Hyundai Elantra 2001-2006
1103105107108109
    In the Twin Cities I've used Dent Wizard multiple times on different vehicles, including a 2001 and 2004 Elantra, with good results. That included significant hail damage on my 2001 Elantra, which came out looking like new at only a fraction of the cost of regular repairs, plus they didn't have to disturb the factory paint.
  • deepsrdeepsr Member Posts: 1
    Yesterday, while driving my car with the AC on, I noticed the temp. gage go up and my ac stop working. Anyone have an idea to what the problem is? Water in radiator is good but the water in the reservoir keeps going low. When car is at idle, engine does not overheat, but when I put it in drive the engine gets hot.
    A couple of things: if the fluid (hopefully antifreeze and not water!) in the reservoir keeps getting low, over a short period of time, that signals a leak in the cooling system someplace. The reservoir is connected to the radiator. If you've let it go awhile and never seen the fluid drop in the radiator, it's possible the leak is in the reservoir or the tube connecting it to the radiator.
    The second thing to check is the radiator fan, which is electric and only comes on when needed. Once on a Civic I owned, the fan went out and the symptoms were as you described: while driving with the AC on, the engine temperature went up (especially when driving at slow speed). The AC cutting off may be a preventative measure built into the AC system, to cut it off when the engine temperature reaches a certain point--but that is just a guess.
    These kinds of problems might be covered by the factory warranty, if the car has less than 60k miles on it and you are the first or second owner. One thing, though--don't drive it with the temperature in the red zone! It could damage the engine, and might void the warranty.
  • gm1258gm1258 Member Posts: 3
    My '04 Elantra has 52k miles on her and will be due for the BIG 60k service
    in a few months time.
    I know this is biggie and so is the price tag.
    My dealer wants $847 to do it all.
    And yet another $125 to change the plugs, wires, and do a minor tune-up.
    Thats almost an even grand for the whole ball o wax!!
    Ouch!!
    This seems a bit steep.
    Am I being ripped off here or what??
    What did most of you pay for your 60k mile service??
    What about independent service by a mechanic familliar with Hyandais??
    Any advice appreciated.
    (by the way, I solved my abherrant mileage loss by changing both
    the fuel and air filters and running a couple bottles of injector
    cleaner through during a recent road trip).
    GM
  • elantraownerelantraowner Member Posts: 16
    That does seem high. I had the 60K done this past January on my wife's '02 Elantra. It cost me $685 and that included plugs, timing belt, and they even replaced the wipers. We live near Evansville, IN and I know the hourly mechanic's labor costs may be different in other areas of the country. That might be a factor. But I don't understand the separate charge for the plugs, etc. That should be all part of the package for the 60K service. Did you need a break job?
  • doohickiedoohickie Member Posts: 949
    Also, if the car is running fine, you don't need the plugs & wires.
    Go in to the dealer with the maintenance section of the owners manual. Then look at the dealer's 60,000 service package. Cross off EVERYTHING that is not required by your manual, and have them quote that to you. When I did this at my dealer, my 30k service cost me only $200 instead of the $350 the dealer wanted to charge me for "recommended" services. Recommended my butt; those are just recommended by the dealer to pull extra money out of your wallet.
    I looked at my service manual for my 60k service.
    Actual work required is replacing the timing and drive belts, fuel filter, air filter,
    flushing coolant, manual transmission and power steering fluids.
    I can change the air & fuel filters myself.
    Beyond that the usuall oil change and stuff.
    For this they want $847.00???
    No break job is included in this.
    All they do is clean the brakes.
    And they want another $125.00 to replace the plugs and wires??
    (I've never gone 60k w/o replacing these in any car - just good pm).
    Everything else on this lengthy list amounts to
    "inspecting" this, that, or the other item.
    Any additional work beyond those inspections is substantially extra.
    The dealership is always a rip off.
    They told me that I could go to an independent mechanic to get
    the work done, have him sign it off as completed, and this will
    still keep me under warranty.
    That said, I will look around for a good mechanic in my area who is
    familliar with Hyandai service.
    I have 53k on her now so I have some time to shop around.
    I'm sure I can find a better deal on this service than the dealer.
    Thanx,
    gm1258
  • drgumsdrgums Member Posts: 51
    I am looking to buy a 2002 Elantra GLS w/ 50K miles asking $4800 cash.
    It is a 2nd owner....car original nought on auction...clear car fax.....owner just put in new front brakes...oil change
    Edmunds avg private price..mid $4000's
    any thoughts?
    KBB has it at $4805 for Good condition, with automatic. But in doing a lot of used-car shopping recently I noticed many cars being listed for well below KBB value. So you should see what similar cars are going for in your area. If $4800 seems in the ballpark for your area and the car passes a mechanical inspection (which I recommend you have done), and the tread is good (OEM tires might be wearing thin by now), it looks like a pretty good deal. You can always see if there is any wriggle room by making a counteroffer. Some private party sellers jack up their asking price, figuring some folks will want to haggle.
    thanks...also I assume the car is a good vehicle?
    anything I should be aware of?
    There was a TSB for the exhaust manifold on some 2002 Elantras. Hyundai extended the warranty on it to 100k miles. I don't recall if it's just for the first owner but I don't think so. You might ask the owner if it was ever replaced. The other thing that you may know about already is that the car has a timing belt, and the replacement interval is 60k miles. So the 60k service is fairly pricey.
    I had a 2001 Elantra GLS which is basically the same car, and it was a great car for me, and now my sister. It's 8 years old now and still running great at 60k miles, and if my son hadn't sideswiped it in the driveway it would still look great.
  • Kirstie_HKirstie_H Administrator Posts: 11,255
    A reporter is interested in talking with satisfied owners of a 2001-2006 Hyundai Elantra who are also parents. If you are interested in commenting on your experience, please reply to jwahl@edmunds.com no later than Friday, November 21, 2008 and include your city and state of residence, the model year of your vehicle and the age of your child/ren.
    Thanks for your consideration,
    Jonathan Wahl
    Corporate Communications
    Edmunds Inc.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • jrwhitejrwhite Member Posts: 1
    I have had my 2006 Hyundai Elantra a little over a month now. I am so dissatisified. I too, feel an overall vibration in my car ( gas pedal, brakes, passenger seat). I have taken it to two dealerships and they say it is normal. After I have driven the car, my leg is sore from the vibration. I believe it needs new motor mounts, so I'm going to take it to a mechanic to see what he thinks. There is no way this is normal because I have not seen to many idiling problems with this car, mainly while driving in speeds of 50-60 mph. I have just invested in new Michelin tires Primacy MXV4, very expensive tires. I have had it balanced, rotated, and aligned. Can the motor mounts go bad after 50,000 miles? I want to enjoy driving this vehicle if only the vibrations would stop. Any suggestions?
  • gomst1gomst1 Member Posts: 58
    "There is no way this is normal because I have not seen to many idiling problems with this car, mainly while driving in speeds of 50-60 mph."
    From experience, speed related vibration is usually caused by a problem with the wheels or tires. Check for: dented/out of round wheels; out of round tires, out of balace tires. Motor mount problems usually shows/manifest at: Idle, shifting gears; acceleration or deceleration. My guess is that you may have a wheel problem.
    Last year I had a new set of Michelin tires installed and balanced (on my van) at Costco only to find out that the steering wheel vibrates at 65 mph. I took it to work and balanced the tires myself. Problem fixed. That tells me that the Costco tire balancer is out of calibration.
  • nj2pa2ncnj2pa2nc Member Posts: 811
    both the low beam bulbs on my husband's elantra went out. My husband was able to change the passenger side one without problem. Does he have to remove the battery to change the driver side or is there an easier way. Any help would be appreciated.
  • jlflemmonsjlflemmons Member Posts: 2,242
    The headlamp assembly comes out the front for bulb removal. The passenger side can be done in place, but not the drivers side. Check the owners manual for instructions on this, they are under the maintenance section. If I recall correctly, two or three 10mm nuts are removed and the whole headlight assembly comes forward.
  • dovid2dovid2 Member Posts: 90
    While I have always changed both bulbs from the back (and the driver's side is really difficult), I heard recently that there is a screw behind the headlight assembly that needs to be removed to take out the whole thing; the two on the top won't do it by themselves. Good luck.
  • cthomcthom Member Posts: 1
    I have a 2001 elantra, from what I have read so quite a few of you have blade issues. Here is my most recent. The passenger side arm quit working? Are they on independent motors? I'm not sure what to start looking for to fix the problem. Any advice would be great.
    On my wife's '01, the nut holding the wiper arm down on the drivers side came loose recently. Now, it didn't stop working but the pressure - wiping ability - against the windshield was greatly reduced. I just tightened it up with a small wrench. So you might check that out.
    AFAIK there's a single motor driving both arms.
    My husband removed the battery which made it very easy to change the driver's side low beam bulb.
  • omthkomthk Member Posts: 5
    My Hyundai 2001 Elantra has 58000 miles. On recent visit to dealer, they told me that my belts are showing cracks and advised me to change them and timing belt along with other belts. They said Timing Belt should be changed either at 5 years or 60000 miles. Do I need to change the timing belt or the belts - A/C, Alt. and one more I don't remember, which as per them have developed cracks. What is normal life of the Timing Belt. Do I really need to change?
    In most every state (CA may be an exception) the timing belt is a 60k maintenance item for replacement. So you should have it done. If it should break, the engine will be trashed. If the other belts are cracked too, those should be replaced. Might be cheaper to have them all done at the same time--ask the dealer if they can give you a break on the fee if you do that. If you don't trust that dealer, you can always get a second opinion from another mechanic.
    On some vehicles if the timing belt goes it can cause some serious damage to the engine. It is recommended at 60K but I have heard some mechanics say you can probably squeeze 90K out of the belts. I am not sure about the Elantra, but for peace of mind I would change it. Especially since it is a 2001 and it is now 2009.
    Thanks to both of you, Your input is highly apprecieted
    I haven't checked my wife's Elantra maintenance schedule but if the timing belt is listed as 'replace every 60K' and the vehicle is still under the 10/100 powertrain warranty (original owner or transferable Hyundai extended warranty) then you will need to get it changed to maintain the powertrain warranty as it relates to timing-belt issues.
    And they shouldn't charge any extra labor to replace the other belts at the same time; just the parts cost alone (maybe $45 or so).
    The timing belt replacement is not labor free as it is considered normal maintenance as will other belts, wipers, oil change. But if you don't replace it or don't keep up with what would be considered a regular preventive maintenance schedule as recommended by hyundai on the vehicle, you could risk having your your 10/10 warranty voided. I recall receiving a paper that made me aware of that when I purchased the car. In other words, if the timing belt went bad before 60K you would have a strong position to cover engine repair under the warranty. If it goes at 75K and you hadn't replaced it, as recommended, you may be out of luck.
    I never said it was. I said the other belts should be labor-free. I've done timing belt replacements several times and have always had the other belts replaced at the same time for nothing more than the parts cost.
    Agree on the warranty coverage. That was my main point in posting - you need to provide adequate maintenance as prescribed by Hyundai (not necessarily the dealer) to maintain warranty coverage. Basically RTFM.
  • nodulenodule Member Posts: 118
    Im about to purchase a MINT condition in and out 2005 ELantra GLS in
    Beige with only 16700 miles on it!. The final price was $9400.00, plus
    NJ sales tax.
    This car looks like it just came off the showroom floor.
    Is this a good deal??
    Hatch or sedan? AT or stick? ABS and/or moonroof options?
    Assuming it's an automatic sedan (most common type of Elantra) with no other options, KBB for a car with those miles in excellent condition is $9885 retail and $8010 private party. So if you are buying the car from a dealer, the price is pretty good. Not very good if it's from a private party. Used car values are depressed right now, just like new car prices, so there may still be some room to negotiate if this is from a dealer. While shopping for a used car recently (including Elantras), I found many excellent units at well below the KBB value.
  • bhmr59bhmr59 Member Posts: 1,602
    Don't forget to check values on nada.com also.
    N.A.D.A. has equal recognition (or better than KBB). KBB usually, but not always, lists higher prices for the "same car" than NADA does.
    I've found the NADA values are typically inflated out of real-world realm compared to KBB and Edmunds. But as I noted, even KBB prices are on the high side now--maybe they can't keep up with the deflation in used car prices?
  • patpat Member Posts: 10,421
    You might also ask over in the Real-World Trade-In Values discussion. That's an excellent source of pricing on used vehicles. Just be sure to provide all the information requested at the top of the post box.
    Good luck to you.
    Maybe it's just the cars you were researching. Or maybe it's a regional difference. In CT, across a broad spectrum of clilents' vehicles, I have usually found the KBB "retail" values to be higher than NADA.
    Just like the car mags emphasize different factors when rating cars, maybe the used car guides weigh things differently.
    The CT general statutes provide:
    "Sec. 38a-353. (Formerly Sec. 38-175y). Calculation of settlement amount on totalled motor vehicle. Whenever any damaged motor vehicle covered under an automobile insurance policy has been declared to be a constructive total loss by the insurer, the insurer shall, in calculating the value of such vehicle for purposes of determining the settlement amount to be paid to the claimant, use at least the average of the retail values given such vehicle by (1) the National Automobile Dealers Association used car guide and (2) one other automobile industry source which has been approved for such use by the Insurance Commissioner. For purposes of this section, "constructive total loss" means the cost to repair or salvage damaged property, or the cost to both repair and salvage such property, equals or exceeds the total value of the property at the time of loss."
    (Good luck keeping warm. We're up to 17* at 12:30 pm. You guys have been getting clobbered :( .)
  • bob48bob48 Member Posts: 2
    just bought an 2004 elantra with almost 100,00 mi. is there anyway to find out if the timing belt was changed at the 60,000 mi service thanks bob48
  • hmownerhmowner Member Posts: 23
    I would like to share possible repairs coming down the line for Elantras over 100k miles (mine is at 120K ). The repairs below were required during the past 6 months.
    - replaced the front two rotors - worn with grooves - and pads
    - replaced the rear drums (worn and rusted + making metallic grinding noise) | shoes + replaced 1 leaking cylinder
    - replaced the two front wheel bearings - due to airplane like noise coming from the front around 40 mph or higher (Shimmy problem may have contributed to early demise of the bearings)
    - replaced manual trans fluid at 120K at the dealer.
    The total repair cost was around $1,000
    Other than the engine noise getting louder with the age and the shimmy problem that never goes away completely, the car's okay.. so far.
    FYI - I had my timing belt replaced at 90K. at the dealer (did not replace the water pump which is still working great).
  • stephen987stephen987 Member Posts: 1,994
    Thanks for sharing your experience. I would've replaced the water pump, because (a) if you do it as part of the timing belt service, there's only about 30 minutes of extra labor involved, and the part itself is cheap; and (b) a friend of mine had a relatively new timing belt fail because the water pump leaked coolant onto it.
  • bullitt5bullitt5 Member Posts: 1
    I'm glad i read your post because i too have the noise from the front end between 35-80 mph..... and it's driving me insane!!!!!!! I've taken my '02 Elantra GLS to about 4 shops now, 2 dealerships and 2 independent shops, and none of them can outline the problem. The steering wheel shakes like a paint mixer around 45 mph and it actually sounds more like a helicopter at high speeds now. They all say there is nothing wrong other than the usual wear and tear (it have 105,500 miles on the odo) and nothing has to be replaced. I personally changed 1 bent rim (pothole) and one of the control arms after our always salt-covered roads rusted it through, but they said everything is ok with those.
    Has anyone else had this front-end shimmy problem?
  • newhartfordnewhartford Member Posts: 49
    Try a search on shimmy and you should get all the reading material you want. Some folks have fixed it with just balancing wheels others unable to fix it. It seems as if the car is not very forgiving about any imbalance in the front running gear. My 03 GLS had it only briefly and it went away with a tire rotation.
    The steel belt in a tire on one of my vehicles began to separated, apparently I was told, due to hitting the sharp edge of a pothole or something else. That caused me vibration problems. It took taking the tires off and having them rebalanced to find that problem.
  • jayessjayess Member Posts: 59
    I just drove and am considering the purchase of an '06 elantra with 26,360 miles. Drives well and appears to be in decent shape. From carfax apparetly it was in a rental fleet in one of the square states for the 1st 18.5K miles then a single owner, dealer just acquired in a trade. It has a moon roof. I noticed a TCS (traction control system) knob on the left side of the dash, apparently hels to keep the wheels from spinning in snow/ice. All google reserch indicates that these two plus ABS 'woodgrain' accents are part of a limited pkg w/leather seats but this has regular cloth. Can't tell whether it has ABS though. Was TCS and moonroof part of a limited qty run ? Build date indicated 11/2005. Dealer went down to 9400+tx and title. Does the price sound reasonable ? And is there anything I should be on the lookout for ? thanks
    If it has TCS it has ABS too. For 2006 there was an options package on the GLS that included ABS, TCS, and moonroof. In fact, that was the ONLY way to get ABS on the 2006 Elantra GLS. If it doesn't have leather, it's not a Limited, but a GLS. In fact, there should be a "GLS" badge on the trunk lid. My 2001 GLS had that anyway.
    $9400 seems high to me for a 3-year-old Elantra GLS, of the previous generation, given that there were big discounts on these cars when new so a $16k list car probably sold for more like $12-13k new. I think they are nice cars (I owned a 2001 and have a 2004 GT hatch), with one major failing: poor side crash protection. If that doesn't bother you, you might try to get the price down a bit more, and have the car checked by a mechanic (although the fact there is some factory warranty left is a big plus). Be sure to check the tire tread; the Michelin OEM tires are not known for long life--I had to replace the ones on my 2001 Elantra after 30k miles.
    Re: shimmy problem.
    I had it since I bought the car in 2001. Road force balance reduces the shimmy for about 2-3 months before it comes back. I put new wheels with hub-center ring and that took care of shimmy problem for about 6-8 months before it came back again, but not as bad. The issue I think is Elantra is very unforgiving about slightest imbalance in the tires. I recently put on Toyo Versado tires and that seems to both lessen the shimmy and the tire/road noise.
    Was able to get them down to $8800, received a $500 coupon in a direct mail solicitation the same day I went to look at the car, and then asking them to split the difference from my original offer of 8.7K. Tires appear to be in great shape. Dealer is including a 6mo/6K warranty but of course that runs concurrent with the remaining mfgs. Think I'm going to buy this car.
    That is a better price. The dealer's warranty doesn't mean much since the car is (or should be!) under the Hyundai 5/60k warranty for quite a while.
    One other thing--be sure to take it out on the highway at high speed (up to 70+ if you can). Some Elantras of this vintage have a "wheel shimmy" issue. Sometimes it's easy to correct if it's present (i.e. a proper wheel rebalancing), but some owners have had trouble eliminating the shimmy, so it's better if it's not there in the first place.
    Tomorrow will be the fifth anniversary of ownership for my Rally Red 2004 Elantra GT 5-door, so I thought I'd say goodbye to the bumper-to-bumper warranty with an ownership summary at just over 42k miles:
    Likes
    * Great driver's seat, firm but still comfortable even for all-day trips. The dual-knob height adjuster (no longer available on the Elantra) and lumbar adjustment help there, along with a well-placed dead pedal. The steering column doesn't telescope, but with all the seat adjustments I never missed that feature.
    * Versatile: 60/40 rear seat folds flat when needed (by flipping the rear seat cushion forward), so it can carry lots of gear and still hold 3-4 people.
    * Reliable: No major problems over its first five years. Biggest problem is the P.O.S. Kenwood audio system, which was unique to the 2004 GT (thank goodness!). The CD player stopped working over a year ago. AM reception was never great, but seems to have gotten worse with time. And the myriad of tiny buttons is a nightmare. Fortunately it's a standard size, so I'll pop in an aftermarket unit with an aux input one of these days. (No big rush--my 17-year-old son drives it now and he needs to keep his attention on his driving.) The only parts I needed to replace outside of normal maintenance were two headlamp bulbs (warranty), struts for hatch (started slowing down so I just got them replaced before the warranty ran out), rear brake pads at 40k, latch for driver's sun visor (DW broke it, covered by warranty), clip for cargo cover (DW broke it, covered by warranty), retaining clip for driver's floor mat (broken by car wash attendant, covered by warranty), rear turn signal lamp (about $2), rear license plate lamp (about $2), and a front side marker lamp (about $2). There was also some damage from a run-in my DW had with a curb in a blizzard 3 years ago (curb won), but that wasn't the fault of the car. Did result in new tires, which have 24k on them now and still good tread.
    * Good looking: I still like the looks of the GT hatch. There aren't many fastback-style 5-doors any more. It has the versatility of a wagon but doesn't look like a wagon (something my 17-year-old son appreciates). The red paint has held up pretty well, and is still lustrous, although there are faint surface scratches and a few small door dings. Some of the alloy wheels have some nicks also.
    * Ride & drive: It's no sports sedan but for an econobox, I think it has a nice blend of ride and handling (sport-tuned suspension and steering). It's pretty quiet cruising on the highway, nimble around town. Except for an occasional squeak from somewhere in the dash in very cold weather, still no rattles or squeaks. The ride isn't as smooth as on the GLS, but not punishing.
    Dislikes
    * Kenwood head unit (see above). While it has good sound through the six speakers, it hasn't held up well and the controls are an ergonomic mess.
    * Steering wheel would be more comfortable if it were a little thicker. The leather cover has held up well though, and feels good.
    * Leather interior: It's held up remarkably well, with only one small scuff on the outer bolster on the driver's side. (I think the car's use as an auto show car for Chicago, Minneapolis etc. in early 2004 didn't help there, as several thousand people probably climbed in and out of the driver's seat.) Otherwise it looks new. But I was never a fan of leather (hot in summer, cold in winter) and had I known Hyundai was coming out with a GLS hatch for 2005 with a sport cloth interior, I might have waited for it. Plus there's no seat heaters.
    I haven't tracked fuel economy over its lifetime, but I do keep track of it at fill-ups and through the trip computer. I average mid-20s in town and mid-30s on the highway consistently, with peaks just over 40 mpg under ideal conditions (4AT). But I drive conservatively. I notice my son got closer to 20 mpg on short-trip, in-town driving this winter (his first with a license). At 70 mph on long trips the best I've gotten is 34-35 mpg. So it's not as stingy with gas as some small cars, but it almost always beats its adjusted EPA ratings (21/29). Its sweet spot is around 55 mph, where it will do upper-30s mpg easily.
    Maintenance costs have been very low, because I've never had to pay for an oil change (long story) and I get free tire rotations/balances from the tire shop. The 30k service was the only major maintenance expense, plus of course the rear brake pad replacement a month ago.
    So overall it's been a positive ownership experience, and I'm glad I bought the GT instead of costlier options I was looking at five years ago, e.g. Matrix, Mazda6i hatch, and Malibu Maxx. Another positive is that I've suffered little in depreciation over the past five years. According to Edmunds.com, the car could fetch nearly $7000 in a private-party sale (KBB has it at nearly $8000). Using the lower figure, that's a bit more than $100 a month in depreciation over five years.
    Plus I still have 58k miles and five years of powertrain warranty left--enough to get my son almost all the way through college. :)
    Took delivery yesterday morning, I'm satisfied but more importantly my dw is! I did check with Hyundai CS and I do have the remainder of the 5/60 including the powertrane since we're not the original owner. I was specific that per carfax it probably was in a rental fleet for the first 18k miles, then a private owner and was told that the warranty as above pass to me - so just shy of 2 yrs or 33640 miles. This is good.
    And according to the VIN, it has ABS subsequently found the unit under the hood, in addition to the TCS which are nice safety features since my 20 yr. old daughter will be getting it. Brand new Uniroyals and a full year on the inspection. Such a deal :)
  • jimbeaumijimbeaumi Member Posts: 620
    Howdy folks! I haven't been on this discussion for a while, so I thought I would check in. I am still the happy owner of a 2001 Elantra GLS 5-speed.
    I've noticed a couple of people talking about the wheel shimmy issue, which I have had a various times and various degrees over seven and a half years. I do remember that one person tried everything to eliminate the shimmy and had to resort to new rotors, as a mechanic at some point overtorqued the lug nuts and warped one or both rotors.
    We are at more than 95K miles, and the most recent repair was covered mostly under warranty, which included a catalytic converter, exhaust manifold, and a portion of the exhaust, all triggered by a simple "check engine" light for an O2 sensor. The service tech seriously angered me by authorizing spark plugs and wires and insisting that I had authorized those items, so I will not revisit that dealer again. By the time I arrived home, however, I decided not to push the issue further to the top because the car was running SO perfectly, truly like new. :)
    A concern at this point is finding a part number and then ordering a replacement for the slim black trim piece separating the rear door roll-down window from the non-moving piece of glass, as it is very rusted on the driver's side, and starting to rust on the passenger side. Has anyone been able to locate this piece or a separate part number on any parts site?
    Cooper tires have been fine after one year. Digital clock refuses to come back to life, even when tapped firmly. Wipers were slowing down quite a bit in the winter. These three items and the trim piece issue are the only concerns I have right now. I love this car, and cannot wait for car-waxing weather!
    I know I had that trim piece replaced on the driver's side under warranty (the bumper-to-bumper warranty) on my '01 GLS years ago; had the same problem with it. The dealership had to order the part. They should be able to do the same for you, if you want to replace it yourself.
    Re the plugs and wires... had they been replaced before? If not, then it probably wasn't a bad idea to replace them now. Of course, the service tech should have waited for your approval to do it!
    My sister still has my 2001 GLS and tells me it's holding up great, just passed 60k a little while ago (she doesn't drive much). Needs a little body and paint work due to a side-swipe from my son a few years ago that I touched up, but it was not a "pro" job at all (although I did use made-to-order paint).
    Thanks, and I ought to order that part very, very soon. From a different dealership, of course.
    Yes, the plugs and wires had been done, which is why I was ticked off about it. The service writer's attitude was just the icing on the rotting cake, which is a shame because he replaced a very pleasant writer who was let go. Dumb decision.
    It's a good thing I am not yet ready to take on a car payment, because as before, I want an Elantra SE, an Elantra Touring, and a Sonata GLS, AND I want to see this car hit the 200K mark. At this point, the decision's been made for me. :D
  • erg135erg135 Member Posts: 3
    I got an 02 Elantra 2.0, and my friend got me a 4 1/2" motech muffler. I went to the shop they put it on and when I drove out I noticed a great deal of lag. I was wondering if that was because theres not enough back pressure and the mufflers to big. if I had a turbo it would be a different story but all I got is a stock engine.
    any suggestions on if I should get a smaller one? Also what size are stock mufflers on lantras?
    please help??????
