Honda Accord vs Toyota Camry
1202123252655
  • yankeryanker Member Posts: 156
    Accord does have af irm ride too firm on bad roads . Accord still has the silly one piece fold down seat as they did on the last one I owned in 1988. Also why they don't have the daylight on feature a full spare and two power seats is beyond me. Camry has heated seats if you pay extra and the foolish money wasted on wheels to get sunroof. Still I like the Accord and it was much much cheaper and the gas mileage is excellent
    The Camry XLE charges an extra $250+ for heated seats while the Accord Ex with leather includes it. as for the wheels I feel any money spent on silly wheels is a waste. We have an Avalon and behind the shiny wheel openings is a rusty brake housing UGLY and a waste of money.
    I still dont exactly follow you, but the XLE V6 has moonroof and alloy wheels standard. Yes, the XLE 4 charges extra for these items, but I personally think the XLE 4 represents the least value of the Camry line. I'd skip it. With regards to leather and heated seats, I will certainly agree that, at the top end of the model line, the Accord is priced better. Similarly equipped w/o NAV, the EX V6 Accord is $26,260 (no floormats though) whlile the Camry XLE V6 is $28,759 (options: XLE Premium Pkg, Side Curtains/VSC, Heated Seats, Floor Trunk Mats). The one Camry ADV is the VSC.
    You may feel alloy wheels are silly, but they are a hell of a lot more durable in my experience than hubcaps, look better in most circumstances, and increase the resale value of the vehicle. The Avalon is available with hubcaps, if thats your preference.
    ~alpha
  • puzzlingpuzzling Member Posts: 5
    I am currently interested in buying either an Accord or a Camry and I have a couple of questions:
    Can someone please tell me what the difference is between 4 cylinders and 6 cylinders...other than there are two more on a 6 cyl?
    And do you feel that it is worth it to pay an extra $3-4k more for the 6 cylinders?
    TIA
  • talon95talon95 Member Posts: 1,110
    Both the Camry and Accord are available with I4 (inline 4) and V6 engines. I'm assuming automatic transmissions in this comparison, since neither car is offered with a V6/manual configuration (with the exception of the Accord coupe).
    Inline 4 means that all 4 cylinders line up one next to the other in a straight line. Due to the physics of such a design, I4 engines have a natural tendency towards roughness (shaking) during operation. However, most manufacturers (including Toyota and Honda) incorporate balance shafts in the engines that eliminate this roughness to a large degree.
    The V6 engines in both cars have 60 degree bank angles, which means that the 2 banks of 3 cylinders that form the "V" do so at an angle of 60 degrees. The physics of this design result in inherently smooth operation, with little of the roughness that naturally occurs with the I4.
    Here's generally how they compare in actual use:
    Smoothness: In both the Camry and Accord, the V6 engine is going to be somewhat smoother. However, both cars' I4 engines are advanced designs that achieve a high degree of smoothness by virtue of their balance shafts. So many people find the difference in smoothness between these I4 and V6 engines to be pretty slight. Determine your take on this during test rides to see if the I4 engines feel smooth enough to you in comparison to the V6 engines.
    Power: The Accord V6 has 50% more horsepower than the Accord I4, and around 30% higher torque. The Camry V6 has around 35% more horsepower and higher torque than the Camry I4. You'll feel the difference, definitely. Do you need the extra power? Only you can answer that. Most people report that they're satisfied with the power provided by the I4 engines.
    Economy: In both cars, the I4 is rated at 3-4 MPG higher than the V6. Both Accord engines call for regular fuel, as does the Camry I4, but Toyota recommends premium fuel for the V6. So you'd find additional ongoing expense with the V6 engines with the fuel costs.
    Other: Honda provides a 5-speed automatic on both I4 and V6 Accords. The Camry I4 has a 4-speed automatic, while the V6 has a 5-speed automatic (that's if you get the updated V6 that Toyota phased in early this year. If you find a V6 Camry with a 4-speed automatic, the V6 is an older, but still good design with lower output than I described above.) A 5-speed automatic allows for better matching of the gears to the engine than does a 4-speed. This helps gives the I4 Accord a greater performance advantage over the I4 Camry than the small differences between the engine outputs suggest. Toyota's automatic transmission are known for their smoothness. The Accord's automatic in previous years was a notch behind the Toyota's in smoothness, but the new 5-speed auto in the 2003 Accord puts it on a par with the Camry.
    Is the V6 worth the extra $$$? Well, it's hard to say precisely, since neither company offers identically equipped cars that differ only by having either the I4 or the V6. Both companies treat the V6 versions as separate models, and therefore the V6 models include a number of additional items as standard equipment that the corresponding I4 models don't offer as standard (or perhaps don't offer at all, depending on the equipment). This varies a lot between the 2 cars, so you'd be best off checking out the manufacturers' web sites or brochures to research this.
    Basically, you have to decide this for yourself... check out the smoothness and power of both engine types and see how they suit you. Again, the V6 models will be somewhat smoother and more powerful, but the I4 models are still quite smooth and powerful in their own right.
    Then you have to decide about the financial aspect. The V6 models are more expensive, with additional standard equipment, so you have to decide for yourself if the V6 + extra equipment is worth the $$$ over the I4 setup. Then there's also the fuel consideration.
    Personally, I have a 2003 V6 Accord. Prior to changes in my personal situation that resulted in a family sedan making sense, I was driving high-performance sports coupes, so I am somewhat of a "power junkie". I'm sure I could make do with an I4, but I really like having the extra power. Plus I do like the additional equipment on the EX V6. But that's just me... I'm not recommending a V6 to anyone else just because I like it. It's more "fun" than practical.
    HTH...
    PS: Holy smoke, Batman!!! I didn't realize until I pressed "Post" that this post was so long! I do go on... sorry about that.
  • anonymouspostsanonymousposts Member Posts: 3,802
    The Accord EX-L has dual-zone climate control, heated seats, tilt/telescope wheel, leather seating, power driver/passenger seats, LED gauges, 6-disc changer in-dash, and remote window operation. After you get a Camry equally equippped you are looking at $25,984 MSRP. That's the same price as a EX V6 Accord and $1800 more than a EX-L Accord with 5-speed automatic. Either Accords are underpriced or Camrys are overpriced. Maybe that's why there is a $1000 rebate on the Camry now.
    max: The Accord sedan does have a power passenger seat in sedans with leather.
  • maxamillion1maxamillion1 Member Posts: 1,467
    Only the EXV6 SEDAN comes with a power passenger seat. The EX-L Sedan I4 doesn't have a power passenger seat, it never has. Hopefully it will once the car gets a facelift.
    Check www.Honda.com for specs....
    Now, Toyota makes power front seats standard on ALL XLE models, I4 or V6.
    The dual-zone climate control in the EX-L and EXV6 is a wonderful feature, and is by far one of the best systems I have yet to try in any sedan.
    No the sunroof is not standard you have to buy the HV package fora Camry 4 It is a good value
     You really don't need the 6 Honda proved that my Accord Ex is darn peppy. The Camry 4 gets good gas mileage but this Honda is Spectacular so far. My only minor complaint is I don't think the ride is as good but I knew that going in.
    Excellent post re: I4 vs. V6- comprehensive, informative, and a good read. I echo almost completely all of your opinions. Thanks!
    yanker- I'll admit flat out that I'm a Camry/Toyota fan. But I will also be honest and say that the Camry XLE 4 is a comparatively poor value. No moonroof, no leather, no alloys, no side airbags as standard- that is not competitive with Accord EX-L. Like anonymous posts says, load it up and youre at 26K. No thanks.
    A better match, most likely, would be the Camry SE 4 cylinder (since it has a firmer ride and steering, I'd imagine Accord prospective purchasers would prefer this one anyway). With ABS/alloys/leather/heated seats/spoiler/side curtains/floormats, you're at $24,900. Compared to the XLE you give up auto climate control (who cares?) and a power passenger seat. Compared to Accord you gain foglights.
    ~alpha
  • kn6164kn6164 Member Posts: 1
    A friend of mine is selling her 1991 Accord for $3000. It only has 61,000 miles and it has been very well maintained. She has all of the regular scheduled maintenance records, etc... The only down side is it doesn't have air conditioning. How much would it be to add it after market? Is it worth doing this at this price? Thanks for any help!
    $3000 plus at least another $800 to $1200 for A/C seems like A LOT to be spending on a 12 year old vehicle. I'm also always weary of low milage- often, this means lots of short trips, which is very strenuous on the mechanicals of vehicles, even Hondas.
    ~alpha
  • curlyripcurlyrip Member Posts: 11
    To me it seems a little silly to compare the accord with the camry. Up until the 2002 model year the two cars were totally different and aimed at different markets. Accords, in all trim levels, are generally sporty. Camry's have never been, and are more of a touring car. However, in 2002 Toyota introduced the Camry SE. This is the only Camry model worth comparing. Toyota specifically markets the SE to lure buyers away from Accord. I for one own a 2003 SE and love it. However, I will admit, that if there was not an SE trim level, I would have never considered a Camry. Even with the SE trim line there are variants. The SE base model with no options compares very favorable with the LX accord. The SE with a basic options package, sunroof, alloys, etc. compares very well with the EX. The Camry LE, stripped down, falls somewhere between the DX and LX. The XLE has no Accord to compare it with. It is a cushy non-sporty sedan. To get close to an Accord EX V6 you have to go SE V6. The cars are very comporable in every way, but the Accord is slightly sportier. Oh and one more comment. There seems to be much discussion regarding dislike in both the Camry and the Accord's styling. However, I bet you put a tri-star on the bodies, everyone would be ooing and ahhhing.
    You make some good points. Note that the power sunroof is standard on Camry SE models since 03. Also the base Camry LE is directly comparable to the Accord LX. The Camry doesnt have ABS standard, but thats it. The LE also has a few features the Accord doesnt offer: standard cassette player for us old timers, standard power drivers seat, and a 60/40 split rear bench.
    Camry LE with ABS is about $20,800, Accord LX (w/ABS std.) is about $20,500.... so thats not much of a big difference.
    ~alpha
  • awhite57awhite57 Member Posts: 2
    I owned a 2003EX Accord - traded in on a new 2003XLE Camry. The good and the bad of the Honda:
    1. Car drifts either right or left at highway speeds. 2. Brake problems - rotors rust and warp. 3. Too many rattles in the car. 4. Seats are too firm and ride is too firm - this depends if you live on smooth or rough roads - I live on rough roads and you can feel every bump, 5. I think the Center area where the stereo is located has too many buttons, 6. Paint - chips very, very easily, 7. Car starts hard like the battery is low. Good Points - excellent 4 cycl. engine and 5 speed transmition, love the EX Wheels, quality of plastic materials for the interior are excellent.
    As for the Camry - 1. A more luxury type of ride,
    2. Car drives straight down the highway, 3. No rattles anywhere, 4. Seat is more comfortable,
    5. Rotors on brakes do not rust and no warping as well. 6. No paint chips on the front end to date.
    Overall - The Accord is a very good car - what keeps it from being an excellent car is all the minor problems that I had and other people are having 0 maybe in the 04 model they will get these corrected. As for the Camry - I just love the car - not quite as sporty as the Accord, but I will take the Luxury ride over the hard, bumpy
    ride. Just put a rear spoiler on the car and it looks great!
  • winbrowinbro Member Posts: 235
    so what did the dealer tell YOU about the drifting at highway speeds? also don't most rotors rust if the car sits for a few days without use?
    and did you take a beating trading an 03 for an 03?
  • dougweaverdougweaver Member Posts: 48
    For the best of both worlds .. luxury and sportiness .. go with the Camry SE. So far we love ours. dpw
    The Honda dealer said there was nothing wrong with my front end, but it still drifted right or left. I check air pressure, rotated tires, but nothing worked. As far as the brakes, I mean they really rusted and they looked bad with the nice Accord aluminum wheels. Also, I would not have traded my car if I did not feel the deal was good and I was able to get what I wanted. Traded the EX Accord
    for the XLE Camry (which included all the additional air bags and Alum. Wheels)for my car and $ 1200. I was happy with that, no matter what your car is you will have to take some depreciation. Also, I had the Accord for about
    7 months and the Camry XLE has more features than
    the Accord EX.
    As nice as the Camry is, equally equip it to my Accord and it's more expensive. Also, Camrys have also had a few issues when it comes to interior rattles. So bad that Toyota even had a press release in regards to it. To each his own but I think the Camry is an "other than" rather than a "better than" and vice versa. They are two different cars with two different intended markets. Just like the TL and ES.
    "As nice as the Camry is, equally equip it to my Accord and it's more expensive."
    That may be true in your case, but there are instances where that is not true, so a blanket pricing statement cannot be made. Here are just two examples:
    03 Camry LE V6 MSRP: $22745
    03 Accord LX V6 MSRP: $23,460
    03 Camry SE 4 auto w/ABS/Pkg B/alloys: $22480
    03 Accord EX 4 auto: $22860
    ~alpha
  • tblazer503tblazer503 Member Posts: 620
    In the V-6 Camry LE package, you wouldn't get the SAB, TCS, 16" wheels, 6-disc in dash changer, and 8way power driver seat, that you would have to get the Convenience plus package, and the VSC and SAB package which would run about 2000 invoice or 2500 MSRP...
    In the 4 cyl comparo, you would be at 23,339 because you would have to add in the SAB, and VIP security system. You would also have the 4spd tranny instead of the 5spd auto. If you want, you could delete the power seat for a 340 credit, for a 22,999 car and then they are pretty even.
    Couldn't help myself, had to add fuel to the fire. =oP
    Side Curtains are available on all Camrys as a stand alone option, you dont necessarily have to get the VSC. Also, the Camry LE has an 8 way power adjustment standard, plus manual lumbar. The Accord LX V6 may have 16inch tires, but they are on steel rims, the Camry's are aluminum. The Accord LX V6 tires are also no wider than the Camry's 15 inchers.
    So... the power drivers seat thing is a draw, I'll call the tire scenario even since the Accord doesnt give you alloys, add 500 to the sticker of the Camry for the airbags, then the Camry has head protection for both rows of seating and the Accord doesnt, but the Accord has 6 disc changer and TCS and the pricing looks like this:
    Camry LE V6: 23,245
    Accord LX V6: 23,460
    I'll revisit the 4 cyl. scenario after the Bon Jovi concert.
    ~alpha
  • nahagnahag Member Posts: 1
    After test-driving the Maxima LE 04, the Camry 03 XLE V6 and the Accord V6, I felt that I couldn't go wrong with any of them, they're excellent cars.
    The Maxima had too much torque steer and not enough head room in the back seat. A fun car to drive, if you like breaking traffic laws and pretending to be in a Grand Prix race.
    The Accord V6 with the leather and all the bells and whistles, was much, much nicer than my old 92 Accord DX, 4 cy. manual 5 speed. It felt like an expensive sports sedan. Great acceleration. The ride was not as comfortable as I would have hoped.
    Another observation is that when I parked my old Accord next to the 2003 Accord, I could see that the new one is somewhat larger. However, when my old Honda was parked next to the Camry 03, the Camry appeared substantially larger than the Old and the new Accord. Based on the specs for both car's sizes I think I saw an optical illusion, because the new Honda and Camry are very close in size according to the stats. It seems to me that the Camry is larger.
    I opted for the Camry. It is a very smooth and luxurious car. The Maple wood dash design looks great. It has all the power I need with the V6. I live in an area with a lot of hills and Highway entrances from a dead stop. I've been driving it for 2 weeks and I really enjoy the comfort, the handling, the space, design (it's very well layed out) the trunk, with it's stay in position lid that won't guillotine you, the sound system (6 in dash cd and cassette, the Accord lacks a cassette)the sun roof, etc. It's a great car and I am happy that I bought it.
    I also paid $200 over dealer invoice and I negotiated for the extended 7 year warranty at $150 over cost. $650 instead of $999. To get this type of a deal you have to do your homework and contact several dealers, via the internet. Edmunds is a great resource on how to buy an automobile! Thank you Edmunds. My regret is that I didn't negotiate a cheep price on the leather protection insurance, rust and paint, etc. So,I didn't purchase that.
    I looked at the Maxima thinking that I could quell that mid-life quest for an adrenalin rush. I realized that I am a safe driver who values a comfortable ride together with a little luxury. So the fun to drive car that sacrifices comfort; lack of head room in the Maxima and rough handling and less room in the Accord, sent me to Toyota for the Camry. It has every feature that I wanted and of course the reputation for reliability. I also value not spending more for an emblem that offers nothing more than status. (Thus no Lexus)
  • jcihakjcihak Member Posts: 60
    Both the Accord EX V-6 and Camry SE V-6 start at about the same price if you equip them the same, give or take a few hundred. BUT, when you take into account Camry's lower resale, higher gas consumption and premium fuel it will cost you more in the end.
        I think the Camry is great if you are looking for a comfortable or soft ride. I found the Accord handled better, was a lot faster (with better MPG), and had better brakes. It also has better visibility. I did not care for the Camry's 90's vintage dash either.
         If you just compare engines you can see Honda got more power and better economy from the same displacement and yet doesn't require premium like the Camry. Technologically, the Camry is years ahead of the Camry.
         I recommend the Accord with no hesitation.
  • ral2167ral2167 Member Posts: 791
    seems to me any lower resale of camry is offset by bigger discount when you first buy the car-- when did honda ever give rebates?
    on the other hand, toyota has that TDA advertising fee they tack on...
    as far as premium fuel, seems to me that's optional on the camry V6-- it's not mandatory correct?
    toyota has much better color choices too... and no power seat available on the accord LX is goofy.
    honda does have better center armrest i think-- more comfy-- better coinbox too (although toyota has improved in this area, i hear)
  • slov98slov98 Member Posts: 112
    toyota doesn't require premium gas, 87 octane for v6, says in the manual
  • imidazol97imidazol97 Member Posts: 27,816
    Anony says
    >Also, Camrys have also had a few issues when it >comes to interior rattles.
    Seems accord has rattles TOO.
    Check the discussion group
    Honda Accord Problems Part 2
    for talk about accord's noises
                   trans problems
                   steering pulling
                   brake rotors warping
                   etc.
    The Camry had some issues in it's first year and so has the Accord. Neither were enough to make either car a bad car or any less reliable/durable. Don't exaggerate.
  • justinjustin Member Posts: 1,918
    ...are both pretty amazing. low $20's for a 200plus HP, roomy sedan, with good MPG's and low repair costs?
    no one would have dared dream about such auto's in the mid 90's....
    of course, i chose the Accord, for interior looks/functionality and power (V6 models).
    however, someone was right when they said the Camry offers better color choices. Honda has always been very stingy in that area. :(
    as someone who has owned both toyotas and hondas, i have no particular bias...
    the verdict is in.... after observing both cars as they pass me by on the highways of toledo (or I pass them by), the honda accord has the better exterior looks....
    (still debating the looks of new solara vs. accord coupe).
    I love the way my 04 EX sedan in silver looks. Especially once we added the fog lights, decklid spoiler, and fenderwell trim. All it needs now is tint and the front spoiler.
  • motownusamotownusa Member Posts: 836
    You guys gotta be kidding!!! The Camry is head and shoulders better looking than the Accord. If you take a poll I am pretty confident 7 out of 10 people will say the same thing. I think the 98-02 Accord was much nicer looking than the 97-01 Camry, which looked dull. The 02-?? looks handsome, elegant, although in a conservative way. The 03 Accord looks plain weird. The rear end is especially ugly. The Coupe looks nice though. As far as the interior goes, I do agree that the Accord has an edge. It looks like an expensive European sedan than a mainstream Japanese family sedan. I hate the dull, gray interior of the Camry.
  • patpat Member Posts: 10,421
    Beauty is indeed in the eye of the beholder. One's impression of a vehicle's appearance is purely subjective.
    Weird or not, unless you are going to pay for my car, I'll stick with the Accord. Well even if someone bought me a Camry I would sell/trade it and go buy an Accord. But that's just me.
    I can't help but notice how many Camry drivers wind up staring at Accord V6 rear ends.
    I can understand their disgust. ;o)
    Most Camry drivers could care less about being in front. The Accord and Camry are two totally different animals now. They offer alot of the same virtues but their personalities are completely opposite.
  • bamacarbamacar Member Posts: 749
    Anyone notice the 2004 Malibu review in Automobile magazine: not specifically what it said about the Chevy, but how much better handling the new Malibu was than the Camry. They said it was sad how soft and middle-aged the Camry had become.
    I had not owned a Camry or Accord before, but found only the quietness an advantage for the Camry. Looks are mediocre for both, but the interior for the Accord is head and shoulders above the Camry. The dash kept saying Buick Century when I looked at the Camry.
    With the 2004 Camry SE V6 hitting the streets, Camry owners will no longer be looking at Accord's rear end. The 04 Solara does 0-60 in about 7.0 seconds with a 5 speed automatic. The Camry Se V6 would probably match Solara's acceleration (same engine, same transmission). Btw, how often do you see Accords and Camrys racing each other? That would be so funny.
  • lelandhendrixlelandhendrix Member Posts: 240
    Well the 2004 Camry SE V6 will still be looking at the Accord Coupe's rear end, as the Accord coupe with a manual transmission will get to 60 mph in 6.2 seconds. There's also no reason to believe the Camry sedan will get there any quicker, but it's possible it could match the Accord sedan at 7.0 seconds.
    I think it would be HILARIOUS for the Accord and Camry to race. ;)
    I own a camry 03 v6.. I'm 25 and love the camry but I'm not a huge car enthusiast..some people in these and honda vs mazda forums keep defending their cars like they are getting paid to do it
    A Camry fan criticizing Accord fans for being passionate about their cars.
    Kinda sums up the whole debate, IMO.
    Like I said, the Camry and Accord are playing to different crowds now. The Accord isn't as luxury-oriented as the Camry and it doesn't try to be. On the same hand, the Camry isn't as driver-oriented as the Accord. One look at the interior of the cars will show this different philosophy. As much as I might like the outside of the Camry the interior just doesn't appeal to this 24 year old.
  • 2003sev62003sev6 Member Posts: 44
    I have to agree with you in that the Camry is larger than the specs suggest. This makes the Camry more of a family sedan than the Accord.
    is quite minivan-like. i require the car to have a console that goes to the floor - i feel like, in the passenger seat of the Camry, one can see the drivers foot on the gas pedal. don't like that.
  • drummerboy_200drummerboy_200 Member Posts: 44
    I looked into this for about a month before buying my 04 Accord EX. Here are there strengths and weaknesses as I saw them.
    Safety:
    Camry SE, very good crash test scores.
    Accord EX, excellent crash test scores and standard side impact airbags.
    Outward appearance:
    Camry SE, I loved the thing the moment I saw it. It's one handsome machine.
    Accord EX, hated it at first, but soon grew to love the large rear end and mad-looking front end.
    Interior:
    Camry SE, Loved the silver instrument pannel (although offset speedometer seemed out of place) and power driver seat, but otherwise felt bare and void of funtionality. Sunroof controls seemed awkward.
    Accord EX, Beautilfull! The instument pannel was stunning. The Controls were numerous and well thought out. Sunroof controls were much better with the addition of a reset button. The seats also felt much more comfortable. They seems longer and the hip support holds you in place on tight turns.
    Power: (4-cylinder models)
    Camry SE, tried to punch the gas on the test drive and didn't get much.
    Accord EX, I don't know if it's the extra 3HP or the 5-speed AT, but that thing flies. I drive 100 miles a day to work and back, and if I don't watch myself carefully I'm topping 80 at only 2500rpm. I have to really watch for cops now.
    Mileage:
    Camry SE, slightly lower fuels efficiency, but 1.5gal larger tank.
    Accord EX, very good fuel efficiency, and hopefully a large enough tank to get me to work and back all week.
    Conveniece of Purchase:
    Camry SE, I had to search 3 dealers just to find one and in order to get all the option I wanted I would have had to wait 6 months.
    Accord EX, All the accessories I was looking for on the base model. All I had to do was pick a color.
    Room:
    Camry SE, large interior and trunk. Addition of split forldown read bench is a big plus.
    Accord EX, slightly less room in interior and trunk, but still ample. Very large trunk opening makes up for it's smaller size. Add to that a single fold down rear bench and cargo storage is not a problem.
    Overall the Accord EX just fit me better.
    We like the outside of the Camry but the interior lost us. We drove a LE 4 cylinder after they first came out and it was a nice drive, if not a memorable one.
  • corvettecorvette Member Posts: 11,824
    Is there any site which lists the interior noise levels for various cars? I can't seem to locate this information on Edmund's. Specifically, I'm interested in how the 2003 Accord compares to the Jetta in noise levels at speed. Any ideas?
    i have had both cars. they are really about the same. the Jetta had more engine noise, but the Accords tires are noisy. so it is about even. on the SMOOTHEST of roads, the Accord takes the prize. we don't have smooth roads around here though :(
    I drove an EX 4-cylinder "around the block" today. My Jetta is the VR6, so there is virtually no engine noise at speed. I'll take the Accord for a longer spin as I come closer to making a decision. The Accord's engine was admirably quiet, especially in the regard that I wasn't able to hear it start. Like many cars, the idle smoothed out once it had warmed up.
  • richards38richards38 Member Posts: 606
    I had a '91 Mazda Protegé I liked and was ready to buy a Mazda 6i last August. But the 4 cyl. with AT was not smooth and as good as the car was in many ways, the drive train was crude. Next I drove a Camry LE--I know Toyota is an excellent car, but the Camry LE is as exciting as taking a bus. The ride is over-soft, the brake pedal spongy, and the interior bland. Then I drove the Accord 4 cyl. which had an engine/automatic trans. combo that was smooth and tractable, a tight, almost sporty ride, and a superior interior design. For my money, the Accord is the class act among mid-sized sedans and I'd recommend it..........Richard
    I have 2200 miles on my 04 EX-L sedan and I love it. Especially the XM radio.
