A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
I'm also concerned about this water freezing in cold weather. THis could make the doors, trunk and hood frozen shut if it turns very cold after a rain storm during the winter. (I had a similar problem with a Toyota many years ago). For those who went through a winter with their Alero, has this been a problem.
The Alero is the first domestic car i've ever owned. The quality of the ride, comfort etc is on a par with Toyota, Honda etc etc. But today in cleaning the car, I cut my hand twice on rough metal places. In addition, it looks like the Alero is put together like an erector set with all teh bolts, nuts etc. The imports have a much more professional look to them. This is just my 2 cents.
Thanks for any advice
Hopefully it will do as well as my mom's 99 GL which has been trouble free for 25K+.
the alero is called the chevrolet alero! Its due to the fact that Caddillac and Chevrolet are the brands of USA GM's sold offshore. Typically they are sold out of Opel (Germany) or Vauxhall (UK)
franchises. In another example, china the Buick Century is made and sold as the same.
That problem will definetely be discussed with my dealer. I'm very concerned about this since I live in Canada and we do have heavy rainfall in the spring and we do have very cold weather. This problem could be a serious issue for me. I've been researching this car for the last couple of days and this is the most informative site I have found!! Any advice before I go to the dealer would be greatly appreciated.
Spend the time to take a good test drive, then decide.
Make sure the rotors and brake pads are the upgraded versions. Many of us had to have them replaced (free by the dealer) because of a defective design. Make the dealer replace them at no charge before you take delivery.
Good luck!
p.s. But come on Olds, why not say this in the brouchure and even tell the dealers to point this out?
http://www.edmunds.com/newcars/2000/oldsmobile/alero/glssedan.html#stdequip
http://www.edmunds.com/newcars/2000/oldsmobile/intrigue/gls.html#stdequip
I have a 2000 Alero 4cyl. sedan. I feel like my Alero doesn't shift gears (especially 3th or 4th gear) properly. At and over 70 mile of speed it doent' shift down quickly or sometimes doesn't shift at all. I went to a dealership, but they said everyting is fine. They said Alero's overdrive is different from other automatic transmission. To speed over 75 miles are very hard and takes long time (even if it is illegal, we need to run that fast sometimes, right?). According to the manual, at the speed of over 65 mile, you have to push accelator all the way down. But it didn't work satisfactorily in my case.
And very interestingly, today I found a website which shows defects of various cars. (http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy1.cfm), and it says "SOME VEHICLES BUILT WITH 4T40E AND 4T45E TRANSAXLES MAY EXHIBIT A NO THIRD OR NO FOURTH GEAR CONDITION".
Does anybody have the same problem as mine? Please help me figure out what's wrong with my car. I hope to hear many cordial responses of you all.
sunroof, spoiler, the performance suspension
package, and 23k miles for around $14.8 + tax. As
far as I know this is a good deal, but if I am
completely oblivious, please let me know. Thanks.
PS - for those thinking of buying the 2000 model, plan on keeping it a long time, cause these things are depreciating fast. I paid $18600 (MSRP of $22250) for mine after rebates and trade-in this time last year, and I see the Trade-In Value according to Edmunds is down to $11,500. To me, that's a $10,750 depreciation off of MSRP in one year. Ouch - Honda's don't depreciate that fast in six years. Thus, I'm keeping mine until the wheels fall off.
Thanks to this site I had a work order opened and had the brakes replaced. So far this car performs like a dream. I had a 93 Jimmy that rattled like a bunch of skeletons in a tight closet so this quiet operation is heaven. I realize it's new but I hope it'll keep running like this for a long while. I read a posting about K&N air filters, my dealer didn't know what that was, is this a U.S. thing or Canada too and can I get more details on these. What is the advantage of having this and what is the cost.
In the meantime I will continue to drive this puppy, trying to think of a name...Must be appropriate...any ideas???
The Low coolant light was on, so when we took it for a test drive, I popped the hood and checked things out. Long story short... evidence of moisture on the oil fill cap and excessive moisture coming from the exhaust. Of course, took it back to the private owner and suggsted they get fixed under warranty. My question. Does this particular engine have any history of cracked heads, gasket problems, or introduction by some other means of coolant leaking into the engine? Maybe just one of those unfortunate things?
If there are any mechanics on line, when this engine is fixed, should I even consider the car due to potential excessive wear from the exposure to a diluted oil situation? Thanks in advance for your advice.
Did not hear about cracking heads or leaking head gaskets with the 3.1l engine. But I had read complaints about the coolant leaking through another gasket, at manifold, if I remember it right. Again, if I remember it right, the complaints were posted on an old Malibu board, now in archives.
As to the long-term consequences of the leak to the engine, I would rather ask an opinion of a skilled mechanic.
it has about 2000 miles now, and I think the
gas mileage is not what's advertised on the
sticker. If you have a similar model, could
you share with me what kind of mileage you get?
The dealer told me that it will get better
after 5000 miles, it's lower when I am breaking
it in, is it true?
Since I am here, I might as well ask:
if you are living in California, do you know
if the DMV would mail me the license plates?
or I need to go there and pick up one in person?
I got the ownership paper in the mail from DMV,
but they havn't sent me the plates. I hate to
go there an wait in the line for 6 hours.
CQ
I hope it is getting good mileage anyway, I still haven't emptied my first tank yet so I haven't been able to calculate mine but I sure hope it's good because the gas prices here a killing us!
My only complaint about the car is that there are some sharp edges around the trunk and door frames and whenever I clean them I cut my hand. I've always had imports and am not thrilled seeing all the nuts and bolts which I never saw on mthe imports. Also, my car is bright white and I find it impossible to keep clean.
a question for marusha: your numbers are
the same as the ones printed on the sticker.
so I guess Olds didn't lie, but...
did you get those numbers before 5000 miles
or after the break-in? how come my gas mileage
is so much lower than yours?
CQ
coalcracker. my freeway mileage is
not any better than 22, but freeways
here are always jammed, so it's same
as city driving or worse.
I wonder why some people posted that
they got decent mileages, while we don't.
Should I take the car back to dealer for
a tune-up? they should make the car
perform as good as printed on the sticker,
right? otherwise it's cheating.
What's your beef? If you want better than that, then you need something with an engine under 2 liters.
Forget the dealer. Its not cheating, its lawyering.
On any car we have had, I averages 2 or 3 mpg better than may wife. She accelerates very fast and then jams on the brakes to stop. I have better driving skills than she does.(I'm no slouch as I was doing 75+ on I95 driving home last night.) I've always found the sticker mpgs to be fairly accurate.
sunroof, spoiler, midnight blue for approximately
2
months. It's a wonderful looking car and it was
love at first sight. It has 2500 miles so far and
was bought with a mere 97 miles. The problem is
this approximately 3 weeks after I had the car, I
noticed a slight knock after the car accelerated
into third gear. I blew it off at first, telling
myself that it wasnt a knock but some other engine
noise that would disappear after engine break in.
Now, eight weeks later, I am still hearing what I
believe to be a knock (or constant ping)in the
engine after the car accelerates past third gear.
It only happens after the car reaches third gear
and occasionally happens in slow and go
situations.
I am totally and completely depressed. Is there
anyone having similiar problems with their new
Alero? Anyone have any suggestions? I am calling
the dealer this week to get it into the shop to
have it tested. My greatest fear is that they
will
tell me its nothing or there is nothing that can
be done. I am SURE that this new of an engine
should not be knocking and refuse to listen to it
for the next ?? years. Any help will be
appreciated.
2 months. It's a wonderful looking car and it was
situations.
will tell me its nothing or there is nothing that can be done. I am SURE that this new of an engine
appreciated.
I wanted to let you know I have a 1999 white GL3 for sale. The vehicle has 30,100 miles on it. I have taken IMMACULATE care of the vehicle, it has NO DINGS! I have meticulously maintained it, and have added HID headlamps. The vehicle has a V6, Bass Boost CD/Tape, Sunroof, 16 inch tire package, and interior is light grey. I want to get out of debt, and will let the car go for around $14,800. If interested, please e mail me at: colliff@lear.com.
If you are considering purchasing a new car,test drive the Alero, you'll be glad you did.
(P.S.-I don't work for G.M., just happy to find a great car after two months of research & shopping)
Because the financing plan was in lieu of the cash rebates, I could not take advantage of the cash rebates. But don't let any of these incentives fool you into buying an Alero. I would trade in the Alero's extra features for quality and refinement.
Although I put 900 miles with no mechanical breakdown, the fit and finish on the car is terrible. The carpet looks like it will come off. The dash has an unfinished look. The interior rattles, the leather shift knob and the center dome light is loose. The fabric looks cheap and ugly.
Furthermore, the engine is loud, coarse, and no where nearly as quiet or smooth as a Honda or Toyota four cylinder. The performance suspension doesn't improve the handling very much but the ride suffers. I could feel every little ripple and bump on the road. There is a lot of impact harshness over bumps. The brakes are OK, but the steering is numb at the center and not always linear.
I am not leaving out the heating/ventilation system. You can not leave it in recirculation mode without turning on the fan. That means I have breathe the smog fumes coming out of cars in front of me and let outside odor into my car. It turns out turning on the fan will turn on the air conditioner compressor. Correct me if I am wrong, but won't turning on the air conditioner compressor reduce my gas mileage? The manual's justification is that this will prevent fogging. But hello! Not everyone lives in cold climates. I live in Southern California where "chilly" is 65 degrees.
People say that Alero offers lot of bang for the buck. But I paid $19,900 (MSRP $21,600) without cash incentives. For this price, I could have bought a Passat, Accord EX, Camry, Taurus, Jetta 1.8T, or a Galant, all of which I believe are superior cars. Not even the $750 Oldsmobile is offering right now on 2001 models should convince you to buy an Alero. Unless Oldsmobile offers a $2000 rebate, like it does right now on 2000 models, just skip along to a Honda, Volkswagen, Ford, or Toyota dealer. If you're bent on getting an Alero, get a GLS with leather and throw out the "premium sound system".
