Visitor Agreement.
All literature I read prior to purchasing was that the Avalon is a "Super Quiet Ride".
Car is equipped with Michelin Tires.
It is most definitely noise generated by the mirrors. I've noticed it before (it does not happen all the time, under all conditions). It took me some time to localize it, but I am convinced that the mirrors are the source. The body is tight and this is a different sound than what I have experienced with body noise.
I do not know of any fix, because the mirrors cannot be moved. I have been able to reduce it, by moving my windows slightly up or down, so that they sit in the door seals differently. I think this may be effecting the air pressure between the window and the mirror housing. It sounds (no pun) strange, but I regularly investigate vibration induced noise and it never ceases to amaze what will generate noise.
I had a rattle that I would have sworn was coming from the right door/floor/seat. Turned out to be the sun visor on the right side. It does not fit tightly into its clip and came loose. It was enough to make a rattle that I could not find, until I sat in the right seat, because my ears said to look elsewhere.
Bejay
It was the visor on the driver side. It doesn't fit tight enough. We stuff a small amount of kleenex in it and rattles go away.
There have been other rattles in the Avy that we thought were one place and were found in another. It's so big, and so much attention must have been spent on getting acoustics right for the stereo, that the side effect is rattles fool the ears more often than not.
Good listening!
I've been posting and reading here for over 3 years and never heard the reverb problem....
What is the term "Dynamat" mean?
JLuther2
According to the company's website, http://www.dynamat.com/ the product is defined as:
Dynamat (Dyna-mat) is a thin, flexible, easy-to-cut and mold sheet that actually stops noise-causing resonance and vibration, by using visco-elastic qualities that promote vibro-acoustic energy conversion. In short, Dyna-mat turns noise into silent energy.
MODERATOR /ADMINISTRATOR
Review your vehicle
(JUST BOUGHT A BRAND KNEW 300M LOVIG IT SO FAR)
Special note: 28 mpg average over 500 highway miles per week; still running the original Michelin MXV's (going for another 10k) and have not touched the brakes - although we're about ready. Maintenance includes oil every 5k, tires rotated every 10k and mostly regular gas.
Everyone that's seen it or ridden in it has been more than complimentary. No surprise to me that Toyota has outsold Chrysler this year!
Thanks - previous car was a 96 Avalon XLS.
Kenb
I have an 02 also. Trying to extrapilate your concerns and compare them to my own experiences. Agree that the car, does tend to labor a bit, when taking off, but that is just do to the way them have it set up, and in addition the insulation of the car. Most of the power is mid-range, but I do not find it hard shifting. It is actually quite smooth if you let it get up to speed and do not push it, then back off on the gas a bit just before it up shifts. The alternator whine, I agree, it can be a little annoying, but nothing that some silicone spray will not take care of. Try that, carefully, while the car is idling, and it should fix the problem. You will have to reappy it now and then.
Hope this helps.
Arthur
Attn: Travelerjb, the car is purchased through my company, no negotiations on my part, they did purchase the XLS fully loaded, every option except stability control for $27,500, with a $36,000 sticker, so I think they reached the bottom line. They are buying in bulk though, so this wouldn't apply to a regular consumer. Other cars like the 300M, Explorer, Bonneville, do come with mats, but my new Kraco's for $25.00 at AutoZone work just fine.
Kenb
Now I know what you are saying. Yes, you are right. When going slow, then depressing the gas pedal, the downshift can be kind of abrupt. This is a just a point where the power curve and the gear ratio are not optimal. Try this. When you are running the car, below 50MPH on a continual basis, like around town or around a tortuous mountain road, take it out of OVERDRIVE. This will give you only 3rd as your top gear, and unless you are going very slow, you won't have as much hunting, unless it goes down to the 2nd gear.
In reference to the post with 44PSI, I do not think you are correct, and this may be very dangerous. 44PSI on the side wall of the tire is the MAX PSI which the tire manufacturer recommends. You Avalon probably takes either 31/32 depending on the 15/16 wheel. It is too light a vehicle for that much pressure and will bounce over curves and be very uncomfortable besides dangerous. Please check your manual or car for the correct pressure.
A.Fisch
Time to let out ten pounds.
On downshifting, if you car is downshifting alot, unless you are sport driving, you are in too high of a gear range. Use you OD off button when needed for prolonged slow driving as well as braking.
A.Fisch
Thanks for the correction. You are right, I am wrong. I meant to write belt dressing. I rush a little less next time. Thanks for the correction. That is what this forum should be all about.
AFisch
Can you give several POC (points of contact) and either websites/telephone for these PU bushings.
A.Fisch
I got the numbers for the Rear Control Arm Bushings, Rear Sway and Front Sway bar frame bushings. Whom did you buy yours from??? This is all they had for the car. Did you put them on yourself??? I realize I will have to get it aligned again with the rear control arms. If you had someone do it, what was the labor cost???
There is a 18mm or a 19mm Front Sway bar. Do the XL come with the 18 and the XLS come with 19mm or is this by year model of the car????
How much more turn in response for the fuzzy steering do you get??? How much do the ride deteriorate???? I already have TokicoHP struts on with stock wheels and tires. Do not want the ride quality to decrease too much and become harsh as it is nice the way it is.
Thanks for the experience and advice.
A.Fisch
I did both sway bars. I really wanted to reduce body roll. I am in the process of having a custom oversize rear sway bar made. I may attempt the front also, but things are tight up there. (I'll let ya' know.)
I also did the front and rear control arms, including a few custom pieces.. the custom pieces come from a LEXUS aftermarket supplier. Toyo does NOT offer replacement bushings??? ...so you have to buy a new control arm!!!! Keep in mind a good friend of mine is a Toyo/Lexus service guy...he told me about an entreprenour who thought this was crazy, and started to mfg a poly replacement for these parts and ordered 'em for me. Which leads us to the install...I did it at my buddy's shop. This means I had the right tools. The bushings can go in with a press, but an air hammer is better.
Then, I had it aligned. I drove a half hour out of my way to go to the "best guy in town" that' means $99 in the Burbank/Glendale area. It was well worth it.
Steering? No major changes. It is a little more precise, but still lacks feedback. This will be my next project. If I can improve the stering, I will seriously consider other improvements....like, supercharging. Maybe next summer???? The ride did not deteriorate, it changed. My buddy has an Avy and swears we have different cars. The Tokico's made a great improvement and made the car a little firmer. The poly bushings emphasized these changes further. Probably too harsh for most Avy owners. As a reference point, the best I can tell you is, "It's almost as harsh as my buddy's Acura TL-type S in a straight line. It handles better than it ever did, but my next new car will probably be a Type S."
Bottom line: I want a sports sedan. It is less expensive and more fun to "hobby" my Avy closer to this goal. Who knows, after the sway bars and a supercharger, it may be the perfect sleeper?????????? -nomad-
Thank you for you time and expertise in your reply above. This forum is heaven, and circumducts all the dealership bull and misinformation.
I found two good vendors. I will get under the vehicle after two or three weeks, as soon as my knee feels better from the surgery I had last week. I will measure the sway bar x 3 at points just lateral to the bushings and report this in this forum.
Fortunately, I too am lucky to have the necessary tools and mechanics, although not probably as good as yours. I am an US Army officer who is fortunate to have an Auto Hobby Shop on base with Mechanics that roam and help us. Each lift bay has its own set of full tools and pneumatic equipment.
The NEW bushings come with an "G" modifier after the part # to signify graphite impregnation. This should be welcome for lubrication purposes.
I have no aspirations of doing more than this as the car is vastly improved, and is the right balance of comfort and handling for the dedicated long driving I do between Army posts in upstate New York.
I Acura is a very nice car and reliable. But, in my opinion, not nearly as comfortable with a bench seat as the Toyota. The cabin is smaller, the ride harsher, nor is it a 5 series. It just doesn't serve my purpose although in Califormia, is might be more fun for you.
Supercharging, and doing more suspension mods are always an interesting test, to see how far the manufacturer has cut costs. Toyota would have done a much better service by not making the steering "light and fuzzzy", putting competent shocks in the vehicles, as well as a little better brakes. The Powerslot Rotors with EBC shoes, and the Tokico Shocks HP make this vehicle much more competent as a highway machine, with the owner's need to gooble up pavement, and get through a long journey in a safe, and fluid manner.
Thanks again, for giving me and the forum your experiences and knowledge. This is really an excellent vehicle for owners to share their experiences.
A.Fisch
With each improvement to my Avy, I am closer to a "fun" car. When I bought it originally, passenger room was of paramount importance. It is a little less important now, and there is no reason to change cars. ...so, I'm having fun with it. 141k miles and people think it's a new car.
Yeah, the "TL-type S" is simply a much more performance oriented car. 270 ponies from the factory. If the Avy keeps going, it may be a few years!! -nomad56-
Thanks again. I will await you experience with the steering rack, the only part of this vehicle that really is technically difficult to improve without major modifications. If you can do it, more power to you. That is terrific.
I will write my experience in this forum re: PU bushings, after the install.
It is snow time up here, and will need to place the snow tires (all around x 4) on the vehicle as the winter's are pretty, but can be challenging driving wise.
If you can let me know what front sway bar bushing size for the front you used, I will correlate it with my measurements. I don't want to buy two sizes or get stuck under the car with the wrong size. That would help.
Again, that "Light and fuzzy" steering, described by Consumer Reports is the ONLY thing, I can think of that we have not addressed with modifications and corrections. The average handling, front dive when braking, etc. all have been corrected. Very interested to see what you can come up with.
I think Acura is remodeling the new RL next August. Hopefully it will be more in line with a true flagship. Enjoying your technical expertise and experience. Thanks for all the input. You have helped.
A.Fisch
THANKS !!
Nomad56??? Any comments on this. I think this is normal noise from the VVT-i engine.
A.Fisch
However, like any other question I try to help with, my first question would be to make sure we are describing the same noise. One says a "rattle", one says a "gurgle". This may be the same noise, or two different situations altogether. -nomad56-
If it is a bit of a growl, my first inspection would be the intake. Look at everything from the intake box to the throttle body for a loose fit(opening) in the intake. Including the air filter, be sure it is seated properly. NOTE: You can remove the top of the filter box and the filter, start the car, and rev the engine a little. See if this is similar to the "growl" you were hearing.
Did the "pitch" of the noise increase with RPM's??
Does it seem like a "combustion" noise, intake or exhaust?? ...or moving parts??
If you post any additional info, I'll help ya' find the demon. Keep us posted, and let us know what the fix is. -nomad56-
