Visitor Agreement.
-V
I my experience, it is worse if I accelerate heavily up the hill and stop at the traffic light.
I wish Toyota would respond to consumer complains instead of giving BS.
I am not sure if changing gas brands helps since different brands are supplied by the same gasoline distributors with only diffrent additive packages. So the gas sulfur levels are going to be same in the entire distribution region.
We did not smell this in any other car we tested. I didn't really think about it until it was just mentioned here.
We almost never have this problem any longer in California, because of our reformulated gasoline, which mandates a much lower sulfur level than is common and still legal in most of the rest of North America.
It is obvious from the volume of complaints on the Toyota boards that the problem is more accute for a number of reasons that I can imagine with Toyota - different mix of metals in the catalyst than some other manufacturers, for instance.
If I'm right, replacing the cat won't do much, because it is the combination of metals in the cat that is just not quite able to deal with the higher sulfur content. Our '94 MB C220 was the last car we owned that had any of these symptoms, but that was before RFG became the state standard.
Going uphill, or putting the engine under heavy load, will indeed exacerbate the problem, since more unburned elements are in the exhaust under those circumstances. Beyond reporting this to the EPA, I don't know what to recommend. You can try switching fuel brands, but that doesn't work in markets where only one or two refiners are supplying everybody's gasoline [and yes, that is more common than you think].
Don't listen to the BS about the smell going away after you buy the car.
It's only been out for like 11 months.
Damn-it-all! The Carolla was the perfect car for me and my family but I just can't buy a brand new car with this problem. I'm not willing to take the chance of buying one that is fine in the test drive but later develops this problem because of too much sulfur. Is there a particular manufacturing facility that makes Carolla's with this problem? If so, maybe I can avoid buying one made from there.
Our '03 Corolla built at NUMMI, and fueled exclusively on the West Coast, has never had this problem...but it also never traveled beyond the range of stations [California, Reno NV, Ashland Oregon] that are supplied by California refiners, and thus with lower sulfur levels.
Understand, the cars meet all emissions requirements and are doing nothing that is "warrantable" - but the volume of complaints suggests that Toyota needs to rethink the mix of metals it is specifying, at least until the rest of the country starts reducing sulfur levels [unfortunately, our do-nothing, oil-company-dominated national "leadership" has allowed the refiners until '06 to get on with it].
And no, this will not "get better" with mileage; I think some dealers and owners are deceived by the intermittent nature of the problem...it can come and go depending on where the fuel was sourced and what time of year it is [many locations get a different blend during summer and winter]. If you are in a locale where ALL of the fuel comes from a couple of refiners, and their crude in turn comes from high-sulfur sources [most North American crude fits this description], then you're going to get higher sulfur content in your fuel pretty much all the time. It doesn't help that the refining business in this country gets more concentrated every year, mostly due to mergers and buyouts. You may think you're getting different fuel by buying from Shell vs Chevron vs Brand X, but in many markets the actual juice is coming from the same spigot - only the additive mix gets tuned to make the different brands. Even that is regulated here in Calif, so our motor fuel is about as generic as it can get.
I would be willing to pay for it... just want it fixed if a replacement converter could be put on my car and solve the problem.
This is why dealers tend to fight you on this - they have no real solution until the parent company hears enough complaints to act on what they hear. All they can do is pull another part off the shelf which is identical to what you already have.
And I repeat: in those states served by low sulfur refiners, there is no problem. This complicates the message that Toyota gets from the NA market as a whole.
My dealer wants to drive the car for a day on Monday to see what they find.
Thanks for helping me understand that Toyota has to go through the EPA before they can make a change.
1. Wife wants a sunroof. We rented one for a weekend w/o a sunroof, and I found it to be quite peppy, even on San Luis Obispo freeway grades. We got 37 MPG highway without the car having been broken in. Would a decrease in performance/MPG be significant (noticeable) due to the weight increase with a sunroof?
2. Vehicle Stability Control: For those who have it- Can you feel any difference? Do you feel it was worth the price?
3. JBL Audio: What's different from the Audio Value Package? The LE we rented had just the single disc player, which was adequate, but I wonder if the JBL system sounds better in terms of sound quality.
Thanks for any input whatsoever!
http://www.highwaysafety.org/vehicle_ratings/ce/html/0223.htm#3
Let me get this straight. They got additional crash worthiness by modifying the CARPET PADDING?
If that were suggested in most engineering schools, the students would be drug tested!
"I hope Toyota does right to their current '03 Corolla customers who may want this modification for improved crashworthiness by making it available either thru a recall or tsb"
I dont think this minor modification warrants a second thought, or your time- if Toyota didnt make it, you'd still be happy that the car got an overall rating of Good. Additionally, its not like you waited for the crash test results to come out before purchasing the car- and thats your issue, accordingly Toyota has no obligation. Certainly, it would be different if a major design flaw was exposed or a recall issued. Clearly, this is not the case.
~alpha
Ken
I don't want it to seem like I'm picking on you this morning, because honestly I am not. But I have to correct you on the above statement, it's not true. For one thing the Kinetic Energy that a vehicle travelling at 80MPH has is 4 times the Kinetic Energy that the same vehicle has travelling at 40 MPH and not double. Secondly hitting a fixed deformable barrier is very different from hitting an unfixed (that is free to move, even with the parking brake on and in Park) deformable car. While these two factors will tend to cancel each other out to some extent, it is not correct to compare the two situations.
Rotten egg smell was very common in the mid 1970's when catalytic converters and unleaded gas just began to be introduced on the marketplace.
I haven't had a car with that condition since then, and I live in an area that has been forced, in recent years, to use RFG with different winter and summer blends to boot, so I likely have seen just about every combination of fuels over the last 20 years.
Any experts out there who know about what Toyota is doing different from the others?
I am not an expert but Toyotas engines are ULEV. One way they accomplished it by having exhaust manifold in the rear side of engine and close to catalist, so the catalist is hotter for cleaner burning. Another thing is that gas in Japan is virtally sulfur-free. Perheps the design of converter assumed low-sulfur fuel. And thirdly, it is possible that the catalist in new Toyotas is diffrent nowadays for lower emissions or lower cost or some other reason.
Go to
http://www.matrixvibe.net/docs/MMC_engine_info.pdf
and see fig 15 on the amount of sulfur in various fuels. A real eye opener.
1- What do I do to get rid of the rust? It appears to be only on the surface (or at least I hope so!)
2- Has anybody else experienced this kind of problem? Do you think that the 2003 Corolla's paint job is particularly easy to chip? I had a 2001 Corolla before, which I used on the same roads, but I've never noticed such proliferation of stone chips and certainly no rust in the stone chips it had!
I'd appreciate any feedback for this nagging and potentially serious problem. Thanks!
If I smell this egg smell in the actual car we end up possibly buying, I will leave. I don't want to take a chance on having this smell continue. I did smell it in the car we tested but like I said, I didn't think anything of it until I read about other people's problems.
Answer - That is correct, however, a 40mph impact into a FIXED or a barrier that is immovable is the equivilant and has the same energy applied to the vehicle that would occur from two vehicles EACH going 40mph impacting or ONE vehicle at 80mph and the other stopped.
Answer: Very different, true, but similar. Hitting a parked car would not be the same as hitting a brick wall, so I agree that a deformable barrier is more realistic. However, the barrier itself is not movable. To get the same result, you would have to have a vehcile of the same size parked up against a building (for example) and then run into it at 40mph. If the vehicle was parked or stopped, free-standing and therefore able to be moved, then you would have to run into it at 80mph to get the same level of forces.
Answer: One vehicle going into a fixed barrier at 40mph is the equivilant of two identical weight vehicles impacting eachother at 40mph each. Or, one of the vehicles can be stopped, but the other moving at the combined speed of travel or in this example, 80mph.
Hope this helps explain where the figures came from.
Ken
I have never experience a rotten egg smell. When the car is cold and running rich, the exhaust smells a little like fresh gas. My 2000 Dodge Dakota (4.7L) tends to smell like rotten eggs when it is first started, but disappears when warmed up. It doesn't bother be at all.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1875102015&category=6445
I thought all Corolla S had black interiors. I know the wheels are wrong. What do you think the real value of this car should be? Any other things I can point out to prove to the seller that he's lying. I may by the car anyway if I can get a good deal out of it.
That Corolla epitomizes why Ebay buying is potentially very risky.
~alpha
Personally, I'm a fan of the new '03 Corolla, while acknowledging the problem with the seating position. At 6' even and 175 lbs, I managed to find a good position behind the wheel, [I have a 32 inch inseam], but if your legs are much longer than mine, it's not possible.
In every other respect, I regard the car as a significant improvement over its predecessor, of which there is an example still in the family [a '98 LE automatic that currently still has less than 18k on the odo].
~alpha
If they could keep the car under 20,500 with nav, leather, sunroof, alloys, side SRS, ABS, pwr seats, etc., I'd bet there'd be people buying it.
~alpha
