Older Honda Accords
13637394142389
  • jrct9454jrct9454 Member Posts: 2,363
    The compressor cycles as needed, depending on temp and setting. Yes, it is noticeable, though no more so than on every other car I've owned...
  • bax2bax2 Member Posts: 8
    So, if I am willing to "play the game" and negotiate, how low should I start.
    The $450 over invoice is what they are advertising, but obviously if they are willing to sell at that price, they can go a lot lower if pushed. I am willing to push, but I need a little advice?
    you asked WHERE I am looking, I am located in Bucks County, PA.
    I have not done any internet shopping, but am willing to give that a try too.
  • nealptnealpt Member Posts: 4
    at all on my Camry ... I wonder if it cycles on and off,
  • raybearraybear Member Posts: 1,795
    I think you can do better there. Availability is starting to become a problem, but I'd start negotiating at invoice and settle a bit higher if you like the dealer.
  • bryhoganbryhogan Member Posts: 23
    Here are the differences between the VP and the LX that I'm aware of:
    - Less HP (same engine as LX, just no VTEC)
    - 14" Wheels
    - No Cruise
    - No Power Doors
    - No Power Windows
    - ABS is not an option
    But, the VP does include...
    - Automatic
    - CD/Tape Stereo
    - Exterior Trim of a LX
    - Wood Trim Interior
    ..And is at least $3k less than the LX.
    Consequently, I purchased the VP purely based on price and likely trade-in value. I was looking to spend about $16k, wanted something larger than a civic with good trade-in value. In my opinion, for $15k, you can't go wrong. Of course, lack of power dooors/windows, cruise and ABS is a sacrifice. (I added cruise and power door locks at an aftermarket shop, but still miss the power windows & ABS.)
  • har1bushhar1bush Member Posts: 207
    how about looking up Edmunds' invoice price, subtract the holdback, and offer that price as a starting point. Unless Honda has some rebates these days (which I havent seen any ads for), the dealer probably wont sell at or under that price.
  • timadamstimadams Member Posts: 294
    Oh boy. Here we go!
    Thanks for the input, I just needed a starting point. I would like to buy an Accord and I would like to get a nice deal too.
    Hopefully, if they are looking to move out the 2001 models, we can agree on a price and I will get my new car.
  • soberssobers Member Posts: 496
    as they will be moving at around similar price (200-250 over invoice) as 2001s. So you are better off buying the 2002!
    Do you think with all the competition from new altima and camry, I will be able to get a 2002 that close to invoice?
    It does make sense to get the 2002, but I figured that I would not be able to get that low.
  • rhuarhua Member Posts: 5
    The owner's manual says the break in period is 600 miles. I just bought an accord V6 and currently have only 200 miles. I wanted to drive to Vegas this weekend (from LA); does anyone know whether this is bad for the car? Does it matter the length of the trip or speed or is it fine as long as i don't rev the engine too hard? Any advice would be greatly appreciated..
  • picenopiceno Member Posts: 55
    I would not drive to LAS Vegas, if I were you.
    Apparently, SUSTAINED high speeds for long periods
    of time are NOT recommended fot new motors. I have a 2000 Honda Accord EX V6, and have never taken it for a high speed drive for longer than 1 hour. You might want to get other opinions.
  • amz997amz997 Member Posts: 61
    I paid 200 over invoice for 2001EX at philadelphia honda. last week my cousin bought 2001 V6 EX at 200 above invoice.
    Call them and Talk to Joe Reid.
  • mmoroskymmorosky Member Posts: 4
    I've noticed that several dealers now have the 2002's. Has anyone been able to determine if there are ANY changes from 2001? Every dealer I ask says that they are the same. I assume there has to be some minor changes. I'm comtemplating buying the 2001 or 2002 EX-L Sedan sometime this month.
    Go on your trip.
    There are two "rules" to follow about engine breakin:
    -Try to vary your road speed, so that you don't run at the same rpm for extended periods of time, say more than 15 minutes. Just vary your speed up and down from time to time. Knowing the typical I-15 traffic to LV, this should be pretty easy. But plan on allowing a little extra time - you should not plan on the sustained 80 mph that tends to be the norm out in the desert on the LA-LV run.
    -Avoid full throttle and heavy kickdowns from a higher gear to a lower; keep the engine revs below about 3500 or so in each gear. No heavy acceleration. And be gentle with the brakes for awhile, as well - give the pads a chance to bed in with the rotors for the longest possible life.
    The main thing is to avoid cruise control because you need to vary engine speed a bit, and keep it below 3500 rpm. But no reason to stay home if these restrictions don't bother you.
    Maybe some revised colors, but very little else is likely for 2002. Production actually started several weeks ago, so the cars should be at the dealers soon, if they aren't there already.
    Thanks piceno and jrct9454. I'm going to see if i can borrow someone's car this weekend, but that info was very helpful jrct..
  • hottoddyhottoddy Member Posts: 2
    Since there is very little, if any, change to the 2002 models, I bet the 2003s will be out in Spring 2002.
    Honda/Acura did this with both the CL and TL-S, both of which arrived in the Spring.
    Naw...I resisted the urge. Yeah, right...figure the invoice less holdback and offer that.
    Nope, I'll refrain from responding in the manner called for.
  • s852s852 Member Posts: 1,051
    However, it is outrageously priced!
    A fully loaded 2002 XLEV6 with navigation is priced higher than full undiscounted MSRP of a 2002 Acura TL with navigation.
    Similar high pricing applies to less equipped 2002 Camrys.
    It is a nicer car with a newer design than the current Accord, but the HUGE price advantage plus probable finance deals for a 2002 Accord VS 2002 Camry will probably save sales of the Accord until the 2003 model comes out.
  • anonymouseanonymouse Member Posts: 2
    Re: bryhogan Aug 13, 2001 5:45pm
    Anyone know of any aftermarket accessories
    for Accord 2001 VP, especially power locks ?
    Thanks in advance!
  • carguy62carguy62 Member Posts: 545
    Isell would know best but I don't ever recall Honda introducing a new generation any time but the fall. Acura yes, Honda no. They usually don't have many changes (except usually an SE model) in the last year of the run and they've always waited until fall, I doubt this situation is any different. Although anything is possible I suppose.
    I had a local aftermarket shop in Cincinnati(recommended by the dealer) install power door looks w/remote and electronic cruise control. The total cost was about $700. They also offered power windows. However, that would have been an addition $700. (Not worth it to me.)
    I'd suggest checking with your dealer. If my dealer didn't specifically recommend this shop, I'd be a little too nervous about having anybody other than a dealer tear into a brand new car.
    Consequently, I'm pleased with the add-ons.
    The local Honda dealer has 2 2002 EX V6's listed on his internet site.
    Brochures are also available. No changes I can see, one color changed. No options added that I can see.
    Price posted is $431 above the 2001 price. This is his 'sale' price, not MSRP price, so this is an increase in invoice price.
    I just don't understand this. The last year of a series, no added options, and $400+ invoice increase. Of course Honda's competition Toyota is introducing a new series, with very large price increases. So, Honda probably thinks it can get this increase for their car.
  • frag235frag235 Member Posts: 81
    Have you seen pics of the new Camry? It looks like a Ford Taurus on the outside and an Accord on the inside!! (It's not a bad looking car, but it did kinda strike me as funny) The I4 Camry will have a bit more power then an I4 Accord though.
    Are there any upgrades to models, standard items that were optional for 2001?
    Was is the new color choice?
    Re: bryhogan Aug 15, 2001 8:39am
    Thanks for your input. My aftermarket place is
    offering a "Clifford Arrow 3" car security alarm
    system. Anyone heard of this one ?
    Another place is offering a Dynatech XR-924
    with "Digital Shock Sensor" security system, a
    virtual unknown company in my book ?
    Apparently the car lacks power doors so I need
    to bear the expense of "door actuators". How
    does all that work ? I mean does all this work
    like anywhere close to the normal power doors ?
    Thanks for your help.
    How can you tell whether or not Honda raised the invoice price by $400? If I was the dealer, I would mark up about $400 over the '01 models simply because the '01 models have lost 1 year worth of resale value and I would want to get rid of the '01 models quickly to get new models in.
    EX I4 is up 100 bucks ! & as per my contact at the dealership prices are up 100-400 through the model range. I guess Honda is planning to offer some change $500 on 2002s when 2003s come out ??? :)) Also new SE invoice is 18700 + 440(?) with Sunroof over 2000 SE & no antilock brakes ! ?
  • scooter64scooter64 Member Posts: 21
    Anyone else have a problem with their engine stalling in wet weather? Mine cuts out ONLY under these conditions: wet/rainy, push in clutch and brake at the same time.
    Sounds weird but it has happened me at least 4 times. Almost got me killed when it stalled in front of the snow plow!
  • marshal1marshal1 Member Posts: 68
    I'm trying to help a friend by a new 2001 Accord EX coupe with the 4 cylinder engine and automatic transmission. The Edmunds TMV price is about $300 over invoice. Does anyone know if this is a realistic price? Would anyone like to share what they payed recently on a new 2001? Thanks.
    Depends on where you look. Inventories are starting to dry up. $300 over is a fair price, I've seen better in California, higher prices in Washington and Colorado.
  • caaqacaaqa Member Posts: 4
    I am trying to decide if 2001 or 2002 model (V6-EX) is of better value. I intend to keep the
    car for about 4-5 years.
    The 2002 is basically the same as the 2001 model.
    Except maybe it has an auto-headlight-off feature.
    The invoice price is $430 dollar above that of 2001 model.
    My question is this: what do you think the price difference will be between the 2001 and 2002 models?
    If the difference is less than 2K, then I believe that the 2002 model is of better value, because it will have about higher resale value of 2K than the 2001 Model.
    Any suggestions/comments?
    Thank you very much!
  • kira2kira2 Member Posts: 2
    I am considering an Accord V-6, EX with leather:
    have owned 3 other Accords that have had fabric/cloth, how does the leather hold up to wear and tear, a lot of maintenance or no?
    After a quick look at the College Hills Honda info, it appears that the price on the '02 EX V6 sedan is up less than 1%...don't know what else one could ask for in the current economic climate.
    I note two other differences: the cargo net as standard, and 16" wheels for the sedan, which were only on the coupe in '01. The auto-off headlights are on the '01 [though I rarely depend on that on our car, it does work].
    As to the leather vs other alternatives, if properly maintained, I think the leather is more than fine. A little conditioner upon initial delivery goes a long way, then a once-a-year go over [just the front seats for most people] with cleaner and conditioner. At the most, this is a 15 minute job, and is no more arduous that doing the same thing with soiled cloth, which shows the dirt a lot faster in my experience.
    Anyway, my conclusion is that you should get an '02 if you have a choice - the car will be worth about $1k-$1.5 more at resale than an '01, year for year until it gets to be about 6 years old. After that, resale depends more on condition and mileage than on model year differences, at least within the same generational family [in this case, the 1998 through 2002 cars share a common body style and are part of the same generation].
    I saw an ad yesterday (CA Bay area) and a Accord EX 4-cylinder was up for $18888... I'm not sure if it had leather or not, but I think that's just a great deal (I think there were about 4 in stock for that price so I dont think it's a demo car either).
  • jmaterojmatero Member Posts: 253
    I've owned accords in the past but when sitting in the current generation (non-power seats) the most upright position is still too reclined for my taste. Enough to make the car too uncomfortable to drive for me. Does anyone else find this? Do cars with power seats extend further upright? Thanks.
    I had four actuators (for the power doors) installed and the remote keyless entry by "Pursuit". I believe this portion of the bill was about $400-450 total. (I also had cruise installed for about $250, I believe.)
    The power door locks work by pulling up or down one of the existing front door locks. When you do this, the actuators kick-in and lock or unlock all the doors. Very simple and effective. (No need for any additional switches.) Consequently, I was happy that they didn't put in a switch for the doors. My fear of having them "cut" a hole into each door would have prevented me from going down this path.
    Best of luck.
    Ok, went and got out the handouts.
    2002 Honda Sedan EX V6 has P205/65R15 Alloy.
    2001 Honda Sedan EX V6 has P205/65R15 Alloy.
    Doesn't say they have 16inchers in 2002.
    I've not looked at Coupes, didn't know they had different wheels (16inchers).
    Both (2002/2001 Sedans) have auto-off headlights.
    Local dealer Internet site says he sells $316 over invoice.
    2001 MSRP $25,540, selling price $23,123.
    2002 MSRP $25,740, selling price $23,554.
    MSRP increase $200, selling price $431 (Invoice increase, I assume).
    I still see no added features for the money. And this looks like almost a 2% increase. Course there is a little inflation in the world.
    Dark Emerald Pearl is gone, Noble Green Pearl is new. Gone one was very dark green, new one is a medium green (British racing green?). All other colors are the same. Interior colors the same.
  • 3kingdom3kingdom Member Posts: 3
    I have decided to buy Honda Accord EX V6 3.0 with leather and I would assume at this time, most dealers would let the car go at $23,000 out the door. I tried Goudy, Nelson, and World Honda with no luck.
    Do you think it is reasonable to ask for 23,000 out the door?
    Does anyone know any dealers would offer me at that prices?
    It cannot be $23000 out the door. Maybe $23000 plus tax and license.
    LA is the most competitive Honda market on the planet; that said, no one is going to let a new EX V6 "out the door" for $23k, since tax/lic implies a transaction price of around $21k. This ain't gonna happen...
    As for the '01-'02 differences, I defer to anyone with a real brochure - I was keying my remarks off the College Hills website, and it mentioned 16" wheels for the sedan...probably erroneous. And yes, since they seem to have taken a further 1% bite out of dealer margins [higher invoice], that implies a transaction price that will be about 2% higher. This will come back in the form of higher resale value for at least the next 5 years, especially if you can get a good deal on an '02 early - we bought our '01 in Sept '00, so have gotten our money's worth out of the first year's depreciation. Anyone who buys an '01 now takes the hit all at once in the next 60 days.
    I would look for at least a $1000 difference between an '01 and an '02 before picking the former over the latter...that would cover your resale difference for the next few years. If you can't get that, it makes sense to buy the newer model.
    You hit some of the best dealers in the region, if they won't do it no one will. There are a couple of others but I don't see anyone willing to sell much below invoice, maybe a couple hundred at best if you catch them at the right time.
    If you figure about 10% on top of the selling price you'll have a decent estimate of the out-the-door figure.
    Just do the math backwards to see what you are really offering for the car! I'm not sure that the sales tax in L.A. is now but it's 8.8% where I am. Most really ridiculous offers I see are "out the door" offers.
    Dealers do not *charge* sales tax and license fees. They simply collect these monies and forward them to the state!
    Haven't seen one yet but I hope the poster was correct in saying they look like a Taurus!
    I did hear elsewhere that they REALLY boosted prices. I hope this is the case too! Camrys are great cars and strong competition for us.
  • bobcatbobbobcatbob Member Posts: 187
    Camry prices will be about $1,000 less than they were for the 2001 model year. Here is a link to the Toyota press release on Autonews.com. In addition, the 2002's were shipped to dealers this week because of dwindling 2001 inventories.
    Toyota could not "jack prices way up" becasue of increased competition from the new Altima, which WILL be a competitor to the Camry and Accord.
    Test drove an LE 4cyl (thank goodness, much improved pickup, excellent midrange)with ABS, alloys, pwr drivers seat, keyless entry and a few odds and ends - $22,358 MSRP including dest. The New Camry does get expensive when loaded... the one in the showroom was just under $30K with the Nav system, 6 disc CD, Side Curtain airbags, V6, Vehicle Skid Control, etc, some items the Accord doesnt have (for now).
    ~alpha
    They are not $1000 less than last year. Once no-cost value packages, rebates and other discounts on the 2001s that are not available for 2002 models are factored in, it is much more expensive out the door.
    Once you add all the options, plus some new ones that were not available on the 2001s, a 2002 Camry will top put at about $31500.
    You can get a 2002 Acura TL with similar equipment, better warranty and service and more power for less than a fully loaded 2002 Camry.
    As Toyota dealers struggle to hold out for full MSRP for the next several months on the 2002 Camrys and with no rebates on the 2002 Toyotas, it will much more expensive than a similarly-equipped 2002 Accord.
