Peak close to 30, wife driving w/o AC.
33,000 miles
Read several posts on the Avalon rotors. Looking for excellent after market rotors and price range.
Would Bendix Co. rotors be acceptable?
Front brake pads - Toyota original equipment or after market?
Jim
Cleaned the windshield with Maguires cleaner/wax, Rainx & then new Ansco/anco, whatever the correct spelling is, new blades - same problem.
Recleaned with Maquires cleaner/wax, treated with Rain X then new Toyota wiper blade inserts. Seeing as how I fit a little above the average age of the Avalon driver with the "senior citizen" discount inserts cost me 6 clams and a few pennies.
Wipers now work as new.
JLuther
I am a regular contributor to this forum. IMO, not the gospel, I have had nothing but bad luck with the OEM rotors. I cannot recommend them. They are inferior in construct and quality, and as you see, warp prematurely at 20K. Many OEM, Honda too, are having trouble their rotors. See the Honda website for the Accord. Painful.
Go to www.raceshopper.com and ask for ED. You will have many rotors to choose from depending on your application and driving demands, but ALL will be much better quality than OEM. The slotted and drilled will give you the best performance but you will feel a slight undulation in the brake pedal. Some do not like this, but the stopping distances on dry and especially wet conditions are markedly reduced. Change the pads also, but ask about brake dust as the performance pads add more brake dust, especially the fronts. IF you are not used to doing this yourself, take it to a qualified shop. It doesn't have to be a Toyota dealership.
I have SP rotors, drilled and slotted on my 02 Avalon, and the difference is remarkable. I pull a trailer sometimes and do much interstate/rural highway driving.
Good luck
"Feed the forum"
abfisch
Not exactly sure what is meant by wiper slap, but if you mean they lift from the windshield secondary to the rake at high speeds, I have some answers. Since sometimes, not all the times new wiper blades do not take care of this, the only solution I have found, is to go to the local NAPA Auto parts store, and get something called "Snuggies". I know that sounds queer, but they are black, metal, clips that attach to the wiper arms that cause a larger pressure than the springs supplied with the car. You may have to bend the springs slightly so as they do not scrape the plastic motor housing under the windshield but they hold the blade tighly against the windshield without any lift at speeds above 60MPH. I have not found them to overheat any wiper motors in cars I have owned including a 90 Honda Civic EX 5 speed, and this Avalon XL 02.
Hope this helps.
"Feed the forum"
abfisch
My '99 XL went 92k on the original pads, front and rear. And still had pad left at trade-in time for my '03 XL (which just had new front pads installed at 35k). Turning the rotors, which I generally do not like, on the '03 was barely necessary but was done. Still plenty of material left on the rotor, as measured.
What this means for the new model is anybody's guess. At 275 hp, the suspension and brakes will need a major overhaul. It will interesting to see if Toyota puts the hardware in the car to control that much power. And will we finally have road feel above 40 mph?
Since MY 2000, Avalon brakes, like the struts, have been a weak link in an otherwise very dependable car. Other thoughts always welcome, or "feed the forum" ......
I realize the name is a turn off, but they work for wiper blades that "sail". Many times, at higher speeds, even within the speed limit, the air stream, rake of the windshield, condition of the rubber or silicone blades, etc. lead to ineffective clearing of the windshield. Ofcourse, other things should be entertained, which you have done, including changing the blades, checking the retention springs to make sure they are causing enough downward pressure on the windshield, and I would imagine the wiper arms you have on are original equipment, which I recommend for this particular part. Realize, by my other posts, I have no trouble expressing my dislike for inferior OEM parts when applicable, as I do not advocate blind customer loyalty, especially in their premium or flagship car. If all of this does not work, go into a NAPA parts store and ask for a pair of snuggies. They are external black wires, about 3 times the diameter of a coat hanges with an external spring. They are almost undetectable on the wiper arm, and increase the downward pressure of the arm/blade assembly to the windshield. Make sure you have thoroughly cleaned your windshield too, which I am sure you have done already. It is an inexpensive part, less than $10, and I have found it of high value, in driving in the upper Northeast, at highway speeds through rain, ice, and snow.
abfisch
I agree with your observations on the whole. I think the struts and brakes, however, are not lightweight, but rather of poor construct or inferior in metarlgy(sp?) and design, for the weight and suspension geometry of the car. Many posts substantiate that a premium strut vastly improves overall performance of this vehicle, including but not limited to, handling, transient response, stability, and braking. The warpage, seen on some of the front rotors, not exclusive to just the Avalon (read the Honda Accord posts for the 2003 model if you want to shake your head!), IMO, are do to the poor construct and metal components (read cheaper) of the rotors, as well as the weight balance under braking secondary to a strut that does not control the vehicle all that well, especially at higher legal speeds.
Regardless, of the conjecture on the other posts about the NEW 2005 Avalon, and the horsepower increase, it makes little sense other that for discussion purposes for anyone to guess. If it stays FWD, which I am guessing it will, 275HP will produce enormous amounts of torque steer, which will have to be technically controlled. Since I have found that I rarely run the vehicle over 3500 RPMS or 85MPH, I rarely have the need for that HP. Rather, increasing the displacement to 3.3 or 3.5L like the Nissan Maxima, would hopefully give a boost to the low end torque, which should translate into a lower amount of down shifts and slowing down up steep grades and an increased towing capacity, above 2000lbs.
Enjoy your Avalon. All it needs is premium quality struts and brake parts and you would be suprised how much improved while retaining the same good quality properties you originally bought it for.
"Feed the forum"
abfisch
Recently I was reading a Motor trend article comparing luxury cars, BMW 7 series, MBS S series, Lexus 430, etc. While the article did not list rear seat room dimensions, the article’s interior photos did show an individual sitting in the rear seats of the featured cars. I was struck that the passenger’s knees were hard up against the front seat back in the Lexus 430, but not the others.
I checked the rear seat dimension of the 430 in Consumer’s Guide web site, and was astonished to read that whereas the Avalon has a minimum rear seat leg room of 40.1 inches, the Lexus 430’s rear leg room space is less-37.6 inches!
I am 6 feet, so my driver’s seat pushed a ways back. My equally tall friends and I find the Avalon’s rear seat room provides a 4-5 inch distance between knees and front seats, and plenty of toe room, too- all on a 107 inch wheel base, and $30,000 less than a Lexus 430!
At age 66, the Avalon is truly a Geezer Pleazer!
The rear seat knee room was a major factor in our purchase decision. In our case it was wanting enough knee room so our 8 year old and her friends wouldn't be kicking the back of the front seats. Now she is the primary driver of the Avalon and her 6'7" friend and other tall friends easily fit front or back. She's not the only teen around here driving an Avalon.
abfisch
Currently only having probems with the front brakes.
Luther
I find using combination cleaner and conditioner products don't work as well cleaning as cleaner only products. Using a separate cleaner makes the job a two stage process, first use a cleaner then use a conditioner, making the job take twice as long. I've tried several brands and found Meguiar's leather cleaner and conditioner didn't clean as well as Eagle One cleaner or BlueMagic cleaner.
Fronts do most of the work. Fronts can be changed separately without do the rear, which happens mostly on front drive cars. Usually fronts changed at 40-50K or so, and then they both are changed at 90-100K the next time.
Any quality rotors with ceramic or semi-metallic pads will do. The slotted I like but just a personal preference. The advantages are better WET braking performance and less over-heating. It rains ALOT here in northern NY and I pull a small utility trailer sometimes, so I find this advantageous. The disadvantage of slotted rotors is #1. you can fill a little vibration in the brake pedal and as well as a "whirring" sound when applied if you open the windows. It is the slots hitting the pads. The sound is slight, you have to listen for it, but nevertheless is there and some would rather not have this. They are more difficult to 'turn" properly if needed to be adjusted. Another advantage to slotted, is they "disglace" the pads, sort of like cleaning them. If you have ever seen the surface of a pad after 40K miles, especially stop and go, you would see a hard sheen to it. This does not happen with slotted rotors.
Bottom Line: Get what you like and can afford and make sure they are done properly. Have them or you bleed the system too, but any air or a change of fluid every 3 years, regardless of mileage.
abfisch
easily you can make a deal through net if you hit someone who wants to make the sale and will work
at it, but, also the vast the difference in dealers and how incompetent some can be in using the internet.
I live in New Orleans. I went to a couple of local dealers and test drove the care, but the prices were marked up above invoice and I could see it was a waste of time trying to haggle from there down.
I weighed the idea of finding exactly what I wanted in another region and flying there to pick it up and drive it back vs. getting something a bit more expensive here with things I didn't want. What I wanted was Premium Luxury Package (Leather, etc), Vehicle Stability Control/Anti-skid, and Moonroof.
If I could have gotten only those, the invoice price was about $29,300, which includes a $600
holdback for the dealer.
Around here, those options could only be obtained with a lot of other extras.e.g. the heated seat
option added $300; others put the invoice up around $29,900 -- $30,000. Sticker was $34,000.
The exact invoice was hard to figure because some of the extras were from the Gulf States distributor and not priced on either edmunds or the consumer reports pricing service (Consumer reports pricing service is $12/model. Thought it was worthwhile, once I decided what I wanted.)
I looked at dealer sites in the Atlanta area and found a similar problem with add ons, but some cars that were close to what I wanted, say with only mats. However when I checked airfare, I found what I thought was going to be a $100 one-way trip only applied with a 10 day-2 week advance purchase. Otherwise it's $150-200 and you don't get in early enough to guarantee being able to drive back to New Orleans in one day, meaning a potential motel bill.
Buying out of St. Louis, with the only unneeded option being heated seats, meant a $250 one-way
ticket and a 2 day drive.
So, I decided to give internet shopping a try. I went to a number of dealer sites within a 100 miles and looked for cars that had what I wanted. Since Avalons aren't high volume cars, there wasn't a big selection, so I knew I didn't have a lot of bargaining power. I finally emailed three dealers that had what I wanted. I told each of them I would give them what I figured invoice was, $29,900 (as I said above, I was guessing a little bit), but that I knew they had to make something, so I was willing to talk if they gave me a reasonable offer. I also mentioned that I was emailing several dealers and was ready to buy. One dealer was local, two were in Baton Rouge, 90 miles away. I gave them both the email address, office phone and cell phone so they knew I was ready to buy.
Within a couple of hours, I had a quote of $30,500 both by email and voicemail from Cynthia Tassin of Coleman Toyota of Baton Rouge. I don't know if the plug is allowed here, but I thought I'd try since I was very impressed with her willingness to close the deal and go the extra mile.
Also within a couple of hours, I got an email from the other Baton Rouge dealer saying he was checking inventory and carefully considering the price, blah blah and would get back with me in a
few hours.
I never did hear from the local dealer, so I called their internet sales guy to see if he had gotten the offer. He acted like he hadn't, then said he was looking at it, but _his_ invoice was $30,600, that he'd have to get a good bit more than that, that his friend's mother was interested in the car, etc., etc. I told him that it was a little more than I could affordm and quickly got off the phone.
I called Cynthia back and made the deal for $30,400 plus tax in about 10 minutes. I might have
gotten another hundred or two off, but was willing to pay that because it had been pretty painless
deal and she had responded quickly. She was going to have it detailed and we were to pick it up the next day in Baton Rouge.
Everyone was happy that evening until the wife wanted me to show her the car on the dealer site and she found that it was the dark gray, which I had thought was an acceptable color. She was scared to tell me, but she didn't like it. To make sure I found another local dealer that had that color in stock and we drove and looked at it just before it got dark. I had to agree with her that I didn't like it either.
So next morning I had to sheepishly call Cynthia and explain. I was pretty emabarassed, but she
wasn't ready to give up on the deal. I told her about the other Baton Rouge dealer having a
satisfactory color in stock, but she said she wasn't allowed to trade cars with them. (I still
hadn't gotten a quote from the other dealer.) She said she'd call back and, in about an hour, she
had found one in the desert sand (gold color) at another dealership. I had the emergency kit, but
she said she could remove that, but it had mudguards, so it would be an extra hundred - $30,500.
Plus it didn't have the air deflector for the sunroof, but they would install that for $50 which was their cost (Invoice is $63). I also let them charge $175 for documentation, but was still happy. She said could have it the next day for us to pick up.
That night, almost 48 hours after the initial offer, I finally got an email from the other Baton
Rouge dealer offering "rock bottom internet price" of $30,900 plus tax and title. I didn't jump at
it.
We went and got the car. I paid cash and they said I had to see the finance manager for the paperwork. Was afraid that they would come up with some extra charges. Turned out he just wanted to
make the mandatory offer of an extended warranty. It was about $900 for ten years, but wasn't from
Toyota. When I turned it down, he said: "I thought you'd say that," and we completed the paperwork.
Hardly high pressure
We drove back home. I got to drive it back because my wife was too scared to. We have been very
satisfied. Five or six days later, I got a call from the local dealer asking if I was still
interested in their car. Two and a half weeks later, I got a call from the Baton Rouge dealer. They just don't get it.
My, My, how have times changed; in 2000 you would be lucky to get a dealer to entertain a reduction of $500 below MSRP. Today, an XLS can be had at invoice or less. Good luck with your Avalon, enjoy the ride.
www.kbb.com
Try it for Gulf States area and the Southeast area. It's much better than the Edmonds site or Consumer Reports because it gives the dealer invoice pricing for each option. The port options are priced differently and have different packages in each area.
Absolutely too high.
If you check Boch Toyota they show 9 04 XLS's in stock, 4 with invoices in the 28K range. You ought to be able to email them and get an invoice price offer.
Lojack only makes sense for cars with high theft rates unless you are just paranoid. The hightest theft rates cars in the US are 10 year old Toyota Camry's and Corollas and Honda Accords and Civics.
I listed this string in the above format: " http://www.picrack.com/001/other/Img03%20Av%20Best%2015%20640x480- .jpg " without quotes. It changed it when I submitted and added a - and a space before the .jpg. - .jpg
Can anyone tell me what the problem is?
The link below works fine.
If no pic appears, click on this, or, paste this into your browser.
Besides the regular oil and coolant changes, what maintenance has your '95 needed?
I'm getting ready to do a fluids change (brakes, transmission, and coolant at the next oil change. Time to replace the tires too. Still on the OE front brakes, but will probably do a four wheel brake job too.
By the time I add the costs to change belts and hoses, brakes, fluids, put new tires on, and maybe new shocks, there is a significant investment to be made in a 9 year old car.
The car still rides and handles well, gives reasonable mpg, and looks very good inside and out.
4. BMW 5. Ford. He rarely sees Toyota, Nissan, Honda or their corresponding luxury progeny broken down. My car is Black with tan cloth interior and still gets looks from the youngsters when I drive by. People can't believe it's mileage and it has no rattles. I'm surprised by how similar its front looks to the 92' LS 400 that parks in the same lot. You'll have many more good years of reliable ownership for as long as you choose to hold it.
But the '03 XL is a different car. The front brake pads went out under 40k. They could have gone a little more but that was enough for me. The rears look like new. But then, this car has been driven much more in suburban settings than interstate travel. The factory 16" MXV's went 40k but would have gone 50k plus with more frequent alignment and a better air gauge. My fault. With more interstate driving, my guess is 60k max...more is possible. I buy the MXV's (H rated) because of the quality. Just wish they were not so expensive.
The only problem to date with my '03 is that the battery went bad. Significant corrosion buildup on the negative terminal. The battery case actually cracked near the top. The dealer said everything is fine now, with a new battery. If you own an '03 you might want to look at your negative battery post.
These are great cars for the money. Sounds like the '99 Aurora was a good car, too. Enjoy.
I rotate tires every 5k miles although have never had an alignment but the guys at the tire place check my wear patterns periodically. I'll let everyone know what what tire and brake life can be expected with 95% highway miles.
Regarding past posts, I am 40 years old (my understanding is that the typical owner is much older) and I purchased the car because of its reliable reputation, quiet and comfortable ride, and awesome cabin atmosphere. I have had riders favorably compare to their Cadillacs regarding ride and rear seat room.
I appreciate your comments on the forum.
I recently installed a Roady. Originally I used the FM modulator with all wires almost invisble (plugged into the outlet in the console and ran the wires under the console and through the ashtray and mounted the Roady with a "custom" stand). Looked good, but then I later tried the tape adaptor. Couldn't believe how much better the quality was. Doesn't look as good though - I don't like the wires running up to the tape.
Does the radio have an aux input for a direct connection? It's a JBL stereo (upgraded from base, I think) with Toyota 16824 printed on the face plate. Or, can I plug in where the tape player hooks up (I don't play cassettes)? I haven't taken the JBL radio out to check. I don't want to tackle that unless it will hook up for me. (I don't want to break anything, I'm good at that). Or is there a better way? Any and all advice is welcome.
I have also noted that when music is playing the background noise is virtually unnoticeable. I use the 107.7 frequency and found the best response in the NW corner of SC. Good luck. I love that XM variety. It is amazing the improved clarity vs regular radio you notice when you get a nearly pure signal as with the cassette adaptor or as is in my Tahoe factory unit.
I suppose I have two questions:
1. Any recommended sites with installation info for Satellite and any tips to someone who's never done this?
2. Has anyone had any bad experiences with a cassette audo adapter? I have a Sony and used with my mp3 player it sounds very good. But, I blame it for killing the cassette player in the used-to-be wife's 94 Deville, which now won't eject her german language lesson tape. I have also noticed that when I use it in the 99 Lumina that I drive, I hear a clicking, as if the cassette mechanism is trying to play the "tape". It hasn't caused a problem yet in the lumina, but I haven't used it much because I'm afraid it will screw up the tape player.
BigMike2 - I have only been using the tape adaptor for a couple of months and have had no problems. There is a hiss you can hear between songs (like there really is a tape in). Don't know if it's indicative, but our two eldest kids left their cars and three adaptors here when they went overseas and our youngest tried to use his Walkman in one of the cars the other day and only one of them worked.
But overall, I'm pleased. I certainly would like to find a way to hook it up direct, though. I just don't want to break anything trying to figure it out myself. Best Buy installed the Roady originally and broke the ashtray ($200 for a new one). I hired them to do it because I didn't want something broken - they did pay for it though. In all fairness to them, they probably never installed one in an Avalon the way I asked them to, and probably work on hundreds of different makes and years.
I'm excited to see the information posted by Nomad56. I will be looking into that option.
Nomad,
Does this apply to the JBL systems with in dash 6 disc changers? It is all one unit.
Does using that adpater mean you "forfeit" use of the in dash CD player for your aux audio device (mp3 player, sat radio, etc.) ?
Where can you come accross a TOY-PIE adaptor?
what would be the best way to have one of these installed ?
Should I buy one and just take it to best buy/good guys/etc and see what they say ?
I could see their installer getting twitchy about installing something they dont sell.
I use my mp3 player a lot in my avalon and I commute every day a fair distance so i am definitely interested...
hmmm...
If you are a little more neurotic, like me... I eventually drilled the console shifter cover and installed a flushmount female mini-plug. No hanging wires. I just plug in a mini-plug to mini-plug cable(plug 1 end into the car; 1 end into the player), an 18" cable is just right, for me, to pick up and operate the player, if necessary. I placed the plug on the front inside of the shifter "pocket", and the player sits in the pocket behind it. It's a slick setup. If want it done RIGHT, I recommend this type of a "finished" install. -nomad56-
http://www.carstereohelp.com/strtoyota.htm
You can also look at:
http://www.logjamelectronics.com/pietoyaux.html
...they sell them and have some tech info. ie) Radio models it will NOT work with, etc. -nomad56-
