I've noticed a leak from under the engine bay. It is too thin and clean for engine oil, so must be power steering or auto-box fluid. Unfortunatly, the latter has no measuring tool. I've looked underneath, and the leak appears to be coming from up above the starter solenoid area, but it is impossible to be sure as the leak travels with the wind etc as we drive along. Does anybody know where i should look to check for leaks from the power steering system and auto box?
The leak is not significant, but I'm worried damage might be done if the levels fall too low. The power steering dip-stick showed a small drop of oil missing, but nothing too significant.
Are these engines renowned from auto-box and power sterring leaks?
Thanks for any help here.
Ian
Talking of coolant. I have a sludge problem. I thought it was the Dexion. I flushed it and put in another brand. After about 3 months, the sludge comes back. It's not excessive, but leaves a heavy film around the expansion tank. Do you think I might have this intake manifold gasket failure? I'm not losing coolant or engine oil by the way.
I also am concerned about the winter driving capabilities, sounds like the stock tires are bad, and Michelins are needed. Any other comments on this issue? Why is the traction control not on all the time? It sounds like you have to says oops, looks slippery, better use traction control.
Sorry if I sound stupid, comments welcome on above topics, and on resale value.
Our traction control is always on, though there is a switch you can use to turn it off (not sure why people would, but it is an option). I think what folks are saying is that there is a slight delay between wheel slippage and the traction control activating. But it's not a matter of deciding to use the traction control or not, because probably most of us keep it on all the time. My husband and I do, anyway.
Re: the intake manifold gasket problems others have mentioned, we haven't experienced that yet.
A buddy seems to think that the power steering fluid smells burnt, and that there are metal shavings in the fluid.
The breaks are fine.
Any ideas? Need some help here!
Looks like the brake problem is not solved yet, my 2003 needs new inner pads at only about 26,000. The outer pads are still well short of the wear indicator, however, so the first indication was the grinding sound. Has anyone had luck getting the dealers to cover the first set under warranty since this is so premature? I have had over a half dozen GM vehicles over 15 years, and have never had one go less than 50k, some 70, even minivans towing boats. They used to use low quality brakes on base cheap vehicles, but you'd do better if you went up a trim line -- apparently I didn't go up far enough...or maybe you can't go up far enough in an Alero
Anyone recommend a specific brand of aftermarket metallic pads that improves the life? I see Raybestos in previous post.
All service records were provided, and all service work was perfomed at the dealership.
However, the 100,000 mile work has not been performed.
What servicing is recommended?
Are there any special Tranny Fluids or Coolants for this car?
Does aluminum require specai antifreeze?
Any feedback, good or bad on the 4 cylinder engine or the Tranny?
The only additional service required at 100k other than the normal things is a spark plug change. Coolant is Dex-Cool which is good for 150k or 5 years. If it has not been changed yet, you may want to get this a little early at 100k just to be safe. I would stick with Dex-Cool. It is a good long life coolant. Trans fluid is lifetime, unless you tow or live on the surface of the sun. It doesn't even require checking unless there is a leak.
Personally, I live in suburb of a small city, population of 120,000. Drive only 7.5 miles to work, one way. The path is mostly flat, except one 300 ft. hill. However, there is a lot of turns and the roads are rather twisty. 24 traffic lights in one direction, 27 lights back, not to mention a couple of stop signs. I guess, the constant acceleration and deceleration is hard on transmission.
The fluid is probably good for life in flat rural place with moderate climate. A farm in Iowa, Indiana...
Any ideas of what I can do to fix this? I'm not sure if this is a major concern or if my daughter's safety is at risk. Thank you for any advice you may have.
I dont see anything in the manual about a timing belt or timing chain service.
Does this engine have a belt, or a chain? Any info on what the service interval is on this component? Don't want to ping pistons and valves with a stripped belt or chain.
Alerofan
I was having the same issue with my Alero. After several issues of having my battery die I realized that if you put the car in park and press the gear shift button (I'm assuming its an automatic down) in and move it around a bit the key should then return all the way back to off... Hope this is clear enough---
Today when I was leaving the University Library, I noticed that my red 'SECURITY' light was on after I started my car. I know that this is related to the ignition switch and the Passlock II system, but I was wondering how long you guys thought that I would have before I needed to replace the ignition. After shutting off my car, I restarted it to see if the light would go out, and it did. Also, I didn't notice the light on before I started my car the first time, which I know can happen as well. So any thoughts on this would be greatly appreciated. I can't afford to spend $300 on a new ignition since I'm a poor college student
BTW, she is a silver 2002 GL1 V6 four door with just over 48K miles on it.
Jeremy
2. Ignition switches do not like much weight. Like when couple of pounds of keys are dangling under the switch. Better if the car key is separate.
What is the average MPG on both the 6 cylinder and 4 cylinder 02 / 03 models?
As with gas mileage, just before my accident, I was getting 32 miles per gallon pure highway. I am home from school now and my mom just moved, hence I had to move with her. I am now 60 miles round trip away from work, so I've been doing a lot of highway driving. Pure city is pretty crappy at about 22-24 MPG. I am continually surprised by this car's MPG on the highway considering I now have just under 50K miles on my car, it's a V6, and its a pushrod engine. Its about as good as a new Honda Accord V6 on the highway
Jeremy
P.S. The security thing came on again only about 10 minutes before my accident. I still need to get the key cleaned though....
Anyone out there ever removed the driver seat?
Congrats on your purchase Myalero02, and I wish you luck with her. By the way, what color, engine, and trim package do you have? I have a 2002 GL1 V6 Sedan with 49K miles and it's silver.
Jeremy
P.S. I got more news on my car today: it won't be done until the 17th of June AT THE EARLIEST :mad: I'm only a little angy...
I own a 1999 Alero GX. The problem is the fuel gauge gets stuck at about 3/4 of a tank of gas then when I get to about half a tank it jumps back and forth between full and empty. Can anyone please help me which fixing the problem? thank you
I am looking at replacing some of the interior parts, like some of the dash sections or door panel pieces. Does anyone know what website I can find these items. Whenever I search for them I always get directed to aftermarked parts and when I type in OEM parts it does not include interior part. Please Help!
It may be possible to fix this as a do-it-yourself repair, but we couldn't manage that at the time due to it being December, and we don't have a heated garage.
Jeremy
By the way, I get my baby back on Friday!!!! :shades:
