If you read my original post, I never said that Honda's glass was inferior to other manufacturers. However, tinted windows make a huge difference for two reasons: 1. The 60% UV transmission referred to in other posts is significantly reduced. Not only does this protect the occupants, but it also increases the life of the interior materials. 2. Tints have been proven to reduce interior temperature in direct sun. This is a benefit because the car cools off much faster and again...interior materials suffer less damage from heat radiation and have a longer life.
My last car had 3M film with a medium gray tint. I was never burned by the sun as I am in my present car. It matters little; my Honda dealership recommended a good tint man.
I found these links interesting:
http://answers.google.com/answers/threadview?id=551464
http://www.wonderquest.com/windshield-dots.htm
3 mornings ago, leaving my garage, when pressing the brake pedal to shift into gear, I felt a slight vibration coming from the brake pedal, and a buzzing noise that sounded abormal to me...
I turned off the engine, opened the hood, and started checking for the fluid level in the "clear" plastic ABS reservoir... It is quite difficult to determine the level of brake fluid in that reservoir, and since I have a can of brake fluid in my garage, I decided to try and pour some in... What do I got to lose...
...Well, a HALF CAN worth of fluid was able to enter the reservoir, till I could see it filled up.
.... I turned on the engine again and VOILA, THE ABS LIGHT NEVER CAME ON AGAIN (so far, knock on wood)!!!......
I love my old Honda!
...Not so sure about my dealership service department, though...
Check your pads too. As they wear, the fluid level in the reservoir drops.
..And I was refering to the ABS fluid reservoir, not the Brake fluid reservoir. They are 2 separate reservoir (in this model at least.)
...Yes, there MAY be some leakage somewhere in the ABS system. But with a 10 year old car, I'd rather pour in half a can of fluid every few months, than pour out hundreds of more $...
If we're talking hard dollars and sense, then what's your and your family members' lives' worth? We're not talking about a dead power window motor or a balky CD player. There are two essential safety systems in every car, and they're not air bags and enhanced side structural protection. They're the abilities to reliably steer and stop your way out of trouble before the additional systems have to be depended on.
The brakes work perfectly fine even without the ABS, as you should know.
I have so far invested over $1,500 in maintaining the ABS functioning, being a big believer in ABS.
But with a 10 year old car, you have to make some compromises, sometimes.... So, I will keep driving a safe car, and pour in a half can of brake fluid into the ABS reservoir, if necessary, every few months --- and be happy and safe.
The top speed of this vehicle can be no where near the 160 mph of the Speedo; what is in fact the top speed of this car?
Probably has a governor limit or hp limit of 110.
Accord has seen fit to placed its huge speedo right in front of me with numbers of 100, 120, 140, 160... I pretty much never go over 80, so half of it is wasted.
Other isocracy is that it's fuel capacity is listed to be 17.1 gallons, but we have been only able to get 15 gallons into ours, even when the needle is buried deeply into E. We know one isn’t suppose to run them dry, but in a bind it is nice to know you aren’t carrying 2 gallons of inaccessible fuel.
Excellent Forum. Keep up the good work folks.
Learning a lot here... maybe more than I need to know about defrost ac.
As for oil change interval we will stick with the Honda manual, and when the 3 yr 36K warranty is up, will switch over to Castor Oil Synthetic 5w20. We do wonder who makes/blends Honda’s 5w20 motor oil. I haven’t seen any indications of Honda having its own lube oil plant. Consensus is, that perhaps K&N may be the best oil filter. Again wonder who makes Honda's oil filters.
Happy motoring
Houston TX
(Castrol at one time marketed a castor oil-based racing oil. The oil from castor beans is an extremely stable and effective engine lubricant that withstands the high temperatures typical of high output engines run close to the max for several hours, but it has one minor problem: once heated to operating temperature, it undergoes a non-reversible molecular change that results in the stuff agglutinating into a semi-solid glop in the oil sump that defies extraction once allowed to cool back to ambient temperature. Competition engines in the late forties and early fifties which ran castor oil had to be drained immediately after race time, refilled with a conventional mineral oil, restarted to thoroughly circulate it, and only then be shut down and allowed to cool.)
Many years ago I got stuck in the middle of nowhere in Montana, driving my aunt's Mercedes with the needle on the fuel gauge showing 1/4.... It took us a half day to be towed to the nearby (40 miles away) town and another few hours before the mechanic told us smiling that we were simply out of gas...
And don't worry about those 2 gallons of "inaccessible fuel".... of course you car DOES use that fuel...
...Enjoy your car. Don't worry too much...
Mrbill
For people with an 05 sedan, do you have lights on the bottom of the rear doors that light up when the door is opened?
In the front doors, there are lights which illuminate when the doors are open. In the rear, there appears to be a red reflector but I'm not sure if it's supposed to light up. Both my rear doors DO NOT light up...
How about yours??
Thanks forum!!
It's a Honda feature called Grade Logic. When the vehicle is going downhill and you apply the brakes gently, the transmission will downshift to help slow the vehicle down. It's in your manual.
HI,
How about yours??
Thanks forum!!
Have you ever felt the ABS - I mean really felt it?? It's more like a pounding under your foot IMHO.
...it's not the linkage but rather the need for careful engagement of the sensitive, precise clutch...............IMHO.
..which is to take nothing away from my well-engineered 6M coupe: it just requires that I drive better..............
..best, ez....
I would describe it as a loud rumbling or grinding sound. This is accompanied by a frightening shaking sensation too. When this happened during a panic stop in a friend's EX 05, everyone said what the heck was that???
Honda has finally got back on track with the '06 Accord and Civic and all I can say to Toyota and Nissan...watch out guys!
The Sandman
If you are playing a disk full of mp3 files, will the it start playing the files exactly where it left off - since the last time you turned the car off? I believe this is called the "resume" feature. This feature exists on my Panasonic CD/MP3 player I had installed in my 95 Civic. It is a very handy feature. If you are playing 150 songs, you don't have to scroll through fifty songs to get back to the song you were listening to the last time you were in the car. I downloaded the manual for the Honda mp3 player, but it doesn't say anyting about this.
Steve
Mrbill
blackxv6 states the above in post #17939. I would like to know if this is true. The Accord is one of the vehicles that I am considering along with the Camry but I am concerned about this statement.
I would like to hear from 2003-present owners of the Accord, particularly the I4 auto, if this is true concerning shuddering brakes. Shuddering brakes is usually caused by out-of-round or uneven rotors.
..best, ez.....
Here's where you can order the most current Accord DVD:
https://iweb.alpine-usa.com/pls/admn/ha.header?p_make=Honda
The site states: "Never interchange DVDs with different colored labels, or ones with versions less than what is printed on your current DVD. Navigation DVDs obtained from friends, Internet auctions or outside of the normal ordering process may produce error messages, or cause the navigation system to malfunction."
They also say: "The next version, 3.50, will be available for purchase October 2005" and "This year's update includes updated points of interest (POI) and map coverage. There are no additional navigation features."
Try it next time you pull into the garage. Just leave the lights on and see what happens.
