~alpha
I am suprised by the problems everyone has had with their Sentras... maybe I have been lucky. I have a 03 SPEC V and love it! I haven't had one little problem with it and it is a blast to drive.
A friend of mine has a Mazda 6 and my car will kill his all day long in both acceleration and handling (he has the 6 cylinder). :P
What a great car!
The new cars only come with automatic tranny, unless you
get the Spec V model which I don't want.
Does anybody out there have an SER automatic? I was
wondering how well the automatic tranny works with
this engine?
Also is this car dependable?
The Sandman
Another question does anyone here know of any place we can donate it to ? it is in pretty bad shape but hate to just junk it I am sure it is good for at least the parts in some areas .
Sincerely,
Rob L :confuse:
Do you know how I can find out if the recalls on my 2001 Nissan Sentra have been taken care of??
Rob L
The Sandman
Any ideas on what causing it. I think I'll be taking back to the repairman who put in my engine.
Joe
Joe :confuse:
What should I do next? I was thinking of having it diagnosed again for free with Auto Zone and let them tell me what they notice what's wrong and go from there, unless you have another suggestion.
Thanks again,
Joe
Nissan Sentra 1997 GXE 1.6 :sick:
Joe
About one month ago things got worse. The automatic shift lever stays stuck in park with, so I cannot shift into gear. The parking lights come on by themselves and I have to turn the light control swithch ON to turn the lights off.
Finally, this week, the battery went dead and the repair shop said that the alternator ws not charging. Upon dissambling the alternator, they found nothing wrong it The tested it, pût it back in and the battery still does not get charged.
My dealer has looked at the car five times so far and has not been able to solve the intermittent problems.
Am I the only problem with weird, intermittent electrical problems?
This is so ridiculous its almost funny.
Where is thesafety switch located?
According to the general consensus here, when the battery and brake light come on, the alternator is shot. Another guy had his alternator overcharge and blow out his lights on the forums too.
I replaced the alternator, but the battery and brake light is still on. I see 3 fuseboxes on the car. One driver side under the dash, one under the hood on the driver side, and one under the hood on the pass side, but I dont' see any fuses that would seem to be blown. Am I just missing the fuse, is it there? If so, whats it labled as? What else could it be if its not the fuse? Thanks in advance.
You do need to be concerned. One repair would make it too expensive.
The Sandman :confuse:
My Sentra only has 33,000 mi. on it and has been well-maintained. A while back, the "service engine soon" light went on. It was intermittent at first but then stayed on...When I took it into the dealership this week, they charged me $100 to diagnose it and said the mass air flow sensor had gone out and that replacing it for $570 would fix the problem. I asked "how can this be happening on such a low-milage car, and why should a little part cost so much?" They said that they don't just replace the little part--they replace the entire housing around it because "that's how Nissan prefers it." I refused service, thinking I might get it done cheaper elsewhere. (I even called every junk car place and no one had the part...) An independent mechanic I talked to said that he couldn't get the part from anywhere but Nissan, and that I was better off just having them do it since after talking to them about obtaining the part, (and discussing my car specifically because they realized it was me/my car he was inquiring about) he got the impression my car was having "serious computer problems that they'd be better at fixing."
I have also had the "sticky gas pedal" issue I've read about on this forum, and the dealership wants another $100 to do an induction cleaning service.
I feel like this car is barely out of warranty but this won't be covered, and that from what I've read here despite Nissan knowing about this commom defect, they don't seem to give a damn to make it right, and that even after some people have replaced the sensors and cleaned the buildup they are STILL having problems.
My question is this: has anyone out there had ANY success working things out with the folks at 1-800-Nissan1, or do I basically have no recourse but to pay up and hope this fixes my problems? Incidentally, the car has never had great power, and compared to my peppy old Civic, it just feels like a real dog in the performance department and I feel totally screwed. Help!
Before this happens to you,
Last week had car stalling but restarting fine. Before going to the dealer repair shop I looked up some info on the internet and found that there were two recalls (of which I wasn't informed) relating to stalling and starting . You all know them as the crank sensor replacement and the foam around the ECU replacement.
I called the dealer and they confirmed that my car was under this recall and that thet would do the work at no charge.
The day I was to bring it in the car would'nt start. They had it towed in and did the recal work and it stalled on the test drive. After 4 hrs of labour (at my cost) to find the new problem they determined that the ECU needed to be replaced because it was faulty. $1600.00 later my car is now running (don't know for how long. Lost all confidence in this car.)
My beef is :
If the recall to the foam around the ecu was neccessary so that the emitted sulfur does not cause corrosion to the ECU and eventual failure of the ECU. I believe that thier failure to inform me by letter or phone to do this work caused the eventual failure of my 4 year old computer.
I don't think I was responsible to pay for this.
I am considering taking recourse and want people with similar problems or advice to come forward.
Your advice would be GREATLY APPRECIATE.
:confuse: Rob L
Rob L
Rob L :confuse:
I was incredulous--I said "You're telling me that you're putting the onus on your CUSTOMER to research problems due to YOUR faulty manufacturing even though the law says you must contact us?" and she said yes. She was extremely rude and would not budge on anything, I don't know what the answer is, but I'm telling you to prepare yourself for a fight. I'm also interested that you never got the notice either, and that surely your problems--and maybe mine as well--are the result of driving around like that all that time! As for me, I still haven't had the work done on my car--now that I've done this research, I am going to call them back, open a case number, and tell them all that I've found out about similar problems from this site. I urge you to do the same.
I am a mechanically ignorant person. I have a 1997 nissan sentra that has recently started giving me a lot of trouble. The car will not start suddenly. At this point everthing else works like power windows, lights, horn etc. so it is not the battery. It will start working by itslef after a couple of days and would stop again. I have taken it to 3 mechanics and spent a lot of money on it. Does anyone know what the problem might be?
B
After reinstalling them, I started the engine and left the electrical connection off of the EGR/EVAC unit and found the EGR valve was then getting vacuum. I reconnected the elec. connection to find no vacuum to the EGR valve, but the connector was showing apx. 13 volts. Under the EGR/EVAC unit, was a second electric connector, which was showing apx.3.5 volts. I'm not sure what the second connector operates, but I suspect it operates the EGR temature sender.
Due to the low voltage reading, I checked the fuse pannel inside the car and found one fuse identified as "ST", from the fuse location chart. I have no idea what the "ST" stands for, but I suspect it might have something to do with the 3.5 volts on the EGR tempature sender.
I also checked the oxygen sensor and the PVC valve and they are OK.
The Sentra smog check was done this past week, with everything passing, execpt the "CO" reading. This portion of test was added to the California test two years ago, which it passed in total then.
I would appreciate any input I can get, as I had planed on selling the Nissan this weekend, but obviously those plans fell through.
Thank you in advance... ...Bob in Calif...
39.9 MPG indicated on trip computer over 364.4 miles and calculated mpg was 39.8 mpg. Wow!
I never expected more than 34 or 35 mpg.
Driving conditions were 70 F outside temp., 4 lane divided highway with many sections trhu towns and city's with stoplights. 60 mph speed limit and 60 mph is the speed I set the cruise control.
I previously owned a '95 Sentra which I never got diagnosed but once it hit 70k miles, the same symptoms appeared. That's when I traded it for the 2001 piece of crap I'm dealing w/ now.
I've also had to have the horn re-wired as others here have mentioned.
Any feedback is welcome!
