Visitor Agreement.
I wanted to add my voice to the question posed above: I had a Prius for a two-week stint as a rental - it had about 5000 miles on it. In those two weeks I did a lot of driving, maybe 1500 miles, and while I admit it was a lot of highway driving, it was not ALL highway driving, and my mileage always fell between 42 and 44 mpg. I was a little disappointed given the figures quoted here and on the EPA sticker...what does one have to do to attain high 40s or even 50 mpg in 3/4 highway driving? I am used to achieving the EPA's freeway mileage number in mixed driving on all the other cars I have had. (I am pretty light-footed with the gas pedal)
I wasn't using the A/C much - it was winter.
http://john1701a.com/prius/prius-advice02.htm lists the things to be aware of.
The most common oversight is tire-pressure. It makes a big difference. 35/33 (PSI front/back) is way too soft, yet some owners discover their tires have pressure even lower. 42/40 is strongly recommended. It will increase both MPG and the life of the tire.
Another factor that many people just aren't aware of is the level of the oil. Too much causes internal drag. Owners discovered this by observing the Multi-Display after draining out small amounts. Ideally, it should be about 1/4 to 3/8 inch below the full mark. So if your service squirts in oil from a bulk barrel, definitely check the level afterward.
JOHN
The older mechanical voltage regulators had a bi-metalic ambient temperature "sensor" that caused the regulator to charge the battery to a higher voltage with lower temperatures. A matter of physics. I know that the older electronic regulators also had this feature but can't say for sure about modern day.
All options with the exception of nav and side airbags which the dealer said wasn't yet shipping.
In the spring of 01 I test drove one for two weeks.
There was no question in my mind that the highway MPG was substantially lower than city stop and go. But still, on the highway at 70+ the performance was quite satisfactory.
The low highway MPG problem seemed to me to be based on a design flaw in the firmware. On the highway once the battery was fully charged it seemed that the firmware "switched" modes and then wanted to use the battery as an aid to the engine just simply (it wasn't really "needed") to bring its charge back down to the level wherein it needed to go back into the charge mode.
On a 200 mile 70MPH drive on cruise at reasonably, substantially, even speeds it seemed to needlessly discharge and then recharge the battery continuously.
44HP electric motor vs 8HP for the Honda, of course the Prius has more off-the-line get up and go. The amount, ratio, of torque the electrics can generate substantially exceeds the gasoline engine.
I will immediately be converting the headlamps to Hylow HID and the parking/tail/stop lamps to LED (Ledtronics) and disabling the A/C compressor with ambient OAT below 65, if that isn't already possible.
Any guesses?
So when you first startup the Prius, it gives you a little something before the engine gets warm enough to provide regular heat. It also delays the engine from restarting a little bit while waiting at an intersection.
JOHN http://john1701a.com
Is there anything one can do on the Prius? I can keep the auxilary battery charged with my trickle charger. Does it hurt the nickel hydride batteries to discharge? Is there any kind of a charger one can put on the traction battery to keep it up while we are away? Are there any fuses that can be pulled to minimize the discharge rate on the batteries? I have submitted an email question to Toyota on this question, but haven't yet received an answer.
I kinda doubt there would be an equivalent to the trickle charge situation though...it is a sealed battery pack with 42 cells or something like that!
Thanks for your comments!
Is there an engine starter on the 12V battery?
If not, long term storage might result in the traction battery being fully discharged, at least discharged to the point of no engine starting capability.
Anyway, late this spring I'll let you know it it worked! I do think I should back into the garage before I leave it though as it backs up on the electric motor only!
Below freezing, fuel economy drops considerably and depends on the length of the trip. Short trip drivers report about 10 mpg drop (into the 30s) while people who drive about half an hour or more report correspondingly les impact, usually in the low 40s.
Actual starting appears to be unaffected except for those who have actual problems like water in the fuel or bad injectors (there was a batch of bad injectors in 2001, it seems).
However, note there is an unresolved situation with the 12V "auxiliary" battery in that when it dies (all batteries give out sometime) there is no warning - the system just won't boot up. The battery can be jumped with almost anything (reportedly even a 9 volt battery, and certainly a 14 volt cordless drill battery) because it only pulls in a sequential relay and boots the computers, but in the US it seems the replacements are ordered from Japan.
Mike P
When I was at a Toyota dealership recently, the Shop Foreman told me I could alternatively just disconnect the battery if I won't be using the car for an extended time period. Another option he recommended is to get a "Battery Tender Jr.", which is something one can use to trickle charge a lawnmower or motorcycle battery. He got a motorcycle magazine for me and in the back pages there was an advertisement for such a unit. I haven't yet investigated that further. He said that small charger could be hooked up to the auxillary battery with no need to disconnect the car's battery cables. I would have to make sure of that last point before I would really do it that way. Don't want to hurt my Prius.
Bill
The same applies to any car, but the 12V battery in the Prius is so small it is especially susceptible. On the plus side, it can be jumped with almost any battery that puts out about 12V... one of the Yahoo gurus jumped his with a 14 volt drill battery and a small pair of clip leads. The battery just runs the power steering pressurizer pump for a few seconds, then pulls in a sequential relay and boots the computers. The engine is cranked by the 273 volt "traction" battery.
My wife wanted a *new* car, and we both wanted an improvement over our 20 mpg beasts. I believe conventional power trains will be well down the road to obsolescence even in the public eye by the time we give up our new car, so we focused on hybrids. We didn't know how much we'd come to love driving the Prius.
Environmentally, I think it is a toss-up. Every car on the road will still be driven until there is no home for it any more. If you don't drive a used car, somebody else will drive the one you didn't buy.
Given that, it would be better to recycle the used cars that are already in the fleet, if they are fairly energy-conserving (think of all those Geo Metros from the 90s, unloved and unwanted).
But, if your current car is an 18 mpg gas hog, like many SUVs and large sedans, it might be better to trade for the new Prius anyway, since its mileage is a big enough increase to compensate. Of course, in the view of the environment (and not your financial advisor), this is only true if you scrap your current vehicle. If you sell it to someone else who continues to drive it, you have not accomplished a net gain for the system.
Not true. I saw one with leather 2 years ago. A dealer here just had a third-party convert to leather after the factory delivery. It's not a big deal... if you have the money.
In general, Toyota's perception of the market for this car is that leather is very low on the list of priorities for most of its customers. So while you are obviously an exception, don't look for them to offer this any time soon. An independent conversion is the most readily available answer.
If anyone is wondering why the Prius is receiving such a recent redesign, it's because the original Prius debuted in Japan back in 1997.
Also, apparently Toyota loses about $20,000 for every Prius it sells because they cost about $40,000 to produce. Perhaps Toyota's loss will be much less on this vehicle as it's more advanced and the Prius' sales are growing. 2,532 units were sold last month, March. Go Prius!
It is a sedan already. It just has an unusually short front-end (since the hybrid system is so small) and the tall interior makes it appear even shorter.
>> I would think that the design of a hatch would result in
>> more weight which is a huge problem in this kind of
>> vehicle.
Weight hasn't been a problem at all so far. And to create a hatch, it doesn't involve adding much more material. It's mostly a cost issue.
Also, the 2004 Prius is actually larger than the current version, yet it weighs less.
Prius hasn't lost money in years. Toyota broke even awhile ago. And within the last year, they starting making a modest profit. So as you can imagine, the upcoming redesign will provide an even greater profit. That will make everyone involved in the sales aspect much more interested in selling lots more Prius.
The (hybrid) wheels of progress are really begin to pick up speed now.
I don't understand how Toyota is possibly making a profit on this vehicle. I don't see how Toyota went from a $20,000 loss to profit.
Why not? The physical design isn't any more complex than a traditional vehicle.
Remember, since Prius is a "full" hybrid, some components found in traditional vehicles were eliminated. That and taking into account the fact that the hybrid is now mass-produced reduces cost enough to make it competitive.
I bet they will offer a sedan version of Prius for '04 as well as hatchback. Toyota is the king of sedans after all. But I will be looking for the hatchback!
Since Prius advertisements are almost non-existant compared to many other promotion campaigns, it kind of makes you wonder how big of a portion of the sticker price helps to pay for that. With Prius, it's almost a trivial amount. The calculates to a real cost reduction.
That should result in probably cutting at least 0.5 to 1 second off the current 0-60 time. I also like the fact the new model will likely sport better fuel economy, too.
Actually, Prius's primary purpose is emission reduction. The great fuel economy is a benefit from that design. (By the way, it says 51.0 MPG on my Multi-Display right now!)
>> 0-60 time
That value doesn't mean much anymore. The current Prius satisfies all but the most extreme heavy acceleration needs already. The new Prius should satisfy all of them. Anything beyond that is just fluff. Of course, there is a market for unneeded features in the US...
Didn't my 7th grade math teacher call that a balanced equation?
Or do emissions reduce at a different rate than fuel economy increases?
Anybody checking for fumes from the battery set?
To assume that that anything beyond what YOU have decided is adequate for YOUR purposes is unnecessary (even "extreme") for anyone else. Those who pay more attention to traffic than to their "multi-display" may draw other conclusions.
The fact remains that the hybrids are among the poorest performing sedans currently sold, particularly when you consider their lofty price!
