A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Mazda MPV: Problems & Solutions
RJ
TIA
RJ
The alternative is to buy a similarly equipped Honda Oddysey LX for $24,600. I like the larger size and the stronger engine, but I'm not willing to pay $4600 more just for that.
Any thoughts would be appreciated.
It sure would be nice if we could search the boards. Hosts, what gives?
A number of owners with similar problems--more on the 00's than on the 01's--have had their dealer take the car to an independent balancer and had their problems solved that way. Not matter what the solution is, you shouldn't have to pay to for it. If it needs new tires to drive smoothly, the company should pay for them if you're still under warranty.
Don't give up and don't give in!
RJ.
I also have a different steering wheel vibration while the vehicle is at a complete stop and in drive (foot on brake). This is more of an ultrasonic vibration rather than the minor shaking I get while moving. I go into neutral and it goes away. Again, this is very minor but it's there. Dealer couldn't feel this either.
Scarter, I would really like to know if going to a different tire helps your situation, should you choose to go that route.
I'm not happy about these vibrations but I'm living with it because I just don't have the motivation to argue with the dealer getting them to fix something they claim they can't detect or is "within spec".
The tire "experts" talk about handling differences which I might take seriously if I was driving a Viper or Corvette rather than a conservatively driven minivan. I am resisting paying $100 to $200 more for a set of H rated tires which get 40 to 50% of the mileage.
I do have a question though. I would like to replace the stereo and add a cassette/CD combo unit, but I can't find anyone who knows what dask kit to use for this van. Does anybody know anything about this?
Thanks a lot!
dougsey: your vibration sounds exactly like mine. Don't know if I'll get new tires, though I'm definitely leaning that way. I'll give the dealer another shot, but you're right about the hassle.
msgjvh: thanks for the link, but I'm having trouble finding the TSB. If you go to Info, then 2001 under TSB, it says "no TSB info is available". What's weird is that I know I've been on that site and even seen the tie-rod TSB (???)
My 2001 Mazda came with Yoko Radial 376 tires. I wasn't too thrilled when I first saw them but am presently quite pleased. I had the perverbial pulling/wandering problem until I set all the tires at 36PSI (after a long story).
Anyway, I have 16,500 miles and the wear is very slight. I have not rotated tires yet. Both front & back show little difference between them. That could be due to the fact 70~80% of my driving is at 75MPH. The ride is very smooth @ that speed. My wife's Sienna Dunlops (@13K) are not holding up very well but hers is mostly stop & go - and spend money....:))
Thanks in advance.
/java
I called my dealership parts dept. to price one (I mean, how much could a little plastic disc cost?); much to my surprise, they quoted a price >$20! For one!?
I'll try the warranty angle.
Thanks, you've made my day!
Steve
I guess I have to make an appearance this week.
/java
I don't know if this was addressed with the 2002my revisions, and it has always struck me as an aerodynamic issue...and I'd don't know how you'd fix it except for maybe putting some of those acrylic window visors on the van and see if that does it. Her it isn't much of a problem since it's not usually warm enough to want to have windows open on the freeway.
Happy motoring!
/java
/j
I have not yet heard back from Mazda about what they might or can do about the problem. The tires that are cupped have about 14,000 miles on them while placed in the rear.Hind site is 20/20, but I'd say I first noticed the problem when they had about 12,000 miles on them. Anyone else out there with this problem? I've been told that having shims installed would correct the problem, but shims are not considered to be an ideal fix.
Whichever the case, it does seem out of spec, and the only way I've known to manipulate toe on most rear wheels is with shims as you've said, or suspension replacement. Fwiw, I've never had an issue with a shim-adjusted rear toe correction, it's not like the shim will fall out or anything :-)
A few automobiles actually have suspensions with adjustable rear toe (aside from shim adjustment), possibly Honda w/ their very nice double-wishbone rear suspensions may be one and lots of cars that run on race tracks have adjustable rear toe settings. All the street cars I've ever adjusted rear toe on, you placed a shim in the hub area that adjuste the alignment of the rear wheel, toeing in or out depending which way you placed the shim.
Keep us posted on what Mazda says,
/Java
It's good to hear that shims are probably OK, so I won't have to go through the ceiling at the Mazda dealership if that's the only fix they have. At least it sounds like a better alternative than looking at tires that have nearly all of their tread remaining, but go woowoowoowoo down the road!
Thanks again and I'll keep you posted about Mazda's answer.
TB
/j
If Mazda's specs are between 5 and 32 (or 3.2) and your toe is at 36 (or 3.6), and your van is within warranty and hasn't been in an accident, then I would be screaming Facory Defect and demanding the rear suspension be changed out under warranty to factory spec. Shims may "fix" the problem, but it skirts the issue that the van left the factory (or at least arrived in your driveway) with a defective rear suspension. Make them fix it correctly.
It's always a good idea to be rational and be sure that you know the facts before you go somewhere screaming and come back with crow on your breath.
I have searched the web to no avail for details on this TSB. On the vakcer site, I see mention of a real brake squeal, but not a solution. I also searched the NHTA site, but found that you have to pay a fee to see TSB detail. I couldn't find anything about a brake problem on that site anyway.
I know several of you have had this problem and I'm curious to see what your resolutions were, if any. I just can't believe it's caused simply by brake dust. Am I going to have to go to the dealer every time my brakes squeal and have them blown out? Sounds pretty ridiculous!
I saw the TSB but unfortunately couldn't convince the dealer to make a copy of it for me. The fix involves replacing pretty much everything in the rear brake assembly. I had mine done at 37,000 km at no charge and they even replaced the shoes (for free). I suggest you to go back to the dealer (or to another dealer) and ask them to show you the description of the TSB No. 0102R. They are either lying to you, or looking into a wrong source (I'm not aware of any other TSB for MPV addressing squeal problem).
I'm happy to say that over 6 weeks later, there's still no squeal. That is such a joy driving a quiet van :-)
As soon as the details on this TSB will become available, they will appear on the MPV web site in the Info section. BTW, there are some more TSBs/Recall info posted there recently: http://www.vakcer.com/mpv
I hope this helps.
Good Luck!
/Java
Question to Alex and Java: is the squeal TSB 0101R or 0102R? On nhtsa, it's listed as Service Bulletin #0400101R, Bulletin Sequence #620, NHTSA Item # SB620006, Date 06/01, and there is no 0102R. The description is the same as the one on the vakcer site, so I'm sure it's the one.
BTW, my squeal is not constant, but what is predictable is when it occurs: not when I first apply the brakes, but just that moment prior to the vehicle coming to a complete stop.
SC
It was a toss up between the MXV4+ and the X-Ones. I have a set of MXV4+ on my Accord and I'm very pleased with them, but I've noticed that they are not the greatest in the rain (lots of summer rain in FLA) and they wear down fast. The X-Ones are supposed to be excellent rain tires and their tread depth looks to be about 4 miles deep! I'll probably trade-in the MPV (for a new MPV, of course!) before the tires are worn out....
SC
Any response?
1. What kind of cracking noise is that? Could it be related to front disc brake pads shifting around? While that particular noise is more clung than crack, there is a TSB on that to deaden the sound (it is still normal for brakes to emit that noise)... However I doubt that this is the problem you are having based on your description. Could you provide more info on this particular issue?
2. Well, premature tire wear seems to be a common problem nowadays, and not only with MPV. However I'm happy to report that mine at 25,000 miles are sill good.
3. Is there any sign of impact (dent/scratch)? Some moron hit my van with a door or shopping cart and scratched the paint from the passenger door handle and put a dent in the middle of the door. I'd definitely cut her/his tires for that :-). I also have some paint chips, especially after I got under "stone rain" on highway one day. Some truck must have lost half the cargo load of gravel and when a bunch of cars got in the area, rocks were flying as hail. I got my share of chips that day :-( Is your van white by any chance? I heard that white was somewhat "weak" for 2000 model year. At least white and silver was changed for 2001. (I have 2000 Silver, BTW)
4. What was wrong with the vinyl? Just curious.
My dealer told me there's a TSB out on this problem. It has something to do with them installing/replacing shims in front brake pads. Dealer is going to apply TSB this week. I will advise this board on the outcome.
What exactly are you referring to when you mention probs with your exterior vinyl that your dealer replaced?
Overall very happy with MPV ES 2000. Biggest problem is wife complaining about brake noise.
