Older Honda Accords
1338339341343344389
  • koumeikoumei Member Posts: 7
    You forgot to mention the Special Edition. LX-V6 does not have alloy and moonroof.
  • atlantabennyatlantabenny Member Posts: 735
    It's an automatic; a complete stop makes the tranny engage 1st for stand-still takeoff is what I meant.
    kourmei, Honda looks like it's out to capture new customers in 06. This link shows the LX-V6 with moonroof and alloys as standard indeed.
    http://automobiles.honda.com/models/specifications_descriptions.asp?ModelName=Accord+Sedan- - - - &Category=LX+V%2D6
  • mrs27mrs27 Member Posts: 2
    I've had Honda Accords for as long as I've had my driver's license and have only just started having this problem within the last several months. I currently drive a 98 Accord, and after a night of heavy rain, the car will not start. I've heard from a neighbor that there is a problem with moisture getting into the ignition (or something like that), and usually after a few hours the car will start fine. This time, I've not been able to get her started for nearly 2 days now........ The car sounds like it's going to start, but never turns over.
    Does anyone else have this problem?
  • rhaeffelerhaeffele Member Posts: 149
    "The belt vs. chain thing doesn't concern me, it's more the 1,200 difference between the selling price of the cars. Plus belts are usually quieter, so it's worth the $700 after 100k. All about trade offs I suppose."
    Agree. While generally assumed to be longer lasting than belts, chains can and do break, too. And if that happens, the flailing pieces show no mercy to nearby parts they contact. Chain tensioners on overhead cam engines seem to require periodic service just about as often as belt tensioners, so there's often service of some sort required between 80,000 to 100,000 miles, regardless, even if the chain is still intact and healthy. Belts are really not that poor a compromise.
    " I currently drive a 98 Accord, and after a night of heavy rain, the car will not start. ... The car sounds like it's going to start, but never turns over."
    Actually it is turning over. It just never quite "catches" and runs until whatever's wet dries out. I must confess I no longer drive an Accord, but your problem is a car problem, not an Accord problem. The usual suspects are ignition system components - distributor cap (if present on '98 Accords)*, spark plug cables and boots, and ignition coil(s). Your dealer or mechanic shouldn't have much trouble tracking the problem down. My late wife had a VW "bug" when we first met - the stupid car did exactly the same thing you described until I replaced the cracked distributor cap. (probably the main reason she married me)
    *A cracked distributor cap can be a very effective engine disabler when moisture is present. Just a few drops of water in the wrong place, and you walk.
    Thanks for the tip !! Hopefully things will dry out soon so that I can drive the car to the mechanic.
  • bradespbradesp Member Posts: 21
    I'm looking to buy a clean, dependable used car for my 16 year old daughter. I'm looking at the Accord and Camry. I want a 4 cylinder for gas mileage benefits.
    What year would you recommend I look at in terms of bang for the buck? I'm looking to find something with less than 80,000 miles that's been well cared for. Because of budget, I'm limiting my search to years 1997 thru 2002. I'd like an 03', but don't think I can swing the bucks.
    bradesp
    "I'm looking to buy a clean, dependable used car for my 16 year old daughter. I'm looking at the Accord and Camry. I want a 4 cylinder for gas mileage benefits."
    Either make would generally be a good bet, though some mid-nineties Camrys had a reputation as "sludge monsters". Take a penlight and small dental mirror along if you look at any Camrys. Remove the oil filler cap on the valve cover and peer in with the help of the mirror - if you see lotsa black goo inside, keep walking. (While Hondas aren't particularly prone to sludging, given the model years you're contemplating, don't hesitate to look inside the valve covers of Accords, too.) The newer the better, finances permitting. Concentrate on mature owners - less liklihood the car's been thrashed, and more liklihood the car's been maintained - unless owned by some little old lady who only drove it half a block to the corner grocer and back once a week. (I'd sooner consider a car that'd been freeway driven fifty miles a day than an urban crawler that rarely got properly warmed up.)
  • roberts5roberts5 Member Posts: 35
    With gas prices going over $3.099 a gallon, what is the most efficient speed cruising a 1000 trip miles in the 2003 Accord LX 4 with auto? I am definitely trying to be lighter on acceleration and look farther down the road for traffic and lights.
    Happy Hondaring!
  • hermannhermann Member Posts: 38
    Gas is 2.89 today in KC, On a recent trip to Branson I got 32MPG cruising between 70-75 MPH..This is the best I have got on my car in 6000 miles. Hard to cruise on the Interstates around here any slower, you will get run over and flipped off..
    Dan
    What hermann said with the addition not to hesitate using your A/C. Once above 40 mph, wind buffeting around open windows takes a heavier toll on fuel economy than A/C compressor drag.
    "...any slower, you will get run over and flipped off.." -hermann
    I guess the middle finger salute is the coup de grace after some moron with an attitude runs you off the road, eh?
  • imidazol97imidazol97 Member Posts: 27,691
    I have always felt that comparison of drag with windows down to using the air conditioning compressor means ALL the windows down. That does cause lots of buffeting. I often put one front down an inch and a rear down an inch on one side or the other and get a smooth air flow without buffeting. I really feel that does save gas. But when it's HOT or humid I don't hesitate to use the air. Just slow down 5 mph and enjoy.
  • lastwraithlastwraith Member Posts: 350
    Wouldn't pressing down on the accelerator until the car downshifts accomplish the same thing? I mean, you may have to near floor it, but the car should definitely find first at some point.
    just a thought, i know it would be inconvenient to have to stop just to get first in town
    I've not tried flooring it to engage 1st, given that WOT (wide-open throttle) is something I prefer not doing. However, you bring up a point and reading the owner's manual, Honda says it's ok to manually shift the auto tranny to 1st without stopping. Maybe I've just about forgotten the fact that auto trannies can be manually shifted. Thanks for the comment.
  • nri007nri007 Member Posts: 1
    Recently I bought a Honda Accord 2005 2.4 VTi from John Blair Honda in Melbourne Australia. Their service is great, however the brand new Accord I bought has given me problems. The door windows were creaky, had to get them fixed. The suspension are very poor, road vibrations are felt on the stearing :confuse: . The automatic transmission makes large clicking noise while shifting from reverse to drive (Is this normal?). The water jets for the front screen are not aligned properly. The air conditioner makes a loud clicking noise when put on. Most importantly, observed that the paint on the bonnet has developed bubbles. It is only 3 months and the paint is showing this defect :confuse: . This is my 4th Honda, until now I used to drive Honda preludes, this time decided to buy a family car and opted for the Accord. This Accord is Made in Thailand, this could be the reason for all these quality related issues. Did anyone observe these type of symptoms with the Accord 2005 2.4 VTi??? :cry:
  • blaneblane Member Posts: 2,017
    The 2006 Civics have an AUX (auxiliary) jack allowing use of third-party audio devices such as portable XM and Sirius radios, iPods, etc. I cannot find anything in the 2006 Accord brochure indicating whether that vehicle will have a similar AUX jack.
    Anyone know?
  • carbuyer25carbuyer25 Member Posts: 20
    I recently purchased a 2005 Honda Accord LX Sedan. In the owner's manual, it says that only Honda brand Coolant, Honda brand Motor Oil, Honda brand Transmission Fluid, and Honda brand Brake Fluid should be used.
    It says that use of other non-Honda brand products may result in damage to the car. Is this true, or just a Honda ploy to get me to buy high-priced fluids from the dealer? Would using non-Honda brand fluids void the warranty?
    Any thoughts? Thanks.
  • bartalk3bartalk3 Member Posts: 692
    That's a laugh. Where's that from--their own special Honda oil well in Saudi Arabia, refined in their own Honda refinery?
  • rbevz67rbevz67 Member Posts: 69
    Are ceramic brake pads factory equipment on the 2005 Accord EX 4cyl sedan?
  • midnightcowboymidnightcowboy Member Posts: 1,978
    No, Honda and most manufacturers do not OEM ceramic brake pads. They are after market.
    I've read the threads about the known tranny issues in 98-02 years and I'm very concerned. None of the threads though help me understand how to determine if a vehicle I'm considering has or is prone to the known tranny troubles. Also, if I'm buying a vehicle in the 70-80K mileage range and have intentions of driving this to at least 150K without major repairs am I being unrealistic? I've had no difficulty driving my toyota's this long without incident and it concerns me that others feel the tranny issue will put me at great risk of meeting this expecation.
    Also, I saw mention of a 7 yr/100K extention on the tranny warranty by Honda, but I can't find anything officical from Honda at their website. Can someone clear this up for me?
    bradesp
  • biker4biker4 Member Posts: 746
    You might get a more informed reply on the Acura TSX forum - that's basically what you have.
    Other than the block of the engine, there's little in common between the US Accord and your Accord.
    Paint issues seem to be more common these days - regardless of maker.
  • akaristosakaristos Member Posts: 18
    Now that the 2006 Accord has been officially released, I think it is very beneficial to all that we discuss various topics related to it, such as starting and developing pricing, new features, pros and cons vs. 2005 model, desirable options and other issues. I for one appreciate and value various contributions and learned so much. Presently I am thinking of buying a 2006 Accord SE 4 cyl, Manual and need help towards that end. Thank you.
    Use Honda or EQUVALENT coolant, oil, trnasmission fluid, barke fluid and don't worry about it.
    If you use EQUIVALENT that met SAE specs no problem and no worry. almost all brands meet the requred specs.
    You should be okay.
    BE HAPPY, DON'T WORRY,
    MidCow
    "That's a laugh. Where's that from--their own special Honda oil well in Saudi Arabia, refined in their own Honda refinery?"
    carbuyer25's concerns are justified. You're correct - I haven't seen any oil derricks with "Honda" plastered on 'em, either. As far as motor oil is concerned, any brand 5W-20 API "SM" motor oil with the "starburst" seal on the front label will be fine in current Accord motors. Honda brand motor oil at the dealers is blended and bottled for the company by ExxonMobil and is virtually identical to Exxon "SuperFlow" and Mobil "Drive 5000" - except priced higher at the dealers. (While all Honda dealers necessarily stock and sell Honda brand motor oil in their parts department, few if any, use it in their service bays. They typically buy bulk barrels and pump it into customer cars like a forced colonic at oil change time.) With coolants and transmission fluids the situation is different though. Like most manufacturers now, Honda has developed a specific ATF for their own trannies in cooperation with one of the major blenders. Use of other than Honda Z-1 ATF will virtually assure early failure in these trannies. Shift quality will also probably suffer if a substitute fluid is used. Honda and its fluid co-developer settled on a specific type of friction modifier to control "juddering" - a cyclical pulsation when shifts or torque converter lockup occur. At its worst, "juddering" may be accompanied by an audible squealing. Universally available GM spec. "Dexron III" fluid is definitely NO LONGER the recommended fluid in these boxes, though Honda allows for its temporary use in an availability emergency. So-called "All Makes" ATFs that purport to be compatible with OEM fluids are only their respective blenders' best guess at compatible friction modifier characteristics - "one size" does NOT ever fit all. These premium "All Makes" ATFs are rarely less expensive than the genuine article at Honda dealers, either. (Unlike many other auto manufacturers, Honda doesn't price their proprietary ATF outrageously.) Honda's is a semi-synthetic, too. The issue of coolant is less dire, but still requires some consideration. All three of the Japanese "big three" automakers have settled on a generally compatible coolant technology in their extended life coolants. None of these fluids use silicates as their primary corrosion inhibitors any longer. Instead, they use a hydrated organic salt, sodium benzoate, which forms a mild acid in solution, Sodium benzoate is often used as a preservative in packaged foods, too. When sodium benzoate in solution contacts bare metal in the cooling system, it forms a protective layer against corrosion. But, it can take up to 3,000 miles of driving to do so. So, the Japanese manufactures also include a stiff dose of a phosphate salt in their mix. The phosphate, A> gives virtually immediate protection until the organic acid can displace it, and B> coincidentally protects water pump impellers against erosion pitting damage ("cavitation") should there be a compromising break in the organic acid coating from circulating hard debris. Any Japanese extended life antifreeze/coolant concentrate can be safely used in any current Honda, Nissan, or Toyota. Honda's and Nissan's use a green marker dye, and Toyota's uses a pink marker dye. None of these green extended-life syrups are the same as conventional high-silicate content Prestone (which is no longer in production). There's no directly equivalent U.S. aftermarket extended life product advised by those three manufacturers, but Zerex "G-05" comes closest in protection philosophy. Like the Japanese developed coolants (actually blended and bottled in the U.S. for distribution here in the States) G-05 uses sodium benzoate. But instead of phosphate content for co-protection, G-05 uses reduced levels of silicates. The G-05 technology was developed in Germany by BASF over two decades ago and has been factory fill in Mercedes-Benz, SAAB, Peugeot, some VW, and some BMW cars, among others, ever since. It does have an established track record in iron, soldered brass, and aluminum applications. G-05 is also now factory fill under the respective auto manufacturer's names in most domestic Ford and virtually all Chrysler products. The retail pricing for the Japanese coolant concentrates varies from around $13.00 to $20.00 per gallon per individual dealer policy. G-05, which is NOT specifically authorized by the Japanese "big-three", can be had at retail for about $10.00 gallon. NOTE: NONE of the "big-three" Japanese auto manufacturers recommend or even nominally accept the use of GM DEX-COOL antifreeze at all.* DEX-COOL's organic acid corrosion inhibitor is not at issue, but DEX-RON uses no silicate or phosphate content as co-corrosion protection and the Japanese are concerned that may be the basis for future problems with time. While I'm not personally convinced their concerns are justified, it might be an issue for a car still under warranty, so make your antifreeze choice accordingly. Neither the dealer nor a manufacturer's zone rep can argue with fixing a cooling system related problem under warranty if the car owner can show receipts and a log for timely coolant changeouts with his car make's own brand antifreeze/coolant. The same goes for the proprietary ATFs. Some of you may have noted the availability of store brand extended life antifreezes in the last year - notably at Wal-Mart and Advance Auto stores. These are virtual unlicensed "clones" of the DEX-COOL technology. I'll confess that I personally used Havoline DEX-COOL (who also blends and bottles "Mr Goodwrench" DEX-COOL in my '96 Honda for over three years without any issues whatsoever. But, I'm not making a blanket recommendation that other Honda owners follow my example. I'm now using Wal-Mart's "SuperTech" extended life antifreeze in my current ride - an '03 Hyundai Sonata aluminum V-6. At one year to the day, yesterday, it's still bright, clear green in the radiator - something that could not be said of Hyundai's factory-fill that turned cloudy in less than two years. I've laid out what I've learned about the various fluids so y'all would have a summary. But, make your own determinations according to your own esperience.
    *which is somewhat weird since the Saturn VUE uses a Honda V-6 and GM pours DEX-COOL right in despite Honda's dire warnings . . .
  • ctalkctalk Member Posts: 646
    Wow. Your exhausting :sick: :P
    No one held a gun to your head.
    :P
    Wow, you seem to know a lot about Honda's engines.
  • coupedncalcoupedncal Member Posts: 252
    I just went to honda's web site and they have listed 2006 model year Accord and the base model is no longer DX which now means the starting price of Accord is now $18k +. I think it is so they can upsell the Accord and Civic and make room for Fit/Jazz model which is likely to come in at about $13k to $14k.
    Did anyone else notice this too ?
  • mamamia2mamamia2 Member Posts: 707
    I got 1,200 miles on my Accord. I met a friend who bought the same car 6 months ago. He told me about his first visit to the dealership, for his first oil change at 3,750 miles. He was shocked to pay some $300 for the oil change, tire rotation and some other insignificant check ups.
    I wonder, why should I pay the dealer $300, when I could as well visit my good old Shell station mechanic, pay $25 for the oil change, rotate the tires (why is that needed, I don't know...) for another $25 -- and save money and aggravation?
    Does this first oil change need to be done by my dealership?
  • acousticacoustic Member Posts: 7
    My dealer offers an $18.50 oild change at 3.5K miles. I say it's not worth the hassle of taking it- AND WAITING. I'll go to the local express lube. CHEERS.
    Sadly your friend's dealership ripped him (a new one). The good news is that dealership represents only a minority of Honda dealerships whose general or service managers are that shady. Unless the front tires were incredibly out of alignment (highly doubtful), your friend's car would not have needed a tire rotation at 3,750 miles - and neither will you. In fact, I'm told that Honda doesn't recommend an oil change on new engines untill 10,000 miles. (If you don't mind, would you check your owner's manual's recommendation for 1st oil change?) As to your particular situation regarding dealership vs. local garage/service station routine servicing, either is OK. As long as you keep the receipts for inspection for the service done at the stated time/mileage intervals in case there's a mechanical problem down the road, if done by your service station, your warranty remains in effect no matter what a Honda dealership service writer might tell you. (Your warranty is issued by, and paid for, by Honda America, not the dealership.) Even for people like myself who do their own routine maintenance, the manufacturer cannot deny a warranty claim as long as the car owner can present receipts for materials and fluids and keeps a written log of the procedures performed unless the manufacturer can prove otherwise. (and "proof" means the presentation of physical evidence by the dealership's or Honda's rep before an arbitrator, not mere opinion) Just make sure you use the recommended viscosity range of motor oil in the current or greater API classification in the future. (currently 5W-20, API "SM", and the "starburst" seal on the front label) The oil filter does not have to be Honda brand, either. (Honda doesn't make oil filters. Honda sources their "Honda" brand oil filters from two suppliers - "Filtech" in Japan, and Fram from a factory in Canada. In most cases the "Honda" oil filters bought from a dealer in North America are the Fram-made filters. The country of origin on the box or the filter will verify the source. Purolator, Champion, Fram, WIX, Baldwin, NAPA, and others - even store brand filters such as Pep Boys' "ProLine" (made by Purolator), Wal-Mart's "SuperTech", and Auto Zone's "Valuecraft" brands (both made by Champion) are fine as long as the equivalent designation from the catalog cross reference is used.)
    rhaeffelle,
    Paragraphs PLEASE. Your posts 17774 and 17781 are worth reading, but it is very difficult to do so.
    I have averaged 30 mpg on my 2003 LX 4 with auto. Does the extra power justify spending $10,000 more and still have to shell out some $6000+ to replace the batteries after some 90,000 miles? I usually have no passengers and I have hit 38 mpg on a trip. Is the hybrid worth it?
    Hope you enjoy your Hondaring!
    Thanks so much, rhaeffele!
    OK, so here is the FULL story, after I actually called the guy (last night I was relying more on my wife's interpretation of the story...):
    His dashboard "Service Required" yellow light came on at about 3,750 miles. He took the car to the dealer for the first oil change which cost him around $30.
    The ripoff happened on his SECOND visit, at around 7,000 miles, when the Service light came on again. It was THEN that the dealer charged him over $300, claiming they also rotated the tires, cleaned the brakes and a bunch of other check-ups...
    Now, the V6 manual says that only under "Severe Driving Conditions" you're supposed to change the oil every 3,750 miles (or 6 months)... For non-severe condition you can do that every 10,000 miles or every 12 months...
    SO, my question is now: Why does the Service light on my friend's car (and probably on mine too, soon) goes on according to the Severe Driving Condition?
    BUT more important, if you go to your own mechanic (or do it yourself) HOW DO YOU SHUT OFF THAT YELLOW DASHBOARD SERVICE LIGHT? On my old '95 Accord I can shut the yellow Service signal off easilly. How do you do that on the new Accord?
    "Is the hybrid worth it?"
    Hee, hee, hee - that's the pertinent question that hybrid drivers arrogantly dismiss as impertinent. ;)
    "HOW DO YOU SHUT OFF THAT YELLOW DASHBOARD SERVICE LIGHT? On my old '95 Accord I can shut the yellow Service signal off easilly. How do you do that on the new Accord?"
    Short answer? I don't know either. (I had a '96 Accord - stick the ignition key into a slot in the instrument cluster and, Prest-o Change-o ! - the yellow [or red if you really went too long] service warning changed magically into soothing green before your startled eyes. It was a great idea.)
    mamamania2,
    OKAY OKAY i am reading the Honda manual for you, here is the answer:
    Page 62 in the Accord Coupe manual:
    (1) Turn off the engine
    (2) Press nad hold the Select/Reset knob on the instrument control panel, then turn the ignition switch to ON (II).
    (3) Hold the knob fro about 10 seconds until the indicator goes off.
    Also on page 62, the maintenace light is based on mileage only and has nothing to due with severety of the conditions:
    4cyl:
    since last reset.
    8,000 miles comes on fro 2 seconds when you turn ignition sw on
    8,000-10,000 same as above then falshes for 10 seconds
    greater than 10,000 constant light on.
    6 cyl:
    since last reset.
    6,000 miles comes on fro 2 seconds when you turn ignition sw on
    6,000-7,500 same as above then falshes for 10 seconds
    greater than 7,500 constant light on.
    Realize I could have given you the typical curt answer, RTM, but I instead cose to look up the answer for you. All of 2 minute after looking in the index.
    Cheers,
    MidCow
    P.S. _ Next time you take the car to the delaership do two things. First lookup the recommneded service items, decide which you want. Or (2) as the dealer what thay plan to do and which are absolutely must ( like changing the oil and filter) then bypass the optional ones.
  • chucko3chucko3 Member Posts: 793
    The answers for all your questions are in the owner's manual.
    You READ the manual? I sure wish others here did the same.
    The alignment problem should have been covered by warranty at 3750 miles!!!
    If Honda uses Fram for American filters...
    I read for years here about filter comparisons. I finally tried Purolator on my cars and the oil stays clearer longer. I change at 3000-4000 miles based on how much cold weather useage. But I can tell a difference. I have some Fram filters to use up on the older car or with more frequent oil change periods.
    Okay, work is slow, so I have some time to ponder. I don't mean to make frivolous (sp?) posts, but I am curious. My son noticed the 160 m.p.h. on the speedometer. He asked me "how fast will it go?"
    Being that I have a 4-cylinder, what might be the top end of this car? Thanks.
    Cowboy, all I can say is THANKS!!! I really appreciate it.... And a bit embarrassed....
    ...Yes, the manual DOES give you the instructions (page 67 on my sedan's manual)... And I DO usually read manuals....
    SO, the conclusion is:
    For the FIRST oil change, at 3,750 (or 6 months), I guess going to the dealership makes sense, as long as you check with the service manager in advance, exactly what they do and how much it would cost.
    Then you go back to your good old mechanic for your next oil change and whatever needs to be done, according to the service manual.
    I think I got it this time.
    "Being that I have a 4-cylinder, what might be the top end of this car? Thanks."
    Realistically? On flat ground at sea level (ideal conditions), maybe around 117 mph to 120 mph, perhaps a tad faster.
  • banditboybanditboy Member Posts: 54
    I am picking up a 4 cyl accord soon.But got to say i never ran into
    so many jerks in a dealership since i moved to shopping for a honda,
    I am travelling 100 miles to a dealer .
    The test ride was good on the dx[i think so ...it had a sunroof and was good]
    As far as oil changes go i will do 1 at 600 , 3000 and then reset,.I have followed on many engines and do find metal piece at 600 and some in 3000 in the pask vehicles.so any way once that is done mobil 1 all the way ,.
  • 4runnering4runnering Member Posts: 10
    Referencing a Feb. 2003 Car and Driver article 'Splashing in the Mainstream',
    I believe the Accord with 4cyl. and man. 5 spd. had a tested top speed of 125mph.Splashing in the Mainstreamlink title>
    "As far as oil changes go i will do 1 at 600 , 3000 and then reset,.I have followed on many engines and do find metal piece at 600 and some in 3000 in the pask vehicles.so any way once that is done mobil 1 all the way ,."
    banditboy, that regimen qualifies you as One Really Smart Guy in my book. Too bad more people don't realize that all new engines "make metal" to a greater degree during the first several hundred miles of run-in. The larger pieces aren't a concern because they're trapped by the oil filter. It's the smaller, sub-20 micron particles that can slip through the filter medium and bang around within bearing clearances that will unnecessarily chew up an engine's precision bearing surfaces during the remainder of the break-in process. The first oil change in any engine's life is aruably its most important one. 3,000 mile oil and filter changes for predominently urban driving thereafter is good preventive maintenance against future oil-related problems. If the car is usually driven at freeway speeds (50 mph - 75 mph) commuting to work, 5,000 miles is adequate because those sustained speeds are the easiest miles an engine can see.
    I am interested to know other's opinion... If it's so crucial (which is sounds...) than why would Honda recommend it done at 3,750??? I am now at 1,200 miles.
  • indyfanindyfan Member Posts: 22
    I have a new Accord which is approaching 2000 miles. Can the oil be changed my myself without a big hassle or must it be taken to a garage.
