I'm with you. I thought I did well getting 60,000 miles on the front brakes and 80,000 on the rear on my ES. I'm having a hard time believing that I even will duplicate my brake (non)wear, much less improve it that much; the 5er has so little engine drag that I find myself braking a whole lot more than I used to do...even uphill sometimes in order not to plow into the slowpoke in front of me. In spite of downshifting.
(I wonder whether they meant to say 85% gone instead of remaining...?)
My new 06 530i is outstanding!
Which brings up a question. I run tires with the recommended air pressure, 33 psi front and 41 psi rear; rotate and balance every 7500 miles and check air pressure once or twice between rotations. The original Michelin Pilot Primacys lasted 37,000 miles and still had tread life, but the Goodyear Eagle F-1s will be lucky to make 20,000 miles and are wearing on the edges. Do different tires require different pressures on an individual car?
Regarding how thin, well that's a tough call. On both of my BMWs, I've found one pad (of a total of 8 per car) that wore unevenly, and in the case of my 328i, the bottom of the pad probably had an easy 2-3mm of material remaining while the top of the pad was completely gone, allowing the metal backing to score the rotor. The weird thing about this was that due to the thickness of the remaining pad, the brake sensor hadn't been tripped yet, I changed the brakes because of the grinding. So, how thin? Me personally, I think 5mm is my personal minimum, as for what BMW says, "Wait until the sensor illuminates", which is probably 1-2mm.
Regarding tires, I remember reading my E39 manual and being a little surprised at the recommendations, which are 29/33 (f/r) for normal loading and 33/41 (f/r) for fully loaded (five passengers and/or luggage). Personally, I didn't like the front tire wear at 29 (the shoulders seemed to go away too quickly), and I didn't like the skittishness of the car with 41 in the rear, so I ultimately settled upon 33/35 (f/r), which served me quite well. Regarding different tire pressures for different tires, yes, I've heard that as well, however, there should only be a pound or two max difference between how any given tire handles the best or gets its best longevity.
Regarding the difference in tire wear, in theory at least, the F-1s should last longer than the Primacys. Given the tire pressures that you are running, my bet is that you have a front end problem, either alignment and/or worn out components.
Best Regards,
Shipo
That is my best guess...
regards,
kyfdx
Best Regards,
Shipo
Treadwear ratings are only valid when comparing tires from the same manufacturer..
I always thought they were absolute ratings, but they aren't.. Connor from Tirerack went over this quite awhile ago.. Of course, that makes no rational sense, but it is indeed the case..
IOW, 320 vs. 220 might be valid if both tires are Michelins, but it means nothing if the tires are different brands..
regards,
kyfdx
EDIT.. also, the surveys are only accurate within the same tire type on tirerack.. So, a Grand Touring Summer tire survey numbers, don't correlate with a Max Performance Summer tire numbers.. IOW, more useless information.
Best Regards,
Shipo
Any reason why the recommended tire pressure in the rear is so much higher than the front?
The manual on my 2005 530i (non-SP), for example, indicates 29/35 (f/r) for 4 passengers (max.) and 36/44 for 5 passengers + luggage. On a car close to the ideal 50-50 front-rear weight distribution, the pressure difference (6-8 psi) doesn't make sense. Any explanation?
Martin
I think lowering the pressures I am using will increase the edge wearing. In any case I intend to order Michelins PS2s in June. Hopefully they will wear like the Primacys without the noise.
hpowders
Best Regards,
Shipo
Don't care for the AUTO mode in the 530i or in my wife's '98 Lexus ES300, so they are always in the OFF position. I like being in control.
Martin
Well, I assume i-Drive works similarly in 05 and 04 E60s here, there and everywhere.
Apart from that said by turnbdown, there is a way for regulating the intensity of the fan-blowing if you Mom likes to keep the AC system switched into AUTO mode. But she needs to preset i-Drive.
She should first press the AUTO button but no more buttons at the dash. Next, she should press down the main i-Drive button at the center console. Then the "settings & service screen" comes up. She should select there "vehicle adjustments", then "AC adjustments" and next the blowing intensity of the fans among "slow" "middle" and "high" steps (I guess she will be happy with the "slow" one, as I am). After that, only the heating/cooling intensity is left to be controlled by the dash buttons when the AC system is switched into AUTO mode.
Nonetheless, she might have more fan intensity anytime she needs only by rolling the AC center dash button. This simultaneously switches off the AUTO mode. By pressing again the AUTO button at the dash, everything falls back into which is preset.
Best regards,
José
Now, how about your twitchy suspension and excess tire wear? :sick:
Best Regards,
Shipo
Best Regards,
Shipo
The manual states that all one has to do is press the button and the entertainment system would turn off.
The technician stated that radio was not defective and that BMW was aware of the “bug” in the software.
The tech went on to state that BMW was aware of this bug and a fix would be out by Fall or end of the year; he went on to warn that the downloading of the new software into the car’s system would take approx. 2 days.
So for any of your other owners/lessees having this similar problem with your radio, be on the look out between the Fall and end of this year to query the dealership about the fix for the radio.
No, of course not, but if they start with uneven wear patterns and thereafter wear evenly, they will remain uneven.
(PS--nyccarguy: Happy Pesach. I hope your mom cooks as well my mom does [and bakes as well as I do].)
Okay, next question (Take II); do you have any idea of what brand and model of tire you are going to spring for next? I was nearly faced with that problem before my lease was up, and after doing some research, I ended up more unsure of 'which set next' than I was before I started.
Wait, wait! Okay, next question (Take III); what's the condition of your spare tire? When I turned my car in, the spare had never been out of the trunk, so if I had decided to opt for another set of OEM tires (Michelin Pilot Primacys), then all I would have had to do was buy three and take the best of the four used tires and swap it into the trunk.
Decisions, decisions, decisions. :confuse:
Best Regards,
Shipo
Take II: Great question; I've already started pondering this. I was planning to post a question about it, because the Pilots I have rate well at Tire Rack, but the Pirellis rate higher. BOTOH, I have always put Michelins on my cars, and if I remember correctly, my only experience with Pirellis was when I bought my Lexus. Those would be the tires that wore out so fast that Lexus paid for half the cost of a new set.
Take III: Another excellent question, which I cannot answer tonight because the house alarm is on and I don't feel like turning it off to go out to the garage. But if the spare turns out to be something good that's brand new or close to it, I suspect I'll just buy three of the same...unless someone gives me a compelling reason to do otherwise.
Everyone that gets them, seems to think they are the best thing going... 3-series or 5-series... Great all-around performance, with an acceptable ride...
I have regular Michelin Pilot Sports.. and while I like them, I'm not wild enough about them to recommend them to others (they came with the wheels I bought).
regards,
kyfdx
The PS2 is a new tire.. they only keep the old Pilots around, because a lot of BMW drivers wear out the rears first, and want to keep a matched set...
Of course, you'll need a winter tire/wheel package next fall..
I know it is a pain... but, it is worth it...
In the meantime, if anyone has any (other) bright ideas, I'm all ears (eyes?).
Because of treadwear and noise issues, or something(s) else?
"That is probably what you have for a spare tire."
Two points for you! (I was going to give you a cigar but that would be politically incorrect.) The spare looks like it hasn't ever left the trunk. Which brings up a new question: Tires get old and brittle from disuse. At what point would it be prudent to replace the spare with something newer?
Mine has never left the trunk, also.
I am using the Pirelli P7 A/S (tread wear 260, traction AA, temperature A) that came with my 2004 5-Series. I am happy with them after 20,000 miles. Good grip & traction and few noise until now. I had to drive on snow only two times this past winter. One of them the snow was little and very humid and I could manage well on it. The other was after a storm and then I put one pair of those Scandinavian tyre covers made of fabric. Easy to install, 30 miles of driving and everything was perfect. However, as others do (my friends who live at the mountains included) I rather put snow tyres on my car if I had to drive more times/miles on snow.
Best regards,
José
I wish you lots of luck in your new 5 series. Definitely one of the best cars I've ever owned, and that's only after a week of driving. Enjoy
Interesting. A week or two ago I opined that BMW hadn't posted their new fuel economy numbers for the 2006 engines as they were an exact match for the 2005 numbers. I was then confronted with overwhelming evidence that suggests that the claimed 12% improvement in fuel efficiency was not realized in the new line of engines. Now you come along and suggest that after only a tank or two that you are getting better mileage after all. Any specifics? ;-)
Best Regards,
Shipo
Check out the site:
Ugliest Cars of 2005
