Visitor Agreement.
And it's wayyy too late to have the classified as a lemon, if that's what you meant.
Here's a curiousity though: My 00 Accent also had problems with the throw-out release bearing. It made a whistling/rubbing sound whenever the clutch pedal was in the up position. They agreed it was bad and replaced it but also replaced the clutch without me complaining about it. The noise has since come back but to a lesser degree. I wonder if something else is causing the bearing to wear out too quick.
Someone in the Sonata threads mentioned that Consumer Reports has given a "recommended" rating to the Sonata, indicating that quality has risen quite a bit. I haven't seen the latest issue yet, but I hope that this turns out to be true.
Best of luck to you.
Overall I've been very pleased with the Elantra and would buy it again if I had to do it over again. In fact, I've wondered about what small car I would buy if there were no Elantra. There aren't any others currently available that meet my needs as well as the Elantra does; a 3-Series would, but it would cost a tad more. ;-)
Just so you know, regarding my problem Elantra, all of the work has been done at Elantra dealership shops, but I did switch to another dealership halfway through these problems. That is why I switched, hoping to make a difference. Except for the initial clutch work done at the first dealership, which I don't think was done properly, I don't think the rest of the problems are due to mechanic errors - just a lemon of a car.
Just curious, why? You have only put 16,000 miles in 2 years. My 01 Elantra will be 2 on Dec 11th, I am currently at 63,000 miles and even I don't follow the severe service interval. I just wondered.
Paluka, the '03 Corolla came out in February, and the Civic has not changed significantly for '03, so Edmunds.com had lots of time to look at them. If anything, the Elantra suffered from timing in that the Elantra GT sedan would have qualified for the under-$15,000 category and should have received higher marks than the GLS. I am a bit surprised (and pleased) that they chose the Elantra over the Corolla. I personally think the Corolla is a notch better overall than the Elantra GLS, if you can fit in the driver's seat. I don't, so the Elantra is the better car for me. Edmunds seems to put a lot of value on value in their reviews, and the Elantra has an advantage over the Corolla there. I rank the Protege right up there with the Elantra, but it too is not the car for me because of its harsh ride.
Maybe the 7,500 mile oil change satisfies the warranty (up to 100,000 miles), but I like my engines to run for more than 200,000 miles...so I change at 3,000 miles). Maybe it isn't necessary, but I normally pay only $10 - $12 for an oil change and tire rotation, so it seems like cheap insurance...
What does happen though - and this applies to any oil is that they become diluted and contaminated by impurities - unburnt petrol, exhaust polutants etc etc. Also the additives that are added to the oil breaking down and lose their effectiveness over time.
Where synthetics are of advantage are under severe conditions, whether they be weather or things like motor racing.
My 2 cents worth.
Driving 55 can be dangerous.
I just decided today to have my vehicle replaced under the lemon law. I really like Hyundai, and so I don't want the money back but I just had too many problems with my current car. First, I constantly have rattles in my doors, which they tried to fix once with no lock, and the second time they said they couln't here them. It is true that they where not present at that time but I don't have time to go to the dealer right after my door starts rattling. The door seal had to be glued as well and it is still sticking out a little bit. Then the main problem I started to get was a cluch noise, resistance. The first dealer tried to fix it once, which did not help, and then they tried to order and replace some switch which even I knew was not a problem that was causing the noise. They returned the car to me with the same problem like it was already fixed. I thus went to another dealer. There, they replaced the main clutch cylinder, which did not help, and finally decided to rebuilt the whole clutch assambly which fixed the problem. After 3 months of driving, I am starting to get the same problem with the clutch (rubbing noise). They tried to fix it more then 4 times and they did not fix it so I have a reason to file a claim, and I am just doing that because I don't have time to go to the dealer everymonth with a 9 mo old (now) car. Also during the summer, my instrument pannel window cracked from the heat. They replaced that, but I had to go back because a piece of plastic was sticking up from the instrument pannel which they had to adjust. Just a lot of bad service. Currently I still have steering wheel shaking while braking in high speeds, so I assume the breaks or rottors are going bad, and I won't even bug them to fix it because it is too much trouble. I also have a wistleing noise comming from the left top drive side when going above 85 miles per hours, which they can never check, and finaly my trunk starts to squeek. You can see how many problem I have and it whould not happen on a new car. The thing is, I love the car for the price. You get everything in is, plus a great ride and performance. I just don't want it to break that much. I hope they will give me a new car, and it will be more reliable.
Just wanted to share it with all of you.
As for the wind noise, I do not think it is normal at least at 85 mph. I don't know if the A-pilar is the one on the driver side in the top front left corner, but I think that is what a-pilar is and this is where I have the noise. The first time I got it was when I went about 105 but that was only for a few seconds. Now I get it 85-95 or so and then it goes away. I think this is due more to the insulation which causes the air to leak and make that noise. Hope that helps.
