Visitor Agreement.
"if anything, DO NOT ever use premium in your Corolla. If you do, premium will actually increase the carbon deposits in your engine and exhaust, because the Corolla engine (and any other 4-cylinder engine for that matter) don't change their timing ratio when you use a higher octane engine."
Hmmmm...
Do you have a reference for this statement?
Sounds rather dumb.
Actually, the VVT-i engine (1ZZ-FE) has a hefty compression ratio of 10.5:1 or so. Such compression usually requires a higher octane gas to prevent detonation. For this reason, the ignition timing is heavely modified in Corolla to accomodate 87 gas. Some people report measurably better milage with 91. I would not be surprised if HP also increases.
Did anybody do a dyno study on 1ZZ-FE with various fuels?
About your comments on the new Corolla engine, yes the compression ratio is very high, but like you said, "For this reason, the ignition timing is heavely modified in Corolla to accomodate 87 gas". In this respect, the Toyota V6 also is modified to accommodate 87 octane gas, yet the owner's manual recommends 91 octane for "improved performance". The Corolla engine, to my knowledge, does not have engine knock sensors like the V6 has, and therefore has no real means of distinguishing between octane differences in the gas. The V6 engine I was told would adapt itself to the kind of gas that was put in by changing its timing ratio. The 4-cylinder does not have this kind of technology. Perhaps due to the higher compression ratio the premium gas would not carbonize the engine as much, but I think it's safe nonetheless to assume that someone putting premium fuel in a Corolla is literally burning away money. In other words, the few extra miles you could get could not compensate for the higher price of premium, and possibly damage engine parts (carbon deposits, and catalytic converter).
as far as corolla's not having knock sensors, i think they do. i could be wrong though... but most new cars nowadays have knock sensors on them.
you are correct that toyota's v6 will take regular unleaded coz they have knock sensors BUT they recommend premium. just like my sienna's manual, it says ok with 87 octane but 91 octane is recommended. many people use regular just coz its cheaper but i personally believe that in the end when the engine gets older, it will affect the engine. since day one, i've been using 91 octane for my sienna. i bought it new, it recommends 91 octane and i spent over 30 grand on the van - i'm not about to get cheap on the gas!
i see people driving lexus with v8 that recommends 91 octane, yet the use 87 octane coz its cheaper. they can afford to buy a C$80,000 car but they cant afford to buy 91 octane gas!!
I've also seen the same phenomenon at the pump, where they put regular in the Lexus. I don't understand that either. Why is it, however, that GM/Ford/Chrysler V6s don't say that they require premium, whereas Toyota does? Is it because the Toyota V6 is picky, and requires only the best gas? Even Honda touts that their new Accord's V6 still requires 87 octane, they say "due to better engine knock sensors". Maybe Toyota is recommending premium to save its owners expenses in the long run? Why, for example, should you put premium in your Sienna when the neighbour puts 87 octane fuel in his Windstar, and it runs fine like that?
I know you can use 87 in the Sienna, so that is a bad example. But several of the Lexus sedans will recommend premium, but will take 87 only with reduced performance. Some require it, and won't take 87, so you have to find out which you have.
It is not because some do not have knock sensors - all cars have knock sensors, it is just that some have less ability to retard timing or advance it for changes in octane.
In the case of a car like corolla, you may just be shortening your engine's life by putting in 91 when it is supposed to use 87, because you are creating a hotter and more powerful explosion in each detonation than the engine is designed for.
It has two sticky things on it that glue the holder to the windshield. It has to be in clear view for it to register each time you cross the bridge. I'd like to put it on top of those black dots to make it less visible, but I'm worried they'll get damaged in case it needs to be removed. If so, I'll just stick it below the rear-view mirror.
I apologize if you feel insulted.
I hate when misinformation is spread.
I never heard that premium fuel could cause carbon deposits. I would like to learn new things so please provide a reference to support this statement.
The only association of carbon and premium fuel I am aware of is that cars with carbon deposits require premium fuel to prevent knocking.
BTW, somebody stated above that:
"you may just be shortening your engine's life by putting in 91 when it is supposed to use 87, because you are creating a hotter and more powerful explosion in each detonation than the engine is designed for."
Acctually a fuel with a higher AKI (anti-knock index = octane rating) actually burns more SLOWLY than fuel with a lower AKI. This is because the fuel is less volatile and requires more heat input before it begins to ignite.
So, there is no "explosion", no "detonation" and no reasons to damage the engine.
Coming back to Corolla, the engine's computer system retards the ignition timing (reducing horsepower and fuel economy) to keep the engine from knocking while using 87 fuel.
People generally report increased fuel economy with 89 and 91 fuel in Corolla. To me, it clearly suggests that the engine changes timing in responce to better gas.
I have no proof however and thus this is only speculation.
warranty. Recently my corolla gets some dings on
a door and the top, and windshield was hit by a
small stone on highway, which caused a little
crack of half inch long. But when I went to the
Toyota dealer, they said both of these problems
were not covered by the bumper-to-bumper warranty.
Oh yes, there are several places where the paint
coat was scratched and rusted, they said that was
also not covered. Are these true or the dealer was
cheating?
My car recommends 87 but I've used premium since day 1 and I can tell a difference. The engine seems a little peppier if I use premium. If your engine is calibrated to run on premium it will make a difference, if it's not then there is no significant advantage to using a higher octane than the manufacturer recommends.
but I was ignorant about warranty and thought this
is a good place to learn. Now I know who shall
deal with my problems.
Since that warranty only covers mechanical defect,
and my Corolla doesn't have any of it (it's such
a good car), I'm a little regret having bought
the warranty. It's of no use and just waste of
money. (Am I ignorant again?)
bumper to bumper basicaly means the parts in your car not related to everyday wear/tear. example: you bought your car for a week and for no reason, your front grill or headlights just fell off or your rear light assembly fell off - this would be covered under the bumper to bumper warranty.
read your manual and it explains what is bumper to bumper warranty and what it covers.
terceltom: LOL! I was thinking the same thing! But he/she did say "no significant advantage", so maybe they do not consider the slight boost they feel is "significant".
Road damage and wear items are not covered by the bumper-to-bumper warranty, but if you paid for an extended warranty, you will be covered if things break, like power windows (expensive, covered for free), interior trim or buttons (annoying if you have to pay for them), other stuff like that. Not to mention the important expensive stuff, like the transmission and the engine.
So the extended warranty can be good for peace of mind.
The above is an absolute contradiction of terms! Is the statement a joke and I missed the point?
Engine seems peppier- How would you know if you've never run regular gas in it?
If there's no significant advantage to running premium fuel, why are you doing it?
I know it feels peppier because once on a trip we put 87 octane in it and could tell a difference in engine performance and fuel economy as opposed to using 91 octane. Other than that 1 time the car has ran on premium only.
Your arguments not only fail to convince me but also give me some ideas that the common knowledge about combustion engines is quite superficial around here.
Disclamer: I am not an engineer, far from it actually.
I drive mostly in city in my 2003 corolla s and the milage is very stable at ~27 mpg with only one exeption of 30.5 (very very light acceleration trial).
I now experiment with higher octane and will try synthetic oil like fgf did.
BTW, somebody reported periods of poorer fuel economy associated with strong H2S (rotten eggs) smell several weeks ago in one of the Corollas forums. I hope you don't have this problem.
Cheers
and 325/12.1 would be very close comparisons. I also have had the strong "rotten egg smell" which Toyota service has told me is just in the gas which is BS . The 410 total mileage has been by far the best I have had.
if there is one thing I know, it is that running premium in an engine designed for 87, particularly one like the '03 corolla that is not designed to accomodate it, WILL lead to premature wear...
beyond that, I tend not to explain myself that well in writing, so that may be the weakness here...
alpha
Lets see......11 gal tank. How do you put 12.1 or 12.2 in it without running out of gas. The most I've ever gotten was 385miles on a tank and that fill took just under 12 gal.
And your calculations are right on. Must have been a lot of city driving with the a/c on for that tank.
As William Shakespeare wrote: "There are more things in heaven and earth, Terceltom, than are dreamed of in your Toyota owner manual."
Disclaimer: I am not an English literature professor, far from it actually ;-)
(running and ducking....)
It is dated 1998 and thus, no description of VVT-i nor plastic planum intake. One interesting point: the motor is most efficient at 3000 RPM. This illustrates possible MPG improvements with CVT.
http://www.matrixvibe.net/docs/1zzfe.pdf
But this brings up a different question:
I still have over a gal of gas in the tank when the gauge hits "E". I've never put more than 12 gal in. I suppose this could be a good thing (never run out of gas). But I'll be monitoring more closely to see how many miles I can get from a tank at a conservative 33 mpg figure.
Just thought you might want to know.
Also, low fuel levels contribute to possible fuel line freeze ups in frigid climates.
Then again, some cars have holey leather seats!
If I could get rid of the sulfur smell I would be a happy camper.
Also, my wife wants me to get the extended warranty. How much will it cost? What will it do for me? Is it worth it?
