerbradharmer Member Posts: 15
    My cassette tape deck is giving me the error "CLEAN" and it won't play any cassettes. I tried a cleaning tape but it spits that out too. Anyone run into this or know how to clear the message? I've tried the following
    1. Pulled the fuse
    2. Pulled the battery
    3. Tried cleaning cassette. It gets ejected like any other cassettes I tried.
    -BRAD
  • klugkaiserklugkaiser Member Posts: 1
    Okay i have following the forum pretty closely but still no luck. I own a 2000 impala and my quest for a decent sound system has become a nightmare. I bought an after market radio for my car and did not feel like buying the $100 module that i believe doesnt do anything. I had the cassette radio and the stock amp in the back. I read the one post that was entitled "How To Install aftermarket Radio In My 2000 Impala w/o $120 wiring harness" but the pins and wires did not match up with my car. I went to my local mechanic and they printed me off the only radio schematic sheets provided by chevy and it was a cd player version w/o an amp so it didnt help out at all. Many of the wires were not there or were in a different place. At first i struggled to even get power to the new after market radio. Finally i was able to realize that my stock radio did not have a constant 12v where it use to be so i had to wire one off of one of the fuses from the side. So now i've figured out that i have the correct wires hooked up for the constant and the ignation/acc but now no music is playing. I grabbed a speaker from my garage just to test it and the radio and wires were fine. The car won't play the music though. I believe it has something to do with the amp in the trunk. One post said that they bypassed the amp completlely. I'm wonder, can i just get rid of it in gerneral? I'm eventually going to hook up an amp and subwoofers in the trunk and im wondering if i really need the stock amp. Haha i've destroyed my old wiring harness and i have few spare wires that go to nothing, i'm thinking it i should jsut cut everything and make it direct, i'm already this far in the hole. Please help me out, im kinda missing my old radio because it sure beats the hell out listening to the wind and staring at the empty hole in my dash. Your advice is greatly apprechaited.
  • mandahoutz22mandahoutz22 Member Posts: 2
    BIG question. I have a 2004 chevy impala. All of a sudden the radio stop working. I can still see the time and what is playing on the radio but there is no sound. Not even a chime coming from the door, or the low fuel light or anything. I have a factory amplifier.. anyone have any suggestions on how to get my radio working, without paying 200+ dollars for a new amplifier???
    Only option is , if low mileage, talk to the GM customer service people. Otherwise take it to a good local car audio place and they should be able to do it for less than $200
  • ferranteferrante Member Posts: 6
    Here's your answer. Your amp is not getting power. there is a conecction under your carpet that goes to the rear or the vehicle , it's about at th emiddle of th ecar on th eright side, the coecction is prob corroded due to condensation. What we did is ran a new power supply to the amp and bingo we have radio. before figuring this out we changed the radio, we changed the amp , we removed the carpet completely and checked the wires and connections. after all this we put it all back and still the same radio works but nbo sound and no door chime, we then tested power to amp and bingo we found th esiple yet hard to find answwer.....GOOD LUCK>
    That is awesome!! Thank you sooooo much for the info! So now, how do I go about fixing it? How much would it cost to get fixed? Is it a simple fix?
  • geocarpgeocarp Member Posts: 3
    Can you be a little more specific on where that connector is? I have the same problem and I would love to get this fixed. Thanks! You might just be a life saver!
    Well to start you first off have to remove seats, center console, and trims to remove carpet. once done the connection is halfway down the car on the right sid ejust behind driver seat, sits just at the center pillar area. ...... Now the easiest way is to rewire a power connection off the ignition to turn on amp. you can get this done at a stereo shop . if not once you have access to conection you can clean out and silicone spray so no water gets in. the reason why it was coroded is the cabin filter sometimes does not fit in correctly and water come in from outside through the cabin filter. ......... does this help you any. Mike
    Phew! That helps alot! I will have to find someone to do this for me. I might be able to do simple but this is beyond me. It might also explain why sometimes my passenger floorboard is moist. Thanks!
  • sambo64sambo64 Member Posts: 1
    i have a 2005 impala the radio looses reception when i use rear defogger the problem just started and seems to be getting more frequent
  • brobruciebrobrucie Member Posts: 1
    Thank you for that info, do you know if this is the same area where the connection will be on a 2000? I just noticed the seatbelt buzzer not working and payed it no mind then the radio started fading in and out, i started to buy a new amp that is how i ended up on this site. thanks for sharing this info.
  • topless75topless75 Member Posts: 1
    Hey guy! I landed on the site trying to find out how to fix my 2007 impala ss radio that keeps goin in and out. I've read along throughout your thread and your problems are the very same as mine so it seems to be an ongoing problem with these vehicles even through a generation change. I do have an aftermarket radio in which i had to install an additional harness to keep all of my factory settings (onstar, chimes, etc...). At one point i though it may have been the harness, which I've replaced one time, but starting to think it is the amplifier or switch that has been constantly mentioned. If ANYONE has any additional guidance on this problem, PLEASE let me know! Eventhough I have 2007 it may actually be the same problem and switch could be in nearly the same location but i AM UNSURE!!!!!! Thanks in advanced!
  • lovemasterlovemaster Member Posts: 1
    GOT A 2000 CHEVY IMP. RADIO WORKED WHEN I BOUGHT IT A FEW MONTHS BACK AND NOW I GOT NO SOUND .. SOMETIMES IT WILL PLAY FOR A ABOUT A 5 MIN THEN GO DEAD AGAIN.. ALL THE LIGHTS AND CLOCK ETC ARE WORKING. WENT AND BOUGHT ANOTHER RADIO TODAY AND PLUGGED IT IN AND GOT THE THE SAME THING.. ZIP. THERE IS POWER GOING TO THE AMP.
  • wayniac67wayniac67 Member Posts: 12
    This is how my problems with my Chevy Impala started and it was in the summer ,so the cold had nothing to do with it, First it started with radio not working sometimes,then radio would stay on when door open and have to manually turn it off,rear defroster quit working,chiming when you take key out,then my battery started going dead,A 2008 car,a new car that I am paying 450 dollars a month on and of course that started when all I have left is a power train warranty! I bought it because my used car was breaking down,bought a new battery ,still went dead,The dealership was no help,I am not letting them look at it since they will charge me who knows what even if its something minor! I have a brother who is a mechanic ,hope he can find out the problem,I am furious,Have always been a Chevy lover but the love is slowly fading! :mad:
  • pdcardriverpdcardriver Member Posts: 1
    Hello - I have a 2006 Impala 9C3 (unmarked police car) that has an issue that's driving me insane. I am trying to listen to my Sirius Radio via the AUX jack - it has been working fine for a year, now all of a sudden the radio is switching from AUX to FM for no reason (no one is touching the band selector switch). When I hit AUX it tells me NO DISC (it's also the CD) it will not stay in AUX mode. The FM wireless transmitter is nothing but static, so this AUX mode was perfect.
    Any ideas? Thanks in advance.
  • chevyjunkiechevyjunkie Member Posts: 1
    ok i have a 2004 impala ls. when i bought the car it did not have a radio in it... the owner was in the process of replacement when i got it. it has the stock amp and i bought a sony X-plod. all the wires are correct as to the diagram that came with the $100 interface. there is full power to the stereo but absolutly zero sound!!!! what is the fix! im goin crazy!!!!
  • impalaguy89impalaguy89 Member Posts: 1
    Make sure you hook up the blue wire coming off of your harness to the blue/white wire on your aftermarket radio. That should fix the problem. :-)
  • johnboy87johnboy87 Member Posts: 1
    i have an 01 impala LS. the radio started fadeing in and out now i have no sound at all and i noticed that the door chimes dont work either. help please. could this be the same problem?
  • sjm123sjm123 Member Posts: 1
    does anyone know how many watts the stock stereo in this car is?
  • decibelstalkerdecibelstalker Member Posts: 1
    Too much bass is bad. It makes other people want to kill you when they are sleeping and your car comes down the highway buzzing like a boiler ready to explode. Think of the damage your loud bass is doing to your ears and your car. The windows are subject to extreme vibrations. All the sheet metal welds are being stretched and weakened from sheet metal vibrating up and down at tremendous speeds. All screws and bolts are loosening from the low frequency energy surging through the cars interior and exterior fasteners. Eventually the speakers themselves start to fail. I think your teenage kid borrowed your car and drove all night long with the audio at max and full base. My car only driven by me sounds great. No problems with the bass. I have a 2002 LS Impala. Its like when walking and not picking feet up. The heal off the shoe wears out. Notice the Chinese made shoes have no heal but have support on inside of shoe. Still people wear out the heal of their expensive Chinese shoes. They even curve the heal up to limit the wear factor. But still people wear the heal out. Your radio is worn out from not using it correctly. You may be going deaf and cranking it up too loud all the time. Ever had an audiology test?
  • pb219pb219 Member Posts: 1
    Hey I'm having the same problem in my 07 impala police package. Getting real frustrating. Just wondering if you've had any success with a fix? I've tried everything I can think of. Thanks!!
    I gave up on my 2005. I bought a $5 bypass online and it did not work. I cut the wires and matched the diagram here and it did not work. I am not handy enough to run new power lines so I just have my mp3 player in the car.
  • mike699mike699 Member Posts: 2
    2007 Impala, sometimes they work sometimes not ???
  • billz1967billz1967 Member Posts: 2
    I've been reading a lot of the posts here on the fading in and out of the stereos in the Impala. I have the same issue...have had it into the dealer four times...and they still can't figure it out. They tell me that they don't hear what I'm heraring. They've replaced the stereo...they've supposedly checked the antenna wiring..they've replaced the antenna module...and is still has the same problem. I haven't seen where any models past 2007 have had this issue? If you have...have you found a way to correct it? This fading in and out is really driving me crazy! Need to find a solution or get rid of the car!
    Have you been in touch with Customer Assistance regarding this concern yet, billz1967?
    If you would like for us to check into this further for you, please email us at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation so far).
    Sarah, GM Customer Service
    Sarah, sorry I didn't see your message earlier..but, I have had it to another dealer, Jim Butler Chevrolet in Fenton, since the last post. They replaced the back glass with the antenna in it, replaced the amplifier again, and replaced the coaxil cable. None of which corrected the problem. Jim Butler said that GM has closed the case and I would have to talk to someone in Consumer Affairs. They gave me the number 1-800-222-1020. I have to talked to two people at GM Consumer Affairs, Terrance on 4/10/13 @ 12:15 pm, and Amanda 4/22/13 @ 11:00 am. Both times I was told that I would hear back from a District Specialist of GM within 24 hours. As of to date...I still haven't heard back from them. This problem with the stereo has become a complete and utter nuisance! My brother has the same car, a 2012 Impala LTZ, and has never had any issues with his car. He's the one that talked me into purchasing my car. I wish I could say the same about my car. I have owned many cars through the years and have NEVER had a problem like I am having with this one. I would sincerely appreciate a call from the District Specialist, as promised, and would like to get this problem resolved once and for all. I have waisted way too much time on this issue. Thank you for your immediate attention to this matter. If you wish to contact me, you can do so by emailing me at billz1967@yahoo. com or at bclickcustomhome@sbcglobal.net..or..you may call me at 314.402.0089. The last four digits of my VIN# is 1521 Regards, Bill
    Bill,
    I've responded to your post through email. I look forward to your response.
    Amber N.
    GM Customer Care
  • chillydogchillydog Member Posts: 1
    wondering what the resolution to the radio problem was as i also have this issue with my '12 impala ltz. the local dealer replaced the radio but still terrible reception
    Hi chillydog,
    I'm sorry that you're still having poor reception even after the dealership replaced the radio. If you'd like for us to try and help with this situation please contact me by email. I can be reached at socialmedia@gm.com [attn Amber].
    Amber N.
    GM Customer Care
