~alpha
I have no statistical evidence, you may be right, but common sense says that a device that will prevent slids in hard braking will save many lives.
Jumping from one car to another like this can be revealing, but it doesn't reveal much if there are significant differences in the tire quality and pressures between the two cars. The presence or absence of ABS is meaningless in the context you describe - it has no effect on overall brake feel at anything but panic pressure on the pedal.
You can gradually increase engine speed as the miles pile up, though I hold it to 5000 rpm max until 2000 miles, and rev it as high as necessary after that.
3000 rpm gets you close to 80 mph on the automatic - we took several extended trips during the first 2000 miles and I would have gone crazy trying to keep it at 55 mph. Toyota continues to repeat this in all of their breakin instructions, and it is simply a waste of print. Pay attention to engine speed, not road speed.
Incidentally, ours is making noticeably more power and is a tad quieter at the 2500 mile mark - it used less than 1/8 of a quart of oil during the first 1000 miles, and none since, indicating that all is well and right on the money.
How does anybody manage to drive 1,000 miles without exceeding 55 mph?
Best Regards,
Shipo
try to do 55 on the expressway..haven't exceeded 60.
My salesperson said it's more about the
RPM's..best to keep them low..certainly
below 4000 rpm. I haven't exceeded 3000
RPM's yet. With the 5 speed, at
55 mph..it's less than 2500 rpms in 5th gear.
Also..try to vary the speeds that you drive
My advice for your daughter would not be to grip the steering wheel tight. Rather she should look where she wants to go, which is not into whatever is obstructing her path, and to steer in that direction. There is no point in having ABS if you are not going to use the advantage it gives you. In this case it allows you to retain some degree of steering control while braking as hard as road conditions allow.
Best Regards,
Shipo
I am wondering whether the dealer is the best place for it or doesn't matter at all?
Any input is appreciated!
Now I am just nervous that I am going to hear it again. Has anyone taken his or her car to the dealer to see what the noise is all about. Is there a remedy??? Would love to hear from someone. Thanks, Patches
scroll up 20 messages..do it like twice
and look for the message by richardworth.
I asked the same thing a few days ago.
I have the rattle in my car too, but
I'm not taking it in until i get my
first oil change in a couple of weeks.
Try driving with the windows up, A/C
and stereo off so you can hear. Mine
rattles mostly on bumps at low speed.
If yours is the same thing you may
not hear it on the expressway.
As I said, it seems to have subsided, and I hope to never hear it again. Does yours stop happening and then come back again or do you hear it each time you drive your car. It sounds like you only hear it at certain times. My noise kept up even when I was on the highway going to work, but coming home, I only heard a little bit of it when I went over bumps.
I did find another message on another board that mentioned their repair people installed foam to silence rattle.
It was #52 on the Corolla Matrix group (I think).
Again thanks. I will keep looking on this board and will let you know if I find out anything else.
if I am driving with the windows down
and the cd player on it drowns it out.
I'll be posting what happens after I take
it in..probably in a couple of weeks.
I have never even pretended to follow this guideline from Toyota, and have never had anything but sterling service from all of our Toyota products, going back to 1981. None have ever used any oil, had any internal engine problems before 130,000 miles, or otherwise shown any signs of abuse.
The Germans emphasize not exceeding 4000 rpm during the first 1000 miles, and varying engine speed and load, and using those guidelines have given outstanding results.
Since the question was specific to the point about 55 mph, I'll repeat: if that's what you want to do, fine...but it has nothing to do with the breakin of the engine or its eventual long, trouble-free life. For that, the main thing is to keep engine speed at a reasonable limit until the rings get seated.
So, if jrct previously owned Toyotas that did 130k miles with no engine problems without following the break-in instructions, he probably could've done 200k if he did follow them! A moot point to say the least...
said that they replaced the crash panel insulation.
That may or may not be the same as the foam
you read about.
My car's rattle had been sensitive to the temperature, cooler = louder; warmer = less. So, patches69, that may explain the difference between your car's morning and lunchtime change. I am wary of when the cold weather returns its effect on developing any new rattles.
I would also suggest to try going to a closer dealer to fix your problems. At first I was driving 25 miles to the selling dealer for fixes. By the time I needed to fix my instrument panel rattle I just went to a local (2 miles) dealer/service. They fixed it just the same. Afterall, each dealer wants to establish customer loyalty for their service dept which is where they make most of their money anyway.
Ifan - I just discussed the possibility of going to Toyota in town here because it is so much closer and less work and time. I have to take half days off from work to go to where I bought it. I had a Corolla previously and used the service people here for that one when I needed it - like for a timing belt and tires. And I did not get that one here either because each time they did not have a manual (clutch) here, and I got a much better deal at these other places.
So, I really appreciate your advice. I just feel a little uncomfortable because I did not buy the care here. But you are right. They would want my business, and maybe they make money even when it is under warranty.
Your idea about the temperature does make sense. I did not hear that noise at all today, but I didn't go out until about 4:00 pm, and it was quite warm out. I work tomorrow, so I'll see what happens early in the morning when it will be cooler.
Thank you both very much for your responses!! I feel better than I did last Friday!
I live in Detroit. I am I'm interested in 2002 Honda Civic EX and 2003 Toyoda Corolla CE. Which one will be fit for the snow weather in Detroit? I usually use my car to commute to work and occasionally drive 4 hours to Chicago on holiday. Could anybody recommend me which one I should buy?
BTW, some people told me that it is a better deal to buying a one or two years used car still within warranty than buying a new car? Could anyone also tell me your opinion on it?
So far the car has been a joy to drive and we have not had a single problem. 33 mpg around town and 39+ highway with the automatic.
Thanks to everyone who helped us make our decision 19 1/2 months ago. (Especially Britton)
1. 2000 Echo 27,000 miles manual A/C
OR
2. 1999 Corolla 39,000 miles Manual A/C
The Echo sticker (over)price is about 10K and the corollas is about 11K( too much for both but that just where barganing comes in).
Anyway, excluding looks, what do you all think?
A
A
I don't drive with the seat pushed the whole
way back. Some taller drivers have indicated
that they have difficulty getting a comfortable
driving position. I think the reason for this is that when the driver's seat is all the way back,
the steering wheel is a bit of a reach.
All of the models come with tilt-wheel
and tilting it down seems to help some.
You really need to just take it for a drive
and see how it feels for you though.
the CE, and might require a factory order.
The CE's I have seen at local dealers have
the weather package..maybe power door locks.
Don't know if that has changed at
all. I have the CE without ABS and the
brakes are very good.
