Visitor Agreement.
I appeal to other MPV owners, please check your van to see if you have this problem (actually, it's so bad in mine that you would know it if you have the problem). I think that the presence of raw fuel smell cannot be a good thing, and it is nauseating.
1. THE NOISE IS MORE OF A CLUNKING NOISE I GUESS. THE DEALER CHANGED THE CALIPER BOLT AND NOW IS WAITING ON MAZDA FOR A NEW FIX. THE NOISE IS JUST IRRITATING.
2. THE COLOR IS RED WITH WHITE CHPS. THE CHIPPING PROBLEM IS NOTHING WITH ABUSE, THEY ARE FROM A POOR PAINT JOB. THE CHIPS ARE AT THE BOTTOM ( WHERE THE ROUGH PART OF THE DOOR). THESE CHIPS ARE ON THE DRIVERS AND PASSENGER DOORS AND THE CHIPS ARE IDENTICAL ON BOTH SIDES. THE DEALER HAD MY DOORS PAINTED AND MADE ME BUY MUD FLAPS, SO THE PROBLEM WONT HAPPEN AGAIN. I DIDN'T THINK I SHOULD HAVE HAD TO PAY FOR MUD FLAPS BECAUSE OF A BAD PAINT JOB.?
THE ONLY THING THE DEALER HASNT FIXED YET IS THE PAINT CHIPS ON THE BUMPER AND HOOD ( WHICH ARE EXCESSIVE)( YES, I HAVE A BUG DEFLECTOR).
3. THE DEALER REPLACED ALL VINYL ON EXTERIOR OF THE VAN: BOTH MIRRORS, THE PIECE RIGHT IN FRONT OF THE WINDSHIELD, WINDSHIELD WIPERS FRONT AND REAR, VINYL STRIPS ON THE ROOF. THE BLACK VINYL WAS FADING WHITE.
4. I AM STARTING THE PROCESS OF CONTACTING MAZDA, WHICH BECOMING A JOY IN ITSELF. ANY RESPONSE THANKS
BTW, if you'll use regular capitals rather than all caps, your postings will be a lot easier to read. All caps is the Internet equivalent of runing down the street screaming your head off.
Not that I haven't felt like doing precisely that when dealing with Mr. Cementhead.
RJ
Question - Does not MPV have heating in the back, or is mine malfunctioning ? The heater in the front just works fine but not the rear.
I know this has rear a/c, I would assume it would come with rear heater as well.....it worries me becos i will be moving to the boston area soon.
happy motoring,
/javadoc
the heater will never reach the 3rd row seat.
I guess I will have to get rid of the MPV.
MSGJVH
P.S. The rear air is an absolute essential though.
Happy motoring,
/java
Thanks For clarifying..........which part of the country are you at.
I am trying to get a feel for do I really need rear heater for Boston weather ?
by javadoc
Which part of the counrty are you refering to ?
so, you both don't think I abosolutely need rear heater for Boston weather.
please help.
My 00 MPV does not have rear heater( which only comes up with 4 seasons package ), we are moving to the masschussets area.
I would like to hear from those living in the Northeast about the need for the rear heater...
Any advice would be helpful !
/Java
I'll bet you are over 40K miles and the impeller in the pump is broken into numerous pieces.
That is probably the weakest point in these engines. Autozone stocks a aftermarket waterpump that doesn't use the plastic impeller Ford/Mazda (and even BMW if that makes you feel any better) uses in their pumps.
Fortunately it is a pretty simple job to do. There is a how-to somewhere over at www.contour.org which is a rather valuable site to research 2000-2001 MPV engine issues since the engine is shared with that car.
HTH
TB
A very viable solution if you do feel you need it, is to purchase an auxillary heater from JC Whtney. They are about $50 bucks at the very most and will do fine for the rear of the van. I once used one of these in an old Ford truck that needed some serious work on the heating unit. It worked just fine. Too bad the truck wasnt worth more than the repairs.
First, they're nowhere near as cold as Java's winters. A few days will get below 0 F (depending on whether you're on the coast or inland)
Second, what makes New England winters so special are the infamous Nor'Easters. The cold wind blowing from the Northeast pushes the windchill below 0 F frequently
So how does that apply to the rear heat? Well, I'd take Java's numbers on the temperature, so for maybe a couple days a year, you'd want to have some blankets handy in the MPV (it's a good idea anyway). As far as the windchill, you shouldn't have to worry. Once you're in the MPV, the windchill isn't a factor.
It all depends on where you're moving to Boston from. If you're moving from SoCal (*G*), then no amount of rear heat will make you feel warm. You're gonna freeze your tootsies off until you get accustomed to the climate.
I'll be moving from Houston.....we will feel frozen anyway.......
Betcha you're gonna miss all this humidity.
And them there Northerners talk reeeel funny.
I remember amagazine quoted having the same problem in theirs as well.
any issues with yours ?
Our DC minivan had this feature, and I believe the MPV does as well.
TB
I've been to the dealer three times now for my door. They did the WD40 trick twice, then replaced the door the third time, though the replacement was for cosmetic reasons. I understand WD40 has it's place, but I shouldn't have to use it every WEEK! Perhaps my fuel door is being cable challenged.....
Anyway, DOES the LH door have a safety latch to prevent it opening while fueling? I don't think I've seen it...I've seen the kid latch. Also, I was told by the dealer that if the LH door is open, then the fuel door will not open (makes sense), but if the fuel door is open, the LH door WILL open. BTW, if you pry the fuel door open, the LH door will open, so be careful - I know.
Does anyone know if there's a manual release in the back for the fuel door? Nice [non-permissible content removed]-saving feature that I've had on other cars....
SC
turned out i was flicking the fuel door opener too quickly to have an effect (which worked fine for the 1st year of the van). i've learned to hold the opener at the top a second or two longer and its been opening with no problem ever since... never used WD40 either.
btw, 40k problem free kilometres and counting!
Also there is a lock of LH door when the fuel door is open. At least it works on my MPV. When I open the fuel door, the left hand sliding door cannot be opened.
HTH
Alex
"Ok, which one of you kids scratched my van"?
"We saw YOU do it at the soccer game, Daddy...".
Didn't think they could see me that far away....
lol
/java
I then realized how my daughter almost caused a calamity while I was fueling that day. I remembered that the front pin WAS pushed in and stuck, so prying the door open had nothing to do with it. If the front pin is stuck down, the LH door will go past the catch, and you will need a new fuel door #:-o
ROFL bob57!
SC
I too did the test, but I did mine this morning (2001 LX). I concur; the LH sliding door will NOT open and slide back if the fuel filler door is open enough to allow the black pin to the left of the fuel filler to protrude fully.
Also, if the LH door is ajar, the fuel filler door will not pop open.
However, my wife claims that this first feature did not work for her several weeks ago. Could it be that the black pin gets "stuck", occasionally?
I think in the old days, a car came standard with rubber floors, and you got carpet if you paid extra.
I think I am going to try some velcro, and see if the velcro will stick the plastic to the carpets.
I did replace the engine air filter and cabin micro filter at 15,000 miles as per manual instructions...
Or have someone ride with you in the back and listen to all suspicious noises in attempt to locate the source of your problem.
Try those!
/java
I couldn't stand the rattle when I shut the rear tailgate. I imagined all sorts of scratches and scuffs as the plate vibrated on the back of the van.
I've been happy with my solution.
TB
