Visitor Agreement.
Thanks for the excellent info on the pillar speakers. Where did you put the external amp and did you amp all four speakers or just the rears? Are your connections to the back of the factory radio or by the speakers? Sorry for all the questions but you really have me interested to start this project.
Thanks, Al
Good luck with your 2002 Honda Accord, you'll need it
I installed the external amp in the trunk on the driver side. The Taurus/Sable use the RCU (rear control unit) for the radio operation. If you lift the trunk material away from the body on the drivers side you will find the RCU mounted on the wheel well. The driver side worked out well as the amp is near the RCU. I used a 4 channel amp and "repowered" all four speakers. If you only want to repower 2 channels I would suggest the fronts. By powering the rear speakers more than the the fronts you will loose the "soundstage". Kind of being at a concert and standing with your back to the stage. For me it isn't natural to have the music coming at me from the rear. The connections are another story! I have auto climate control so there is no way to add an aftermarket stereo to the dash. To keep the dash in tact I used line output converters (LOC) at the RCU. This requires CUTTING the speaker output wiring from the RCU and wiring in the LOC. This effectivly reduces the speaker level outputs to preamp levels. These preamp level outputs in turn drive the new amplifier which in turn powers the speakers. The cutting and hookup of a new amp is not as scary or difficult as it sounds BUT there are some phases of this operation that will make you swear and swear and swear some more! Namely running the new power wire for the amplifier. You will have to run a 4-10 gauge wire(depending on the power of the new amp) to the battery to power a new high power amp as the existing wiring is too small to supply the required power. Without new wiring you will induce noise into the system and overload the factory wiring. To get the new wire into the engine compartment requires going through the firewall. I did not want to drill through the firewall so I had to find existing holes from the factory. To do this you have to remove the parking brake assembly and the fusebox to get at the fasteners that hold the carpet down. While this isn't difficult wait till you try to put the fusebox back in!!!!!!!! It took me an hour of playing around with different angles to get it back in. After the carpet is out of the way you will find several rubber grommets that can be pierecd to feed the new wire through. Use a small gauge wire to fish it through and then wrap the small gauge wire to the larger wire to aid in the process. This was the first real pain in the butt! The second was if you elect to run new wire to the speakers. I did because the factory wiring appeared far too small to handle the new current. Let me say at this point that I do not do this for a living and this was only a DIY project. I did get help from people on the alt.audio.car newsgroup. There were several posters there who said that using the factory wiring was sufficient. Anyway, if you elect to run new wire the rears are easy the fronts are a nightmare! If you open the front driver side door you will see that Ford uses a hardwired pin connector to attach the wiring from the door to the body. To run new door wiring requires the removal of this unit and either adding new pins to accomodate your wiring OR drilling out two blank expansion slots and fishing the new wire through the holes. Either way it is a pain and will give you a new appreciation for audio installers. No wonder they are all in their early twenties! If this hasn't scared you off yet please let me know and I will post the rest of the install for you. Please note a couple of things. 1) The system that I installed sounds better than the MACH factory system! Beautiful highs and plenty of power for an aging rock and roller. 2) It sounds very clean except for an annoying pop when you turn the system OFF. This is caused by a delay in power turn off built into the FORD circuitry. I'm sure there is a solution I just have'nt found it yet. The pop isn't loud and from waht I have read and been told is not harmful. I'm a perfectionist and I want it gone! 3)The cost was about $500 all totaled including wiring and connectors. Much of the system was purchased on e-bay at lower than retail prices.
Scott
I just bought a 40gb mp3 Nomad music jukebox with 10000 songs at the drop of a hat. No place to plug it into my system! I am using a wireless FM transmitter for now but does anyone have any input on how I could splice in an input jack to plug in my mini portable and have excellent sound quality?
Also, there are a few brands: Weatherflecters, VentVisors, maybe others. Anything to recommend on that score?
TIA, rob
Three rebuilds in few ten thousand miles means that rebuilt were made unprofessionally. Important thing is to find the professional transmission shop (looks at
http://www.atra-gears.com/ ).
What about Accord - I never considered it seriously. It just looks wrong, and the new Accord is the same - plain vanilla. Is just not good looking car - too much boring even by Japanese standarts.
Passat actually qualitywise is no better than Accord or Toyota but costs a way too much higher and is less reliable. Quality of interior is not higher, it just looks as a high quality. And after all it is not a big car.
So good luck with your choice but it doesn't mean that we all have to drive Accords or Camries.
Good Luck
I'm just thinking out loud here, but if you could get that to work somehow, you'd have a direct connection to the head unit and use the controls on it. Hmmm. Might not be worth it, but the capability is there in your car already if you can use it. The Taurus wiring diagrams volume of the service manual has the info you'd need (though maybe not the logic specifics--I forget).
Wonder if the guys at Radios and More (www.radiosandmore.com) can help. They are who I bought my changer from. They are up on the technical stuff.
As far as posts about Taurus transmission or other problems, new or old: With any high volume car like Taurus or Camry or Accord you are always going to get some who have had problems.
Unfortunately, the only data accessible by the average consumer is the Consumer Report data, which also has it's own problems, as the data can only be obtained from it's readership database, which can also be highly biased. Also, CR's survey questions regarding reliability are too open ended, in my opinion. But CR is another subject. Taurus, in recent years has been rated by CR as having average reliability, so it is not "bad" compared to others. Also, since all vehicles reliability has improved over the years, "average" reliability is also much better reliability than "average" was a few years ago.
When you throw in the Taurus low purchase price, it appears to me to have a good combination of price/performance/reliability. Yes, we likely all will agree Taurus depreciation is high, but that subject is related more to how long you keep your vehicles, and comparing the total depreciation loss can vary greatly depending on the time period you keep your cars.
PS Yes Badgerfan is a University of Wisconsin fan.
A loaded V6 Camry with similar options is pushing 30K on MSRP and could probably be had for about 26-27K. Toyota is only offering 4.9% financing for 60 months in the Boston area.
Figure that the out the door cost difference between the two is conservatively about $7K, plus add in the extra $2200 in interest you'd pay on the Camry over 60 months and the savings is close to $10,000. Unlike depreciation, this is real money in your pocket that you don't have to pay out either in a down payment or in monthly installments on the loan. I'd be the first to admit that the Camry will likely be more reliable say 5-10yrs out, but is that reliability so much better to warrant a 10K premium up front? Am I likely to incur 10K in repair costs over the life of this car? The answer is a pretty resounding no! Throw in what I would argue is a better looking car, and the Sable wins hands down.
Final note is that when I bought my Sable, I didn't see many of them on the road. Now, two years later, I see them all the time. Looks like the word is out!!
By the way, I see some rage in this board against posters bad-mouthing the car, and I want to say that while I am embittered about my experience, I have no agenda in mind. Put yourself in my position. The first FORD I bought - a 74 new Mustang besides being in the shop for 11 weeks the day after I got it for a power steering hose that they didn't have a part for, had a leaky A/C compressor the very first year. And now some 20 plus years later I have A/C problems again. My 82 Jetta still has a working compressor after 240K miles (the Freon has leaked out but the compressor works) I was proud to buy American and would have still bought another Ford if they had Dearborn had given me some recognition for all my problems. My statement still stands-this company does not monitor defects as well as it should and try to fix them. It is there in the stats. Phil Ford has recognized the quality problems and hopefully will give them high priority. Nasser and his ilk simply concentrated on making money for himself and the company by cutting costs.
an auto shop told me today there is a kit for the Taurus with auto climate but I think they were confused.....the only kit I have been able to find for the 96-99 Oval is the ones with the 3 dials.
If it really slams back into first, that's not normal. If it noticeably bumps, that's probably normal. Or at least that is my understanding.
Also, the trans adapts to your driving style. If you drive gently normally, it will tend to shift abruptly if you floor it a few times, since that's 'new' to the trans (at least until it gets used to the new driving style). If you normally drive with a heavier foot, and then go easy, you may get mushy shifts for a bit. That adaptive nature affects the shift quality, shift points, and the bump back into gear when you give it gas when slowing down.
Given that, I am not sure there's anything wrong with edmunds2460's transaxle. It can be hard to diagnose over the 'net without seeing/driving the car, too.
I don't mind posters raging against the car on this board if it is legit.I come here to get some info, maybe help someone with an answer to their question etc. However, some of the raging just doesn't seem legitimate. I mean two trannies replaced in 68k driving highway miles! Then two posters ask for symptoms and 10 days after there is no response. makes me question the integrity of that post.
There have been some good post on the tranny in the last week or so. My biggest concern when buying this car was the durability of the transmission. This was my first automatic and I was aware of some issues with earlier model Tauruses.
As far as cutting cost, all car makers have done it. They need to to stay competitive.have you looked at the new Camry body? Looks pretty cheap to me.
My first tranny problem occurred at about 4,000 miles. I noticed when I was in first gear, either slowing to a stop or beginning to accelerate, the car would violently jerk forward. A couple of times I came close to rear-ending other cars, and once I came close to going through a retaining wall at a shopping center. I took the car to the Dealer several times about the problem. While I was having the Catalytic Converter replaced (at 5,550 miles), the Technician took the car out for a test drive, the tranny problem occurred to him! I was informed at that time that I could not have my car back, because of a tranny problem. I was told by the Dealer that FORD asked to have the tranny returned to them for trouble shooting. I am not sure that FORD really asked for it back... doesn't really matter. In December 2001 (40,000 miles), while on the Freeway, the car went from 4th to 3rd gear for no reason, and it remained there and would never go back to 4th gear. This time, the Dealer had my car for 1 1/2 months because the Regional Inspector that came to the Dealer to look at the Tranny told the Dealer that it wasn't a tranny problem, it was an electrical problem. The Dealer refused to accept the Inspectors findings. Tests done by the Dealer found NO electrical problems. After countless phone calls to FORD and 1 1/2 months later, FORD agreed to replace the tranny. Puts a sour taste in my mouth about FORD.
I hope this answers questions. I do like my Taurus. It is one of the most enjoyable cars to drive... especially for the price. Like I said in my earlier POST, I spend alot of time in my car. If I could afford a Luxury car, I would have one.... Perhaps a Jag?!
And, again, I forget when they started the adaptive transmission control, but the Taurus from at least '95 has it, as do most modern automatics from all companies. I'm not kidding--it does learn things like how much throttle you tend to give it when starting off, how hard you accelerate, when you lift, etc. These bits of info are used to figure out the best shift points and the way to engage or disengage the gears. Dunno if the '93s had this degree of electronic trans control.
And, just to play devil's advocate here, I think the newer cars are much better, in general. I have a '98 Taurus. The only non-scheduled repairs were a set of sway bar links (~$100 installed) and two high-mount rear stoplight bulbs (~$2). That leaves me $4898 in repairs to go over the next 54,000 miles... :-) (Not doubting you at all, but it appears that the 1996-up design has been more reliable. That, and all cars tend to deteriorate at least a little with age and mileage. That doesn't help you any, I know...)
And, as for Jaguar, they had a HORRIBLE reputation for reliability and quality until Ford bought them and invested millions in improving plants and quality. Strangely enough, Ford has improved Jaguar by leaps and bounds... (I am fairly sure the new Jag and the Lincoln LS share some of the powertrain parts in some models, including the transmission...)
http://images.prosperpoint.com/images/1714/86737-12910.jpg
Local shop says a company called METRO sells a unit that will do this, but I went to their web site they only have the version as shown in the picture for the previous post (non-auto climate control).
I just blew 500 bucks on a big mp3 jukebox and just need to find a way to get an AUX input with mini jack hooked into my system. I would be willing to get rid of auto climate to get it if its possible but I don't think it is.
http://www.crutchfield.com/cgi-bin/S-IOy3tF5juOd/ProdView.asp?s=0&c=2&g=42500&I=020FM200S+
I could be wrong but I believe that this is your only option
I don't like the fact it goes through the FM, but I guess if its my only option then it would have to be.
That little iRock transmitter I have is worthless in Metro areas.
Jeff
I would welcome anyone's experience with the air filters in the new Sables.Do they thoroughly screen out street and exhaust fumes? I currently drive a '92 Sable Sedan and am considering buying a Sable LS Wagon. I do mostly bumper to bumper inner city travel and in the winter, have set the dial knobs on the old Mercury to red/hot and turned the other dial to MAX A/C, since with the compressor running the air gets recirculated within the car and does not pull fumes in from the street. However, I have a circulation problems in my feet and they freeze. Most foreign cars allow you just to recirculate the air and set the heat to floor. This is not the case in either old or new Sables. In the 2002 LS- all computerized- I attempted to replicate my old strategy: pushed the button to increase the temperature to 80 degrees, but also pushed the button to floor ( yes it was hot), and then pressed the MAX/AC button and that cut off the heat and the temp dropped to A/C levels , although the readout still said 80 degrees.
If I thought the air filter worked, I could just increase the temperature in the winter and heat the floor, but I am wary...very wary...since Ford tends to skimp on quality. I would appreciate your experience and thoughts.
No worries for either engine from that end--chains last pretty much for the life of the engine.
What specifics do you have (last post) that Ford made specific improvements in the transmissions of 2k and later models?
You may want to have the garage that rotated your tires loosen and retighten the nuts to the proper amount using a torque wrench. Otherwise, it may be necessary to get the rotors machined and then again when the wheels are reinstalled, torqued to the proper level, which should be in any good mechanic's shop manual for the specific vehicle.
This came up in much much earlier threads. Concensus seemed to be what badgerfan discussed earlier, plus generally thinner/cheaper rotors these days on all cars that warp easier, and by Ford going cheap in 2000 by "de-contenting" the sable and taurus by eliminating the rear disc breaks on the sedans.
Solutions at the time were fight it and demand new rotors (good luck), bite the bullet and turn the rotors, buy aftermarket rotors that are more substantial and less prone to warping.
Doesn't sound like yours is too bad -- my steering shook a lot when breaking during any city driving at almost any speed.
Hope this helps.
Actually, rear disc brakes don't really add a lot to braking performance because as you say, front brakes do most of the work. This is true even on rear wheel drive vehicles, as the weight tranfers to the front during braking. Four wheel discs does give a marketing advantage, however.
Rotor warping isn't limited to Taurus, it seems almost epidemic to all new vehicles domestic and import, and is most likely due to attempts to keep unsprung weight down to the minimum, thus thinner and more warp prone rotors is the result.
Maybe it's the competitiveness in the mid size family car market and maybe the few extra dollars make a difference, but not to me. I found it annoying for example that on Ford's bread and butter family sedan, that all but one car on dealer lots that I looked at had the side airbag/power passenger seat/traction control bundle of options. One gold (ughh!) car had it, but lacked the Mach Audio. MSRP on that bundle was something like $390. For $390 more, on top of a 20,000 purchase, I would have loved having those options. Dealers and or Ford however didn't see fit to order/ship cars with this option. Similarly, rear disks and a semi-dual exhaust would have been worth another few hundred to me. Could leave these off the stripper, cloth seat/manual window versions, but on the alleged top of the line LS/SELs, you'd think the price point would be more forgiving. So much for family safety....
Also, given the leather seating option, why can't the factory and/or the dealer install a heated seat package?? To get seat warmers, need to go to the Lincoln line at much more $$$$.
