Still trying to figure out if the 12 disc Delco CD Changer (like the one on the MNR web site) will work with the UPO radio (CD/Cassette). I've e-mailed MNR to see if they can provide any info. I'll let everyone know what I find out.
I've also figured out why the CD Changer harness isn't an option here in Canada. It's automatically installed in ALL 2001 Impalas. I checked a base impala yesterday at the dealer and the plug is there in the trunk. Brad
(Cross-posted to the Impala Accessories & Modifications forum... though I'm unsure why we're discussing the CD Changer there and not here. )
FWIW: I just got an email back from Chuck Hutton Chevy (www.gmpart.com). They're asking US$332.88 for the 12-CD changer (part #25708970), which includes shipping and is tax-free (unless you're in TN--I'm not.) There are none currently in stock, but they can order it. The price is 15% off of the MSRP ($391.62) -- I wonder which price my local part dept will quote me?
I'm still unclear whether this is just a "plug and play" installation using the wiring harness that comes installed with the UP0 radio or not.
OK, on reading the manual for moving clock ahead one hour this past week, found where it says skipping will generate an error message of "err". This is not what I see, instead, the entire unit blanks out as if the power has turned off. This goes from 1 to 3 seconds, though yesterday I had to actually hit the power to bring it back on-line.
Anyway, I have a service apt. for next Wed. morning as I think an internal short in the CD unit is the culprit, just wondering who else, if anyone, may have experienced this.
Never heard of cd's skipping except from you. Roads here in Michigan are pretty bad, particularly in the spring, and mine's NEVER skipped in over 7000 miles. I think you have a defective unit.
it took a little more than your normal install. first it required a "Headunit relocation kit" i got that from www.metraonline.com Or have your local stereo shop order it.
thus i mounted my factory headunit in the trunk on the drivers side to the side of the 6x9 (you see in the pic)
i mounted the amps one on eachside on the fold down rear seat (also in pic) i threw in a 1/2 farad capacator to aid in the power of the amps.
i have 6.5" jlaudios on the front kick panels, and 6x9" jl's in the rear deck
Hello once again, I posted a while back that In the accessories and modifications thread that I was going to do some audio upgrading to my 2001 Impala (Sandrift metallic). I thought yall might be intrested as well.
After many conversations and decisions on this particular subject with my installer friends, it has come to actually buying new equipment and choosing my installer. I am currently planning to have this stereo upgrade completed in early July. Yes, it will take some time as I have to work at my real job and can't just take off to do it.
The component list if you are interested in attempting this modification is as follows:
Please be advised, this component list is not for the budget minded!!! The components are very expensive and in designing this system I have a very strong lean towards sound quality!
Front speakers- Focal 165 k2 Rear speakers- Stock Subwoofers- JL audio 12" (2) Head unit- Stock w/line converter Equalizer- Precision Power DEQ-230 Amplifiers- Lunar L100 And Lunar L200 (crossovers are built in) Misc- Stinger power and audio cables
As configured for 4ohm stereo the amps give me a total of 200watts for front and 400watts for subs. These amplifiers are very conservative in their rated power at the 4ohm rating. They will actually be pushing a bit more power than listed here.
At this time I have found that in the front doors, you can mount a mid/bass speaker that has a mounting depth of 3.5 inches with no modifications to the door (I would recommend no more than 3" depth to be safe to clear the glass when rolled down),and a speaker size of 6" but you will have to probably modify the speaker adapter present. The location of the speaker and tweeter is pretty good from a sound stage standpoint. The door will be sound deadened with several materials, to prevent resonance’s coloring the sound.
That is all that has been decided for now. The amps are ordered and on the way. The rest will be gotten a bit later just before the end of June and then the car goes in for install in the first week of July. Until then I may not have many updates.
I may put up a web site detailing the whole installation process, with pictures and the like. If you want more info.. I will be here to answer any questions. Thanks and have a great day!
What good quality speakers do you recommend for the front? Do you know if the 6 1/4" Boston Acoustics will fit? I heard the front factory speakers are somewhat "off-size".
Well, I have heard allot of speakers in my 12 years in car audio and have been impressed by the following brands. MB Quart, Canton, Boston Acoustics, Alpine, Focal.
Now, the real question is how much are you willing to pay for a good quality sound. All of the above are very good quality.. And accordingly have very good sound characteristics. It really comes down to what you like vs. what you can afford. I recommend listening to the speakers at the dealers shop. But keep in mind that what you hear in that shop is the best case listening environment. If you keep that in mind that you are actually going to put these into a car.. the whole thing changes. Specifically the off axis response will change. So.. when you listen to these speakers.. find the sweet spot.. then move back a couple of steps. (this simulates an off axis placement). Then move forward a couple of steps.. note the size of the sweet spot. (Count how many steps you take both forward and back) This will give an idea of the size of the off axis response.. the wider the zone.. the better.. the narrower the harder it is to make the speakers sound good in a car door.
This is how I test for speakers I would use in a car.. It is really up to you as to what sounds good though. A super high priced set of speakers does not necessarily mean you will have stellar sound. So, I cannot recommend any one brand to you. But I can give advice on what you should listen for.
As far as speaker size for the front doors. They are a bit off size but not so much in size as the angle at which they are mounted. If you don't want to modify anything.. Then I would stick with a 6" -1" tweeter separates. Like what is currently installed. A 6.5" can be fit in the location but you will have to modify to mounting and possibly cut a bit to give the diameter you need and you may have to mount the tweeter in a different location. This should all be possible with a good installer. If you decide to have them installed take your time. Find a installer who will talk with you and voice your questions. A good installer will point out the obvious as well as tell you what can be done with a good modification. If they or the person you are dealing with wont do that.. DON'T DEAL! Move on to someone who will take the time to answer your questions. The more satisfied you are with the people.. the better you will feel and the better your system will sound!
Sorry for the long winded reply.. I seem to get carried away about one of my favorite subjects!
What if I decide to replace the front speakers with Boston Acoustics and at the same time, I want to keep the factory tweeters. Is that possible? Is there any space for both...6 1/2" speaker plus the 1" tweeter?
I called around and I was told that the OnStar system is plugged into the same socket that the changer harness would have been. So if you use a aftermarket harness, you can't have OnStar.
With that in mind, I tore apart my console to take a look at the back of the radio. Unfortunately, because the radio is above the climate controls, I really couldn't see the back of the radio. It looks like there are two plugs in there. I'm working on a How-To page on removing the console.
I took a multimeter and probed the CD connector in the trunk and got 12V.
Has anyone else measured the connector? Pinouts can be found on my page.
Chris e-mailed me about another connector in the passenger compartment. It's in the same location as the aux power connector, but it's behind the carpet. It has five wires coming out of it. The same color codes as the ones in the trunk changer connector, minus orange and black (12V and ground).
I disconnected the battery (better safe then shorted) and used a wire to jump the orange-black wire and the green one. I got continuity in the connector in the passenger compartment. I pulled the jumper and re-checked. No continuity.
This means that while we do get power at the trunk plug, it's likely that the audio and data lines are not connected to the radio.
I am getting the feeling that you can get either OnStar, or CD changer, but not both.
I e-mailed Chevy on this, but so far nada. I'll post a photo of the connector on my page in a few hours.
That sounds fine with me, I have the 2k and don't have onstar connected, this of course doesn't help those with a 2k1, I'm still waiting to hear from the real world guys at Hutton radio shop to see if this is a possibility.
On a different note, I was posting on the big Impala board because what I was talking about seemed like it would be information the board as a whole might be interested in, instead some people think you shouldn't mess with anything and GM makes no mistakes, or that what's good for the masses is good for everyone. Many people were very satisfied with their 2k stereo amps, many were not, I was dissatisfied and wanted something better. I didn't appreciate the comments of someone acting like I'm some punk who wants to go Boom boxing down the street. And even if I did, who gives a rats pitootie? I appreciate the efforts put in by you to find a solution to this issue, I've already spent over 500.00 trying to come up with the right combination, granted I keep getitng credit from hutton for the changers that aren't right, but I still have to go to the trouble of sending all this stuff back.
While I personally don't notice a problem with the Impala radio, I do see room for improvement. And even if I thought it was the best system ever, I realize others may feel differently. People buy $30K+ trucks and take them right to the shop to add the lift and monster tires. It's their money and it's their truck. Whatever makes them happy
There was one Impala owner that ripped out the whole stereo and replaced it with a $5K system. Unfortunately he took his page down. Then there is the other owner that dropped a blower into his engine bay. Something about needing a little more power.
I may not see the rational behind these modifications, but I can be (and am) impressed by the amount of work these people put into their vehicles. People think (read that wife, parents, co-workers) that the time I put into maintaining my Impala web page is silly. But I enjoy it, and that is reason enough.
GM has to build the car for the masses. It's up to each owner to make the car fit them. Some people see the car as a tool. Point A to B. For others, it's a reflection of their personality. Be it low pro tires and rims, spoilers, blowers, radical paint jobs, booming stereo systems or even a bumper sticker or two.
And on the radio issue. Most of the time I am toodling along, just listening to the radio. But sometimes I want to pump it up and better speakers, upgraded amp and a CD CHANGER would be nice to have.
I upgraded the page again and added a CD Changer How-To page. Haven't figured out the changer issue yet, but I posted photos of the connector in the passenger compartment.
Hunter, if you don't have OnStar, you can get an aftermarket harness and run it from the front to the trunk and not use the factory harness. Check out M&R Electronics on the Accessories page. There is a link directly to the Impala stuff.
I thought it would still interfere with the rds system, that's why I wanted the delco changer so it would be compatible, supposedly. I don't know anymore and the whole thing is frustrating. I might just take my ball and go home...
You're getting to the point where I am. I spoke to so many different sources and kept getting different stories. I finally spoke to a guy at my local Delco authorized service centre. He said he has successfully installed the Delco 12 disc changer in an Impala, but it did require a special harness. By the time all is said and done he said it could cost upwards of $800. Too rich for my blood at this point. I think I'll just have to get used to carrying a wallet of CD's! Brad
I have been following the conversation; I would like to chime in on this as well.
In all I have read in this forum, the prevailing complaint is the lack of information on compatibility with after market items as well as GM endorsed products.
I for one am in this same situation with my "Audio upgrade". I am keeping the stock deck and upgrading everything else. The problems start with "how do I integrate the features of the radio" with the rest of the system? Will my onstar system still work? And finally.. can I get a cd changer to work with the deck that came with the car. I regret to say I do not have any firm answers on these issues as of yet.
I will in July. I will be completing the install on my Impala at that time. I think (my opinion) that if the consumer base would look at the big picture of after market items they would like to use (during the life of the car), they would suddenly realize that for what they buy in a car.. it should support anyone's ideas of what to add.. (car audio, engine enhancements, performance suspensions and the like)instead of being locked into a proprietary design. I currently see a trend of the automakers offering more features but to get them they "build in" to a point that you cannot work around the features. That then becomes allot of people's problems.
Like in the case of my audio upgrade. I like the radio deck that is installed. I would like to keep it for the features. The only problem is that the deck does not include a set of "line out" speaker outputs. So consequently I have to use a speaker level to line out converter to run the signal to my amplifiers. This is not optimal. As line level signals would be very much preferred. This "feature" of line level outputs would simplify allot of aftermarket audio upgrades. And it is not that hard to do.. (AC/Delco do you hear this, you have offered this in the past why not now?)
The CD changer issue, boy what a topic.. If the consumers would just stand up and demand from GM/Chevrolet that we need more information. (I know, easier said then done), but if we call the appropriate people, we might eventually get there. And I must say this group had gone a long way's to try and get that information. And I say keep pounding on them.
I would like to see the issues resolved myself, as I would like to use the factory radio/cd changer in my system. But I suspect after my initial run on this.. I will have to replace the radio/cd player to get better sound quality.
I guess my main gripe is that the cars being built now include more features, but in getting those features you are essentially locked into a one-way street. I would like to see a progression from this design to keeping the added features but make them so they can be used with other things instead of proprietary designs that can't be interfaced with anything else. Repeat after me, EXPANDABILITY with out limits!!
I posted this here almost 2 months ago: ********************************************** "#400 of 422 DURAFLEX - Future Audio prediction by duraflex Mar 17, 2001 (05:58 am)
Prediction: MP3 car audio players.
MP3 is an audio compression algorithm that is pretty incredible.
Basically, you can get very near CD audio quality in about 1/10th the space of an audio CD file.
One conventional CD disc can easily hold well over 200 tunes in MP3 format ! ! ! That's over 10 hours. Imagine the possibilities.
For those considering a trunk mounted CD changer, perhaps a combo MP3/CD player may be available in the not too distant future. "
PatHOST quickly added that MP3 players are already being made.
MP3s recorded at 128kbps are almost indistinguishable in audio quality from a conventional CD unless you have a great ear and are listening on an excellent full fidelity system.
Nice work, Nathan! I wish I knew who the manufacturer was (am I missing it or is it just not there?) I'm guessing you'll let us all know when you hear back from Crutchfield about compatability with UP0/OnStar, right?
Also keenly interested to hear how this puppy hooks-up, since you've learned that the trunk connector terminates near the glove box. I *strongly* want to avoid another FM-modulated changer if possible. 6 years with a JVC FM unit in my Grand Prix was plenty!
as usual of course but I thought we couldn't use an FM modulated unit in this car because of RDS? Hell I'd have just used the system Hutton sent me and lived with the extra controls at this point. I haven't sent it back yet so if you have more news about this Nathan I'd appreciate it. Frankly I'm tired of going thru it all, it has been three weeks of frustration and I don't need anymore
I was unaware that an FM-modulated changer would interfere with RDS, or vice-versa. My beef with going the FM route was primarily due to my experience over the past 6 years. Even though I monkeyed with the gain setting on the transmitter, there was always a noticable hiss in the background. Made my CDs all sound like they were dubbed onto tape.
My comment was because I was really looking forward to having a hard-wired changer that I could operate directly from the head unit (or steering wheel controls). The sound quality would have to be better, and not having an extra control unit in the cockpit would be a huge plus too. Win-win. I wasn't aware that there were RDS-related issues that I should have considered, and I'm not implying that modulated units *are* compatible with RDS-equipped radios. As Schultz used to say, "I know nothing!"
I haven't returned the 10 disc changer I got from Hutton yet and it looks like if it will work (and My installer says they have done many and they work fine)I'm just going to keep this one and have in installed on Thursday. I've had enough. I was not unhappy with the last FM modulated system I had and it was a cheapo, I'm hoping this Delco brand is better still, I guess I'll find out huh?
The RDS (Radio Data System) encodes data and is transmitted via subcarrier frequency. The RDS radio strips this data from the incoming signal.
Since the FM modulated changer is set to a specific frequency, the only problem I can think of is that when you are using the FM modulated CD changer, RDS may not be available.
My only experence with this was a $15 adaptor that took the signal from my MD player and converted it to a FM signal that my car radio could pick up. Because there was no direct connection, I would lose the signal from time to time. For the changer, do you plug the antenna into the changer then plug the changer into the radio?
My JVC 12-CD FM changer was as you've described... the antenna plugged into the modulator, and the modulator plugged into the radio. Besides the hiss I mentioned earlier, having the modulator in the antenna circuit also cost me *ALL* of my AM reception. Every frequency in the AM band is blanketed with noisy static.... even when the changer is off.
It's entirely possible that this was a JVC-unique problem, or an installation error, but this is the only modulated changer I've ever had, and my experience hasn't been all that good.
first off... anyone who will splice into the antenna to install a cd changer is NUTS! poor sound quality, listen to the difference between the radio and the cd, same thing there. if you gonna do it, do it right, you HAVE to relocate the factory head unit! no other/cheaper/easier way around it. as you'll see here
www.memoryseller.com/pics.htm
i took the time and did it right. and still maintain all the functions of the on board computer. to reset the change oil light, i just reach in the trunk for a quick second. thats it..
What about those people who say anyone who spends money to upgrade a working sound system is nuts?
The FM changer is a perfectly acceptable route. If you have a lease vehicle, a FM changer can be easily moved from vehicle to vehicle. If you are on a tight budget, you can have a CD changer for under $300. How much does it cost for a new head unit, compatible CD changer, and associated harness/cables?
Sound quality is subjective. I used a portable CD player with a cassette tape adapter for years and I was perfectly happy. Some feel that records produce a warmer sound that is superior when compared to CDs. Some think the Impala's "premium" amp is a paperweight and others don't have a problem with it.
I paid for the radio with CD and cassette and would not replace it. Among other things, I would lose OnStar and my steering wheel radio controls. In addition, to me, replacing the working head unit is like throwing away $500 (the cost of the radio itself).
I wouldn't take the path you did, but my circumstances and priorities are different from yours. You have decided to invest the time and money into something that is important to you. I can admire your effort and results. At the same time I can appreciate the decision of the individual who uses a FM based changer.
The e-mail I got back from Chevy about the CD changer said they didn't have any technical information about the Impala and I should talk to my dealer. Like the dealer know's all...
Why is it customer assistance if they can't assist a customer?
Well my installer says they do it all the time, so I guess I'll just wade in and see what happens, I get crappy AM reception already so i don't know if it will be worse or what. If it';s the case I won't be able to listen to Jim Rome anymore... Oh well
I have a problem with just one FM station - 92.5 WXTU out of Philadelphia. Unlike every other, there is a delay before its signal is heard when I hit its preset button. (ALL others are heard instantly.) When I am listening, the sound will drop out for a fraction of a second. Any guesses?
Mine was that the RDS radio is searching for an ID or other update.
I am NOT in a fringe reception area and no othere station does this.
Would someone with a 2001 IMPALA TRUNK AMP please post the MAKE, MODEL and REFERENCE number on their amp as well as the build date of their car (on open edge of driver's door).
Duraflex--amp specs. for my Impala with build date of 12\20\00 as follows: Model # 10309548 Serial # 569074 Made 12\00 Made by Matushita Communications Industrial Corp. Made in the USA of foreign and USA parts Please indicate any difference from yours.
Lance- I have the RDS radio with both tape cassette and CD player? Do you? Your car is a 2001 model - right?
My car was built 01/00. My (bypassed) amp is also a Matsushita but apparently NOT the same as yours. It's curious that your newer car has an amp with a lower (earlier?) model number.
Mine is: Model No. 10432572 Ref No. CY-BG2911ZC Serial # 331780
Does your amp show a REF. NO.?
I disconnected my amp 11 months ago because it ruined the sound.
Supposedly, later units sound just fine. I have yet to hear a 2001. How does your unit sound?
My 2001 Impala (build date 09/00), according to the model numbers, still has the _old_ amp, so it has apparently been changed in the middle of the model year. Assuming the amp is the determining factor, now I'll have to find out whether they're compatible (i.e. could I upgrade to the new amp easily). Better yet, have Chevy pay for it - although I don't know if I have a case for that, what do you think?
Is it possible that changing the amp within a model year could be interpreted in a way that there's something wrong with the old amp? If so, I'm thinking if it's possible to talk Chevy into changing the old amps to the new ones under warranty... Who knows.
I believe Roderacer just arranged for his LS to be picked up this Saturday, and I'm expecting to get mine on Saturday too, so one or both of us will have 4/01 or 5/01 build-date cars and can let you know what the brand-spakin'-new Impalas are getting hooked-up with.
The new Delco 10 disc changer is now installed in my Impala, in the trunk on the right side of the trunk on the floor, it seemed to me the least worrisome place to put it. The sound is fine, no problems so far, I came with a remote but they did put the wired control just under the a/c switches, I can mute it and control the volume from the steering wheel but can't change discs, not a concern for me though. So far I'd say I'm as satisfied as I'm going to be.
I'm curious about a fix on that amp though, paid more for that amp and it's useless in the trunk, sounds good disconnected though...
On my radio cd unit(no cassette). Yes Duraflex my impala is a 2001 with a Dec. 20, 2000 build date. I am no audiophile so when I first listened to my system after reading the last 6 months of posts I thought it sounded fine but thought I must have a poor listening ear and not able to detect the poor sound. I questioned all passengers as to their honest opinions without telling them the background of the issue. They all thought it sounded fine. Not out of this world but fine.
Went to the dealer with questions about the new / old amps. After giving me a couple minutes worth of BS about the whole thing, I managed to get the service guy to actually do something. The model #s on the amps are real GM part numbers, but he could not find any information other than the price for the new amps - and the price for both of them, btw, was $216 - pretty steep. He didn't know whether the old amp could just be replaced with the new amp, i.e. if the rest of the system was compatible, but promised to find out and call me about it today. We'll see.
I'd very much like to switch to the new amp if it significantly improves sound quality. I'm not all that thrilled about the sound quality as it is now with the old amp, but not dissatisfied enough to spend over $200 to fix it. I know I could go for the bypass but I'd rather have it done "right".
Nope, didn't get around to doing that - I didn't have time yesterday to look at the new amp at the dealer any closer. We'll see what the service rep gets back to me with - if he does.
I'm thinking they must be compatible - they probably wouldn't have changed the other audio components in the middle of the model year. What then becomes the $200 question is whether an inferior amp can be considered as a defect or not. I'm willing to bet Chevy/GM will insist it's not a defect, but maybe if enough of us complain to them under a single case number and insist on amp replacements under warranty they might change their minds.. (Hey, I can dream, can't I? ;-)
Brad
any questions, lemme know
PS
Let me know if you live in Orange County, CA.
http://home.hawaii.rr.com/impala/
Brad
Ok, I can get off my soapbox now..
and questions lemme know, i'd be happy to help.
eric@masterlinx1.net
Model # 10309548
Serial # 569074
Made 12\00
Lance
Mine is:
Model No. 10432572
Ref No. CY-BG2911ZC
Serial # 331780
Your car's build date (on driver's door edge)
AMP MODEL NO.
REF NO.
S/N (on amp only)
Do the connectors look the same as on nathan's website???
http://home.hawaii.rr.com/impala/Amp_bypass.html
Car build date: 12/00
Amp model: 10309548
Ref no: CY-BG2911ZC
S/N: 562718
Mine is the same as Lance's.
Dave
build date.
Lance
The Model numbers you both posted are different than mine.
I am going to request your model number as a replacement for my amp which has never worked right from day one.
Are they the same?
If so, I would bet dollars to donuts they could be swapped out.
That 2000 "amp" is a $200 doorstop in my book.
