It's the one thing that really bugs my brother about his van.
"Galls me how STUPID, LAZY, People try to blame someone or some company for their stupidity and laziness."
The engine does NOT have to be running for the car/van to be shifted out of PARK! Chrysler was obviously just looking to save a few more bucks because of their dwindling sales! I never knew that I could do it in my former 300M until I discovered it accidentally one day. I was always under the impression that the shift interlock had been in place for years because most of my previous late model cars had it!
fastdriver
2) Was a shift interlock device required (i.e. by Federal safety regulations) on the 300M at the time it was built?
Is there a way to install one of these devices with an aftermarket product?
I too am often a cold callous person but to call someone "stupid" and "lazy" after hearing her head was crushed by a minivan is just plain heartless. Reality is intelligent people often do "stupid" things in the blink of an eye, and that's all it takes for a tragedy to happen.
By the way, do you think Ford was innocent in the design of their Pinto gas tanks or the tanks on their police-equipped Crown Vics that mysteriously exploded with the consistency of a Sammy Sosa corked bat pounding balls out of a park? The auto manufacturers are humans. And humans make mistakes. And humans often try to cover up those mistakes while their attorneys get paid to help them cover up their mistakes. If you live in a glass house don't throw stones.
I had assumed that it was the interlock that wouldn't allow you to move out of park unless you were pressing on the brake. Is that not the same? I check our 2002 GC and you must be pressing the brake to get it out of Park.
Common sense alone should convince most people to turn the ignition off when getting out of the vehicle and place the selector into Park.
No Shift Interlock is NOT a design flaw. Many of us prefer to have a vehicle without the Shift Interlock just as we did not like the feature in the early 70's where the driver's seat belt had to be fastened for the engine to start.
I have always worn the seat belt and the 3 point seat-shoulder belt but felt the early 70's feature was a nuisance.
If your questions are for me......
Chrysler told me NOTHING about the 99 300M except that they would fix the left drift BEFORE I picked it up! :-)))
I would guess that there is NO Federal guidelines regarding the shift interlock. As far as I can remember all my cars from 1979 had such an item and maybe even the ones before 1979! If there is no Federal guideline, then there certainly should be one so no one else will die!
hansienna-
Speaking of intelligent people and common sense, the car/van does not have to be running and does not have to have the key in the ignition for the gearshift to be moved OUT OF PARK and into gear! Thank God you don't design cars or do you work for Chrysler?
fastdriver
Would you happen to know if Chrysler was the only manufacturer without a shift interlock device until 2001?
fastdriver
http://www.safetyforum.com/interlock
http://www.khorrami.com/Cases%20Web/Chrysler/Chrysler.htm
fastdriver
Your sites are interesting, but I'd like to see some that a bit less biased towards getting clients (Primetime doesn't count a lot with me either).
There was a longer version of the whistleblower story here, btw:
Fired employee battles Chrysler (Ithaca Journal)
Thanks for the link. He seems to be appearing in a few newspapers.
fastdriver
I called a repair shop that said they could fix it, but it never seems to be broken when I have time to take it in!
So, here's my question: how hard would it be to pull the dash gauges and look for this loose wire/connection myself? Obviously, I would have to invest in one of the repair manuals, but I wanted to hear from soneone who may have tried this before. I don't want it to turn into one of those repairs that you get halfway into and realize you need a special tool that is only sold every other weekend at some parking lot in Detroit.
I have done some repairs to my vans in the past (radiator on my 88 Voyager) so I'm not afraid to tackle this if it's pretty straightforward.
When I started the Van, AC was not working, indicators were not working and the turn signals were also not working. I was wondering if any of you have faced this and if yes, how did you resolve this?
Thanks in advance.
Problem: rocker arm shaft broke where journal bolt goes into head boss; Because of 3rd party warranty coverage limitations, I need to understand more about how the damage could have occurred: head vs rocker arm (and/or components)
Question: which came first, the chicken or the egg? Could this type of failure possibly have originated in the engine head? With the head boss being a non-moving part, it just doesn't make sense to me that the problem could have originated here, which is what the warranty co is claiming - also stating that the breakdown was caused by a Dodge engine design flaw that is a very common cause for this type of breakdown - however, after speaking with several experienced Dodge mechanics - it seems that this problem is not very common at all. I have looked over the engine & from the appearance of the shaft where it is broken, it really looks to me like the shaft broke prior to the head boss.
Any help that any of you could provide would be appreciated. I have spent many, many hours attempting to educate myself on the workings of the engine - but, at this point, I need advice based on actual experience and/or engineering explanations regarding all possible and/or impossible scenarios. Thank you.
I had posted back in May about steering problems. That was fixed but now when I drive the van the air bag indicator light flashes on and off and a bell sounds.
The owners manual says it indicates a malfunction with the air bag control module
My husband is out of town again, that's why he bought me a newer van so we would not have to worry,,,,, anyone had this problem and knows what to do ????
I took it out tonight and it did not do the light show this time.
I called the dealership and was told it would be covered under warranty but had to get it hooked up to the computer to find out what the problem was. Our van is 2002 and I had read that the clock spring problem was in earlier models.
The service man I spoke to said it was an electrical thing and to be careful driving it,,, makes me feel good !
Now, I wonder if they would cover the AC on our 1988 Caravan with 196,000 miles on it? Too much to hope for? Oh well, you can always dream.
To the guy who had the bad transmission in '88...give us a break. If I'm not mistaken Chrysler is still the best-selling van in America. (And don't tell me it's because they're the cheapest because Kia stole that from them a few years ago). There's no sane person that would buy a D/C van if they were still having abnormally high transmission problems. D/C would have run out of "suckers" by now. I have a '96 (the problem year!?!?) with 108k miles and absolutely no transmission problems. Don't try to elevate anecdotal stories to the level of tried-and-true data.
- Rob
I believe that some of these problems people are having has to do with "Dealers" who don't know what they are doing in the first place and that will create more problems.
The 3-speed series was never a problem. In fact they've been very reliable.
Again, if my memory serves me correctly, at the peak of the problem years the failure rate for the UltraDrive was about 18 or 19%. While that's above the current US average (4%), in '88 through '94 the failure rate wasn't that much more than the national average.
Ford, GM and Honda have had problems in this area, too, by the way. In fact, the highest ever recorded transmission failure rate was around 46% on GM's THM200 series that was put in full size GM cars for a while.
It is quite untrue to state that "nothings changed" with Chrysler transmissions. Chrysler has upgraded their transmissions over the years, especially the minivan series. If you visit a transmission repair shop nowadays, you'll see what I mean.
Dusty
To keep my transmission alive: 1. I added an auxiliary cooler ($32 and 1.5 hours)(standard after '98 I've been told), 2. I change the fluid every 15,000 and filter every 30,000, 3. I check every quart of fluid to be OEM standard (mine uses ATF +3), 4. I keep the overdrive off in city driving cutting shifts about 40-50%, 5. when backing I stop before shifting to drive. Roy
if my oil pressure is real low-just above the bottom red line on the gauge-is it likely the oil pump? When I shift to low gear on the Auto Trans. and increase the RPM, the oil pressure does increase a little bit, but when I shift back to drive, the oil pressure drops.
Also, what is a MAP sensor? Oxygen sensor? EGR valve? the other day the van wouldn't start. It would chug a little(about 750 rpm) and then die. When I tried giving it a little gas, an occasional knocking sound came from the engine bay. Any help would be great!
The arm rest fell off, the paint had to be re-done, the window trim was damaged and was replaced with,,, you guessed it,,, more damaged trim. The thing was in the shop more than in our drive-way. There were 3 re-calls the first week we owned it. Mechanics were unable to set the security on the key less entry system, making it useless. This is minor stuff compared to the fact we started to have transmission problems with less than 2000 km on it. Mechanics told us it was just the way a Windstar drove,, NOT ! Try driving a vehicle that does not respond when you give it the gas, trying to merge into traffic on the freeway! Then having the thing hammer into gear and take off, enough to cause whiplash.
We took it back and left it with the keys with 4000 km on it. We wanted no part of it.
So before you think of buying a Ford, check the boards and do some research on re-calls, you'll save yourself so much time, money and aggrevation.
Must be some more to this story....
Ford has had so many problem with the Windstar. We like the Caravan we have , it is a much better built vehicle.
ramou, black oil is usually excess combustion blow by into the crankcase past worn rings. A compression test would confirm this likelihood.
Rob
Keep in mind also that this defect was not present in all of the transmissions they manufactured that year. If you have one that has a smooth piston bore, you probably will never have a problem caused by that defect regardless what precautions you take.
However, if the machining of the piston bore in question has never been addressed, then I could see why 1995s would continue to have a problem. This piston bore is part of the transmission case. It's not something that can be replaced. There is a repair for it, however. A competent transmission shop can make the repair at overhaul time.
Dusty
- Rob
We have a 2002 Grand Caravan Sport. How does the rear A/C work?
Is it all run off of the same compressor? Does it have a separate coil? If so, where is it located? Or is it just separate temp control and fan which runs off of a single A/C unit?
Thanks...
The recall work has been done and just yesterday I picked it up from the dealer who had kept it for a week to repair the transmission pump. The problem arose the week before - the van would not consistently go into gear.
Oh, and have you all received your letter in the mail to let you know the A/C warranty has been extended to 70,000 miles because it is likely to break?
No, I'm not happy. I didn't pay big bucks (well it is big bucks to me - I'm in California) to deal with these kind of problems. I might expect it with a used car, but not a new one.
You mentioned the extension of the A/C warranty. Honda just extended the warranty on their Ody transmission because they are likely to break and the people who own Hondas are happy about this. At least Chrysler is stepping up to the plate and providing a longer warranty.
There is however a recall on the power steering hoses.
Had the van in today and they did both and reset the computer. Gave us a Ram tuck 4x4 to drive for the day since we were from out of town.
Service has been great.
