I'm 6'2" and I have plenty of head and knee room which was one of the reasons that I selected the TL. Does scholl know that the seat has an up/down adjustment?
Motortrend had rated the 2000 3.2TL at 6.7Secs 0-60 while "Road and Track" rated the 1999 3.2TL at 7.2Secs 0-60. It is commonly accepted that the 1999 TL with the 4-speed transmission and the non-free flowing intake manifold was slower than the 2000 3.2TL by about 0.50 secs 0-60 - a lot more difference in the quarter mile....so if we were to extrapolate the 1999 R&T test to a 2000 3.2TL, it would take it right to 6.7Secs again. Car&Driver, who have pretty conservative testers rated the 2000 3.2TL at 7.2Secs 0-60, which is the slowest recorded time for the 2000 TL from any major publication.
Here are the acceleration figures from the comparison test done on the 2000 3.2TL, 2000 Lexus ES300, 2000 Infiniti I-30 (which is similar to the Automatic Maxima) and 2001 Oldsmobile Aurora V6 (Motortrend - June, 2000 issue)....
---------Acura 3.2TL-----Lexus ES300-----Infiniti I30--
0-30------- 2.5 ------------ 2.8 -------------------- 2.9
0-40------- 3.7------------ 4.0 -------------------- 4.1
0-50------- 5.1------------ 5.9--------------------- 5.9
0-60------- 6.7------------ 7.9--------------------- 7.9
0-70------- 9.0------------ 10.1-------------------- 10.0
0-80------ 11.5------------ 13.3-------------------- 13.0
0-90------ 14.3------------ 17.0-------------------- 16.6
Qtrmile--- 15.2@93.1 ----- 16.0@87.5 --------- 16.0@88.5
As you notice, the other cars did not stand a chance from right off idle to much higher speeds....the Acura always held the upper-hand....when compared to the 1999 TL, transmission and intake modifications in the 2000 TL improved low-end torque and mid-range power, even though peak hp/torque numbers remained the same. Of course, with the advent of the 3.2TL-s, all these figures have been bettered......
Also, the Acura (EPA classification - midsize) is heavier than both the Lexus ES300 (EPA Classification - Compact) and the Infiniti I-30 (EPA Classification - mid-size) yet has better mileage figures (better hwy figure than the I-30).
Mileage of Acura 3.2TL: 19city/29hwy (3483lbs)
Mileage of Lexus ES300: 19city/26hwy (3351lbs)
Mileage of Infiniti I30: 20city/28hwy (3194lbs)
(The Acura weighs 3494lbs with the Navigation)
Later...AH
The cars are great even though the dealer experience is definitely not even in the same league as Lexus. The salesmen are positively sleazy and of the old-school...
antonk:
If you look at the power graph of the Acura, there is about 200 lbs/feet of torque in the Acura, almost a little off idle, even though the peak Torque happens at about 4700 rpm. Also, in the earlier acceleration statistics, you will notice that the Infiniti I-30 (similar to the Maxima) is EXACTLY 300 lbs LIGHTER than the Acura (with Nav - the test was done with the NAV version), yet is thrashed in 0-30, 0-40, 0-50, 0-60, 0-70, 0-80, 0-90 and also the quarter mile....even though on paper, the Infiniti has got a better Power/Torque NUMBER....street starts account for 0-30, 0-40, 0-50...acceleration of a car is not dependent on the peak HP/Torque numbers (which are entertaining but will not serve any purpose in day to day driving) but on the way the power appears all along the power band and also how it reaches the ground (via the transmission)....
Later...AH
Too much torque! (How often do you read that?) It's much to easy to generate wheelspin, especialy since we're dealing with an automatic. The traction control engages frequently in slick conditions and it works well. I just wish it didn't have to.
Otherwise, it's pretty stable. Snow tires would help, but it can hold its own without them. The SportShift mode allows me to drive a gear or two above normal once you get going and the car is balanced well. Defrosters and such all work well, so visibility isn't an issue.
Dunno what your budget looks like, but the MDX might be a good compromise.
As far as comparing 0 – 60 times on Maxima vs TL S Type I believe a stock Maxima with a 5 sp man would take a TL 225HP but not an S Type. I used to drag race a ’55 Dodge with a full race Chrysler hemi and a hopped up ’58 Corvette many years ago and agree that a strong flat torque curve is more important than peak HP.
To DC Wong : My Stillen supercharged Maxima is a stock ’95 in all other respects and it handles pretty well. Some torque steer but not bad. I put it on their dyno and got over 235HP at the wheels which works out to between 275 – 280 at the flywheel.
You can avoid that by either using a standard ascii editor such as Notepad, or just using the post box directly.
Hope this helps.
Pat
Sedans and Women's Auto Center Message Boards
The Acura has been an absolute pleasure throughout the ownership. The expensive double-wishbone suspension of the Acura makes its presence felt at higher speeds, where the Camry (with cheaper Macpherson strut suspension) attains a certain floaty disconnected feel. You can go to much higher speeds in the Acura and feel comfortable while doing it. With the Toyota Camry, you are certainly uncomfortable when the speed builds up - but the target audience of the Camry is also, I believe a little less youthful - so that is no biggie. Acura dealers are a little better than the Toyota/Honda set-ups since you get loaner cars for every scheduled service visit, in addition to the above mentioned perks when one has to wait at the dealership. In addition to that, there is 24hour road-side assistance, concierge service, trip interruption benefits etc. Lexus dealership experience however, is a lot more professional and even better overall. The service departments go out of their way to satisfy their customers - can't say the same about Acura dealers.
Later...AH
I just purchased an 01 TL, and am wondering if there are any on-line places to purchase genuine Acura accessories at discounted prices on the web. There are a few of these sites for Honda's (partscheap.com, handaparts.com, etc.), but I haven't been able to find any for Acura accessories. If you know of any sites like this, please let me know.
George
Later...AH
Is the dealer over-charging for this? Can I do this myself?
What a mistake Acura made in choice of wheels! The complaint of the pre-2002 TL was that from the front it looked like an Accord or Civic. Now the front is more distinctive with the reworked grill and lights but the wheels make it look like and Accord versus the much more distinctive wheels of the pre-2002 TL.
Ed
It really sounds as if the roof is just "flexing" at the seals to the glass panel.
It's been pretty cold here in Wisconsin, so I have yet to check the seals and weatherstrips for dirt.
Has anyone else experienced a problem like this?
display. I attempted to cut the system off but no matter how many times I pressed the off button it would't cut off. The air continued to blow cold the whole time. After about 5 minutes the 68 came back on the screen and I was able to cut the system off. Also I haven't verified it in the owners manual but my center armrest moves forward and this in turn has improved the comfort level in the seat 100%. I say this because I'm rather short and I tend to lean a little when I drive. Any1 experience the auto climate situation listed above??
The back support in the TL is fine. You may have to keep playing with the seat til you fine that just right spot but once you do, it's the bomb.
Carey
I too experienced the wacky reading on the climate control screen. I don't recall the exact items that were being displayed, but I wasn't able to control it at all either. This lasted all of 10 seconds and I remember it happening on 2 separate occasions. (BOW it's a 2000 AL) This occurred about 5 days after bringing the car home and now, after over a year of using it, it wasn't recurred. Let me know if you find out more information about this as I'd be interested in hearing about it.
with regard to the climate control situation, I have heard this happen before on 2000 models also...since its one of those things that happens out of the blue, it would be hard to prove the problem to a dealer. Hasnt happened yet in my car...but again, I have heard other people complain about the exact same thing. Really strange, but keep in mind that computers today go whacky sometimes!
Have a 2001TL ~2000miles. Since the time I got the car I have felt that the wind noise is excesssive.It begins to increase at speeds over 40 miles and is a kind of hissing noise that appears to be coming from the top of the windows.This increases with speed and in windy conditions.
Took it to the dealer who tried adjusting the window alignment.This did not help any.Took it back and he now tells me this is "normal".
Any objective measures/tests available to diagnose and solve this?
Anyone with similar problems?
You can "test" this theory by driving with the mirrors folded down. (A difficult proposition.) If you get less noise, it is the mirrors.
I find the noise noticable, but not anoying.
Otherwise, I find the Audi 2.8 A4 too compact and a bit slow...crazy interior layout. The Infiniti I30 I never even considered...no exterior style whatsoever...also a bit slow off the get go. The Lexus ES300 seems like a car my wife would enjoy...very luxurious interior...roomy and comfy...and NO excitement however. The IS300 is too new... would rather buy the BMW 325i. The MB C240 is also the slowest of the bunch, I think. I love the design and reviews of this one, but I would rather fork over the extra $10000 with options for the 3.2L model. The BMW 325i is my second choice right now. It has some quality, great performance, always good reviews, of course, at a price (maybe another $4000 optioned out if your lucky, I guess compared to the TL). BUT I like having a damn midsize, NOT a compact. That's one the main reasons for giving so much consideration to the TL. The TL is of course indicative of reliablity, value, and very good (not great) performance. Two minor things, however, get rid of the that damn fake wood and redesign the [non-permissible content removed]! Overall, I really do think the TL has a somewhat classy uninhibited look. Love the grill!!!
• Transmission - when going up hills I feel a sudden downshift and have to put my foot down harder - consequently it sometimes feels as if the engine is straining itself going up these hills. Is this a normal function of the gradelogic system or do I have a problem?
• There is a metallic rattle in the dash that sounds as if it's coming from the left vent. 2 trips to the dealer and they couldn't reproduce. It's fairly constant. Anyone had this?
• The passenger seat, or something around it squeaks as if something's loose when it is occupied. Anyone had this?
Is this a good buy?
