I was going to extend the warranty on my 04 GA GT since I'm over 24K now, but my wife is a financial manager and was running around with a spreadsheet showing why it's better to wait until I'm closer to the mileage expiration at 36K so I just said whatever.
miles. However, I am concerned that the anti-lock brake and low traction light came on when making a sharp left turn. It only stays on until the next time the car is started, but it's done this twice. I'm sure it's tire related, but wonder if the installers could have done something to mess up the anti-lock system. Any thoughts?
DC
Those Accords are looking better and better all the time.
DC
We had both of ours replaced before it hit 60,000 miles -- had 140,000 miles on our previous '95 Corsica and '87 Taurus and they had the original front wheel bearings.
:confuse:
No call by 4:30 yesterday either, so I called again. "Electrical problems are difficult to fix." No estimated time for completion. No apology for the lack of communication, or inconvenience of being without a car for (now, Thurs.) 3 days.
No explanation for why when I bought the car they said they provided loaners for repairs taking more than 3 hrs., and they don't offer one now on the 3rd day.
I told them I have to go out of town on Sat. and need the car back. I was given no promises, only that the service tech would be informed.
I'm really fed up. I've been unusually polite and restrained so far, but if they leave me hanging without word at 4:30 again today, they'll see "the other side of midnight" with me!
This didn't sound right to me so I called the local GM dealer's service dept. and the service writer said that although the book says that that he recommends changing it at 50000 anyway. Anybody have an opinion on this?
I live in a suburban area and car is driven about 8 miles each way to work with a few redlights on the route but not an excessive amount like driving in the city.
Also the manual doesn't mention anything about changing the fuel filter.I also asked the dealership about this and they recommended every 30000 miles which sounds right to me. Was just wondering how well these transmissions hold up if you don't service them if they are not used under harsh conditions.Car has the 2.2 4 cylinder engine.
I checked into the fuel filter and the consensus was that it should never need to be changed for most of us, as long as you use a good brand of fuel. If for some reason your area is known to have fuel quality problems then I suppose it's good peace of mind to do it.
My 99 Grand Am had over 100K when it was totaled in a collision and I had never changed the fuel filter, even though I did buy a new one, it's still on the shelf where I left it. I don't know if it will fit my 04 or not, I suspect it will.
There was only one interior moulding that needed replacing when the car was new and I brought it to the local Olds dealer (Gidron in Yonkers NY) and they managed to scratch my brand new car terribly on both the front and rear bumpers (which they has to repair... but I was pissed). I can honestly say they were horrble.
Anyhow since that tumultuous beginning, the car has never been back to the dealer for a warrnaty repair.
But recently the drivers side interior floor has been wet. Very wet. Definitely a water leak (though I have not ever seen the actual dripping water). I see issyvoo has some similar problems... and his dealer is saying the windshield seal is the problem.... I've seen other posts talk about deal issues around the doors. Anyone else have any ideas on what the issue may be? And most importantly, were the dealers able to correct on the first visit?
I plan on bringing the Alero to another dealer that I purchased 2 GMC trucks that also sold Olds' that is also about 60 miles away. They have an excellent service dept (Park Cadi Ponti GMC in New Milford CT) but wanted to have some idea what I might be in for with this fix. I hate to trade her in (she is low miles... like 25k).
She is under the second part of the 5/50 warranty....
I hope they will pull a miracle with the Alero leak (that I did not buy there).
Oh and my dome light recently stopped working in the 'door' mode. Maybe it is time for a trade... maybe the CTS stripper with the 5 spd!!!
http://www.autopart.com/fpr/fpr2004OLDSMOBILEALERO.htm
Here is some information that may help some of you. The initial link is to a bulletin from GM Engineering as it applies to GM Fleet Trucks and Vans. Following that, there is a re-write of the same bulletin so that we can apply it to GM cars. I used this Modification on my 2002 Oldsmobile Alero as a Permanent Disablement of Passlock.I did not install a remote starter. It works great.
http://www.gmupfitter.com/publicat/bull/bull26.pdf
PASSLOCK I or II DISABLEMENT
The following is a procedure to disable Passlock I or II Systems for vehicles in which remote start/stop system installations are required. This procedure is required because a remote start system will not function with the current Theft Deterrent System (Passlock) which is included on many 1996 and up GM vehicles.
Please note that this modification is intended to be used only in conjunction with the installation of a remote start/stop system and does not provide a procedure to install a remote start/stop system.
CAUSE
If an attempt is made to start a vehicle by a means other than a key rotation in the ignition switch, the Body Control Module (BCM) will interpret this start as a vehicle theft and disable the fuel injectors.
CORRECTION
A minor wiring modification may be made to allow the vehicle to be started remotely. This modification includes adding a switch to allow the customer to select “ON” to allow remote starting or “OFF” for normal Passlock operation.
CAUTION: When this modification is performed and the switch is set to the ON position, the theft deterrent feature will be disabled. When the theft
deterrent is disabled the SECURITY/THEFT SYSTEM telltale will light up indicating that the theft deterrent system is NOT functioning.
PASSLOCK MODIFICATION
Refer to appropriate GM service manuals and/or SVMQP Electrical Guideline Manual for instruction on splicing and electrical connections.
1. Select a suitable on-off switch (see note below) which will be used to disable/
enable the Passlock System. Mount the switch in a location such that it is
accessible to the driver and will not interfere with normal vehicle operation.
NOTE: This is an extremely low current circuit (approx. 7mA), it is therefore very important that a high quality, low energy, fast acting switch be utilized
for this application.
2. Turn the ignition switch to the OFF position.
3. Locate the Main Ignition Switch Harness in the Column. GM's Passlock System wires exit the Ignition Switch Tumbler together and then join with the Main Ignition Switch Harness. (See http://www.bulldogsecurity.com/ or http://64.85.6.118/diagrams/diagrams.asp and select your Make, Model and Year for wire colors and clues on the quickest way to access these wires.)
4. Locate the Yellow Passlock Data Wire which is included in a bundle of three tiny (20 GA) wires wrapped in friction tape.
Cut this wire and splice a 0.5mm2 (20 GA) yellow wire to each end of the cut wire.
Keep wire length to a minimum. Route modification wires clear of moving parts.
Connect the yellow wires to the switch such that the contacts are OPEN when the switch is in the ON position.
5. Turn modification switch to the OFF postion (contacts closed).
6. Start vehicle to verify normal operation. If engine “cranks but will not start"
recheck the switch position (contacts should be closed), wire connectors and
modification wiring.
SWITCH OPERATION
To enable remote start:
Start the engine with the ignition key (modification switch must be in the OFF
position). Turn modification switch to the ON position (contacts open). The
SECURITY/THEFT SYSTEM Telltale will light up indicating that the Passlock System is inoperative.
Once the SECURITY/THEFT SYSTEM telltale has been on for at least 5 seconds the vehicle can be turned off and then remotely started.
To disable remote start:
The Passlock System can be reactivated by turning the modification switch OFF
(contacts closed). Vehicle can either be running or off when this is done.
Please note that the VCM/PCM will record Diagnostic Trouble Codes (DTCs) related to the security system when the modification switch is in the ON position (circuit open). This is due to the way that the VCM/PCM interprets this condition.
NOTICE
Any condition which removes battery power from the Vehicle Control Module/Powertrain Control Module (VCM/PCM) (e.g. dead battery, disconnected harness connectors, etc.) will prevent the vehicle from being restarted. If the engine exhibits a “cranks but will not start” symptom, place the modification switch in the OFF (contacts closed) position. This will reactivate the Passlock System and allow the vehicle to be started with the ignition key.
Ray
Proud Member of The Anti-Passlock Club :P
Thanks all!
Dave
Ray
I'm a new on this issue. Looks great. A lot of tips for non-experienced people just like me.
My question is about Alero user's manual. I got my car without this, and I'm looking for this because there are some tips we can get there.
Could you please help me with that?
Thanks in advanced.
MT
Can anyone advise what is wrong please?
Kathy
