Visitor Agreement.
vvti
have you heard anything about when the site will be back up, the cause of the site being down, or what the site owner's plans are to continue the site (I haven't had my is300.net fix for awhile, suffering from withdrawal...)?
What a shame... Too bad for Lexus.
Also, I checked with L-Tuned today and they said they should have some "aftermarket" parts by September. They're dealer installed and guaranteed by Lexus, but still considered aftermarket. The person I spoke to said they'd have some 18" wheels, improved suspension, and other mods, but no performance upgrades. He said those may arrive later. Sounds interesting.
This issue has been discussed on IS300.net for months. There's a TSIB # on the issue, and Lexus currently has a new TRAC ECU as well as an ECU reprogram available if you want it, but it's not mandatory. The number is TSIB-EG003-01
Many have had it installed, (I'm still waiting for mine to arrive), and have posted positive results, as well as improved shifting when in M mode.
Hope that helps.
Even though I bought my IS in June, it has a VIN number that falls in the range of those that might require a fix. So far I haven't notice any "bogging" problems, but I'll bring it up at my 1K service appointment and see what my dealership has to say.
The LSD option is useful in all weather, not just in snow. You're buying a performance car, and LSD adds to that, and for $300, it's worth it for when you decide to get a little frisky in the corners (dry or wet).
It's too bad IS300.net is down. They've been having some problems with thier server, so I don't know when it'll be back up. When it is though, there's a ton of people in your area that could give you more info.
I had some disappointment when the IS300 came out with an automatic, and I think that not having a Manual was a big mistake.
While the Lincoln LS has a Manual, it is a heavy car and available only with a relatively low-tech 210hp Duratec V-6 from the upline Taurus. The new 3.9 V-8 is only available with an automatic.
While Lincoln-Mercury could make the LS a true BMW 5 series killer and they have the parts to do it, they lack the will. For instance, LSD is very needed and unavailable. The Getrag five-speed has no overdrive fifth gear, so 80 mph is a 3000 rpm proposition even with a 3:07 rear ratio. Of course, a six-speed Manual, which is getting increasingly common in the Audi, MB240, new Focus, Sentra and of course, the upcoming IS300 is the solution. A .70 sixth gear can allow low revs even with a deeper rear ratio.
Thus, the Lincoln LS Manual if unchanged, may remain a half-baked "performance car".
When my lease is up, I will consider the six-speed IS300. I really like the straight-six design over the V-6, having the same engine in my Cressida for 17 years with no problems.
Questions: does anyone know if the six-speed in the IS300 will be a Toyota/Lexus design or a Getrag? Does anyone know the ratios - tranny and rear end compared to the current automatic?
Lexus will be really dumb if they don't put LSD as standard in every Manual. You will just spin tires all day. Traction Control is not a substitute!
With a six-speed, the IS300 will be a real 3-series killer. With Toyota reliability, lower parts prices, and the potential to modify an engine from a family that goes from the Cressida through Supra and the early GS/SC300 series, this could be a monster car. Stan in San Diego
For tight gearing and too many revs at highway speeds in 5th, the IS is unfortunately a prime example - it's one of the reasons the fuel consumption is too high for a car of this weight and engine displacement. Of course, the tight gearing makes for instant response in high gear, but I would prefer it more relaxed than the current ratios permit.
This is right on. I love the acceleration I get even in 5th. Many times in passing I don't even bother with 4th. But it comes with a price of fuel.
They probably didn't mention it because it's one of those things that they won't fix unless you notice the symptoms. In other words, it's not a recall, just a recommended fix to "enchance performance". I think that's a lame excuse. Even then, you shouldn't need it unless your VIN# is under 10025186 for the ECU and 10029014 for the TRAC fixes.
actually, i think black interior is more flexible because you can get the aluminum or carbon fiber aftermarket trim. i saw a black/black one with aluminum trim and it looked nice. also, i've already got several marks on my door due to my shoe scraping against it as i exit. i don't think these would be visible on black.
i'm not sure if he was lying (because everything else he said was untrue), but a dealer in torrance, ca told me if you want LSD, you have to get the luxury package (lsd, heated seats, and ivory interior with the piping).
You can agree or disagree with my choice / preferences, but the problem is that I had no choice at all because Toyota marketing decided no one on the Left Coast should get that choice. I suspect the same is true with the limited slip.
You're right though. I don't think I've ever seen 16" on the lot.
On the topic of LSD, it was something I wanted and was shopping for, and the only ones I saw that had it were the ones loaded to the gills, which is what I wanted anyway, so it worked out. I've heard that about California as well, so I don't think they're pulling your chain.
I know my point of view is not widely shared among the typical target audience for this car, so I don't expect Toyota to pay much attention...until sales start falling off, which is exactly what has happened. I think they misjudged just who the audience might be for the car, but it may take them awhile to figure that out. They think someone like me should be interested in an ES; instead, they could lose me to the German competition, all of which have nearly the same handling with better ride quality...never mind the zoomy, edgy image they want the IS to have. I think they have already found all of the zoomy-edgy part of the market that is out there, [absent those who are waiting for the manual trans, of course, but watch that particular submarket dry up just as quickly after 6-9 months next year] and have lost sight of the thing that makes the German cars so unique: the COMBINATION of great ride and great handling, with no special bias to one over the other.
I've been buying BMWs since 1966, and MBs since 1968 - what I really want are their tactile qualities in an affordable, dependable Japanese package. That's what I was originally hoping for when the IS was first conceived as the Altezza...instead, they targeted the hard, outer edge of the market, and now wonder why that part of the market is so small...duh....
http://www.mag-x.com/scoop/altezza_gita0106/index.html
After speaking with a lot of other owners, I've come to find out at 25, I'm one of the older ones driving this car. Throw up some heart pounding, twisty carving ads with music from your favorite rock star, and I think they'd see the sales start to form, just in a different age group.
See, I'm 80% sure that the 16" tire-equipped car would be just what I'm looking for...I'm unable to prove that without traveling 2000 miles to a market where those cars are available. I'm in no special rush, so things may evolve the way I want them to...a good test is how they equip and pitch the wagon.
And your point about age / demographics helps make my point: there are only so many people under 25 with the means, resources, and desire to pony up this kind of money for a new car. Toyota is already finding out that may be a smaller niche than they thought - well, I'm waiting, checkbook in hand, whenever they want to get beyond their original vision and start really competing with the Germans in the market for a compact, quick TOURING SEDAN, which is what the 325 and C240 are.
It's ironic you can't find 16" wheels. I wanted 17" wheels with graphite rims but couldn't find them. Ended up getting a car with 16" wheels, intending to put snow tires on them this winter and buy aftermarket 17" rims with summer tires next spring. I might change that plan though because a like the ride comfort vs performance balance that the 16" wheels provide.
Like you, I don't fit the IS target demographic. I'm 36, married with two kids. I prefer the look and image of the BMW 3-series better than the look an image of the IS. But in the final analysis, at least for me, the IS was more FUN to drive. Is it better to look happy or feel happy? Also, the stereo was better, the AC was better and I anticipate the reliability and service will be better.
The car I bought is blue with the luxury package (piping and wood). It did not have the LSD.
Here are some of the cars I want to look at, and have done some reading on but yet to test drive:
- Acura TL-S
- Nissan Maxima 2002 with 260 ponies
- 2002 Altima 3.5 V6
- Audi A4 (low performance to doe ratio), Camry
(blah), Grand Prix GTP (American), BMW (way
to much $$ for this boy).
I asked a friend about the above and he recommended the IS300. Now, those of you who have done shopping and decided on the Lexus, perhaps you can give me some opinions.
The Max I have has been reliable, and is nice, with good performance. Going to the TL-S, any Audi or BMW, or the Lexus I am looking at and extra $7,000 or so. Should I test drive all of the above, or are some of them not worthwhile? Are there others in the $30,000 +/- price range I should consider? Is the IS300 available in 4 door and 5 speed. I do prefer 4 doors, and manual. I do live in snowy Canada so RWD might be a bit more tricky.
What car did you have before you IS300? I guess acceleration is quite important, but handling, reliability, and fun factor is just as well. We boys always get stuck at the 0-60 numbers, and I think the IS300 as at 215 hp, and ??? ft/lbs, which on paper is less than some of the other in its class.
Hope to here your opinion. I do plan to do some testing the next little while. 90% chance it will be either Nissan, Acura, or Lexus.
With the IS300 selling so poorly I don't see why you don't express your problem with the wheel/tire combo to your dealer and state that it's the last determining factor in your purchase. I'm sure that they'll either order a set and sell them to you at invoice (best of both worlds) or have a set shipped in and mounted on a car so that you can test drive. The first seems more likely though.
bigbadboss101:
New Altima and Maxima will share the same engines in 02' (Optional on Altima). Acura TL competes more along the lines with an ES300 although the S-high performance version would only lack the handling of the IS300, similar P, TL is a slightly larger car. Audi for 02' will be redesigned,a bit bigger. Audi currently offers Turbot charged 4-cilinder and 2.8 liter 6 (3.0 liter for 02') IS300 is of coarse 4 doors w/ a manual tranny available for 02'.
Clublexus.com runs a close second for the IS, but is mainly geared towards the GS series and other models in the Lexus family. That's where all the .net memebers have been hanging out until the T1 is back up.
The WRX is a excellent car if all you value is driving performance. There's not much on the road that can keep up in the straights and the twisties. It's a boy racers dream, in the boy racers budget. I test drove one for the fun of it and had a blast. This car is fun to toss around, just as much as my IS. Acceleration was great, but a little bit of a let down - low end torque didn't seem to be there either. I guess I thought it would have more kick than it did, and the lag was noticable (where's the boost gauge?!), but that's expected. All in all though, a proven pocket rocket and a joy to play with.
As for interior (cheap), exterior (yikes), driving comfort (keep your trips short), luxury (what luxury), sound system (weak), safety (watch your back) and passenger room (squeeze in folks) -- well, you know. But that wasn't what it was designed for, and it's the main reason they only charge $24,000 for it. Improve/add those qualities I just listed, a moonroof, leather, xenon, real performance tires, 17" rims, heated power seats, climate control and Lexus reliablity/quality/service - you have a $30,000+ car, and consequently, a heavier one, affecting accleration and handling. It's a trade off really. That make sense? If you think the IS is overpriced, I can't imagine what you think of the 330Xi. That's where I might agree with your comment on status.
Enjoy it if that's the route you go. Should keep a smile on your face for sure.
Tested the IS300 and liked it very much. I will need to test drive it again to visit the twisty roads, and may be test the standard when that becomes available in September. The saleman told me leather and roof comes together, not one without the other.
