I was wondering if anyone would have a suggestion to fix my problem before I consult my dealer. I have a '99, 4 door, Alero and over the weekend I wanted to raise my "powered" seat up. When I flicked the switch up (located at the bottom left side of the seat) the seat motor hums but the seat doesn't move up (or any furthur down for that matter). Would anyone know how to fix this little problem of mine?
BEFORE the accident I had a couple of minutes to try out the traction control for the first time. I wasn't too impressed. It says in the manual that it limits wheel spin. I noticed however, that it takes a real heavy foot upon acceleration (and the act of keeping it heavy) to have the system intervene. I punched the gas upon a green light, but the LOW TRAC light didn't appear until after about 6-8 seconds of wheel spin. If you are used to driving in the snow (which I am) you usually recognize wheel spin and quickly let off the gas. You don't need the car to do that for you on top of letting you know conditions are bad with the LOW TRAC light. That's just me though...
RE JK296: It sounds like there might be something wedged (maybe a coin or a straw) that may be causing your problem. I'm not an expert on this car (yet), but check to make sure that underneath the seat is completely clear.
Jeremy
1: Trunk sometimes takes a hard slam to close, or may take up to 4 tries to get the job done.
2: Today there was a profound clicking when I had the heater on, and the sound didn't quit when I changed the directional knob on the heater. It was coming from the area where the heat comes onto the front passenger foot-area. It finally quit after having the heater off for about 10 min. then restarting.
3: There is an occasional bubbling noise when braking. Had this on my Malibu but never had it checked out.
Anyway, like I said, it's nothing that needs to be done now, just before the warranty runs dry.
Today I was standing over the kitchen sink and I accidently dropped my key fob and keys into a bowl that was full of water. I quickly pulled them out and pretty much assumed they were toast...much to my surprise though they worked!
Anyway, feedback on my little issues would be great. Thanks in advance.
Jeremy
Jeremy
Brake bubbling is a new one?
Our Alero has had 1 issue, a fogged up headlight. The other issue now is a creaky driver seat. The car is amazingly rattle free though, I love that part.
Since it had gone past the 36,000 mile bumper to bumper warranty, neither the dealer I purchased it from nor GM would fix it even though the cause of the defect was simply poor factory workmanship and materials used to manufacture the Alero.
The pictures of my 2002 Alero and how terrible the dash and door pads have come un-glued an buckled can be viewed at http://www.alero.info.
This is a site every one who owns an Alero or who is thinking about buying an Alero should see.
If a dealer who is trying to sell you an Alero will not give you a written guarantee the they will replace the dash and door pads in case you have the same problems with the dash and door pads coming unglued like mine has--pass it up no matter how good the car looks at the time.
Trust me, the dash and door pads will not hold up and will sooner or later look just like mine does right now on my 2002 Alero at 37,000 miles in 2 years. The defective dash and door pads had nothing to do with the miles the car has been driven.
I have an '01 GL2, Black 4-dr w/ the 2.4 and 5-sp. Love it, and have had 32,000 virtually trouble free miles (except for failed turn signal/hazard switch).
It DOES have Traction Control, even w/ the 5-sp. Like you say, it's not the best system out there, but it does kick in and is pretty effective w/ a manual tranny where you can start in 2nd or 3rd gear to further lower torque.
The dash is pulling away from the center vent in my Intrigue.
GM may (and I think will) fix it under "good will" but they don't have to. Let us know what happen.
:-P
I got the estimate back on my car today. Here's what they need to do:
1. Rear decklid - repair(re-align)
2. Rear bumper cover overhaul
3. Rear bumper cover - refinish
4. Replace 2 rear bumper cover retainers
5. Replace rear bumper cover absorber
Then on top of these charges there is the hazardous waste disposal, paint costs, and rental car charge. Total the estimated $742.76 USD. One again, I'm glad it wasn't my fault.
When I had first showed the estimator the scratches (or what I thought to be scratches) he immediately informed me that they were stress cracks in the paint and bumper cover. Interesting...
I really wish this hadn't happened, since the car has less than 30K on it. :-(
Wish the "Silver Bullet" good luck when she goes under the knife...err, I mean screwdriver.
Jeremy
BTW, It looks like my tires need just a bit more air in them. Even if I add a little to all of them, do I still have to reset the LOW TIRE PRESSURE light? If so, is the only way to do it by removing the fuse panel cover on the driver's side dash? I heard that another way was by using the reset button on the dash. Is this true?
Jeremy
Seat creaks when I sit down initially and move around more than a little. It sounds like an old door though not as loud. I suspect it needs some lubrication but it's hard to know where with the power seat mechanism under there so I will let the shop do it next oil change.
Do you have alloy wheels? If so, you may find that you need to air more frequently now that it is cold out. I know some people (including myself) have had issue with tires losing air more frequently b/c cold weather causes different rates of shrinikng in the wheels and tires - resulting in slight air leaks.
I've never heard that you could use the (odometer?) reset button on the dash to reset the tire sensor. If you find out how, let us know!
Traction control: on our 2000 Alero GLS (V6, auto) the traction control system comes on within a fraction of a second as does the light.
Tire pressure in cold weather:
http://www.tirerack.com/winter/tech/maintenance.html
I would definitely (for starters) looks at how the trunk lid operates and see if something is bent out of shape/misaligned or, even better, maybe it just needs to be cleaned and lubed. Having to slam your trunk like that is definitely not right.
Has anyone seen or heard of something like this with 3.4L V6 Aleros. Just curious of what might be to come. Then again, we've never had any warped rotor problems so it's a bit hit and miss on this stuff.
Jeremy
Today I got the windows tinted on the Silver Bullet...she looks sweet! I got them tinted as dark as legally possible. I got every window other than the windshield done for only $89.00. There are zero bubbles in it and it looks great!
Jeremy
Jeremy
How deep is the scratch?
jeremy
There have a couple of paint scratches on our Alero but I have not got around to touching them up. It's hard to see these things on your pride and joy!
Speaking of wheels, I need a balance and rotation. I noticed a little shim in my wheel while on a trip to Ft. Collins, Colorado today. There was only a bit of shake over 90 mph...oops...did I say that out loud? (I wanted to stretch her legs a bit.)
While on my outing, I realized that this car does an awesome job on the highway. The MPG is extremely impressive compared to city driving. I usually get about 230 miles per tank (I fill it up before my light comes on), and today while still having a quarter tank left, I have 210 miles on the tripometer. Hopefully that will come out to at least 25 MPG.
I was also curious, when you guys figure your MPG, how do you do it? What tank size do you use? I think the tank is approximately 14.1 gallons, but of course the light comes on long before the 13.5 mark. I usually do it with the miles driven divided by what it takes to fill it up. I run the engine on Conoco, Texaco, or Shell mid-grade gasoline, if that makes any difference.
Today I did notice one or two rattles. One where the dash reaches the windshield and the other near the upper door speaker around the A pillar on the passenger side (I think I mentioned this one before). I also noticed a little bubbling or ungluing on the passenger side door padding where it meets the window. Hopefully this will only be isolated to that one door. I'll be sure to get it all fixed before 36K.
Also, I know a guy who works at a Goodwrench service dealer. He told me that before the warranty runs out, to bring her in and tell the advisor that there is "some sort of oil leak," whether you actually notice one or not. He said that many GM vehicles develop any given leak before 36K and the techs are likely to find something that will be fixed on the dealership's dime.
I still haven't gotten the back end of the Silver Bullet fixed yet. The insurance company that is supposed to be paying for it is giving me the runaround and I'm getting pretty sick of it. When they called to take my statement, they tried to get me to say something that would point the finger away from their driver who hit me. Yeah right...I may be dumb, but I'm not THAT dumb. They also said an adjuster would contact me by Monday...still waiting.
On a lighter note, I was thinking about giving the car a true wax. On my Malibu, I used Eagle One Wax As You Dry a couple of times and got pretty good results. This time though, I think I will do it the hard way. I wanted to look into Eagle One Carnauba Wax, but we'll see what I end up using. BTW is it too soon to do a wax? I have 26.5K miles on it.
Anyway, everything is great here. I'm in love with the car still and hopefully will be for a very long time to come. I can still smell the new car smell...ummmmmm :-) I will definitely try to post photos of my baby.
Jeremy
Anyway, I was curious what brand and weight of oil everyone runs in their Aleros. In my Malibu, I used Valvoline 5W-30 Durablend, which is a synthetic blend. I was thinking, however, of switching to Mobil 1 pure synthetic in my new ride. I have always used and will continue to use Fram oil filters as well as air filters. Feedback on this topic would be great! Thanks.
Jeremy
Still no rattles but the seat belt mechanism makes a clicking rattle sound sometimes. Too minor to bother with it. Still have the sqeaky seat.
Merry Christmas.
The last time consumer reports tested motor oil (which was quite awhile ago) they saw no benefit in synthetic oil and recommended regular dino oil.
I also like Fram filters back from the days when I used to do it myself. Now I settle for whatever the quick change place has. If you do a search on Fram you can find some discussion boards giving them a bad rap. It seems when you dissamble them and compare some of the internal parts to other brands the Fram falls short. However, I see no evidence that Fram does not provide the filtration required by today's engines. The more expensive filters may be overkill.
About the oil, my grandmother used to have a Ford something or other when I was younger, in which the shop she did her oil changes at, used Pennzoil, the makers of Quaker State. At like 45K the engine went. When they replaced the engine, they said the failure was due to excessive wear in the cylinder walls. Who knows if that was the real reason, but that's why I stay away from Pennzoil and Quaker State, as does my family. I guess it also could have been because it was a Ford...
Jeremy
I checked the tire pressures (Michelin Arctic Alpins on steel wheels), and they were all 30psi so no problem there.
After we got back home, I brought it in and had the front, driver's side wheel bearing replaced. A quick spin down the highway clearly showed how much quieter the car now was and now you could hear the real tire noise - which is actually not nearly as loud as the failing bearing.
Damage (CDN$)=$295 aftermarket part+$58.40 labour
OEM part was $150 more, which I did NOT go with.
According to the mechanic I spoke to, this is a pretty common repair among Grand Am too (a fellow N-chassis!).
Okay, so to the list of "classic" N-chassis problems:
(1) wheel bearing
(2) warped rotor
(3) blower motor resistor
(4) intake manifold gasket
(5) fuel-level sensor in gas tank
Personally, I like long product cycles. At least I know what I'm getting into.
Jeremy
Jeremy
Jeremy
Averaged 26 mpg or more for the distance. Was a program vehicle with 8000 miles when purchased and 34202 when traded in on a 2002 Buick regal with 8000 miles.
I will now take my wife's 2000 GX intrigue with 48000 miles and let her drive the fully loaded Buick with most every whistle and bell. However no heated seats.
Liked the Alero but the Intrigue is a much better ride. Fuel mileage was within 10% of being the same between the two.
Other than intermediate shaft and steering rack the Intrigue has been bullet proof.
Sitting in the two car garage and looking at a buick and intrigue one wonders, what's the difference? The ride is probably a little softer in the Buick. But, otherwise they are almost the same.
I just love the proven designs that are being discontinued.
I must find this Info. again as to where the Buick regal reliability was better than the camcords and the minima or something like that. This was supposed to have been in Nov. consumers Digest and the Wall Street journal.
Glad you like your Intrigue as much as we enjoy ours.
Jeremy
If you compare vehicles at:
http://www.jdpower.com/cc/auto/index.jsp#
With only giving weight to the longterm dependability, and list the Regal against the Accord/Camry/Altima it comes out looking pretty darn good.
As a make, Buick has done well based on 3-year reliability -- so why the heck can't GM put that know-how into ALL of their products ?
http://www.jdpower.com/awards/industry/pressrelease.asp?StudyID=7- 49&CatID=1
Are the Buick components really THAT much more expensive that a Pontiac or (now lamented) Oldsmobile ? As Honda and Toyota have shown, people are ready to pay for that and THEN some, although it takes a while to change a reputation.
Of course, it takes a while to lose 10 or 20% market share too.
Jeremy
http://www.canadiandriver.com/news/04images/05g6_1.jpg
Beautiful.
Jeremy
