Visitor Agreement.
Is the car really not running well? Or is the only problem the service light?
If its not running well, we'd need ALOT more details to even venture a guess as to the problem(s).
1. Turn ignition off, press and hold the trip odometer reset button.
2. While holding the button turn ignition on (without starting the engine).
3. The service light will start flashing after 10 seconds.
4. Release the trip odometer button within 4 seconds.
5. The instrument cluster will produce a sound when the reset is complete and the light will go out.
*If the button is not released with 4 seconds, the light will not reset;; but it will stop flashing.
Also the compressor and the fan motor work independently but not together. Please adivse.
billhead
You can get it chipped for a few hundred bucks. Produces tremendous results on a turbo car.
Just don't go running it on a track until you upgrade the exhaust, though.
There are plenty of chip manufacturers. I personally had planned on going with upsolute on my T5 ... but never went through with it, and now the car is gone. oh well.
anyway, what i liked about upsolute is that you could get an option where they give you a remote control to change the program to either stock or boosted. I thought this would be great if you either lend your car out or use valet parking. I believe it was around $400-$450 for this particular setup. Just the standard chip without the remote is maybe $350-$400. I haven't checked their prices in a while.
I'm not sure about manually putting it up, but I'd imagine this would also involve removing the door panel.
Have you tried holding the switch and gently pulling up on the glass. Any result? Usually if the motor is just tired, you can get the window up this way.
They represent TME, which is a Swedish tuning co.
I had a bad experience w/ upsolute so I'm leery of them.
IPD is GREAT! Don't get me wrong. They do a tremendous amount of legwork for the volvo aftermarket scene, and their products are typically top notch. I just don't use them that much, personally. I purchased their stainless brake lines and some other odds and ends over the years. I just could never justify buying the more expensive stuff from them or even the common repair items (FCP Groton or alloemautoparts were much cheaper for the same stuff).
Did you have to mail yours out? The other advantage that appealed to me about upsolute is that there was a dealer near by, so I could just drive there and have him do it on the spot.
I had my service dept overnight a new one.
There are several causes of squeaking. Old pads, new pads, missing or broken retainer spring, lack of that pasty stuff the installer should put on the back of the pads, glazing, and probably other issues I'm failing to mention.
You need to hose off the calipers regularly.
Thank you for your help...
Jeannine Fallon
Corporate Communications
Edmunds.com
I'd have to say that's a throttle issue ... again. Its not responding to your inputs. If the ETM was just replaced several months ago, I'd go back to the same dealer and let them know you think you are having a problem with their replacement unit.
Yes, RPM go down and engine starts to stutter for a couple of seconds at low speeds. More specifically, if I am driving at more than 25-30 miles, I just feel temporary loss of engine power which corrects itself within 4-5 seconds -- and car starts to accelerate thereafter.
Differently, and when driving more slowly (i.e., after a complete stop) the engine will actually decrease RPM and it will be difficult to accelerate -- so that I actually pulled to the side of road..........
Separately, sometimes engine shuts down when I have no gear engaged (manual transmission). It also sometimes idles irregularly (between 800-1000 RPM) although not as wild as experienced two years ago (and when they changed throttle body).
Do you still recommend to go to dealership indicating issue with previously installed ETM unit (ETM was replaced free of charge in June 06 with following invoice indication: ETM was replace RO#247772)?
By the way can you direct me to a source to learn more about basic functionality of ETM unit?
If you search this board we are on now for ETM and ETS (the ETM is part of the ETS system), you'll find quite a bit of discussion right here.
Speaking of which, you may want to get yours cleaned and see if that fixes the problem.
If the problem is consistent (meaning the rpms ALWAYS drop when sitting still), I suppose it could be something like a vaccuum leak, but that would be tough to track down. Since the ETM is a known problem that crops up time and again on these cars, that would be the first place I would look.
But your suggestion that eddy4good search this discussion is a great one. Too often people don't think to do that and the "Search This Discussion" is a powerful and very useful tool.
Back aways in this discussion, I did repost some info from another forum on the ETS, though, so i'll leave it at that. Anything else I could post from another forum at this point would only support that same quote I posted. So we're good (for now).
Before going back to the dealer for ETM cleaning, is it usual that the dealer charges a fixed amount ($105) for each diagnosis (i.e., noise/malfunctioning, warning light, etc.) that I ask them to investigate? vs. running the clock on all combined issues and charging an hourly rate alltogether?
On a visit several months ago, I ended up being charged 2-3 diagnosis fees of $105 each even though I got some of the items fixed during the same dealer visit......
I addressed the issue with the service manager but he referred to their customs and a sign in their office stating the minimum diagnosis fee. While I can understand a minimum diagnosis fee for "looking at the car", I can't see any reason for such excessive charges. Are there any VOLVO service standards that would apply to each dealership?
I don't believe I've ever heard of such a high diagnosis fee and certainly not charging multiple fees for one visit.
The common practice I am used to is a minimum charge of a half hour of labor. Sounds like $105 is their per hour charge, so the diagnosis fee should be $52.50. Alas, each dealership is an independent business, so they can set their own rules. I suggest finding another dealer or an independent mechanic who specializes in volvos.
Where do you live?
Since the host OK'd it, I'm going to point you to a "database" of sorts where people have rated various shops and dealers. You just need to find your area in the list.
By the way, if you keep getting the light, I suggest replacing your gas cap. I had the light on mine on occassion when I first got it. As the car got older, it happened more frequently. Finally at near 100k miles, the light would come on EVERY time I got gas. So I paid $7 or so for a new cap online and never had the light again.
man, that's kinda scary, huh?
geesh... i dunno. If you had to unlock the radio, it sounds like it lost all power. So I'd be looking for a bad connection. Not to get you worked up or anything, but that would have me really worried. I'd be afraid to drive it right now without knowing what happened.
To the hosts: Please delete my discussion topic. I am sorry again.
Does anyone know how long is the airbag warranty for a 1998 S70 GLT?
Here is my dilemma:
In May 2005 (mileage: 104,000), the SRS light came on. Dealer said the code was 222 and said that the passenger side airbag was faulty and had to be replaced. Total Cost: $1,900.
Recently the SRS light came on again (mileage: 108,000). My mechanic pointed out to me and ask me to look at the driver side of the car. Printed out there was something about driver/passenger airbag and it stamped out Jan 2007. My Volvo was manufactured in June 1997. Does that means that my airbag is still under warranty?
Took it back to the dealer and pointed out the information by the driver said and they said that their computer says 5 years.
Can anyone in this forum help me out?
Thanks in advance.
The system needs to be inspected at the 10 yr mark, and replacement is sometimes in order.
Chintan Talati
Edmunds Inc.
Well, I doubt its the compressor because the compressor usually either works or it doesn't. I've never heard of a compressor working intermitently.
I can't give a definitive answer to your problem, but I can say I wouldn't pay $1450 to fix it. If nothing else, I'd be looking for a replacement computer from a junkyard, Ebay, or a cheap wrecked parts car from an individual seller.
