Visitor Agreement.
When tuning to XM bands, I notice that the volume (signal strength) is much lower than on the other bands. One must turn up the volume much more on the XM band than on the FM band, for example. And the sound isn't quite as good either (save for the normal FM static). Also, when you switch from XM to FM you have to quickly turn down the volume because the difference is that noticeable. I realize that I can add an amp to the overall system but I was wondering if there was a way to boost the XM signal (between the ant. and the receiver) other than just adding an amp to the speaker output. Your thoughts are appreciated.
Speaking of XM, one feature I miss terribly from my Skyfi is the ability to scroll through all the stations on the display to see what's playing on all stations at any particular time. I doubt it will happen, but I'm curious: could the features of the XM/Audio/Navigation system be easily updated if Honda wanted to do this? Any other thoughts on the possibility of this happening?
Are you going to take yours in to the Honda dealer you bought it from for an inspection? I would be interested to hear your results.
The thing that does not make sense is that the noise is directly tied to the throttle. Throttle pressed=noise, release throttle noise stops. It happens around 42-50mph.
I have not pursued the tire problem yet since I am not yet convinced it is a tire.
Can you guys tell me what brand and grade of gas you are putting in your Accords? Also, the noise does seem to be around the 45 MPH mark, but I have also noticed it at higher speeds when I release my foot off the gas. Can you guys tell me what are the mileage on your vehicles and if the noise has gotten worse or stayed the same with time?
briansbluetoy -- The wheel well thing sounds like a stretch to me. My noise is definitely throttle-sensitive, but we're talking about an extremely gentle movement of the pedal. Can't imagine that could be linked to the wheel well, but that's just a guess.
I will be going in for my service in a few weeks and will let you all know what they tell me about this noise.
We pretty much have the same situation. The vehicle runs great, no major complaints. I probably started noticing the noise around 2000 miles, we have about 3000 miles now. We utilize premium fuel, so I know it's not the fuel. I remember when I had a previous vehicle and had the 60,000 miles service done on it, (my mechanic changed almost everything imaginable, from timing to water pump, other belts, wires, plugs, etc.) After this was done I noticed a whistling noise coming from the engine compartment. It did however went away by itself, I assume after the new parts broke in. However, please keep us informed as to what the dealer claims to be the cause.
I am trying to decide between the V6 and 4 cylinder EX. The V6 has traction control. Is that a significant safety advantage? Apart from the fun of a V6 is there a serious reason for choosing that over the 4?
Thanks for your advice.
It is well known that Hondas are not quiet and quite bumpy. So I prepared a set of ear plugs. The 3 dollar investment turned my Accord into a Lexus in terms of interior noise level.
Gas mileage is very good for both engines, but you can expect perhaps 10 per cent more miles per gallon with the 4 cyl. which is worth considering if you drive enough. Also, the 4 cyl. engine has a timing chain that lasts the life of the engine. The V6 uses a timing belt that must be replaced after a certain number of miles or years.
Traction control is not really an issue with the 4 because the 4 cyl. doesn't generate the torque that will slip the wheels as much as the V6. There's a position in the AT to make second gear starts that help prevent wheel spinning on snow and ice.
If you often carry a full load of passengers and fill the trunk, or if you frequently must VERY quickly pass trucks on 2 lane roads, you might want the fastest car you can afford.
Be sure to test both before making your choice--don't just buy the V6 because you think you might need it--the 4 might be a better choice......Richard
Dave
it wouldn't STOP be from buying the 4 cyl Accord if that is what i wanted, but i would be replacing the timing chain just like i would be replacing the timing belt to be safe.
Your point's well taken, though - for Hondas and their 105k replacement recommendation on the belt, the differences are not as dramatic as many people think. In either case, most people will sell the car before the cam drive needs any servicing at all...
I chose the 4-cyl myself; given the way I drive (fairly conservatively) I don't need the extra power, and I enjoy the better gas mileage as well as the lower up-front cost.
The car I am driving has the rear-view mirror upgrade and I noticed that the driver side visor makes contact with the mirror when placed in the down position. This happened several times this afternoon and is quite annoying since I have to reset the mirror everytime. Does this only happen with the mirror upgrade or does standard mirror do this???
I also noticed that in order to adjust the AC fan you have to choose the AC button and switch to that screen on the navigation display and select your fan speed instead of having a simple switch on the dashboard. This may not seem like a big deal but when you first get into the car the navigation product can take up to a minute or so to get past all the legal disclaimers which leaves you sitting there with no airflow until it finishes. FYI, I live in Texas and it is already HOT here.
Are there other little issues hiding out there that I am not yet aware of? Please let me add that the missing key cylinder on the passenger side is of no consequence to me but these other items leave me with the feeling that there are some things Honda did not consider while designing. So far, I do not find these kinds of negative perks with the Acura but I am sure it has it's share.
Any thoughts and comments are appreciated.
PS If anyone is interested, I have worked the following deals after much deliberation over the past month or so (both are Automatic Transmission):
2004 Accord EX-V6 with Navi - $26,000 (includes very good money for my trade)
2004 Acura TL with Navi - $33,700 and OK money for my trade
One member, who will probably weigh in on this himself when he sees your post, reports that the "fix" didn't resolve the problem for him. I'm not aware of any other similar reports on Edmunds, but he may be.
-Never drive the car away from the dealership [including the first drive after purchase] without retorquing all 20 wheel bolts with a decent torque wrench [Craftsman makes several at reasonable prices - pick one]. Use whatever the book says - typically 76-80 ft-lbs - but the real key is to MAKE THEM ALL EVEN. It's uneven torquing that it the culprit 50% of the time or more.
-Avoid hitting the brake discs with a stream of cold water right after getting off the road or using the brakes hard [freeway offramp, etc.]. Let them cool down before doing a car wash.
-And yes, sometimes pad materials and lousy rotors will still do you in - ONE use of the brakes in 100F degree weather on a freeway was enough to warp the rotors on our '92 Sable; after being replaced, they warped again within 5000 miles, even with my pampering.
It's a common problem these days across many brands. Honda is by no means alone. But there are defensive measures you can take, and the most important of these is to get a good torque wrench and socket and use it religiously. I'm driving my 14th Mercedes at the moment, and I don't trust their dealers any more than I do Honda's, always doing my own retorquing if the wheels have been pulled for any reason.
13 gallons average 16mpg and 31 bucks to fill up the tank. OUCH! Also driving with autoclimate set to 70 degrees.
as far as MPG's, i have never even been close to 16 mpg. maybe once your car breaks in you will get better numbers. i have never been below 23 mpg on my 03 V6. i think the 03 V6 is the same as the 04 V6.
If the Accord is so bad that you want to trade it .. what will be better? I am all for someone dumping a car if they aren't happy. I would rather someone trade their car than post endless posts about how unhappy they are. But I am curious as to what you think will be better than the Accord?
"I would rather someone trade their car than post endless posts about how unhappy they are." someone asked about my experience, and i replied. nothing "endless" about it.
i think you should try your best to lighten up just a bit
personally, for me, the Honda experience this time around reminds of my VW experience. EXCEPT, with the VW, i enjoyed driving the car more. i will most likely be rid of the Accord soon. no idea where to go next though. not Toyota. at the feature/price point that i am looking at, it will probably be VW. i guess, if all cars have problems (which they all do), i would rather buy the one that treats me like a person (Honda as AWFUL customer service). VW appearsto be concentrating on quality again these days, per all the trade mags i have read in the past few months.
Is it just me or the paint job on Accords is really inferior?
The best way to remove these contaminants is with a clay bar, followed by waxing/polishing. Several brands are available, Mothers Gold, Clay Magic, and Zaino.
I used the Zaino process of Dawn wash, Clay, and ZFT/Z1 on our 2004 silver Honda. The touch of the finish and the shine are great.
Obviously you are a good negotiator - congrats!!
You might go to their site, plug in your NJ Zip code, and see what they say compared with what you paid. I'd be curious about the result...
On the other hand, its price was pretty much spot on with what I negotiated for a Camry SE a couple of weeks ago.
Under normal driving I get a little over 300 miles on a tank...driving like I stole it w/AC on most of the time. There is still some in reserve but I pushed too far once and ran out at 341mi. I have gotten as high as 402 on a (250 miles HWY 152 city). Not been on a full tank road trip yet.
The trip computer is now saying im getting 13 mpg
/grumble
Anyone had experience with LeBra merchandise? Should I buy the Honda product or will the cheaper one be just as good?
You still need to take it off regularly to clean under it as anything that gets in there will scratch the paint. I really never had an issue with scratching.
Thanks again...
You can get an original Full Bra from Honda for about $100.00. Go to hondacuraworld.com. If you live outside of NY you don't pay taxes and shipping is free, but you do have to pay for handling, which is about $3.00. We have the full nose mask (bra) on our Accord now for about two months and it makes the vehicle look so much sharper and besides that, it protects the paint and fits like a glove. My brother has a LeBra brand on his vehicle, but it doesn't come close to the way Honda had the bra custom cut, to fit perfect. We don't drive too much, so I take it completely off once a month, and polish/wax the entire vehicle. Good Luck
The nose of the Accord has a lot of exposure to chipping, so I wanted to protect it, especially here in the Northwest, where logging trucks seem to throw all sorts of nastys at you.
Thanks for all the feedback!
Going with a clear bra like Expel, StoneGuard, and etc is a far better solution.
