Older Honda Accords
1309310312314315389
  • mike_emike_e Member Posts: 9
    I just called Honda concerning the air-bag recall at 1 800 999-1009. The guy I spoke to said that the recall will not affect the V6 models. According to him, only a certain number of the 2004 and 2005 V4s will be affected. Has anyone received similar information. Is this authentic?
  • lmacmillmacmil Member Posts: 1,758
    Can we assume your posting this 3 times was a mistake?
  • ghuletghulet Member Posts: 2,564
    The cooling capacity of the A/C system is based on the car's interior volume. I doubt that the compressors are different. What's different is the load on the engine relative to its output once the compressor kicks in. If the compressor requires 10 hp, that's a much larger percentage of the four's output than the six's.
    If one were moving from another 4 or a low power V6, the 4 will seem adequate. Anyone moving from a decent size V6 (I'm currently driving a 3.5l, 230 lb-ft Intrigue) is going to be underwhelmed by the 4.
  • richards38richards38 Member Posts: 606
    I had a company-owned 1985 Pontiac Sunbird (like the Chevy Cavalier with a couple of Pontiac nostrils on the front) and it was a vastly different car with the A/C on than with the A/C off.
    The 1.8, 4 cylinder was barely adequate in power and when I switched on the A/C, it was like heading straight uphill--REALLY sluggish.
    My next car (mine, not a company's) was a 1991 Mazda Protege DX--same 1.8, 4 cyl. engine size, but far more power and turning the A/C on didn't seem to slow it down at all. Both cars had automatic transmissions.
    The '04 Accord EX-L 2.4, 4 cyl. feels very quick whether the A/C is on or not. I think that most newer cars have more efficient compressors that take less power from the engine......Richard
  • imidazol97imidazol97 Member Posts: 27,703
    gearing is different so that the engine is running faster and the load of the compressor has less noticeable impact at the given speed.
    With the newer cars the fuel supply is probably changed when the compressor comes on so that the driver doesn't notice a drop in power.
  • anonymouspostsanonymousposts Member Posts: 3,802
    I've put about 2,500 miles on our Accord over the last 3 weeks and I have to remark how awesome this car is.
    It kept me comfortable, safe, and gave me 33+ MPG with an average speed of 80 MPH and the climate control on at all times. Not to mention the XM radio is awesome. Was able to listen to the Dirty Dancing True Hollywood Story to keep me awake during a two hour jaunt starting at 4 AM.
  • emaleemale Member Posts: 1,380
    okay...okay we get the point...you love your honda. and all other hondas...! you don't need to post that every other day... :)
  • ktnrktnr Member Posts: 255
    Regards cooling capacity, I'd agree that the IDEAL cooling capacity of the A/C system would be based on a car's interior volume (and glass area). However, in the case of the 1999 Mitsubishi Galant, the A/C compressor was sized for the weaker 4-cylinder engine leaving even the V-6 version unable to cool the interior well in very hot weather. Clearly then, engineering compromises are sometimes made.
    Coincidentally, I too moved from a 3.5 liter, 231ft-lbs V-6. Surprisingly, my 2.4 liter Accord is just as fast in overall acceleration, primarily due to the Accord's amazing 5-speed automatic transmission. Personally, the only thing I miss is the V-6's off-idle smoothness (below 2,000rpm). However, I couldn't justify spending $2 a day, every day for the next five years to get that extra smoothness so here I am.
    It's been at least a few days since I posted how much I love our Accord.
    If someone can rant about the same problem over and over again I can post about the positive aspects of the Accord as well.
    I know the 4 is adequate. I rented a Camry 4 on vacation this summer and only once or twice did I wish for a little more power. I think the main noticeable difference between the 4 and 6 is passing power. With my Olds, I can zip around cars on 2 lane roads and never feel like I should be doing it quicker. That's not the feeling I had with the Camry. When/if I do by an Accord or Camry, I'll spend the $2/day.
    "I do by an Accord or Camry, I'll spend the $2/day."
    The cost of gasoline and insurance will be higher for the V6. Tires probably will cost more too, since with more power present, we tend to use it more and wear tires down faster.
  • jrock65jrock65 Member Posts: 1,371
    emale,
    Can you elaborate on what you mean by "dampner in the back shelf area"?
    The sound does sound a lot like the exhaust banging against something, as you described.
    How did you fix the problem?
    That's true but I'll suck it up. I'm also looking at used 2004 Acura TLs and Infiniti G35s. Most of those operating costs pale in comparison to the depreciation anyway. I just couldn't go back to a 4 cyl now, no matter how good it is (except for the Acura TSX).
    Looking up the metric dimensions for the Accord today, I noticed on Honda Canada's web site that the Accord only comes with a choice of black or ivory interior. Oddly, no exterior color or trim level comes with the gray interior (my favorite interior color and fairly popular overall in the USA).
    Can any of you Canadians hazard a guess as to why this is?
    here is the Technical Service Bulletin honda performed on my car:
    Make : HONDA Model : ACCORD Year : 2003
    Manufacturer : AMERICAN HONDA MOTOR CO.
    Service Bulletin Num : 03018 Date of Bulletin: MAR 04, 2003
    NHTSA Item Number: 10001301
    Component: STRUCTURE
    Summary:
     RATTLE FROM THE REAR SHELF. *JB
    if i understood correctly...they installed some type of insulation/dampener under the rear parcel shelf so that it wouldn't rattle. in my car the rattle sounded like either the suspension or exhaust was banging on something.
    hope that helps...
    Thanks emale.
    How often are people changing oil on their Accords?
    3750 miles or 7500 miles?
    Do more frequent oil changes improve gas mileage?
    Also, do you guys use synthetic or regular?
    Does using synthetic improve gas mileage?
  • hmurphyhmurphy Member Posts: 278
    Oh my god. Please let's not start these discussions again. Just search throught previous discussions to learn everything you ever wanted to know (and more) about these topics.
  • badgerfanbadgerfan Member Posts: 1,565
    And please do not refresh after you post, as you post the same thing again.
  • aggie1995aggie1995 Member Posts: 318
    jrock wrote:
    "How often are people changing oil on their Accords?
    Do more frequent oil changes improve gas mileage?"
    Let the Games begin!
    Noooooooooooooooooooooooooooooooooo!!!!!!!!!!
  • patpat Member Posts: 10,421
    jrock65, the suggestion to search through the discussion is an excellent one - the "Search This Discussion" feature will point you to all the information - and way, way more - than you ever needed to know. :-)
    I’m relatively new on these forums so I’ll play in this around while trying not to rehash too much what’s been written before. There are three elements of this discussion that I haven’t seen covered in previous oil threads;
    First; you might know that petroleum-based oils begin to break down at high temperatures (above 275-F) but are more resistant to water break down than synthetic oils. Synthetic oils are the opposite, tolerating high and low temperature extremes well but breaking down more in the presence of moisture. Unless you run your engine all day or can afford to change synthetic oil frequently, your best bet then might be to use a petroleum/synthetic blend to cover all odds. Some years ago a Consumer Reports study of motor oil in taxi cabs concluded that fully-synthetic oil held little advantage over using just one quart of synthetic per oil change (somebody here wrote about it previously).
    Second; some synthetic oils claim that they maintain viscosity and resist additive depletion for a ridiculous number of miles (like 15-20,000?). While that may well be true in a lab, in everyday use your crankcase oil will be subject to the build-up of moisture, corrosives, and particulates. So at 15,000 miles your expensive oil may be holding up really well - even though it’s loaded-up with acids and unfiltered abrasive particles.
    I drive my car twice as much as my wife does hers and I used to change the oil in both cars about every 4,000 miles. At 97,000 miles, my engine looked clean as whistle inside while her car at 45,000 miles showed a lot of gumming and varnish under the valve cover. Same oil, same maintenance schedule. The problem was the number of short trips she makes without the engine fully warming to burn off the moisture. That’s why Jiffy-Lube wants to change your oil every 3,000 miles –OR- 90-days. I now believe that I should have been changing my wife’s oil every 2,000 miles (!) whenever I changed my primary car’s oil (about every three months). I guess you could argue that gum and varnish doesn’t necessarily indicate premature wear and that her dirty engine might be just as sound as my clean one was. But I doubt that’s true.
    Third; deciding on an oil-change regimen for your car is about finding a balance between protection and cost. It’s also about buying peace of mind. If you sleep better at night changing $45 worth of synthetic oil every 3,000 miles then go for it. The Consumer Reports taxi cab motor oil study showed remarkably little difference whether oil was changed at 5,000 or 10,000 mile intervals. But those were warm engines, run for looong periods each day. From personal experience I know what shorter trips can do to oil.
    Honda says the Accord’s engines are good for 10,000 miles between changes in normal service. Why not listen to them then? For starters, they don’t know where you live, how you drive, and what quality of oil you’re using. They also warranty your powertrain for just 3 years or 36,000 miles whichever is less.
    Personally, I’ll change the factory oil at about 3,750 miles. Thereafter, I’ll be using a quart of full-synthetic mixed with quality petroleum oil every 5,000 miles. I’ll change my wife’s engine oil at the same time at only about 2,500 miles. For now, I’m stocked up with Honda oil filters that I’ll change with the factory oil and then at every other oil change thereafter. That’s MY balance of cost, protection and piece of mind. You do whatever makes you happy.
  • sockpuppet1969sockpuppet1969 Member Posts: 308
    Does anyone know what type of valve lifters the Accord 2.4 I4 engine uses? Are they hydraulic?
    I just completed my 30K service on my 2003 EX-L. I have been using dino oil until the car is no longer under warranty. At the next oil change, however, I was thinking about changing to either synthetic or a synthetic blend.
    Any thoughts or suggestions?
    One mechanic I spoke to suggested synthetic oil would be fine as long as the lifters are not hydraulic (something about upper . I am probably going to go with the blend. Thanks in advance for your comments.
  • jrct9454jrct9454 Member Posts: 2,363
    The presence or absence of hydraulic valve lifters has absolutely nothing to do with the suitability of synthetic oil. [How does this stuff get started?]
    In ANY modern engine, synthetic oil is reasonable and appropriate, if you can bear the expense. If you are going to change oil at intervals of 5k or less, though, it doesn't make a whole lot of economic sense.
    Virtually ALL Mercedes and BMWs have hydraulic valve actuation, and all require the use of synthetic oil. This is a long, complicated discussion, which veterans of the Edmunds boards do get weary of participating in - but there is no topic more mythological than oil [unless it's tires, another chronic source of stomach acid around here]. It just disturbing to me that "mechanics" continue to perpetuate urban myths on this topic, and others...on another board, I had to step in when a "trusted mechanic" allowed that the front suspension on a W202 C-class [late 90's] couldn't be adjusted to correct for drift...when our dealer did just that on each of our last 3 MBs, including the type of car in question.
    Use synthetic, or not - on an engine this new, the choice is yours, but it has nothing to do with the valve design.
    Hey - you left out oil filter brands as another overbloated topic. LOL.
    On the following site, there are some interesting insights into how Honda's variable valve timing system compares to Toyota's. This might make you think more about your oil changes while you're reading too. LOL.
    http://www.billzilla.org/vvtvtec.htm
  • motownusamotownusa Member Posts: 836
    Very nice article that even a layman like me can understand. It sounds like for most day to day driving the Vvti is the better choice over Vtec since the power comes at a lower rpm.
  • bszetobszeto Member Posts: 24
    Hi all,
    My car was parked on the side of a street, and when I came back to pick up the car, I found it damaged due to a speeding driver that struck the rear quarter panel of the car when trying to aggressively merge onto another lane. The damage involved the suspension and rear bumper as well as bending the left rear alloy wheels. I am just wondering whether there will be a vast change in the "rigidity" and the handling of the car once it is repaired! My car, by the way, is a 2003 Accord EX-V6.
    bszeto
  • talon95talon95 Member Posts: 1,110
    My previous Accord (a 2000 EX V6) was rear-ended while I was stopped in traffic, pushing it into the Jeep in front of me. The repair bill was just under $10,000, so obviously the damage was significant. The car spent several hours on the repair shop's unibody straightening system, and it was key to the success of the repair, IMO.
    To make a long story short, the Accord felt and drove exactly the same after the repair as before the accident, a situation that I attribute to the quality of the unibody straightening job. So just make sure that the repair shop does unibody straightening and has experienced technicians in this procedure, and you shouldn't have any problems with rigidity or handling after the repair.
  • gee35coupegee35coupe Member Posts: 3,387
    and find the best collision ceenter in town. And hope for the best.
    ...will make the car look and drive like new. Ask around for who does the best work in your area.
    Between 2:30 PM and just after 3:00 PM yesterday (Sunday, 12/4) I switched on the XM radio in my '04 Accord EX-L and there was no sound--just the word "LOADING" on the LCD monitor (no nav).
    I don't know how long before 2:30 PM the XM might not have been working and the signal was restored after 3:00 PM and worked later yesterday, too.
    Did anyone else experience an XM outage (I'm in San Francisco and was heading East at the time) or might there be something wrong with the car's radio?
    The radio worked on AM and FM stations when I switched to regular broadcasting after several minutes of silence from the XM........Richard
  • gregoryc1gregoryc1 Member Posts: 764
    If I had a vehicle that had $10,000 dollars worth of damage, I would let the insurance company repair the vehicle properly, and as soon as the process was completed, I would trade the vehicle back to the same Honda dealer that repaired the vehicle. I would not want a vehicle that sustained that amount of damage.
    The one interior feature on my ’05 LX that seems a little cheap is the large monochrome LCD display on the radio. This has black characters and symbols on a gray field with backlighting.
    I just noticed in a photo of a non-nav EX-V6 (with in-dash CD changer), that the radio display appears to be of the luminous LED variety (glowing characters and symbols on a black field). Am I correct that even the LX-V6 (which has an in-dash CD changer) has this luminous LED radio display?
    If so, then bummer. I knew the LX-V6 had a in-dash CD changer but I didn’t realize that there was a big step up from a monochrome LCD display to a luminous LED one. That LED display seems like a much better match for the quality the LED instruments and the Accord’s interior overall. I’m amazed that I never noticed that before. I sure notice it now!
  • dmullinsdmullins Member Posts: 30
    I have an 05' EX-V6 w/navigation and am looking for some online resource for the voice commands. Does anyone have any links for this? Thanks in advance.
  • thoonthoon Member Posts: 74
    All you have to do is say "help" and the navi will display a list of voice commands.
    Thanks, I understand I can say help but I'm looking for an "online" reference to the voice commands. Something I can reference while using my laptop. A web link to the Navigation guide or the command summary.
  • empowahempowah Member Posts: 71
    Anyone know if the 2005 DX models can be retrofitted with air conditioning? Is it still an accessory? How much should it cost?
    I think DXs offer A/C only as a dealer-installed accessory and the price depends on what you negotiate with the dealer (probably about $1,000).
    Note that the DX lacks a rear stabilizer bar in its suspension, so won't handle quite as well--I can't describe in what way; maybe someone else can elaborate.
    You're better off buying an LX which comes with A/C, the stabilizer bar, and a few other features that are well worth the cost. It's my understanding that not much, if any, money is saved by buying a DX and then adding dealer-installed A/C. Shop for an LX instead......Richard
  • maggiesuemaggiesue Member Posts: 2
    I have an '05 Accord EX-L, it has xm, and the 6 cd in dash changer. However, when I load only 1 cd in the player, an original cd, it plays, when I load 2 or more, it skips very badly. And it won't play burnt cd's at all. I read the manual and it will not play rewritable cd's, which the ones I tried to play weren't. Do I just have a defective unit?
    If memory serves, MSRP on the dealer installed A/C system is $1,200 PLUS labor for it's installation. H-and-A sells the kit online for $900.
    Unless you're planning to keep this car forever, remember that you'll take a big hit on resale value - when used LX's are plentiful, who's going to want a stripped DX used?
    Unfortunately my Accord was rear-ended on Tuesday. Kind of irritating to see damage on a car that's 5 months old. Hopefully, we will hear from their insurance company by Monday and be able to start the repair process. So we are left driving our Odyssey and Civic Si. I miss driving the Accord .....
  • pbchoclovrpbchoclovr Member Posts: 11
    Yes, on the DX model the AC is still an accessory and it can be retrofitted by the dealer. I used the information from HandAaccessories to negotiate my price. Got it for $1000 including installation. Hope this helps.
  • blaneblane Member Posts: 2,017
    Why don't you just photocopy the appropiate page in the Navigation User Guide? You can laminate it in plastic for under a buck with the packs of sheets available in any office supply store.
    If you are wed to your laptop, you can scan the User Guide page and store the file on your laptop.
    I totally agree with you. In the nine years I've been selling Hondas I can count the number of DX's I've sold using the fingers on one hand.
    As used cars they are dogs to sell too.
  • sandman46sandman46 Member Posts: 1,798
    Sorry to hear about your accident. No injuries I hope. Did you have the baby on board? Hopefully not.
    I'm sure the body shop will fix the car properly, knowing you and Gee.
    Again, hope all is well!
    The Sandman :-)
    What CD version is the newest accord with navi supposed to come with? Mine came with the 3.30g CD but when I called honda, they said the newest is 3.40b. What CD did everyone's 2005 Accord EX Navi come with?
