Visitor Agreement.
That interesting reading about your problems. When I came over here, the Intrigue 3.5 DOHC was my first choice as it had a really good write up for performance and handling etc. But I could not find one in the exact specification. I could not believe it when GM stopped this model. How do you think the Intrigue compares with the imports? I personally feel GM needs to kick the [non-permissible content removed] out of its marketing people. It's one thing to have a great product, but another to know how to market it.
Ian
No it would not be a sedan at 2250lbs, that why I said it would be a 2 door coupe!! 2250lbs with today's technology would be easily obtainable, even for a smallish sedan. Power to weight saving is I feel, the biggest way as nations, we can save fuel. Look at the huge GVW of picks-ups and SUV's. No wonder their performance is poor compared to the engine power they dish out.
Ian
It's a shame Oldsmobile died because so far there isn't much at GM that I car for in terms of cars. That said, I like the new 04 GP and there are some decent cars coming in a year or two.
Mike
The board is located in the blower plenum near the blower itself. To get to it I removed the upper trim panel in the passengers footwell. If I remember right, the manual said to remove the glovebox for access, but I don't think I did. Look for an electrical connector way back near the firewall on the bottom of the plenum. Remove the connector. The board is held in by two small hex head screws, with one being buried in a small indentation in the firewall (hard to get to). I used a small ignition wrench to remove/reinstall the one near the firewall. A 1/4" ratchet worked fine for the other.
For earlier models, I don't have first hand knowledge but I believe it is essentially the same.
I searched online for the part and found it for $17 but the shipping was $7.50. I understand it is only $25 list at the local dealer so I guess I will pick one up Monday. I may call GM first to see if there is any kind of goodwill repair on this due to the high failure rate.
Mike
It is definitely a problem area that should be covered.
"Suspension - Chassis Lubrication Importance" I found this one interesting because I see no mention of chassis lubrication anywhere in the owners manual.
"Brake Pedal - Clunk/Rattle Noise" I do have a faint clunk in my brake pedal. It's not from the brakes but comes from the pedal/firewall area.
"Front Suspension - Rattle Noise Diagnosis"
"Suspension - Front/Rear Squaking Noise" I do have a rattle type of noise on the front drivers side. It sounds like it's the strut and I figured the only solution was to replace it. I guess I am going to have to spend $25 so I can read more than the titles of these TSBs.
Anyone have any of thes symptons repaired recently and have any idea of the cause.
Mike
Never had been before!I think the reason is oil level(before I had always full at dipstick and now I'm keeping no more than half, I'm using Shell 5w30 oil.
Mike
My wife and I bought a '99 Alero in Jan. 2001 with 32,000 miles on it. For the first 12 months it was great. Then it went all to hell. Here are just some of the major things that needed to be repaired, replaced, etc. in the past 6 months:
- Head gasket(!)
- Fan Speed Resistor
- Fan Modulator(? - can't remember the name of the part - controls which vents the air blows out of)
- Front Tie Rods
- Rear Power Window Motor
- Front Brake Pads/Rotors (even though we got the dealership to replace these before we bought the car, they had to be replaced again 20,000 miles later)
We paid about $2,000 for all the repairs. All this on a car with 54,000 miles on it. Not to mention the dealership (Harris Bros. Olds in Quakertown, PA) was rude and arrogant.
We didn't repair the tie rods...we drove to our local Hyundai dealer (barely made it) and bought a brand new 2003 Elantra GT Sedan (LOADED with more options than the Alero and a 5 year bumper-to-bumper warranty for the same price we paid for a used Alero.
We want to buy American, but as long as they're still pieces of junk, we won't do it. We won't be looking GM's way for a car for many years!
I did have what I consider a normal amount of problems. Rotors were replaced at 13K under warranty. Front pads were replaced and rotors turned down at my cost at 30K. Blower motor resistor board just went (only cost$17). Plus a few minor squeaks and rattles. So far problems have been fewer than with my 2001 Lexus RX300 which I purchased new in 2001 and now have 45K on it. I am often amazed when I compare the features available in the Alero to the Lexus. Not to mention it is about half the cost and much less for service.
Good luck with your new Elantra. Consumer Reports predicted reliability isn't great, but it is one notch above the Alero.
As for Hyundias, they finish near the bottom of the heap in terms of initial quality and long term reliability. If you bought new, at least you have a warranty though.
1) Paint smudging on 3 radio buttons.
2) Outside mirror control broken
Otherwise oil changes and gas.
I honestly wish it had been trouble-free car. We loved the appearance, V6 power, etc. But in the end it was a dog. It's interesting though because my 97 Camaro was a good car...maintenance-free for 3 years...it still had build quality issues, but at least it didn't break down.
You're right - the Hyundais have not had a great record. However, by all reviews I've read and my own experience they are getting a LOT better. GM is constantly criticised for poor build quality and cheap materials...and it just continues. They don't seem to feel the need to address those issues and improve their cars.
I can't stand Hondas and Toyotas - everyone and their cousin has one. We considered the Elantra, Protege, and Focus...obviously ending up with an Elantra GT.
You really should take a look at the newer Hyundais though - the build quality is amazing in a car this cheap.
I honestly hope you all have better luck with your Aleros than we did! But, if not...head on down to your local Hyundai dealer and check out the great cars
http://www.edmunds.com/reviews/comparison/articles/100022/article- .html?tid=edmunds.e.comparison.content..2.Honda*)
The only GM car in there was a Saturn. It got ripped apart for the poor quality, among other issues and finished dead last. And what you know what - the Elantra came in 2nd. That says it for me. Also, I've yet to see a late-model Hyundai with rust here in PA.
Only time will tell, but in my opinion (and obviously many others') Hyundai is now a better buy per doallr than GM.
Hyundias may seem like a better buy but anyone I know who ever had one will never buy again.
Good luck though, maybe they are better now. It will be a while before I trust them though.
The circumstances happened to be just right for the Elantra we bought. It's a long story, but we ended paying $13,000 for a loaded 2003 GT with 40 miles on it. We couldn't touch any other car for that price. Maybe a Cavalier could come close ($15,000-16,000 comparably equipped), but I really have nothing good to say about them (except a strong engine in the Z24) since I test drove one when I was shopping for my car (the Elantra is my wife's). I ended up with a Focus - quite a nice car BTW.
I get those annoying credit card offers all the time...maybe I' actually look into one of the rewards cards
www.gmcard.com
My '02 alero has been flawless and quality is very solid.
I looked at several other cars, including Hyundai, before buying. With rebates and my card incentive, I bought my GX (no trade) for about $12,000. It had many more features and drove much better than Hyundai Sonata or Elantra.
The Alero also has the 5 year bumper to bumper warranty...the warranty that really matters.
Dindak, you are right about the Hyundai warranty having a lot of holes in it. I laugh when I hear TV ads slickly say "10 year warranty".
Speaking of GM quality, I read in USA today on Wednesday about a quality study of most vehicle makes. The survey measured the percentage of garage visits that required service (other than ruotine maintenance)repairs.
Guess which brand needed the least repairs...BUICK. Yep, the GM division beat Toyota, Honda and even the luxury makes. I didn't see Olds, so I assume they weren't part of the survey.
For some reason, I don't think you will hear much about this survey, even in Edmunds. The headline of this survey went something like, Luxury Cars don't need fewer repairs. If Honda had won, the headline would have read, Honda most trouble free car, or something.
This Alero is my first GM car, but from what I have experienced, I will buy again. I know 2 Hyundai buyers who will not be return buyers.
Oldsmobile ranks below industry average, but above Hyunday and practically a tie with Kia.
It's funny to read the rationalizations of some manufacturers whose fame doesn't correspond to the survey results...
:-)I just despised the comments by Consumer Reports, who should be on our side, but is trying to side with foreign manufacturers while many Japanese cars made in America rank up high in the list.
:-POn the other hand, the Alero is far more fun to drive (especially with the V-6) and far better looking inside and out, in my opinion. GM could learn a thing or two from Hyundai about build and materials quality, but I don't know about the long-term reliabiliy of the Hyundai either. I've heard it's much improved, but it hadn't been so good in the past. Given a choice, I'd go for the Alero hands-down; I'll miss it when it's gone!
Bottom line is GM as a company is better and there are probably 5 times as many dealers around to service your car when needed. Hyundia may be better than it was but it still has a way to go before I would consider one.
Heater broke THREE times
Brakes have made noise since purchase, Oldsmobile refuses to acknowledge problem
Seatbelt, yes the seatbelt, even broke. Thank god not during an accident.
Noises while turning the steering wheel
Trim pops off everytime I open the trunk
The car lacks the minimum quality I expect from a vehicle. And be weary of the extended warranty. After 3 years or 36,000 mi, it switches from a New Vehicle Warranty to Majorguard, which doesn't cover nearly as much!
Any other GM dealers in your area?
Best of luck with your next car...
I can't imagine no one in your nick of the woods is listening to you and no one is capable of fixing your car. I'm lucky to have found a good dealer now, but I have delt with bad ones in the past.
Jeremy
