Visitor Agreement.
Thanks a lot in advance.
MMN
Check for vacuum leaks. How ? Any emission control that uses vacuum is a potential source for a vacuum leak. Inspect all hoses, especially ones near the block that get a lot of heat. Replace if suspicious.
Sometimes you can test a peripheral by disconnecting vacuum hose and plugging it with a pencil at the periperal end. If it idles better, the periperhal is faulty because its not suppose to be open when engine is idling.
On the windstar you may have to remove the upper and lower cowl to work on it plus maybe a duct or 2. Make sure you disconnect windshield washer line from upper cowl before pulling it. Otherwise you may break off a nozzle like I did.
If your intake manifold has a gasket, try replacing it.
If all else fails, get the Haynes manual and do every emission control check. You will need a voltmeter.
It's very a possible that your problem is caused by a collection of faults so repairing a single item will not give dramatic improvement.
If 12V OK, swapping out the motor is much easier so do that first. Beware I swapped out my motor and the window worked for a while and then stopped working so now I need to replace the mechanism. If you replace the mechanism yourself you risk breaking the glass . I am a DIYer but I may pay to get that done.
The radio has gotta be a coincidence unless the wiring or a fuse are related. You may want to check the fuse again with with an ohmeter or just replace it if you are relying on a visual inspection. Sometimes it's hard to see where it's blown.
To date, he still has the '91 Previa (220k miles), and we have suffered our 2nd tranny failure on the Windstar, with only 110k miles. Not to mention repeated trips to the stealership for various abs, air bag, check engine lights and sensors, two of which failed within the first week of ownership. (The tech said that the new van wasn't used to being driven since leaving the Ford assembly plant, ha-ha)
So, would you chose a new Flex, or a used Sequoia/Sienna?
For the premium price of the Flex, I've read about too many problems about it already!
The only thing that domestics have on the foreign are the looks, and in some cases, comfort.
But remember-it is always uncomfortable when you're stranded on the highway!
