FWIW, my dealer had to keep my car overnight for some warranty work (the tech had to go to a funeral) so I got a free loaner: a '01 Daewoo Nubria that makes my Elantra feel like a Mercedes in comparison. Oh well, it's free--they don't even expect me to refill the gas.
The dealer tech should have checked all the connections to the lights and the light switch along with all the applicable grounds and the fuse box wiring for the lights.
You also have to wonder if the on board computer even keeps track of what is going on with the lights? Or may be you were refering to an external diagnostic's machine?
I'd say it's time to take this "up the chain", starting with the dealer's service manager. You might also try a different dealer, if that's an option for you.
Hmmmm ... seems to me the tire should be available at a much lower price. I looked it up on the Sam's Club website and can save myself more than $100. Needless to say I cancelled the order and will locate them at Sam's. Hopefully the Dunlops will last a little longer than the Michelins, which I have used for years. They aren't troublesome ever, but they don't last long enough either.
The batteries in these vehicles are notorious for dying in the 3rd year. My 01 elantras died today after 28 months. Hyundai will cover the install and 25% of the cost of the battery. ( a severly marked up battery)
After almost 3 hours in the service dept, I was charged $63 for a Hyundai branded battery.
It is a 500 CCA rated battery that Hyundai will replace free for 12 whole months. (gee, wow, should I be impressed? NOT!!)
I could have gone to Autozone and had them install a 590 CCA, 2 year free replacement, 7 year pro rated battery for the same exact price.
I did ask for the battery warranty info before they installed the battery. They told me they would get it for me. They did. After they installed the new battery. I told them if I had know I was going to be ripped off I wouldn't have let them put the battery in the car. I was tempted to tell them to put the bad battery back in the car and I would go somewhere else for a good battery and not their junk. But after almost 3 hours and a screaming headache I said to heck with it. I told them they would never get another dime out of me for repairs for that car. They would only do fully covered warranty work.
Sorry for venting. Overall the car has been worth buying.
I also noticed that the black on the inside door handle no longer extends back the full length of the armrest. And the dashboard and console in both interior colors is darker than the door panels (dark grey for the grey interior, sort of an olive brown in the beige interior). I could get used to it, but since the edge of the dash sort of flows into the doors, the color should as well.
The subtle changes to the gauge cluster are quite nice, as are the vertical vents (not in chrome, thank goodness). I am very glad Hyundai resisted the trend towards satin nickel finishes on everything, which we all know will wear away within a year. All in all, this is a nice freshening.
New Crimson Red is a nice shade (has grey interior), and there's also Hazelnut, which is that sort of gold color from the Accent.
Re the '04s, have you noticed Hyundai has added remote locking as a standard feature on the '04 GLS? Cruise is still an option, however, as is a CD--two big omissions IMO for a car that is otherwise well equipped. (The other big omission is ABS as a separate option at a reasonable price, ala the Corolla.) C'mon Hyundai, CD players don't cost that much more compared to cassettes these days. Another option I'd like to see (at a reasonable price) is the CD/cassette unit such as in the Sonata. I still have some oldy-but-moldy cassettes I like to play. I think it would fit the double DIN slot in the Elantra. Last time I checked the dealer price on the CD/cassette combo unit it was $700. I could get a state-of-the-art audio system with a CD changer for less than that.
Niels
As far as an easier way, put the car in gear and roll it forward/or backward. Of course make sure you don't roll the car down you driveway :-) I think this still works with and automatic.
These are the things they will change or perform for the service:
Air filter ,Automatic transmission filter(s) ,Automatic transmission fluid,Coolant,Engine oil ,Fuel filter ,Oil filter,Spark plugs change and Tune up.
The price from the Edmunds maintenance guide is $331.14 ($116.76 parts and $214.38 labor),which is $100 lower than the dealer quote for this area. What do you think? Thanks for your input.
ATF, transmission filter and engine coolant: I would go to MIDAS or a similar place but obtain a firm quote first. Make sure they have your transmission filter in stock, otherwise buy it from the dealer and provide it to the shop doing the work.
As to the "tune up", there isn't anything to tune.
Make sure all the belts and hoses are in good shape, check the power steering fluid level -ask the MIDAS or similar shop to do a complete visual check of all the fluids and belts.
Ask for a free brake check. Many shops do this for free if they are doing a tire rotation at the same time.
By the way, WALMART or COSTCO are inexpensive places do to a tire rotation.
Look in your manual for things that should be serviced at 30K but I think you pretty much mentioned everything that has to be done.
I wouldn't spend more than half the amount quoted to you.
Good luck motoring!
My driving conditions have not changed.
Tires are kept at 33-35psi and checked weekly.
I have replaced the oil and filter every 3kmi.
Transmission was flushed and filled at about 20kmi.
1 week after I noticed this I replaced the air filter since it was the original and slightly dirty. No change, still about 23mpg.
Another week after that I replace the NGK platinum plugs with Bosch Platinum. (NGKs=$11ea;Bosh=$2.25ea)
First tank delivered 27.5mpg. 2nd tank back to 23mpg.
This make sense to anyone?
SO..too bad, so sad. What great advertising this makes for the reliability of Hyundai's technicians!
After today's car wash, I went to the dealer lot and looked again at the black '04 GLS they had in the main lot (the remaining many '04s are on a supplemental lot). Someone else has probably mentioned this, but the keyless remote entry is now standard, and I noticed that the 5-speed EPA estimates are now 34/26. Also, the new lighter gray fabric is sooooooo much more attractive (I think I've mentioned this before). Maybe the next car will bring me back to black after all.
Still no local '04 GTs to look over.
I just bought an 03 GLS and got the $1500 rebate.
After rebate, $12150 and had a cd player added!
ElantraStan
Road surface quality of I-95 is distinguishably different from Boston to NY city,in term of smoothness and quietness. Conneticut is the best, Massachusetts and Rhode Island are similar, NY is the worst. NY has the best road signs, large and also easily readable at night.
*2000 Elantra, 29100 miles in 38 months.
Hope I don't see the drop in mileage after 30K miles as post # 3740 did.
$2000 Cash to Customer start: 10/01/2003 end: 10/31/2003 Get Dealer Pricing
Restrictions Customer Cash cannot be combined with Special APR. Special APR or customer cash is only available to current Hyundai owners puchasing a new Elantra. Customer cash includes $500 owner loyalty.
Comments Incentives may vary and are subject to change at any time by the manufacturer; contact your local dealer for details.
Will this car be using the same platform as the Elantra? Judging from the info I posted it'll use the same VVT engine that's now in the Elantra, so if it uses the same platform doesn't it come down to personal preference on exterior and interior styling? Won't these two cars be essentially the same car or very similar?
But also, the Kia Rio and Accent use a similar engine, if you look at the specs. In reality, they are different designs. May be the same type of thing here.
Not sure if the 2.0 engine with VVT will be the same as the Elantra's. Does the current Spectra use a different engine from the Elantra? They would be better off using the same engines for all their cars, like Nissan is doing with their cars. Might be able to cut costs by sharing engines.
And from everything I've heard, the Elantra platform is a lot better than the current Spectra's. They would be stupid not to use the Elantra platform.
And I'm not sure if they are being built in the same factory or not. That's true, there could be some quality differences if they are built in different factories.
